楼主 #1 2021-05-16 23:29:16
electronic_s
大神們有NANOPI NEO AIR 上跑EMMC 的資料嗎?
本身做了張MICROSD 能跑UBOOT,DTB 也正常,能讀extlinux.conf
但照套在EMMC 上就跑不動UBOOT
U-Boot SPL 2021.07-rc2-g59a2b9e6-dirty (May 14 2021 - 19:46:40 +0800)
DRAM: 512 MiB
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device 1. error: -19
neo air 的MICROSD 是MMC0, WIFI 是MMC1, EMMC 就在MMC2
這U-BOOT config 也改了這
CONFIG_ENV_FAT_DEVICE_AND_PART="2:auto"
但依然笨笨的說MMC1 NOT FOUND
想跑在MMC2就是不行
那個UBOOT CONFIG該怎樣搞呢?
還是EMMC BOOT 就必需用舊分法,DTB KERNEL 等必需分在不同PARTITION?
楼主 #2 2021-05-17 15:50:02
electronic_s
Re: 大神們有NANOPI NEO AIR 上跑EMMC 的資料嗎?
試過直接將EMMC 看成MICROSD, 照刷u-boot 和FAT partition 放kernel 和DTS 也沒用
#3 2021-05-17 15:57:01
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
把你的uboot dts贴上来看看,记得用 code标签包一下。
楼主 #4 2021-05-18 09:37:08
electronic_s
 * Copyright (C) 2017 Jelle van der Waa <jelle@vdwaa.nl>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
#include "sun8i-h3.dtsi"
#include <dt-bindings/pinctrl/sun4i-a10.h>
	model = "FriendlyARM NanoPi NEO Air";
	compatible = "friendlyarm,nanopi-neo-air", "allwinner,sun8i-h3";
	aliases {
		serial0 = &uart0;
		serial3 = &uart3;
		mmc0 = &mmc0;
		mmc2 = &mmc2;
	chosen {
	leds {
		compatible = "gpio-leds";
		pwr {
			label = "nanopi:red:pwr";
			gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */
			default-state = "on";
		status {
			label = "nanopi:green:status";
			gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; /* PA10 */
			linux,default-trigger = "heartbeat";
			default-state = "off";
	gpio-keys {
		compatible = "gpio-keys";
		label = "gpio-keys";
		K1 {
			pinctrl-names = "default";
			pinctrl-0 = <&k1_pin>;
			label = "nanopi:k1";
			gpios = <&pio 0 0 GPIO_ACTIVE_HIGH>; /* PA0 */
			linux,code = <KEY_F1>;
			debounce-interval = <8>;
		K2 {
			pinctrl-0 = <&k2_pin>;
			label = "nanopi:k2";
			gpios = <&pio 0 2 GPIO_ACTIVE_HIGH>; /* PA2 */
			linux,code = <KEY_F2>;
		K3 {
			pinctrl-0 = <&k3_pin>;
			label = "nanopi:k3";
			gpios = <&pio 0 3 GPIO_ACTIVE_HIGH>; /* PA3 */
			linux,code = <KEY_F3>;
	reg_vdd_cpux: vdd-cpux-regulator {
		compatible = "regulator-gpio";
		regulator-name = "vdd-cpux";
		regulator-min-microvolt = <1100000>;
		regulator-max-microvolt = <1300000>;
		regulator-always-on;
		regulator-boot-on;
		regulator-ramp-delay = <50>; /* 4ms */
		enable-active-high;
		enable-gpio = <&r_pio 0 8 GPIO_ACTIVE_HIGH>; /* PL8 */
		gpios = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; /* PL6 */
		gpios-states = <0x1>;
		states = <1100000 0>, <1300000 1>;
	reg_vcc_dram: vcc-dram {
		regulator-name = "vcc-dram";
		regulator-min-microvolt = <1500000>;
		regulator-max-microvolt = <1500000>;
		regulator-boot-on;
		enable-active-high;
		gpio = <&r_pio 0 9 GPIO_ACTIVE_HIGH>; /* PL9 */
		vin-supply = <&reg_vcc5v0>;
	reg_vdd_sys: vdd-sys {
		regulator-name = "vdd-sys";
		regulator-min-microvolt = <1200000>;
		regulator-max-microvolt = <1200000>;
		regulator-boot-on;
		enable-active-high;
