楼主 #1 2021-04-29 16:29:58
hz2
[求助]荔枝派nano uboot卡在SF: unrecognized JEDEC id bytes: 0b, 40, 18
如题,uboot是下载的这个https://github.com/Lichee-Pi/u-boot nano-v2018.01分支
在drivers/mtd/spi/spi_flash_ids.c中添加了
{"xt25f128b",       INFO(0x0b4018, 0x0, 64 * 1024,   256, SECT_4K)},
重新编译烧写后还是报unrecognized JEDEC id bytes
#2 2021-04-29 16:48:46
已发帖子: 3,391
Re: [求助]荔枝派nano uboot卡在SF: unrecognized JEDEC id bytes: 0b, 40, 18
只改这个地方恐怕不行, make menuconfig 里面也得改(加?)
楼主 #3 2021-04-29 18:24:57
hz2
menuconfig里面找不到,这句是直接加到winbond的flash下面的,设备树里也改了,不知道哪里出问题了。。。
楼主 #4 2021-04-29 19:17:20
hz2
U-Boot SPL 2018.01-05676-g00188782ee-dirty (May 19 2018 - 15:47:49)
DRAM: 32 MiB
SPL: Unsupported Boot Device!
Trying to boot from sunxi SPI
U-Boot 2018.01-05676-g00188782ee-dirty (May 19 2018 - 15:47:49 +0800) Allwinner Technology
CPU:   Allwinner F Series (SUNIV)
Model: Lichee Pi Nano
DRAM:  32 MiB
Using default environment
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
No SPI flash selected. Please run `sf probe'
#5 2021-04-29 20:37:25
tylor
spi_flash_ids.c  需要添加  xt25f128b  的描述  SECT_4K  用0看看
#6 2021-04-29 21:02:50
已发帖子: 3,391
为了V3S不吃灰,移植NES游戏
http://whycan.com/t_5139.html
(出处:哇酷开发者社区)
