楼主 #1 2021-05-03 23:43:31
WangLY_Snot
已发帖子: 19
F1c100s是否成功启动SPI屏(st7789v)!?
开发板:  LicheePi Nano
u-boot版本:   LicheePi-nano-u-boot-v2018.1
内核版本:Linux-5.7.1
SPI屏:st7789v
suniv-f1c100s.dtsi源代码
#define SUN4I_DMA_NORMAL 0
	#address-cells = <1>;
	#size-cells = <1>;
	interrupt-parent = <&intc>;
	clocks {
		osc24M: clk-24M {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
		osc32k: clk-32k {
			#clock-cells = <0>;
			clock-frequency = <32768>;
	cpus {
		cpu {
			device_type = "cpu";
/*	de: display-engine {
		compatible = "allwinner,suniv-f1c100s-display-engine";
		allwinner,pipelines = <&fe0>;
		status = "disabled";
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		sram-controller@1c00000 {
			compatible = "allwinner,suniv-f1c100s-system-control",
				     "allwinner,sun4i-a10-system-control";
			reg = <0x01c00000 0x30>;
			#size-cells = <1>;
			ranges;
			sram_d: sram@10000 {
				compatible = "mmio-sram";
				reg = <0x00010000 0x1000>;
				#size-cells = <1>;
				otg_sram: sram-section@0 {
					compatible = "allwinner,suniv-f1c100s-sram-d",
						     "allwinner,sun4i-a10-sram-d";
					reg = <0x0000 0x1000>;
/*		tcon0: lcd-controller@1c0c000 {
			compatible = "allwinner,suniv-f1c100s-tcon";
			reg = <0x01c0c000 0x1000>;
			interrupts = <29>;
			clocks = <&ccu CLK_BUS_LCD>,
				 <&ccu CLK_TCON>;
			clock-names = "ahb",
				      "tcon-ch0";
			clock-output-names = "tcon-pixel-clock";
			resets = <&ccu RST_BUS_LCD>;
			reset-names = "lcd";
			ports {
				#size-cells = <0>;
				tcon0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					tcon0_in_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_out_tcon0>;
				tcon0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
		ccu: clock@1c20000 {
			compatible = "allwinner,suniv-f1c100s-ccu";
			reg = <0x01c20000 0x400>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
			compatible = "allwinner,suniv-f1c100s-ic";
			reg = <0x01c20400 0x400>;
			interrupt-controller;
			#interrupt-cells = <1>;
		pio: pinctrl@1c20800 {
			compatible = "allwinner,suniv-f1c100s-pinctrl";
			reg = <0x01c20800 0x400>;
			gpio-controller;
			#interrupt-cells = <3>;
			#gpio-cells = <3>;
			uart0_pe_pins: uart0-pe-pins {
				pins = "PE0", "PE1";
				function = "uart0";
			lcd_rgb666_pins: lcd-rgb666-pins {
				pins = "PD0", "PD1", "PD2", "PD3", "PD4",
				       "PD5", "PD6", "PD7", "PD8", "PD9",
				       "PD10", "PD11", "PD12", "PD13", "PD14",
				       "PD15", "PD16", "PD17", "PD18", "PD19",
				       "PD20", "PD21";
				function = "lcd";
			mmc0_pins: mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
				function = "mmc0";
			spi0_pins: spi0-pins{
                	function = "spi0";
           	 spi1_pins: spi1-pins{
                	pins = "PA2","PA0","PA3","PA1";
                	function = "spi1";
		timer@1c20c00 {
			compatible = "allwinner,suniv-f1c100s-timer";
			reg = <0x01c20c00 0x90>;
			interrupts = <13>;
			clocks = <&osc24M>;
		mmc0: mmc@1c0f000 {
			compatible = "allwinner,suniv-f1c100s-mmc",
				     "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
					      "mmc",
					      "output",
				    	  "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <23>;