	rfkill_bt: rfkill_bt {
        compatible = "rfkill-gpio";
        pinctrl-0 = <&bt_pwr_pin>;
        reset-gpios = <&pio 6 13 GPIO_ACTIVE_HIGH>; /* PG13 */
        clocks = <&osc32k>;
        clock-frequency = <32768>;
        rfkill-name = "sunxi-bt";
        rfkill-type = "bluetooth";
	wifi_pwrseq: wifi_pwrseq {
		compatible = "mmc-pwrseq-simple";
        pinctrl-0 = <&wifi_en_pin>;
		reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */
		post-power-on-delay-ms = <200>;
		clock = <&rtc 1>;
		clock-names = "ext_clock";
	sound_codec {
		compatible = "simple-audio-card";
		simple-audio-card,name = "On-board analog codec";
		simple-audio-card,cpu {
			sound-dai = <&codec>;
		simple-audio-card,codec {
&codec {
    allwinner,audio-routing = "Line Out", "LINEOUT", "MIC1", "Mic", "Mic", "MBIAS";
&cpu0 {
	cpu-supply = <&reg_vdd_cpux>;
&ehci2 {
&i2c0 {
&mmc0 {
	vmmc-supply = <&reg_vcc3v3>;
	bus-width = <4>;
	cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */
	/*non-removable;*/
&mmc1 {
	vqmmc-supply = <&reg_vcc3v3>;
	mmc-pwrseq = <&wifi_pwrseq>;
	bus-width = <4>;
	non-removable;
	sdio_wifi: sdio_wifi@1 {
		reg = <1>;
		compatible = "brcm,bcm4329-fmac";
		interrupt-parent = <&pio>;
		interrupts = <6 10 IRQ_TYPE_LEVEL_LOW>; /* PG10 / EINT10 */
		interrupt-names = "host-wake";
&mmc2 {
    pinctrl-0 = <&mmc2_8bit_pins>;
    bus-width = <8>;
    non-removable;
&ohci2 {
&pio {
    k1_pin: k1-pin@0 {
    	reg = <1>;
        pins = "PA0";
        function = "gpio_in";
    k2_pin: k2-pin@0 {
    	reg = <2>;
        pins = "PA2";
    k3_pin: k3-pin@0 {
    	reg = <3>;
        pins = "PA3";
    bt_pwr_pin: bt_pwr_pin@0 {
    	reg = <4>;
        pins = "PG13";
        function = "gpio_out";
&r_pio {
    vdd_cpux_r_pin: regulator_pins@0 {
    	reg = <1>;
        allwinner,pins = "PL6";
        allwinner,function = "gpio_out";
        allwinner,drive = <SUN4I_PINCTRL_10_MA>;
        allwinner,pull = <SUN4I_PINCTRL_NO_PULL>;
    wifi_en_pin: wifi_en_pin@0 {
    	reg = <2>;
        allwinner,pins = "PL7";
        /*drive-strength = <10>;*/
        /*bias-disable;*/
&uart0 {
	pinctrl-0 = <&uart0_pa_pins>;
&uart3 {
	pinctrl-0 = <&uart3_pins>, <&uart3_rts_cts_pins>;
	uart-has-rtscts;
	bluetooth {
		compatible = "brcm,bcm43438-bt";
		clocks = <&rtc 1>;
		clock-names = "lpo";
		vbat-supply = <&reg_vcc3v3>;
		vddio-supply = <&reg_vcc3v3>;
		device-wakeup-gpios = <&pio 0 8 GPIO_ACTIVE_HIGH>; /* PA8 */
		host-wakeup-gpios = <&pio 0 7 GPIO_ACTIVE_HIGH>; /* PA7 */
		shutdown-gpios = <&pio 6 13 GPIO_ACTIVE_HIGH>; /* PG13 */
&usb_otg {
	dr_mode = "otg";
&usbphy {
	usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */
	usb0_vbus-supply = <&reg_usb0_vbus>;
楼主 #5 2021-05-18 09:40:17
electronic_s
這個DTS 就會開通了EMMC, BOOT 起MICROSD 後能看到/dev/mmcblk2, parted mklabel msdos, 開partition fat32 都沒問題的
#6 2021-05-18 09:43:04
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
一楼的 log 是 TF卡启动的日志? 能不能在 uboot 下发现 eMMC ?
