楼主 #1 2021-05-17 21:13:29
chan
已发帖子: 29
全志官方melis系统在WIN7 WIN10中的环境搭建
全志melis系统环境搭建一向很难,这里讲讲在WIN7WIN10中的如何进行MELIS系统的环境搭建,并增加对64BIT的系统安装支持,
ARM realview&cygwin安装说明.7z
#2 2021-05-17 21:38:35
已发帖子: 3,389
Re: 全志官方melis系统在WIN7 WIN10中的环境搭建
感谢楼主分享, 上面文件有一个特殊符号有bug,
& 改成 %26 才能下载
pdf 版本: realview_cygwin安装说明修改版.pdf
#3 2021-05-18 08:53:01
路漫漫
已发帖子: 65
楼主太牛了, cygwin + mdk 搞定, 可以不用 realview 2.2
#4 2021-05-18 09:57:26
raspberryman
已发帖子: 503
感谢楼主,我以前用 msys,导致编译ucgui的命令行超过8192进行不下去,现在改用cygwin搞定了。
#5 2021-05-20 22:14:51
落日余晖
已发帖子: 34
Creating archive 'elibs_ex.a'
cp elibs_ex.a ./../../../../libs/suniv/elibs_ex.a
rm elibs_ex.a
lib ex build finish!
make[4]: Leaving directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk/beetles/elibs/lib_ex'
make[3]: Leaving directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk/beetles/elibs'
make -C res
make[3]: Entering directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk/beetles/res'
make -C lang
make[4]: Entering directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk/beetles/res/lang'
./../../../../tools/build_tools/LangBuild/LangOSDBuild.exe ./lang.xml
make[4]: ./../../../../tools/build_tools/LangBuild/LangOSDBuild.exe: Permission denied
make[4]: *** [makefile:28: buildlang] Error 127
make[4]: Leaving directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk/beetles/res/lang'
make[3]: *** [makefile:28: buildres] Error 2
make[3]: Leaving directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk/beetles/res'
make[2]: *** [makefile:24: all] Error 2
make[2]: Leaving directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk/beetles'
make[1]: *** [makefile:23: all] Error 2
make[1]: Leaving directory '/cygdrive/d/C200S/melis2.0-sdk-release/livedesk'
make: *** [makefile:6: all] Error 2
奇怪, 两台电脑都出现这个问题 LangOSDBuild.exe: Permission denied
#6 2021-05-20 22:56:04
v_8787
已发帖子: 52
  • 不通过:与技术无关
#7 2021-05-20 23:18:35
落日余晖
已发帖子: 34
https://www.onelib.biz/blog/a/58291269b41431c00fbe4454
搞定了,  给所有 .exe 文件加执行属性:
find . |grep \.exe$ |xargs chmod 777
find . |grep \.dll$ |xargs chmod 777
真是折腾够呛, 睡觉睡觉.
#8 2021-05-21 14:08:52
duanhnhy
已发帖子: 33
图文并貌,值得学习,不折腾就没有进步。。。