			pinctrl-names = "default";
			pinctrl-0 = <&mmc0_pins>;
			#size-cells = <0>;
		wdt: watchdog@1c20ca0 {
			compatible = "allwinner,suniv-f1c100s-wdt",
				     "allwinner,sun4i-a10-wdt";
			reg = <0x01c20ca0 0x20>;
		uart0: serial@1c25000 {
			reg = <0x01c25000 0x400>;
			interrupts = <1>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart1: serial@1c25400 {
			reg = <0x01c25400 0x400>;
			interrupts = <2>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart2: serial@1c25800 {
			reg = <0x01c25800 0x400>;
			interrupts = <3>;
			reg-shift = <2>;
			reg-io-width = <4>;
		usb_otg: usb@1c13000 {
			reg = <0x01c13000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <26>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
		usbphy: phy@1c13400 {
			reg = <0x01c13400 0x10>;
			reg-names = "phy_ctrl";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		fe0: display-frontend@1e00000 {
			compatible = "allwinner,suniv-f1c100s-display-frontend";
			reg = <0x01e00000 0x20000>;
			interrupts = <30>;
			clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
				 <&ccu CLK_DRAM_DE_FE>;
			clock-names = "ahb", "mod",
				      "ram";
			resets = <&ccu RST_BUS_DE_FE>;
			ports {
				#size-cells = <0>;
				fe0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					fe0_out_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_in_fe0>;
		be0: display-backend@1e60000 {
			compatible = "allwinner,suniv-f1c100s-display-backend";
			reg = <0x01e60000 0x10000>;
			reg-names = "be";
			interrupts = <31>;
			clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
				 <&ccu CLK_DRAM_DE_BE>;
				      "ram";
			resets = <&ccu RST_BUS_DE_BE>;
			reset-names = "be";
			assigned-clocks = <&ccu CLK_DE_BE>;
			assigned-clock-rates = <300000000>;
			ports {
				#size-cells = <0>;
				be0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					be0_in_fe0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&fe0_out_be0>;
				be0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					be0_out_tcon0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&tcon0_in_be0>;
		spi0:spi@1c05000 {
           compatible = "allwinner,suniv-spi", "allwinner,sun8i-h3-spi";
            reg = <0x1c05000 0x1000>;
            interrupts = <0xa>;
            clock-names = "ahb", "mod";
            resets = <&ccu RST_BUS_SPI0>;
            #size-cells = <0>;
            pinctrl-0 = <&spi0_pins>;
        spi1:spi@1c06000 {
            reg = <0x1c06000 0x1000>;
            interrupts = <0xb>;
            clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
            resets = <&ccu RST_BUS_SPI1>;
            #size-cells = <0>;
            bias-pull-up;
            pinctrl-0 = <&spi1_pins>;
        dma: dma-controller@1c02000 {
			compatible = "allwinner,suniv-f1c100s-dma";
			reg = <0x01c02000 0x1000>;
			interrupts = <18>;
			clocks = <&ccu CLK_BUS_DMA>;
			resets = <&ccu RST_BUS_DMA>;
			#dma-cells = <2>;
        codec: codec@1c23c00 {
			compatible = "allwinner,suniv-f1c100s-codec";
			reg = <0x01c23c00 0x400>;
			interrupts = <21>;
			clocks = <&ccu CLK_BUS_CODEC>,
				 <&ccu CLK_CODEC>;
