我看了全志的tina的linux内核上有关于ax的驱动,然后果断选中,但是编译烧录到荔枝派nano之后,还是无法识别到网口驱动。然后又去找了官方的驱动移植到内核中,发现还是驱动不起来,,,所以来着,请问一下有没有大佬弄过这方面的经验,特地来请指教,小弟在此先谢过了。
系统的启动日子如下:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.65 (cotodo@cotodo) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #32 Wed Apr 7 02:56:07 UTC 2021
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: CMA: failed to reserve 32 MiB
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 8192
[ 0.000000] free_area_init_node: node 0, pgdat c03c9d84, node_mem_map c03f4000
[ 0.000000] Normal zone: 64 pages used for memmap
[ 0.000000] Normal zone: 8192 pages, LIFO batch:0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=bootlogo@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=32M fb_base=0x81f00000 androidboot.serialno=<NULL> boot_type=3
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Memory: 32MB = 32MB total
[ 0.000000] Memory: 28284k/28284k available, 4484k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0382f44 (3564 kB)
[ 0.000000] .init : 0xc0383000 - 0xc039e9b0 ( 111 kB)
[ 0.000000] .data : 0xc03a0000 - 0xc03ca708 ( 170 kB)
[ 0.000000] .bss : 0xc03ca708 - 0xc03f33c0 ( 164 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[ 0.000000] pll_cpu-set_default_rate=552000000 success!
[ 0.000000] pll_video-set_default_rate=297000000 success!
[ 0.000000] pll_ddr-set_default_rate=312000000 success!
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.005325] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
[ 0.075251] pid_max: default: 32768 minimum: 301
[ 0.080441] Mount-cache hash table entries: 512
[ 0.086441] CPU: Testing write buffer coherency: ok
[ 0.092236] Setting up static identity map for 0xc02b0910 - 0xc02b0968
[ 0.101515] devtmpfs: initialized
[ 0.106934] pinctrl core: initialized pinctrl subsystem
[ 0.112793] NET: Registered protocol family 16
[ 0.117916] DMA: failed to allocate 256 KiB pool for atomic coherent allocation
[ 0.125948] dump_class_init,844, success
[ 0.134531] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
[ 0.157355] bio: create slab <bio-0> at 0
[ 0.163330] usbcore: registered new interface driver usbfs
[ 0.169114] usbcore: registered new interface driver hub
[ 0.174995] usbcore: registered new device driver usb
[ 0.182144] Switching to clocksource sun3i high-res couter
[ 0.206790] get det_vbus is fail, 84
[ 0.212265] NET: Registered protocol family 2
[ 0.219229] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.226341] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.233009] TCP: Hash tables configured (established 512 bind 512)
[ 0.239566] TCP: reno registered
[ 0.242965] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.249081] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.256141] NET: Registered protocol family 1
[ 0.273951] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.280625] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
[ 0.287036] msgmni has been set to 55
[ 0.294354] io scheduler noop registered
[ 0.298651] io scheduler cfq registered (default)
[ 0.303525] [pm]aw_pm_init!
[ 0.306802] [pm]valid
[ 0.309292] [pm]valid
[ 0.325993] uart0: ttyS0 at MMIO 0x1c25000 (irq = 104) is a SUNXI
[ 0.332439] sw_console_setup()1324 - console setup baud 115200 parity n bits 8, flow n
[ 0.340661] console [ttyS0] enabled, bootconsole disabled
[ 0.353208] misc dump reg init
[ 0.357596] lradc_battery_probe:lradc_battery_probe ++++++
[ 0.363823] lradc_battery_dts_parse:lradc_battery_dts_parse ++++++
[ 0.370780] key base: f1c23400
[ 0.374351] irq num: 113 !
