CONFIG_PACKAGE_fswebcam=y
这奇葩 shit SDK真是难搞
跟踪了一下, tslib 可以被安装到文件系统
package/libs/tslib/Makefile
而且可以用这个命令: make package/tslib/install 重新安装:
$ make package/tslib/install
WARNING: your configuration is out of sync. Please run make menuconfig, oldconfig or defconfig!
make[1]: Entering directory '/opt/f1c100s/tina/tina'
make[2]: Entering directory '/opt/f1c100s/tina/tina/package/libs/tslib'
if [ -f /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/tslib.default.install.clean ]; then rm -f /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/tslib.default.install /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/tslib.default.install.clean; fi; echo "tslib" >> /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/tslib.default.install
make[2]: Leaving directory '/opt/f1c100s/tina/tina/package/libs/tslib'
make[1]: Leaving directory '/opt/f1c100s/tina/tina'
#### make completed successfully (4 seconds) ####
然而, 重新 make package/fswebcam/install 缺出错:
make[2]: Entering directory '/opt/f1c100s/tina/tina/package/multimedia/fswebcam'
mkdir -p /opt/f1c100s/tina/tina/out/violin-F1C200s/packages /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam/CONTROL /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo
install -d -m0755 /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam/usr/bin
cp -fpR /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-install/usr/bin/fswebcam /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam/usr/bin/
find /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam -name 'CVS' -o -name '.svn' -o -name '.#*' -o -name '*~'| xargs -r rm -rf
Package fswebcam is missing dependencies for the following libraries:
libgd.so.3
Makefile:50: recipe for target '/opt/f1c100s/tina/tina/out/violin-F1C200s/packages/base/fswebcam_20140113-1_sunxi.ipk' failed
make[2]: *** [/opt/f1c100s/tina/tina/out/violin-F1C200s/packages/base/fswebcam_20140113-1_sunxi.ipk] Error 1
make[2]: Leaving directory '/opt/f1c100s/tina/tina/package/multimedia/fswebcam'
package/Makefile:192: recipe for target 'package/multimedia/fswebcam/install' failed
make[1]: *** [package/multimedia/fswebcam/install] Error 2
/opt/f1c100s/tina/tina/build/toplevel.mk:301: recipe for target 'package/fswebcam/install' failed
make: *** [package/fswebcam/install] Error 2
#### make failed to build some targets (4 seconds) ####
结贴, 搞定
慢动作,分两步:
0. 使能libgd: CONFIG_PACKAGE_libgd=y
1. make package/libgd/install
2. make package/fswebcam/install
$ make package/libgd/install
make[2]: Entering directory '/opt/f1c100s/tina/tina/package/libs/libgd'
mkdir -p /opt/f1c100s/tina/tina/out/violin-F1C200s/packages /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd/CONTROL /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo
install -d -m0755 /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd/usr/lib
cp -fpR /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-install/usr/lib/libgd.so.* /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd/usr/lib/
find /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd -name 'CVS' -o -name '.svn' -o -name '.#*' -o -name '*~'| xargs -r rm -rf
export CROSS="arm-openwrt-linux-muslgnueabi-" NO_RENAME=1 ; NM="arm-openwrt-linux-muslgnueabi-nm" STRIP="arm-openwrt-linux-muslgnueabi-strip --strip-all" STRIP_KMOD="/opt/f1c100s/tina/tina/scripts/strip-kmod.sh" PATCHELF="/opt/f1c100s/tina/tina/out/host/bin/patchelf" /opt/f1c100s/tina/tina/scripts/rstrip.sh /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd
rstrip.sh: /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd/usr/lib/libgd.so.3.0.0: shared object
(cd /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd/CONTROL; ( echo "$CONTROL"; printf "Description: "; echo "$DESCRIPTION" | sed -e 's,^[[:space:]]*, ,g'; ) > control; chmod 644 control; ( echo "#!/bin/sh"; echo "[ \"\${IPKG_NO_SCRIPT}\" = \"1\" ] && exit 0"; echo ". \${IPKG_INSTROOT}/lib/functions.sh"; echo "default_postinst \$0 \$@"; ) > postinst; ( echo "#!/bin/sh"; echo ". \${IPKG_INSTROOT}/lib/functions.sh"; echo "default_prerm \$0 \$@"; ) > prerm; chmod 0755 postinst prerm; )
install -d -m0755 /opt/f1c100s/tina/tina/out/violin-F1C200s/packages/base
/opt/f1c100s/tina/tina/scripts/ipkg-build -c -o 0 -g 0 /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd /opt/f1c100s/tina/tina/out/violin-F1C200s/packages/base
Packaged contents of /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-sunxi/libgd into /opt/f1c100s/tina/tina/out/violin-F1C200s/packages/base/libgd_2.1.1-1_sunxi.ipk
rm -rf /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-libgd
mkdir -p /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/stamp /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-libgd
install -d -m0755 /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-libgd/usr/lib
cp -fpR /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/libgd-gd-2.1.1/ipkg-install/usr/lib/libgd.so.* /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-libgd/usr/lib/
SHELL= flock /opt/f1c100s/tina/tina/tmp/.root-copy.flock -c 'cp -fpR /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-libgd/. /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/'
touch /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/stamp/.libgd_installed
