我的编译步骤完成参照晕哥的帖子https://whycan.com/p_63208.html
编译环境:ubuntu-18.04
编译前安装了依赖包如下
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install -y make gcc g++ unzip git bc python device-tree-compiler mtd-utils
sudo apt install gcc build-essential bison flex gettext tcl sharutils libncurses-dev zlib1g-dev exuberant-ctags g++ texinfo patch vim libtool bc git python3 unzip python3-distutils swig python-dev
sudo apt install gcc-arm-linux-gnueabihf编译版本:buildroot-2018.08.2 并且使用晕哥帖子里面的backup_20190220A.tgz文件
编译结果:
>>>   Generating root filesystem image rootfs.tar
rm -rf /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar
mkdir -p /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar
echo '#!/bin/sh' > /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/fakeroot
echo "set -e" >> /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/fakeroot
printf '   	mkdir -p /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/target\n	tar xf /opt/buildroot-2018.08.2/output/build/buildroot-fs/rootfs.common.tar -C /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/target\n' >> /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/fakeroot
printf '   \n' >> /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/fakeroot
printf '   	(cd /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/target; find -print0 | LC_ALL=C sort -z | tar  -cf /opt/buildroot-2018.08.2/output/images/rootfs.tar --null --no-recursion -T - --numeric-owner)\n' >> /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/fakeroot
chmod a+x /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/fakeroot
PATH="/opt/buildroot-2018.08.2/output/host/bin:/opt/buildroot-2018.08.2/output/host/sbin:/home/linuxbrew/.linuxbrew/bin:/home/linuxbrew/.linuxbrew/sbin:/home/runner/.local/bin:/opt/pipx_bin:/usr/share/rust/.cargo/bin:/home/runner/.config/composer/vendor/bin:/usr/local/.ghcup/bin:/home/runner/.dotnet/tools:/snap/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /opt/buildroot-2018.08.2/output/host/bin/fakeroot -- /opt/buildroot-2018.08.2/output/build/buildroot-fs/tar/fakeroot
/opt/buildroot-2018.08.2/output/host/bin/arm-buildroot-linux-gnueabihf-g++ -c -pipe -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Os --sysroot=/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/sysroot -O2 -O3 -fno-exceptions -Wall -W -D_REENTRANT -fPIC -DQT_NO_EXCEPTIONS -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../rasterwindow -I../../../include -I../../../include/QtGui -I../../../include/QtCore -I.moc -I../../../mkspecs/devices/linux-buildroot-g++ -o .obj/rasterwindow.o ../rasterwindow/rasterwindow.cpp
/opt/buildroot-2018.08.2/output/host/bin/arm-buildroot-linux-gnueabihf-g++ -c -pipe -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Os --sysroot=/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/sysroot -O2 -O3 -fno-exceptions -Wall -W -D_REENTRANT -fPIC -DQT_NO_EXCEPTIONS -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../rasterwindow -I../../../include -I../../../include/QtGui -I../../../include/QtCore -I.moc -I../../../mkspecs/devices/linux-buildroot-g++ -o .obj/main.o main.cpp
/opt/buildroot-2018.08.2/output/host/bin/arm-buildroot-linux-gnueabihf-g++ -pipe -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Os --sysroot=/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/sysroot -O2 -O3 -fno-exceptions -Wall -W -dM -E -o .moc/moc_predefs.h /opt/buildroot-2018.08.2/output/host/mkspecs/features/data/dummy.cpp
