楼主 #1 2021-04-06 17:22:14
542396750@qq.com
已发帖子: 163
F1C100s 使用rtl8723bs模块ifconfig wlan0 up
# insmod r8723bs.ko
[   98.951174] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[   98.987218] RTL8723BS: module init start
[   98.991182] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[   98.998373] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[   99.007351] pnetdev = 33023edb
[   99.055606] RTL8723BS: rtw_ndev_init(wlan0)
[   99.062303] RTL8723BS: module init ret =0
# ifconfig -a
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          collisions:0 txqueuelen:1000
usb0      Link encap:Ethernet  HWaddr 96:1B:35:97:E5:08
          BROADCAST MULTICAST  MTU:1500  Metric:1
wlan0     Link encap:Ethernet  HWaddr 84:20:96:AB:35:09
[  219.087548] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
# [  222.722654] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.729121] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.737095] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.743728] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.750134] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.756627] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.763094] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.769488] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.776036] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.782589] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.788978] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.795435] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.805201] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.811666] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.818277] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.824842] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.831427] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.838140] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.844609] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.851016] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.857606] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.864681] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  222.871585] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[  231.042683] sunxi-mmc 1c0f000.mmc: data error, sending stop command
楼主 #2 2021-04-06 17:23:17
542396750@qq.com
已发帖子: 163
Re: F1C100s 使用rtl8723bs模块ifconfig wlan0 up
求搭救,会是什么原因引起的呢?
#3 2021-04-06 17:29:44
所在地: 你猜
已发帖子: 3,387
这组sdio口可能被别的功能复用了,检查一下dts
楼主 #4 2021-04-07 15:46:12
542396750@qq.com
已发帖子: 163
你好,dts是这样的,没看出引脚占用
/dts-v1/;
#include "suniv-f1c100s.dtsi"
    model = "Lichee Pi Nano";
    compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
             "allwinner,suniv";
    aliases {
        serial0 = &uart0;
        spi0 = &spi0;
    chosen {
    panel: panel {
        compatible = "qiaodian,qd43003c0-40", "simple-panel";
        #address-cells = <1>;
        #size-cells = <0>;
        enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
        port@0 {
            reg = <0>;
            #size-cells = <0>;
            panel_input: endpoint@0 {
                reg = <0>;
    reg_vcc3v3: vcc3v3 {
        regulator-name = "vcc3v3";
&de {
&mmc0 {
    vmmc-supply = <&reg_vcc3v3>;
    bus-width = <4>;
    broken-cd;
&otg_sram {
&spi0 {
    partnctrl-names = "default";
    pinctrl-0 = <&spi0_pins_a>;
    flash: w25q128@0 {
        #size-cells = <1>;
        reg = <0>;
        partitions {
            #size-cells = <1>;
            partition@0 {
                label = "u-boot";
                reg = <0x000000 0x100000>;
                read-only;
            partition@100000 {
                label = "dtb";
                reg = <0x100000 0x10000>;
                read-only;
            partition@110000 {
                label = "kernel";
                reg = <0x110000 0x400000>;
                read-only;
            partition@510000 {
                label = "rootfs";
                reg = <0x510000 0xAF0000>;
&tcon0 {
    pinctrl-names = "default";
    pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
    tcon0_out_lcd: endpoint@0 {
        reg = <0>;
&uart0 {
    pinctrl-0 = <&uart0_pins_a>;
&usb_otg {
    dr_mode = "otg";
&usbphy {
楼主 #5 2021-04-07 15:47:45
542396750@qq.com
已发帖子: 163
有时候没报这个错[  222.871585] sunxi-mmc 1c0f000.mmc: data error, sending stop command,但是获取不了IP
# insmod r8723bs.ko
[   32.295005] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[   32.331661] RTL8723BS: module init start
[   32.335753] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[   32.342842] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[   32.359137] pnetdev = 33023edb
[   32.423322] RTL8723BS: rtw_ndev_init(wlan0)
[   32.431222] RTL8723BS: module init ret =0
# ifconfig -a
# udhcpc -i wlan0
udhcpc: started, v1.27.1
[  290.047818] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
udhcpc: sending discover
#6 2021-04-07 15:50:44
所在地: 你猜
已发帖子: 3,387
缺固件,本站右上角搜一下
楼主 #7 2021-04-07 15:54:53
542396750@qq.com
已发帖子: 163
缺固件,本站右上角搜一下
您好,这个固件已经放在这个目录下了
# cd /
# ls
bin         lib         media       proc        run         tmp
dev         lib32       mnt         r8723bs.ko  sbin        usr
etc         linuxrc     opt         root        sys         var
# cd lib/firmware/rtlwifi/
# ls
rtl8723bs_nic.bin
#8 2021-04-07 16:00:32
所在地: 你猜