楼主 #7 2021-05-18 09:57:48
electronic_s
一樓的情況, 是先在有MICROSD 下, 做了 dd if=./u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8 ,再移除MICROSD BOOT起所得出的結果, 就是這幾句, 想進u-boot 看下都沒門
最近编辑记录 electronic_s (2021-05-18 09:59:57)
楼主 #8 2021-05-18 09:59:15
electronic_s
這是u-boot中的.config
# U-Boot 2021.07-rc2 Configuration
# Compiler: arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16)) 10.2.1 20201103
CONFIG_CREATE_ARCH_SYMLINK=y
CONFIG_LINKER_LIST_ALIGN=4
# CONFIG_ARC is not set
CONFIG_ARM=y
# CONFIG_M68K is not set
# CONFIG_MICROBLAZE is not set
# CONFIG_MIPS is not set
# CONFIG_NDS32 is not set
# CONFIG_NIOS2 is not set
# CONFIG_PPC is not set
# CONFIG_RISCV is not set
# CONFIG_SANDBOX is not set
# CONFIG_SH is not set
# CONFIG_X86 is not set
# CONFIG_XTENSA is not set
CONFIG_SYS_ARCH="arm"
CONFIG_SYS_CPU="armv7"
CONFIG_SYS_SOC="sunxi"
CONFIG_SYS_BOARD="sunxi"
CONFIG_SYS_CONFIG_NAME="sun8i"
# CONFIG_SYS_ICACHE_OFF is not set
# CONFIG_SPL_SYS_ICACHE_OFF is not set
# CONFIG_SYS_DCACHE_OFF is not set
# CONFIG_SPL_SYS_DCACHE_OFF is not set
# ARM architecture
# CONFIG_GIC_V3_ITS is not set
CONFIG_HAS_VBAR=y
CONFIG_HAS_THUMB2=y
CONFIG_ARM_ASM_UNIFIED=y
CONFIG_SYS_ARM_CACHE_CP15=y
CONFIG_SYS_ARM_MMU=y
# CONFIG_SYS_ARM_MPU is not set
CONFIG_CPU_V7A=y
CONFIG_SYS_ARM_ARCH=7
CONFIG_SYS_CACHE_SHIFT_6=y
CONFIG_SYS_CACHELINE_SIZE=64
CONFIG_SYS_ARM_CACHE_WRITEBACK=y
# CONFIG_SYS_ARM_CACHE_WRITETHROUGH is not set
# CONFIG_SYS_ARM_CACHE_WRITEALLOC is not set
# CONFIG_ARCH_CPU_INIT is not set
# CONFIG_SYS_ARCH_TIMER is not set
# CONFIG_ARM_SMCCC is not set
# CONFIG_SEMIHOSTING is not set
CONFIG_SYS_THUMB_BUILD=y
CONFIG_SPL_SYS_THUMB_BUILD=y
# CONFIG_SYS_L2CACHE_OFF is not set
# CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
CONFIG_USE_ARCH_MEMCPY=y
CONFIG_SPL_USE_ARCH_MEMCPY=y
CONFIG_USE_ARCH_MEMSET=y
CONFIG_SPL_USE_ARCH_MEMSET=y
# CONFIG_ARCH_AT91 is not set
# CONFIG_TARGET_EDB93XX is not set
# CONFIG_TARGET_ASPENITE is not set
# CONFIG_TARGET_GPLUGD is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_KIRKWOOD is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_TARGET_SPEAR300 is not set
# CONFIG_TARGET_SPEAR310 is not set
# CONFIG_TARGET_SPEAR320 is not set
# CONFIG_TARGET_SPEAR600 is not set
# CONFIG_TARGET_STV0991 is not set
# CONFIG_TARGET_X600 is not set
# CONFIG_TARGET_FLEA3 is not set
# CONFIG_ARCH_BCM283X is not set
# CONFIG_ARCH_BCM63158 is not set
# CONFIG_ARCH_BCM68360 is not set
# CONFIG_ARCH_BCM6858 is not set
# CONFIG_ARCH_BCMSTB is not set
# CONFIG_TARGET_BCMCYGNUS is not set
# CONFIG_TARGET_BCMNS2 is not set
# CONFIG_TARGET_BCMNS3 is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_S5PC1XX is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_IPQ40XX is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_K3 is not set
# CONFIG_ARCH_OMAP2PLUS is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_IMX8 is not set
# CONFIG_ARCH_IMX8M is not set
# CONFIG_ARCH_IMXRT is not set
# CONFIG_ARCH_MX23 is not set
# CONFIG_ARCH_MX25 is not set
# CONFIG_ARCH_MX28 is not set
# CONFIG_ARCH_MX31 is not set
# CONFIG_ARCH_MX7ULP is not set
# CONFIG_ARCH_MX7 is not set
# CONFIG_ARCH_MX6 is not set
CONFIG_SPL_LDSCRIPT="arch/arm/cpu/armv7/sunxi/u-boot-spl.lds"