/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/bin/moc -DQT_NO_EXCEPTIONS -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB --include .moc/moc_predefs.h -I/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/mkspecs/devices/linux-buildroot-g++ -I/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/examples/gui/analogclock -I/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/examples/gui/rasterwindow -I/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/include -I/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/include/QtGui -I/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/include/QtCore -I/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/include/c++/7.3.0 -I/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/include/c++/7.3.0/arm-buildroot-linux-gnueabihf -I/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/include/c++/7.3.0/backward -I/opt/buildroot-2018.08.2/output/host/lib/gcc/arm-buildroot-linux-gnueabihf/7.3.0/include -I/opt/buildroot-2018.08.2/output/host/lib/gcc/arm-buildroot-linux-gnueabihf/7.3.0/include-fixed -I/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/include -I/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/sysroot/usr/include ../rasterwindow/rasterwindow.h -o .moc/moc_rasterwindow.cpp
/opt/buildroot-2018.08.2/output/host/bin/arm-buildroot-linux-gnueabihf-g++ -c -pipe -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Os --sysroot=/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/sysroot -O2 -O3 -fno-exceptions -Wall -W -D_REENTRANT -fPIC -DQT_NO_EXCEPTIONS -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../rasterwindow -I../../../include -I../../../include/QtGui -I../../../include/QtCore -I.moc -I../../../mkspecs/devices/linux-buildroot-g++ -o .obj/moc_rasterwindow.o .moc/moc_rasterwindow.cpp
/opt/buildroot-2018.08.2/output/host/bin/arm-buildroot-linux-gnueabihf-g++ --sysroot=/opt/buildroot-2018.08.2/output/host/arm-buildroot-linux-gnueabihf/sysroot -Wl,-O1 -Wl,--enable-new-dtags -o analogclock .obj/rasterwindow.o .obj/main.o .obj/moc_rasterwindow.o   -L/opt/buildroot-2018.08.2/output/build/qt5base-5.11.1/lib -lQt5Gui -lQt5Core -lrt -ldl -latomic -lpthread
32+0 records in
32+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 0.0668632 s, 502 MB/s
814+1 records in
814+1 records out
417028 bytes (417 kB, 407 KiB) copied, 0.00202072 s, 206 MB/s
dd: failed to open 'output/images/env.bin': No such file or directory
0+1 records in
0+1 records out
11856 bytes (12 kB, 12 KiB) copied, 6.9301e-05 s, 171 MB/s
3+1 records in
3+1 records out
4298088 bytes (4.3 MB, 4.1 MiB) copied, 0.00327763 s, 1.3 GB/s
4+1 records in
4+1 records out
27197440 bytes (27 MB, 26 MiB) copied, 0.0221604 s, 1.2 GB/s
jffs2.bin
output/build/uboot-v3s-spi-experimental/u-boot-sunxi-with-spl.bin
tar: output/images/env.bin: Cannot stat: No such file or directory
output/images/sun8i-v3s-licheepi-zero-dock.dtb
output/images/zImage
tar: Exiting with failure status due to previous errors
flash_32m.bin1、直接烧录打包文件
sunxi-fel.exe -p spiflash-write 0 flash_32m.bin
烧写完发现芯片不能启动,上下电后依旧停留在sunxi-fel的烧写模式
2、单独烧录
sunxi-fel.exe -p spiflash-write 0 u-boot-sunxi-with-spl.bin
烧写完后,发现可以进入uboot,日志如下:
U-Boot SPL 2017.01-rc2 (May 12 2021 - 10:54:41)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2 (May 12 2021 - 10:54:41 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
SF: Detected w25q256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
=>3、然后依次烧录其他文件
sunxi-fel.exe -p spiflash-write 0x100000 sun8i-v3s-licheepi-zero.dtb
sunxi-fel.exe -p spiflash-write 0x110000 zImage2
sunxi-fel.exe -p spiflash-write 0x610000 jffs2.bin
发现烧录到最后jffs2.bin文件的时候,芯片就无法正常启动了,停留在sunxi-fel的烧写模式。
新人第一次入坑,求大佬帮忙看看,谢谢!
