楼主 #1 2021-04-29 18:30:45
clj578
buildroot-2017.08 编译时遇到 relocation R_X86_64_32S against `.rodata' can
/usr/bin/ld: cmListFileLexer.o: relocation R_X86_64_32S against `.rodata' can not be used when making a PIE object; recompile with -fPIC
/usr/bin/ld: ProcessUNIX.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a PIE object; recompile with -fPIC
/usr/bin/ld: Terminal.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a PIE object; recompile with -fPIC
/usr/bin/ld: final link failed: Nonrepresentable section on output
Makefile:2: recipe for target 'cmake' failed
make[2]: *** [cmake] Error 1
Error when bootstrapping CMake:
Problem while running make
#2 2021-05-06 11:14:19
已发帖子: 3,410
Re: buildroot-2017.08 编译时遇到 relocation R_X86_64_32S against `.rodata' can
日志贴全一点