# CONFIG_ARCH_MX5 is not set
# CONFIG_ARCH_NEXELL is not set
# CONFIG_ARCH_OWL is not set
# CONFIG_ARCH_QEMU is not set
# CONFIG_ARCH_RMOBILE is not set
# CONFIG_ARCH_SNAPDRAGON is not set
# CONFIG_ARCH_SOCFPGA is not set
CONFIG_ARCH_SUNXI=y
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VERSAL is not set
# CONFIG_ARCH_VF610 is not set
# CONFIG_ARCH_ZYNQ is not set
# CONFIG_ARCH_ZYNQMP_R5 is not set
# CONFIG_ARCH_ZYNQMP is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
# CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
# CONFIG_TARGET_VEXPRESS64_JUNO is not set
# CONFIG_TARGET_TOTAL_COMPUTE is not set
# CONFIG_TARGET_LS2080A_EMU is not set
# CONFIG_TARGET_LS1088AQDS is not set
# CONFIG_TARGET_LS2080AQDS is not set
# CONFIG_TARGET_LS2080ARDB is not set
# CONFIG_TARGET_LS2081ARDB is not set
# CONFIG_TARGET_LX2160ARDB is not set
# CONFIG_TARGET_LX2160AQDS is not set
# CONFIG_TARGET_LX2162AQDS is not set
# CONFIG_TARGET_HIKEY is not set
# CONFIG_TARGET_HIKEY960 is not set
# CONFIG_TARGET_POPLAR is not set
# CONFIG_TARGET_LS1012AQDS is not set
# CONFIG_TARGET_LS1012ARDB is not set
# CONFIG_TARGET_LS1012A2G5RDB is not set
# CONFIG_TARGET_LS1012AFRWY is not set
# CONFIG_TARGET_LS1012AFRDM is not set
# CONFIG_TARGET_LS1028AQDS is not set
# CONFIG_TARGET_LS1028ARDB is not set
# CONFIG_TARGET_LS1088ARDB is not set
# CONFIG_TARGET_LS1021AQDS is not set
# CONFIG_TARGET_LS1021ATWR is not set
# CONFIG_TARGET_PG_WCOM_SELI8 is not set
# CONFIG_TARGET_LS1021ATSN is not set
# CONFIG_TARGET_LS1021AIOT is not set
# CONFIG_TARGET_LS1043AQDS is not set
# CONFIG_TARGET_LS1043ARDB is not set
# CONFIG_TARGET_LS1046AQDS is not set
# CONFIG_TARGET_LS1046ARDB is not set
# CONFIG_TARGET_LS1046AFRWY is not set
# CONFIG_TARGET_SL28 is not set
# CONFIG_TARGET_COLIBRI_PXA270 is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_STM32 is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32MP is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_OCTEONTX is not set
# CONFIG_ARCH_OCTEONTX2 is not set
# CONFIG_TARGET_THUNDERX_88XX is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_TARGET_DURIAN is not set
# CONFIG_TARGET_PRESIDIO_ASIC is not set
# CONFIG_TARGET_XENGUEST_ARM64 is not set
CONFIG_SYS_TEXT_BASE=0x4a000000
CONFIG_SPL_GPIO_SUPPORT=y
CONFIG_SPL_LIBCOMMON_SUPPORT=y
CONFIG_SPL_LIBGENERIC_SUPPORT=y
CONFIG_SYS_MALLOC_F_LEN=0x2000
CONFIG_NR_DRAM_BANKS=1
CONFIG_ENV_SIZE=0x20000
CONFIG_ENV_OFFSET=0x88000
CONFIG_DM_GPIO=y
CONFIG_SPL_TEXT_BASE=0x00060
CONFIG_SPL_MMC_SUPPORT=y
CONFIG_SPL_SERIAL_SUPPORT=y
# CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set
CONFIG_SPL_STACK_R_ADDR=0x4fe00000
CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000
CONFIG_ERR_PTR_OFFSET=0x0
CONFIG_SPL_SIZE_LIMIT=0x0
CONFIG_SPL=y
CONFIG_PRE_CON_BUF_ADDR=0x4f000000
CONFIG_PRE_CON_BUF_SZ=4096
CONFIG_BOOTSTAGE_STASH_ADDR=0
CONFIG_IDENT_STRING=" Allwinner Technology"
# CONFIG_SUN6I_P2WI is not set
CONFIG_SUN6I_PRCM=y
# CONFIG_AXP_PMIC_BUS is not set
CONFIG_SUN8I_RSB=y
CONFIG_SUNXI_SRAM_ADDRESS=0x0
CONFIG_SUNXI_GEN_SUN6I=y
CONFIG_SUNXI_DRAM_DW=y
CONFIG_SUNXI_DRAM_DW_32BIT=y
CONFIG_MACH_SUNXI_H3_H5=y
CONFIG_SUNXI_DRAM_MAX_SIZE=0x80000000
# CONFIG_MACH_SUN4I is not set
# CONFIG_MACH_SUN5I is not set
# CONFIG_MACH_SUN6I is not set
# CONFIG_MACH_SUN7I is not set
# CONFIG_MACH_SUN8I_A23 is not set
# CONFIG_MACH_SUN8I_A33 is not set
# CONFIG_MACH_SUN8I_A83T is not set
CONFIG_MACH_SUN8I_H3=y
# CONFIG_MACH_SUN8I_R40 is not set
# CONFIG_MACH_SUN8I_V3S is not set
# CONFIG_MACH_SUN9I is not set
# CONFIG_MACH_SUN50I is not set
# CONFIG_MACH_SUN50I_H5 is not set
# CONFIG_MACH_SUN50I_H6 is not set
# CONFIG_MACH_SUN50I_H616 is not set
CONFIG_MACH_SUN8I=y
# CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER is not set
CONFIG_SUNXI_DRAM_DDR3=y
CONFIG_SUNXI_DRAM_DDR3_1333=y
# CONFIG_SUNXI_DRAM_LPDDR3_STOCK is not set
CONFIG_DRAM_CLK=408
CONFIG_DRAM_ZQ=3881979
CONFIG_DRAM_ODT_EN=y
CONFIG_SYS_CLK_FREQ=1008000000
# CONFIG_UART0_PORT_F is not set
# CONFIG_OLD_SUNXI_KERNEL_COMPAT is not set
CONFIG_MACPWR=""
CONFIG_MMC0_CD_PIN="PF6"
CONFIG_MMC1_CD_PIN=""
CONFIG_MMC2_CD_PIN=""
CONFIG_MMC3_CD_PIN=""
CONFIG_MMC1_PINS=""
CONFIG_MMC2_PINS=""
CONFIG_MMC3_PINS=""
CONFIG_MMC_SUNXI_SLOT_EXTRA=-1
CONFIG_INITIAL_USB_SCAN_DELAY=0
CONFIG_USB0_VBUS_PIN=""
CONFIG_USB0_VBUS_DET=""
CONFIG_USB0_ID_DET=""
CONFIG_USB1_VBUS_PIN=""
CONFIG_USB2_VBUS_PIN=""
CONFIG_USB3_VBUS_PIN=""
# CONFIG_I2C0_ENABLE is not set
# CONFIG_I2C1_ENABLE is not set
# CONFIG_I2C2_ENABLE is not set
# CONFIG_R_I2C_ENABLE is not set
# CONFIG_AXP_GPIO is not set
CONFIG_SUNXI_DE2=y
# CONFIG_VIDEO_DE2 is not set
CONFIG_SATAPWR=""
CONFIG_GMAC_TX_DELAY=0
# CONFIG_SPL_SPI_SUNXI is not set
CONFIG_BLUETOOTH_DT_DEVICE_FIXUP=""
# CONFIG_SPL_FS_FAT is not set
# CONFIG_SPL_LIBDISK_SUPPORT is not set
# CONFIG_SPL_SPI_SUPPORT is not set
CONFIG_CPU_V7_HAS_NONSEC=y
CONFIG_CPU_V7_HAS_VIRT=y
CONFIG_ARCH_SUPPORT_PSCI=y
CONFIG_ARMV7_NONSEC=y
# CONFIG_ARMV7_BOOT_SEC_DEFAULT is not set
CONFIG_ARMV7_VIRT=y
CONFIG_ARMV7_PSCI=y
# CONFIG_ARMV7_PSCI_1_0 is not set
# CONFIG_ARMV7_PSCI_0_2 is not set
CONFIG_ARMV7_PSCI_0_1=y
CONFIG_ARMV7_PSCI_NR_CPUS=4
CONFIG_ARMV7_LPAE=y
# CONFIG_CMD_DEKBLOB is not set
# CONFIG_IMX_CAAM_DEK_ENCAP is not set
# CONFIG_IMX_OPTEE_DEK_ENCAP is not set
# CONFIG_IMX_SECO_DEK_ENCAP is not set
# CONFIG_CMD_HDMIDETECT is not set
CONFIG_IMX_DCD_ADDR=0x00910000
# ARM debug
# CONFIG_DEBUG_LL is not set
CONFIG_SPL_PAYLOAD="u-boot.bin"
CONFIG_BUILD_TARGET=""
CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo-air"