			clock-names = "apb", "codec";
			resets = <&ccu RST_BUS_CODEC>;
			dmas = <&dma SUN4I_DMA_NORMAL 0x0c>,
				   <&dma SUN4I_DMA_NORMAL 0x0c>;
			dma-names = "rx", "tx";
suniv-f1c100s.dts源代码
/dts-v1/;
#include "suniv-f1c100s.dtsi"
	model = "Lichee Pi Nano";
	compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s";
	aliases {
		serial0 = &uart0;
	chosen {
	reg_vcc3v3: vcc3v3 {
                regulator-name = "vcc3v3";
&uart0 {
	pinctrl-0 = <&uart0_pe_pins>;
&mmc0 {
        vmmc-supply = <&reg_vcc3v3>;
        bus-width = <4>;
        broken-cd;
&otg_sram {
&usb_otg {
        dr_mode = "otg";
&usbphy {
        usb0_id_det-gpio = <&pio 4 2 0>; /* PE2 */
&spi1 {
    st7789v@0 {
        compatible = "sitronix,st7789v";
               reg = <0>;
               spi-max-frequency = <32000000>;
               rotate = <0>;
               spi-cpol;
               spi-cpha;
               rgb;
               fps = <30>;
               buswidth = <8>;
			   reset-gpios=<&pio 4 3 1>;
               dc-gpios = <&pio 4 5 1>;
               debug = <0>;
&codec {
  allwinner,audio-routing =
    "Headphone", "HP",
    "Headphone", "HPCOM",
    "LINEIN", "Line In",
    "FMINL", "Left FM In",
    "FMINR", "Right FM In",
    "MIC", "Mic";
编译完成后,将suniv-f1c100s.dtb和zImage拷贝到SD卡第一分区boot当中,
连接电脑,串口打印uboot以及linux内核启动信息,
屏幕一开始嘿嘿的,接着雪花花屏一闪而过,最后黑屏,同时左上角光标不停闪烁。
输入以下内容,屏幕有反应,但是都是雪花点点。。。
echo "Hello" > /dev/fb0
cat /dev/random > /dev/fb0
sl > /dev/fb0
有图为证:
输入以下内容,屏幕正常显示。。。
echo "Hello" > /dev/tty0
cat /dev/random > /dev/tty0
sl > /dev/tty0
有图为证:
测试framebuffer:
root#pi: ~/fb-test
root#pi: ~/mplayer cc.mp4
有图为证:
想不明白啊 。
内核启动的时候,屏幕为何没有打印启动信息,偏偏是花屏一闪而过。
输入"echo ‘Hello, World!!!!!!!!!!!‘  > /dev/fb0",屏幕显示若干个光点。。
莫非字符内容全部显示为光点了?
这是什么原因啊。;?
设备树写对了吗??????????????????
tongue   tongue  tongue  tongue  tongue
请大佬指教。。。。
本人初学linux ,深感亚历山大啊。。。
最近编辑记录 WangLY_Snot (2021-05-03 23:57:32)
#2 2021-05-04 00:05:17
raspberryman
已发帖子: 503
Re: F1c100s是否成功启动SPI屏(st7789v)!?
bootargs console 改为 fb0才行吧
楼主 #3 2021-05-04 00:10:05
WangLY_Snot
已发帖子: 19
raspberryman 说:
试过了没用。。。。
bootargs :   console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
bootcmd:    load mmc 0:1 0x80008000 zImage;load mmc 0:1 0x80c08000 suniv-f1c100s.deb; bootz 0x80008000 - 0x80c08000
楼主 #4 2021-05-06 12:58:10
WangLY_Snot
已发帖子: 19
试着输入下列代码看看。。。。。
=>setenv bootargs "console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw  vt.global_cursor_default=0"
=>saveenv
此时编译的linux是可以在SPI屏和串口同时输出log的,但是SPI屏端还不是控制台,无法使用USB键盘进行控制!!!!
关键之处在于这个文件/etc/inittab
我在这里面注释了console这一行语句。
添加了下面两行:;
ttyS0::respawn:-/bin/sh
tty0::respawn:-bin/sh
还是不能实现SPI屏被键盘控制字符输入。。。。。
大家有没有办法啊???
最近编辑记录 WangLY_Snot (2021-05-07 09:50:10)
#5 2021-05-07 09:59:43
raspberryman
已发帖子: 503
usb键盘? 这个有点复杂吧?
首先确保你的usb键盘工作正常,用evtest测试,然后还要做别的处理才行。
楼主 #6 2021-05-07 10:23:18
WangLY_Snot
已发帖子: 19
raspberryman 说:
usb键盘? 这个有点复杂吧?
晚上试试看,,,只有这样,才是一台小电脑啊。。。哈哈。。。。。
#7 2021-10-11 11:36:06
zerg
楼主有调试好的吗?(我在V3s也碰到这样的问题了)
#8 2021-11-03 09:38:05
HongSang
请教一下如何初始化RGB的?
#9 2022-06-14 14:03:03
ashley32
我的5.2内核修改了设备树 编译不过去
make[1]: *** [scripts/Makefile.lib:294: arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dtb] Error 1