if [ -f /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/libgd.default.install.clean ]; then rm -f /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/libgd.default.install /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/libgd.default.install.clean; fi; echo "libgd" >> /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/libgd.default.install
make[2]: Leaving directory '/opt/f1c100s/tina/tina/package/libs/libgd'
$ make package/fswebcam/install
export CROSS="arm-openwrt-linux-muslgnueabi-" NO_RENAME=1 ; NM="arm-openwrt-linux-muslgnueabi-nm" STRIP="arm-openwrt-linux-muslgnueabi-strip --strip-all" STRIP_KMOD="/opt/f1c100s/tina/tina/scripts/strip-kmod.sh" PATCHELF="/opt/f1c100s/tina/tina/out/host/bin/patchelf" /opt/f1c100s/tina/tina/scripts/rstrip.sh /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam
rstrip.sh: /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam/usr/bin/fswebcam: executable
(cd /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam/CONTROL; ( echo "$CONTROL"; printf "Description: "; echo "$DESCRIPTION" | sed -e 's,^[[:space:]]*, ,g'; ) > control; chmod 644 control; ( echo "#!/bin/sh"; echo "[ \"\${IPKG_NO_SCRIPT}\" = \"1\" ] && exit 0"; echo ". \${IPKG_INSTROOT}/lib/functions.sh"; echo "default_postinst \$0 \$@"; ) > postinst; ( echo "#!/bin/sh"; echo ". \${IPKG_INSTROOT}/lib/functions.sh"; echo "default_prerm \$0 \$@"; ) > prerm; chmod 0755 postinst prerm; )
/opt/f1c100s/tina/tina/scripts/ipkg-build -c -o 0 -g 0 /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam /opt/f1c100s/tina/tina/out/violin-F1C200s/packages/base
Packaged contents of /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam into /opt/f1c100s/tina/tina/out/violin-F1C200s/packages/base/fswebcam_20140113-1_sunxi.ipk
rm -rf /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-fswebcam
mkdir -p /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/stamp /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-fswebcam
install -d -m0755 /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-fswebcam/usr/bin
cp -fpR /opt/f1c100s/tina/tina/out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-install/usr/bin/fswebcam /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-fswebcam/usr/bin/
SHELL= flock /opt/f1c100s/tina/tina/tmp/.root-copy.flock -c 'cp -fpR /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/tmp-fswebcam/. /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/'
touch /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/rootfs/stamp/.fswebcam_installed
if [ -f /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/fswebcam.default.install.clean ]; then rm -f /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/fswebcam.default.install /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/fswebcam.default.install.clean; fi; echo "fswebcam" >> /opt/f1c100s/tina/tina/out/violin-F1C200s/staging_dir/target/pkginfo/fswebcam.default.install
#### make completed successfully (3 seconds) ####
make;pack 之后:
$ find . |grep /fswebcam$
./out/violin-F1C200s/staging_dir/target/rootfs/usr/bin/fswebcam
./out/violin-F1C200s/compile_dir/target/rootfs/usr/bin/fswebcam
./out/violin-F1C200s/compile_dir/target/rootfs-tmp/usr/bin/fswebcam
./out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-install/usr/bin/fswebcam
./out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam
./out/violin-F1C200s/compile_dir/target/fswebcam-20140113/ipkg-sunxi/fswebcam/usr/bin/fswebcam
./out/violin-F1C200s/compile_dir/target/fswebcam-20140113/fswebcam
./package/multimedia/fswebcam
这样就能顺利产生了
最近编辑记录 无根浮萍 (2021-04-21 14:42:09)
请问大佬知道tina怎么用mtd-untils工具升级吗?我在tina里cat /proc/mtd 提示找不到mtd设备。
一直没明白为什么全志的tina要基于openwrt? 用buildroot有什么不妥吗?
app start...
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (Neptune, 5C1C9C53)
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# cat /proc/mtd
dev: size erasesize name
mtd0: 00080000 00001000 "uboot"
mtd1: 00080000 00001000 "bootlogo"
mtd2: 00020000 00001000 "env"
mtd3: 00300000 00001000 "boot"
mtd4: 00a00000 00001000 "rootfs"
mtd5: 00180000 00001000 "rootfs_data"
mtd6: 00010000 00001000 "misc"
mtd7: 00010000 00001000 "private"
mtd8: 00040000 00001000 "UDISK"
root@TinaLinux:/#
木得问题噢
额 我的版本和你一样,我想用mtd-untils工具升级,你会弄吗?看能不能帮我弄一下,有偿的,你邮件给我下,我把具体需求给到你。
potato 说:请问大佬知道tina怎么用mtd-untils工具升级吗?我在tina里cat /proc/mtd 提示找不到mtd设备。
app start... BusyBox v1.27.2 () built-in shell (ash) _____ _ __ _ |_ _||_| ___ _ _ | | |_| ___ _ _ _ _ | | _ | || | | |__ | || || | ||_'_| | | | || | || _ | |_____||_||_|_||___||_,_| |_| |_||_|_||_|_| Tina is Based on OpenWrt! ---------------------------------------------- Tina Linux (Neptune, 5C1C9C53) ---------------------------------------------- root@TinaLinux:/# root@TinaLinux:/# root@TinaLinux:/# root@TinaLinux:/# root@TinaLinux:/# cat /proc/mtd dev: size erasesize name mtd0: 00080000 00001000 "uboot" mtd1: 00080000 00001000 "bootlogo" mtd2: 00020000 00001000 "env" mtd3: 00300000 00001000 "boot" mtd4: 00a00000 00001000 "rootfs" mtd5: 00180000 00001000 "rootfs_data" mtd6: 00010000 00001000 "misc" mtd7: 00010000 00001000 "private" mtd8: 00040000 00001000 "UDISK" root@TinaLinux:/#
木得问题噢
可能是因为脑残吧