# CONFIG_DEBUG_UART is not set
# CONFIG_AHCI is not set
# CONFIG_OF_BOARD_FIXUP is not set
# General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
# CONFIG_OPTIMIZE_INLINING is not set
# CONFIG_SPL_OPTIMIZE_INLINING is not set
CONFIG_CC_HAS_ASM_INLINE=y
# CONFIG_XEN is not set
CONFIG_DISTRO_DEFAULTS=y
CONFIG_ENV_VARS_UBOOT_CONFIG=y
# CONFIG_SYS_BOOT_GET_CMDLINE is not set
# CONFIG_SYS_BOOT_GET_KBD is not set
CONFIG_SYS_MALLOC_F=y
CONFIG_EXPERT=y
# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
# CONFIG_SYS_MALLOC_DEFAULT_TO_INIT is not set
# CONFIG_TOOLS_DEBUG is not set
# CONFIG_PHYS_64BIT is not set
CONFIG_SPL_IMAGE="spl/u-boot-spl.bin"
# CONFIG_SYS_CUSTOM_LDSCRIPT is not set
CONFIG_PLATFORM_ELFENTRY="_start"
CONFIG_STACK_SIZE=0x1000000
CONFIG_SYS_SRAM_BASE=0x0
CONFIG_SYS_SRAM_SIZE=0x0
# CONFIG_EXAMPLES is not set
# API
# CONFIG_API is not set
# Boot options
# Boot images
# CONFIG_ANDROID_BOOT_IMAGE is not set
CONFIG_FIT=y
CONFIG_FIT_EXTERNAL_OFFSET=0x0
CONFIG_FIT_ENABLE_SHA256_SUPPORT=y
# CONFIG_FIT_ENABLE_SHA384_SUPPORT is not set
# CONFIG_FIT_ENABLE_SHA512_SUPPORT is not set
CONFIG_FIT_FULL_CHECK=y
# CONFIG_FIT_SIGNATURE is not set
# CONFIG_FIT_CIPHER is not set
# CONFIG_FIT_VERBOSE is not set
# CONFIG_FIT_BEST_MATCH is not set
CONFIG_FIT_PRINT=y
# CONFIG_SPL_FIT is not set
# CONFIG_SPL_FIT_FULL_CHECK is not set
# CONFIG_SPL_LOAD_FIT is not set
# CONFIG_SPL_LOAD_FIT_FULL is not set
# CONFIG_USE_SPL_FIT_GENERATOR is not set
CONFIG_LEGACY_IMAGE_FORMAT=y
CONFIG_SUPPORT_RAW_INITRD=y
CONFIG_OF_BOARD_SETUP=y
# CONFIG_OF_SYSTEM_SETUP is not set
# CONFIG_OF_STDOUT_VIA_ALIAS is not set
CONFIG_SYS_EXTRA_OPTIONS=""
CONFIG_HAVE_SYS_TEXT_BASE=y
CONFIG_ARCH_FIXUP_FDT_MEMORY=y
# CONFIG_CHROMEOS is not set
# CONFIG_CHROMEOS_VBOOT is not set
# Boot timing
# CONFIG_BOOTSTAGE is not set
CONFIG_BOOTSTAGE_STASH_SIZE=0x1000
# CONFIG_SHOW_BOOT_PROGRESS is not set
# Boot media
# CONFIG_NAND_BOOT is not set
# CONFIG_ONENAND_BOOT is not set
# CONFIG_QSPI_BOOT is not set
# CONFIG_SATA_BOOT is not set
# CONFIG_SD_BOOT is not set
# CONFIG_SPI_BOOT is not set
# Autoboot options
CONFIG_AUTOBOOT=y
CONFIG_BOOTDELAY=2
# CONFIG_AUTOBOOT_KEYED is not set
# CONFIG_AUTOBOOT_USE_MENUKEY is not set
# CONFIG_USE_BOOTARGS is not set
# CONFIG_BOOTARGS_SUBST is not set
CONFIG_USE_BOOTCOMMAND=y
CONFIG_BOOTCOMMAND="run distro_bootcmd"
CONFIG_USE_PREBOOT=y
CONFIG_PREBOOT="usb start"
CONFIG_DEFAULT_FDT_FILE=""
# Console
CONFIG_MENU=y
# CONFIG_CONSOLE_RECORD is not set
# CONFIG_DISABLE_CONSOLE is not set
CONFIG_LOGLEVEL=4
CONFIG_SPL_LOGLEVEL=4
CONFIG_TPL_LOGLEVEL=4
# CONFIG_SILENT_CONSOLE is not set
CONFIG_PRE_CONSOLE_BUFFER=y
CONFIG_CONSOLE_MUX=y
CONFIG_SYS_CONSOLE_IS_IN_ENV=y
# CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set
# CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set
# CONFIG_SYS_CONSOLE_INFO_QUIET is not set
CONFIG_SYS_STDIO_DEREGISTER=y