[ 0.377357] battery_data_hw_init:battery_data_hw_init ++++++
[ 0.383764] lradc_battery_probe:lradc_battery_probe ------
[ 0.392073] spi spi0: master is unqueued, this is deprecated
[ 0.399732] m25p80 spi0.0: mx25l12805d (16384 Kbytes) - fast mode
[ 0.410363] 9 sunxipart partitions found on MTD device (null)
[ 0.416755] Creating 9 MTD partitions on "(null)":
[ 0.422166] 0x000000000000-0x000000080000 : "uboot"
[ 0.429737] 0x000000080000-0x000000100000 : "bootlogo"
[ 0.437368] 0x000000100000-0x000000120000 : "env"
[ 0.444638] 0x000000120000-0x0000003e0000 : "boot"
[ 0.452060] 0x0000003e0000-0x000000c20000 : "rootfs"
[ 0.459722] 0x000000c20000-0x000000ca0000 : "rootfs_data"
[ 0.467646] 0x000000ca0000-0x000000cb0000 : "misc"
[ 0.474899] 0x000000cb0000-0x000000cc0000 : "private"
[ 0.482487] 0x000000cc0000-0x000001000000 : "UDISK"
[ 0.490377] usbcore: registered new interface driver asix
[ 0.496493] usbcore: registered new interface driver ax88179_178a
[ 0.503578] usbcore: registered new interface driver cdc_ether
[ 0.510256] usbcore: registered new interface driver cdc_eem
[ 0.516750] usbcore: registered new interface driver cdc_ncm
[ 0.523250] usbcore: registered new interface driver my_asix
[ 0.529593] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.537233] ehci-platform: EHCI generic platform driver
[ 0.543365] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.550958] g_ether gadget: using random self ethernet address
[ 0.557471] g_ether gadget: using random host ethernet address
[ 0.565117] usb0: MAC 9e:97:ac:13:70:f3
[ 0.569496] usb0: HOST MAC 0a:5d:06:2a:0b:d7
[ 0.574374] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 0.581793] g_ether gadget: g_ether ready
[ 0.587169] /soc/usbc0@0: could not find phandle
[ 0.592426] get regulator_io is no nocare
[ 0.597026] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 0.605042] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 0.616819] hub 1-0:1.0: USB hub found
[ 0.621163] hub 1-0:1.0: 1 port detected
[ 0.626013] wrn: hcd is not enable, need not stop hcd
[ 0.633491] usbip_core: USB/IP Core v1.0.0
[ 0.638415] usbcore: registered new interface driver usbip-host
[ 0.645004] usbip_host: USB/IP Host Driver v1.0.0
[ 0.652306] ipip: IPv4 over IPv4 tunneling driver
[ 0.658874] gre: GRE over IPv4 demultiplexor driver
[ 0.664307] ip_gre: GRE over IPv4 tunneling driver
[ 0.672072] TCP: cubic registered
[ 0.675769] Initializing XFRM netlink socket
[ 0.680690] NET: Registered protocol family 17
[ 0.685700] NET: Registered protocol family 15
[ 0.691142] VFP support v0.3: not present
[ 0.697088] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 0.717378] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 0.738434] devtmpfs: mounted
[ 0.742413] Freeing unused kernel memory: 108K (c0383000 - c039e000)
mount: mounting none on /dev failed: Resource busy
mount: mounting pstore on /sys/fs/pstore failed: No such file or directory
-- run rc.preboot --
-- set volume --
Failed to open mixer
-- play music --
-- end --
failed to open for pcm 0,0
-- run rc.final --
insmod F1C200s-board
app start...
-- wifi connect --
insmod wifi kernel module --------------------
insmod: can't insert '/lib/modules/3.10.65/xradio_wlan.ko': No such file or directory
start wpa_supplicant ------------------------
Line 6: Invalid passphrase length 6 (expected: 8..63) '******"'.
Line 6: failed to parse psk '"******"'.
Line 7: failed to parse network block.
Failed to read or parse configuration '/etc/wpa_supplicant.conf'.
start udhcpc ----------------
-- end --
udhcpc: SIOCGIFINDEX: No such device
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (Neptune, 5C1C9C53)
root@TinaLinux:/# ifconfig -a
gre0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-C4-6D-00-00-00-00-00-00-00-00
NOARP MTU:1476 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
gretap0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
BROADCAST MULTICAST MTU:1476 Metric:1
collisions:0 txqueuelen:1000
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
tunl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-4C-34-00-00-00-00-00-00-00-00
NOARP MTU:0 Metric:1
usb0 Link encap:Ethernet HWaddr 9E:97:AC:13:70:F3
BROADCAST MULTICAST MTU:1500 Metric:1
root@TinaLinux:/#离线
usb0网卡是啥呢?
usb0网卡是啥呢?