感觉是uboot的sun8i.h修改没有成功,或者没有重新编译uboot。
这个文件我没有动过
sun8i.h
 * (C) Copyright 2014 Chen-Yu Tsai <wens@csie.org>
 * Configuration settings for the Allwinner A23 (sun8i) CPU
 * SPDX-License-Identifier:	GPL-2.0+
#ifndef __CONFIG_H
#define __CONFIG_H
 * A23 specific configuration
#ifdef CONFIG_USB_EHCI
#define CONFIG_USB_EHCI_SUNXI
#ifdef CONFIG_MACH_SUN8I_H3
	#define CONFIG_SUNXI_USB_PHYS	4
#elif defined CONFIG_MACH_SUN8I_A83T
	#define CONFIG_SUNXI_USB_PHYS	3
#elif defined CONFIG_MACH_SUN8I_V3S
	#define CONFIG_SUNXI_USB_PHYS	1
#else
	#define CONFIG_SUNXI_USB_PHYS	2
 * Include common sunxi configuration where most the settings are
#include <configs/sunxi-common.h>
#define CONFIG_BOOTCOMMAND    "sf probe 0 50000000;sf read 0x41800000 0x100000 0x4000;sf read 0x41000000 0x110000 0x500000; bootz 0x41000000 - 0x41800000"
#define CONFIG_BOOTARGS       "console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:992k(uboot)ro,32k(env)ro,64k(dtb)ro,5M(kernel)ro,-(rootfs) root=31:04 rw rootfstype=jffs2"
#endif /* __CONFIG_H */我只是修改了.config文件的LCD配置
BR2_TARGET_UBOOT_BOARD_DEFCONFIG="LicheePi_Zero_800x480LCD"修改为
BR2_TARGET_UBOOT_BOARD_DEFCONFIG="LicheePi_Zero_480x272LCD"离线
那你在 uboot控制台 printenv 看下bootargs,bootcmd的变量值
如下
=> printenv
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefi        x}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} ef        i/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${f        dt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr}        ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=fel mmc0 usb0 pxe dhcp
bootcmd=run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp};        then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfi        le}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi;        setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_        vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr        _r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; t        hen bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtc        ontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_ar        ch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(F        EL boot)'; source ${fel_scriptaddr}; fi
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=2
bootm_size=0x2e00000
cpu=armv7
devnum=0
dfu_alt_info_ram=kernel ram 0x41000000 0x800000;fdt ram 0x41800000 0x100000;ramd        isk ram 0x41B00000 0x1000000
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr_r=0x41800000
fdtcontroladdr=43b56388
fdtfile=sun8i-v3s-licheepi-zero.dtb
kernel_addr_r=0x41000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix        }${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_pa        rt; fi
preboot=usb start
pxefile_addr_r=0x41A00000
ramdisk_addr_r=0x41B00000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for        prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scrip        ts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env ex        ists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fs        type ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_b        oot; fi; done
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "$        {soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix i        n ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${p        refix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${dev        num}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable medi        a binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: contin        uing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefi        x}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run b        oot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${d        evnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${pr        efix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x41900000
serial#=12c00001f8900c7e
soc=sunxi
stderr=serial@01c28000
stdin=serial@01c28000
stdout=serial@01c28000
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_        for_boot_part; fi
Environment size: 4050/32764 bytes
=>离线
取0填充文件吧
烧录打包文件flash_32m.bin不启动是因为我没有使用32M的sunxi-fel烧写flash导致,目前使用论坛里的32M工具,烧写打包文件flash_32m.bin可以进uboot了,但是还是没有进入内核。日志如下:
U-Boot SPL 2017.01-rc2 (May 13 2021 - 14:12:35)
DRAM: 64 MiB
U-Boot 2017.01-rc2 (May 13 2021 - 14:12:35 +0000) Allwinner Technology
DRAM:  64 MiB
dotclock: 10000kHz = 10000kHz: (1 * 3MHz * 20) / 6
In:    serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
=>环境变量:
=> printenv
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi
bootdelay=2
cpu=armv7
devnum=0
dfu_alt_info_ram=kernel ram 0x41000000 0x800000;fdt ram 0x41800000 0x100000;ramdisk ram 0x41B00000 0x1000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
preboot=usb start
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
soc=sunxi
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
Environment size: 4050/32764 bytes请问,晕哥的这个backup_20190220A.tgz文件解压到buildroot目录里面后还需要做其他的修改吗?
sun8i.h里的bootcommand和bootargs两行需要放在#include之前。
我放到#include之前后发现bootcommand还是默认值,然后在make menuconfig里boot option里将使用bootcommand这个去掉,就可以。