# CONFIG_SPL_SYS_STDIO_DEREGISTER is not set
CONFIG_SYS_DEVICE_NULLDEV=y
# Logging
# CONFIG_LOG is not set
# Init options
# CONFIG_BOARD_TYPES is not set
CONFIG_DISPLAY_CPUINFO=y
CONFIG_DISPLAY_BOARDINFO=y
# CONFIG_DISPLAY_BOARDINFO_LATE is not set
# Start-up hooks
# CONFIG_ARCH_EARLY_INIT_R is not set
# CONFIG_ARCH_MISC_INIT is not set
# CONFIG_BOARD_EARLY_INIT_F is not set
# CONFIG_BOARD_EARLY_INIT_R is not set
CONFIG_BOARD_LATE_INIT=y
# CONFIG_LAST_STAGE_INIT is not set
# CONFIG_MISC_INIT_F is not set
CONFIG_MISC_INIT_R=y
# Security support
CONFIG_HASH=y
# CONFIG_STACKPROTECTOR is not set
# Update support
# CONFIG_UPDATE_TFTP is not set
# CONFIG_ANDROID_AB is not set
# Blob list
# CONFIG_BLOBLIST is not set
# SPL / TPL
CONFIG_SUPPORT_SPL=y
CONFIG_SPL_FRAMEWORK=y
# CONFIG_SPL_FRAMEWORK_BOARD_INIT_F is not set
CONFIG_SPL_SYS_STACK_F_CHECK_BYTE=0xaa
# CONFIG_SPL_SYS_REPORT_STACK_F_USAGE is not set
# PowerPC and LayerScape SPL Boot options
# CONFIG_SPL_BOARD_INIT is not set
# CONFIG_SPL_BOOTROM_SUPPORT is not set
CONFIG_SPL_RAW_IMAGE_SUPPORT=y
CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y
# CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK is not set
CONFIG_SPL_SYS_MALLOC_SIMPLE=y
CONFIG_SPL_STACK_R=y
CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000
# CONFIG_SPL_SEPARATE_BSS is not set
CONFIG_SPL_BANNER_PRINT=y
# CONFIG_SPL_EARLY_BSS is not set
# CONFIG_SPL_DISPLAY_PRINT is not set
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x40
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET=0x10
# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is not set
CONFIG_SUPPORT_EMMC_BOOT_OVERRIDE_PART_CONFIG=y
CONFIG_SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION=1
CONFIG_SPL_CRC32_SUPPORT=y
# CONFIG_SPL_CACHE_SUPPORT is not set
# CONFIG_SPL_CPU is not set
# CONFIG_SPL_CRYPTO_SUPPORT is not set
# CONFIG_SPL_HASH_SUPPORT is not set
# CONFIG_SPL_DMA is not set
# CONFIG_SPL_ENV_SUPPORT is not set
# CONFIG_SPL_FS_EXT4 is not set
# CONFIG_SPL_FS_SQUASHFS is not set
# CONFIG_SPL_FAT_WRITE is not set
# CONFIG_SPL_FPGA is not set
# CONFIG_SPL_I2C_SUPPORT is not set
# CONFIG_SPL_DM_MAILBOX is not set
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION=1
# CONFIG_SPL_MMC_TINY is not set
# CONFIG_SPL_MMC_WRITE is not set
# CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set
# CONFIG_SPL_MTD_SUPPORT is not set
# CONFIG_SPL_MUSB_NEW_SUPPORT is not set
# CONFIG_SPL_NAND_SUPPORT is not set
# CONFIG_SPL_NAND_DRIVERS is not set
# CONFIG_SPL_NAND_ECC is not set
# CONFIG_SPL_NAND_SIMPLE is not set
# CONFIG_SPL_UBI is not set
# CONFIG_SPL_NET_SUPPORT is not set
# CONFIG_SPL_NO_CPU_SUPPORT is not set
# CONFIG_SPL_NOR_SUPPORT is not set
# CONFIG_SPL_XIP_SUPPORT is not set
# CONFIG_SPL_ONENAND_SUPPORT is not set
# CONFIG_SPL_OS_BOOT is not set
# CONFIG_SPL_PCI is not set
# CONFIG_SPL_PCH_SUPPORT is not set
# CONFIG_SPL_POST_MEM_SUPPORT is not set
# CONFIG_SPL_DM_RESET is not set
CONFIG_SPL_POWER_SUPPORT=y