不清楚,而且我还有个问题这usb0网卡每次启动mac都会改变的,enmm,还有如果成功识别到网卡的话不是以ethxx开头的吗,而且我给这usb0配了IP之后和本地的电脑也ping不通,在同一个局域网
最近编辑记录 MagicKind (2021-04-07 11:37:38)
raspberryman 说:usb0网卡是啥呢?
这个是不是 rndis网卡?
MagicKind 说:raspberryman 说:usb0网卡是啥呢?
这个是不是 rndis网卡?
不是噢,大佬,我就是想用荔枝派Nano连外网
这个是不是 rndis网卡?
大佬,求指导啊,我这弄了好久都没弄出来
先插到电脑Ubuntu看下是什么情况
先插到电脑Ubuntu看下是什么情况
在电脑上面可以识别到那usb转网口模块,就是enx00001000dac1这个网卡
cc@cc:~$ ifconfig
ens33 Link encap:Ethernet HWaddr 00:0c:29:7b:5c:a1
inet addr:192.168.3.114 Bcast:192.168.3.255 Mask:255.255.255.0
inet6 addr: fe80::9ee5:415:cec8:5163/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:619023 errors:0 dropped:8 overruns:0 frame:0
TX packets:26818 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:120983865 (120.9 MB) TX bytes:2973641 (2.9 MB)
enx00001000dac1 Link encap:Ethernet HWaddr 00:00:10:00:da:c1
inet addr:192.168.1.100 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::b2cd:a9d0:c7e2:3064/64 Scope:Link
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:41 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:719 (719.0 B) TX bytes:6307 (6.3 KB)离线
先插到电脑Ubuntu看下是什么情况
大佬,我这有个疑惑点,在nano这块板子的/etc,我找不到关于网络配置的文件夹的,
root@TinaLinux:/# ls
bin lib proc rom sys var
dev mnt pseudo_init root tmp www
etc overlay rdinit sbin usr
root@TinaLinux:/# ls /etc/
banner mdev.conf rc.common
banner.failsafe modules-boot.d rc.d
cedarx.conf modules.d recorder.cfg
crontabs mtab shadow
device_info openwrt_release shells
fstab openwrt_version sunxi-keyboard.kl
group opkg ts.conf
hotplug.d passwd tslib-env.sh
init.d pointercal uci-defaults
inittab profile wpa_supplicant.conf
kaiji.wav rc.button xr_wifi.conf
root@TinaLinux:/#离线
lsmod看下加载了什么驱动?然后你在tina linux有没有勾选对应的驱动?
大佬,我试过了,在内核那部分有加载的信息,可是lsmod的时候查不到这个模块asix这个模块,这该怎么办,,,
[ 0.508581] usbcore: registered new interface driver asix
[ 0.514828] usbcore: registered new interface driver new_asix
[ 0.521478] usbcore: registered new interface driver ax88179_178a
[ 0.528308] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.536070] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.543580] usbcore: registered new interface driver usbtest
[ 0.550631] /soc/usbc0@0: could not find phandleroot@TinaLinux:/# lsmod
cdc_eem 2247 0
cdc_ether 3199 0
snd_mixer_oss 11988 1 snd_pcm_oss
snd_pcm_oss 30646 0
snd_seq_device 4506 0
vhci_hcd 11699 0
root@TinaLinux:/#离线
lsusb 有网卡的 vid : pid 吗?
好尴尬,大佬,我这没有lsusb这个命令,是我没有编译进内核吗
root@TinaLinux:/# lsusb
-/bin/sh: lsusb: not found最近编辑记录 MagicKind (2021-04-09 15:54:40)
tina 的 .config
CONFIG_BUSYBOX_DEFAULT_LSUSB
把这个编译开关打开。
大佬,我发现一个奇怪的问题,lsmod没asix这个模块,然后我insmod的时候又报了失败
root@TinaLinux:~# insmod asix.ko
[ 75.103094] asix: module is already loaded
failed to insert asix.ko离线
神奇 你还是先看下lsusb的结果吧
lsusb命令可以了,但是我无论是插上usb网口还是拔了,也同样有下面的数据,是不是usb这个网口识别不到
Bus 001 Device 001: ID 1d6b:0001
Bus 002 Device 001: ID 1d6b:0002最近编辑记录 MagicKind (2021-04-09 16:47:51)
usb插电脑,是不是出现了adb设备?