已发帖子: 3,387
荔枝派_ZERO的使用rtl8723bs以及dropbear(总结哈晕哥的和大佬们的,免得自己忘记了)
http://whycan.com/t_2035.html
https://cn.bing.com/search?q=wpa_supplicant%20site:whycan.com
先用wpa工具配网,都不给ssid和密码,就直接获取ip,梁静茹给你的勇气? : (
楼主 #9 2021-04-07 16:03:43
542396750@qq.com
已发帖子: 163
感谢指点,我再好好看看
有配过网的
# vi /etc/wpa_supplicant.conf
network={
    ssid="QQ"
    scan_ssid=1
    key_mgmt=WPA-EAP WPA-PSK IEEE8021X NONE
    pairwise=TKIP CCMP
    group=CCMP TKIP WEP104 WEP40
    psk="11223344"
    priority=5
楼主 #10 2021-04-07 16:19:33
542396750@qq.com
已发帖子: 163
可以了,按照下面流程:
insmod r8723bs.ko
ifconfig -a
ifconfig wlan0 up
wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf(按照上面步骤走,手机提示有设备连入)
udhcpc -i wlan0(执行这一步才能接人网络)
重新添加dhcp,再编译,还是一样
查看网络状态wpa_cli -iwlan0 status
测试网络ping 123.149.232.30
按CTRL+C停止Ping
# insmod r8723bs.ko
[   58.380884] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[   58.416880] RTL8723BS: module init start
[   58.420842] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[   58.428059] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[   58.436988] pnetdev = 33023edb
[   58.485664] RTL8723BS: rtw_ndev_init(wlan0)
[   58.492380] RTL8723BS: module init ret =0
# ifconfig -a
# ifconfig wlan0 up
[   78.453132] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
# wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf
wpa_supplicant v2.6
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
ap_scan=1
Priority group 5
   id=0 ssid='cxk'
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Using driver-based off-channel TX
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 3 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0x196618
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0104
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=040a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=040b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=040c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=040d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=090a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=090b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=090c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=090d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0409506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=7f506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0801
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0a07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0a11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0a1a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=1101
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=1102
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0505
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196618 match=0500
rfkill: Cannot open RFKILL control device
nl80211: RFKILL status not available
netlink: Operstate: ifindex=3 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
wlan0: Own MAC address: 84:20:96:ab:35:09
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
wlan0: Setting scan request: 0.100000 sec
wlan0: WPS: UUID based on MAC address: a422be9d-114f-543e-a249-6422664005d5
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Skip set_supp_port(unauthorized) while not associated
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
wlan0: Added interface wlan0
wlan0: State: DISCONNECTED -> DISCONNECTED
nl80211: Set wlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Daemonize..
# [  101.384703] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  101.558770] RTL8723BS: start auth
[  101.569959] RTL8723BS: auth success, start assoc
[  101.586298] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  101.593498] RTL8723BS: assoc success
[  101.748536] RTL8723BS: send eapol packet
[  101.821986] RTL8723BS: send eapol packet
[  101.845836] RTL8723BS: set pairwise key camid:4, addr:b6:64:aa:d9:23:09, kid:0, type:AES
[  101.876654] RTL8723BS: set group key camid:5, addr:b6:64:aa:d9:23:09, kid:1, type:AES
bssid=b6:64:aa:d9:23:09
freq=2447
ssid=cxk
id=0
mode=station
pairwise_cipher=CCMP
group_cipher=CCMP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
address=84:20:96:ab:35:09
uuid=a422be9d-114f-543e-a249-6422664005d5
# ping baidu.com
ping: bad address 'baidu.com'
# ping www.baidu.com
ping: bad address 'www.baidu.com'
# ping 123.149.232.30
PING 123.149.232.30 (123.149.232.30): 56 data bytes
ping: sendto: Network is unreachable
# udhcpc -i wlan0
udhcpc: sending select for 192.168.43.35
udhcpc: lease of 192.168.43.35 obtained, lease time 3599
deleting routers
adding dns 192.168.43.1
64 bytes from 123.149.232.30: seq=0 ttl=112 time=121.242 ms
64 bytes from 123.149.232.30: seq=1 ttl=112 time=77.505 ms
64 bytes from 123.149.232.30: seq=2 ttl=112 time=85.317 ms
64 bytes from 123.149.232.30: seq=3 ttl=112 time=80.254 ms
64 bytes from 123.149.232.30: seq=4 ttl=112 time=103.382 ms
#11 2021-04-07 16:20:42
所在地: 你猜
已发帖子: 3,387
恭喜恭喜,前面那个问题怎么解决的?
楼主 #12 2021-04-07 16:22:37
542396750@qq.com
已发帖子: 163
补充前期准备:
将linux内核中r8723bs.ko放进文件系统
讲rtl8723bs_nic.bin也放进去
一起打包
烧录后,创建目录 lib/firmware/rtlwifi/,把文件放进去,insmod r8723bs.ko
楼主 #13 2021-04-07 16:23:57
542396750@qq.com
已发帖子: 163
恭喜恭喜,前面那个问题怎么解决的?
貌似是TF卡座太松了接触不良,wifi模块比TF卡薄,我压一下卡座弹片,重新插进去,就没出现了
#14 2021-04-07 16:25:25
所在地: 你猜
已发帖子: 3,387
542396750@qq.com 说:
恭喜恭喜,前面那个问题怎么解决的?
喔,原来如此。