没有,我把这个功能关了
│ │ eyesee-mpp ---> │ │
│ │ smartlinkd ---> │ │
│ │ tina_multimedia_demo ---> │ │
│ │ < > MtpDaemon................................................ Tina MTP Daemon │ │
│ │ < > adb................................................... adb for Tina Linux │ │
│ │ < > adbd_auth_service........................ adb auth service for Tina Linux │ │
│ │ < > aec-xt-demo...................... Nuvoton Acoustic Echo Cancellation Demo │ │ 最近编辑记录 MagicKind (2021-04-09 16:58:00)
MagicKind 说:哇酷小二 说:usb插电脑,是不是出现了adb设备?
没有,我把这个功能关了
你的usb模式是什么 otg?host?device?
host模式
;[usbc0]:控制器0的配置。
;usb_used:USB使能标志。置1,表示系统中USB模块可用,置0,则表示系统USB禁用。
;usb_port_type:USB端口的使用情况。 0:device only;1:host only;2:OTG
;usb_detect_type:USB端口的检查方式。0:不做检测;1:vbus/id检查;2:id/dpdm检查
;usb_id_gpio:USB ID pin脚配置。具体请参考gpio配置说明。
;usb_det_vbus_gpio:USB DET_VBUS pin脚配置。具体请参考gpio配置说明。
;usb_drv_vbus_gpio:USB DRY_VBUS pin脚配置。具体请参考gpio配置说明。
;usb_det_vbus_gpio: "axp_ctrl",表示axp 提供
;--- USB0控制标志
;[usbc0]
;usbc0_used = 0
;usb_port_type = 2
;usb_detect_type = 1
;usb_id_gpio = port:PH09<0><1><default><default>
;usb_det_vbus_gpio = "axp_ctrl"
;usb_drv_vbus_gpio = port:PB07<1><0><default><0>
;usb_host_init_state = 0
;usb_regulator_io = "nocare"
;usb_regulator_vol = 0
;usb_wakeup_suspend = 0
;--- USB Device
;usb_luns = 3
;usb_serial_unique = 0
;usb_serial_number = "20080411"
[usbc0]
usbc0_used = 1
usb_port_type = 1
usb_detect_type = 1
usb_id_gpio =
usb_det_vbus_gpio =
usb_board_sel = 1
usb_drv_vbus_gpio = 2047
; USB Device
usb_luns = 3
usb_serial_number = "20080411"内核配置
<*> Support for Host-side USB │ │
│ │ [ ] USB verbose debug messages │ │
│ │ [ ] USB announce new devices │ │
│ │ *** Miscellaneous USB options *** │ │
│ │ 【*】 Enable USB persist by default │ │
│ │ [ ] Dynamic USB minor allocation │ │
│ │ [ ] Rely on OTG Targeted Peripherals List │ │
│ │ [ ] Disable external hubs │ │
│ │ < > USB Monitor │ │
│ │ < > Support WUSB Cable Based Association (CBA) │ │
│ │ *** USB Host Controller Drivers *** │ │
│ │ < > Cypress C67x00 HCD support │ │
│ │ < > xHCI HCD (USB 3.0) support │ │
│ │ <*> EHCI HCD (USB 2.0) support │ │
│ │ [ ] Root Hub Transaction Translators │ │
│ │ 【*】 Improved Transaction Translator scheduling │ │
│ │ < > Support for Synopsys Host-AHB USB 2.0 controller │ │
│ │ < > Generic EHCI driver for a platform device │ │
│ │ < > OXU210HP HCD support │ │
│ │ < > ISP116X HCD support │ │
│ │ < > ISP 1760 HCD support最近编辑记录 MagicKind (2021-04-09 17:02:07)
插其他usb设备,比如键盘鼠标,lsusb有没有找到 VID PID?
这个些功能我去掉了,我现在加上试试
哇酷小二 说:插其他usb设备,比如键盘鼠标,lsusb有没有找到 VID PID?
这个些功能我去掉了,我现在加上试试
大佬,还是一样的结果
修改之后,系统启动有一部分提示,我感到很奇怪但是又不知道是什么问题
[ 0.499927] 0x000000cc0000-0x000001000000 : "UDISK"
[ 0.507841] usbcore: registered new interface driver asix
[ 0.514085] usbcore: registered new interface driver new_asix
[ 0.520731] usbcore: registered new interface driver ax88179_178a
[ 0.527554] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.535312] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.542832] usbcore: registered new interface driver usbtest
[ 0.549851] /soc/usbc0@0: could not find phandle
[ 0.554993] get regulator_io is no nocare
[ 0.559681] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 0.567624] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 0.579477] hub 1-0:1.0: USB hub found
[ 0.583702] hub 1-0:1.0: 1 port detected
[ 0.588629] wrn: hcd is not enable, need not stop hcd
[ 0.595246] mousedev: PS/2 mouse device common for all mice
[ 0.601889] usbip_core: USB/IP Core v1.0.0
[ 0.606692] usbcore: registered new interface driver usbip-host
[ 0.613379] usbip_host: USB/IP Host Driver v1.0.0
[ 0.620403] failed to get gpio-spk and gpio_num
[ 0.627335] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTR
[ 0.635401] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTL
[ 0.643379] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKL
[ 0.651139] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKR
[ 0.658897] sunxi-codec-machine sound.2: ASoC: DAPM unknown pin External Speaker
[ 0.667326] sunxi-internal-cpudai 1c23c00.cpudai0-controller: ASoC: pcm constructor failed: -12
[ 0.677060] sunxi-codec-machine sound.2: ASoC: can't create pcm SUNXI-CODEC :-12
[ 0.685341] sunxi-codec-machine sound.2: ASoC: failed to instantiate card -12
[ 0.693795] snd_soc_register_card failed -12
[ 0.698681] sunxi-codec-machine: probe of sound.2 failed with error -12
[ 0.706739] ipip: IPv4 over IPv4 tunneling driver
[ 0.713233] gre: GRE over IPv4 demultiplexor driver
[ 0.718767] ip_gre: GRE over IPv4 tunneling driver
[ 0.726410] TCP: cubic registered
[ 0.730217] Initializing XFRM netlink socket
[ 0.735009] NET: Registered protocol family 17
[ 0.740077] NET: Registered protocol family 15
[ 0.745444] VFP support v0.3: not present
[ 0.751563] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 0.758792] ALSA device list:
[ 0.762097] No soundcards found.
[ 0.779764] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 0.796324] devtmpfs: mounted
[ 0.800432] Freeing unused kernel memory: 112K (c038b000 - c03a7000)
-- set volume --
-- play music --
-- end --
[ 2.790119] usbcore: registered new interface driver cdc_eem
[ 2.821395] usbcore: registered new interface driver cdc_ether
[ 2.837981] vhci_hcd: module is from the staging directory, the quality is unknown, you have been warned.
[ 2.869587] vhci_hcd vhci_hcd: USB/IP Virtual Host Controller
[ 2.876009] vhci_hcd vhci_hcd: new USB bus registered, assigned bus number 2
[ 2.909730] hub 2-0:1.0: USB hub found
[ 2.913976] hub 2-0:1.0: 8 ports detected
[ 2.930052] vhci_hcd: USB/IP 'Virtual' Host Controller (VHCI) Driver v1.0.0
-- run rc.final --
-- wifi connect --
-- end --就是下面的提示
[ 2.930052] vhci_hcd: USB/IP 'Virtual' Host Controller (VHCI) Driver v1.0.0离线
MagicKind 说:MagicKind 说:这个些功能我去掉了,我现在加上试试
大佬,还是一样的结果
没有VID PID?
没有
那先把你的usb搞好吧,至少得有id
大佬,方便教一下怎么样配置usb吗,我这边搞了三四天,感觉该配置的都配置了
MagicKind 说:哇酷小二 说:那先把你的usb搞好吧,至少得有id
大佬,公司项目急,求帮忙,有偿
你用的是荔枝派nano开发板?还是自己做的板子?
大佬,可以帮我把这个帖子删了吗
MagicKind 说:哇酷小二 说:你用的是荔枝派nano开发板?还是自己做的板子?
大佬,可以帮我把这个帖子删了吗
请问是什么原因呢?整个帖子删掉吗?
对呀,整个帖子删掉