# CONFIG_SPL_POWER_DOMAIN is not set
# CONFIG_SPL_RAM_SUPPORT is not set
# CONFIG_SPL_REMOTEPROC is not set
# CONFIG_SPL_RTC_SUPPORT is not set
# CONFIG_SPL_SATA_SUPPORT is not set
# CONFIG_SPL_THERMAL is not set
# CONFIG_SPL_USB_HOST_SUPPORT is not set
# CONFIG_SPL_USB_GADGET is not set
# CONFIG_SPL_WATCHDOG_SUPPORT is not set
# CONFIG_SPL_YMODEM_SUPPORT is not set
# CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set
# CONFIG_SPL_OPTEE is not set
# Command line interface
CONFIG_CMDLINE=y
CONFIG_HUSH_PARSER=y
CONFIG_CMDLINE_EDITING=y
CONFIG_AUTO_COMPLETE=y
CONFIG_SYS_LONGHELP=y
CONFIG_SYS_PROMPT="=> "
CONFIG_SYS_PROMPT_HUSH_PS2="> "
CONFIG_SYS_XTRACE=y
# Commands
# Info commands
CONFIG_CMD_BDI=y
# CONFIG_CMD_CONFIG is not set
CONFIG_CMD_CONSOLE=y
# CONFIG_CMD_LICENSE is not set
# CONFIG_CMD_PMC is not set
# Boot commands
CONFIG_CMD_BOOTD=y
CONFIG_CMD_BOOTM=y
CONFIG_BOOTM_EFI=y
CONFIG_CMD_BOOTZ=y
CONFIG_BOOTM_LINUX=y
CONFIG_BOOTM_NETBSD=y
# CONFIG_BOOTM_OPENRTOS is not set
# CONFIG_BOOTM_OSE is not set
CONFIG_BOOTM_PLAN9=y
CONFIG_BOOTM_RTEMS=y
CONFIG_BOOTM_VXWORKS=y
CONFIG_CMD_BOOTEFI=y
CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
# CONFIG_CMD_BOOTEFI_HELLO is not set
# CONFIG_CMD_BOOTEFI_SELFTEST is not set
# CONFIG_CMD_BOOTMENU is not set
# CONFIG_CMD_ADTIMG is not set
CONFIG_CMD_ELF=y
CONFIG_CMD_FDT=y
CONFIG_CMD_GO=y
CONFIG_CMD_RUN=y
CONFIG_CMD_IMI=y
# CONFIG_CMD_IMLS is not set
CONFIG_CMD_XIMG=y
# CONFIG_CMD_SPL is not set
# CONFIG_CMD_THOR_DOWNLOAD is not set
# CONFIG_CMD_ZBOOT is not set
# Environment commands
# CONFIG_CMD_ASKENV is not set
CONFIG_CMD_EXPORTENV=y
CONFIG_CMD_IMPORTENV=y
CONFIG_CMD_EDITENV=y
# CONFIG_CMD_GREPENV is not set
CONFIG_CMD_SAVEENV=y
# CONFIG_CMD_ERASEENV is not set
CONFIG_CMD_ENV_EXISTS=y
# CONFIG_CMD_ENV_CALLBACK is not set
# CONFIG_CMD_ENV_FLAGS is not set
# CONFIG_CMD_NVEDIT_EFI is not set
# CONFIG_CMD_NVEDIT_INFO is not set
# CONFIG_CMD_NVEDIT_LOAD is not set
# CONFIG_CMD_NVEDIT_SELECT is not set
# Memory commands
# CONFIG_CMD_BINOP is not set
# CONFIG_CMD_BLOBLIST is not set
CONFIG_CMD_CRC32=y
# CONFIG_CRC32_VERIFY is not set
# CONFIG_CMD_EEPROM is not set
# CONFIG_LOOPW is not set
# CONFIG_CMD_MD5SUM is not set
# CONFIG_CMD_MEMINFO is not set
CONFIG_CMD_MEMORY=y
# CONFIG_CMD_MEM_SEARCH is not set
# CONFIG_CMD_MX_CYCLIC is not set
CONFIG_CMD_RANDOM=y
# CONFIG_CMD_MEMTEST is not set
# CONFIG_CMD_SHA1SUM is not set
# CONFIG_CMD_STRINGS is not set
# Compression commands
# CONFIG_CMD_LZMADEC is not set
# CONFIG_CMD_UNLZ4 is not set
# CONFIG_CMD_UNZIP is not set
# CONFIG_CMD_ZIP is not set
# Device access commands
# CONFIG_CMD_ARMFLASH is not set
# CONFIG_CMD_BCB is not set
# CONFIG_CMD_BIND is not set
# CONFIG_CMD_CLK is not set
# CONFIG_CMD_DEMO is not set
# CONFIG_CMD_DFU is not set
CONFIG_CMD_DM=y
# CONFIG_CMD_FPGAD is not set
# CONFIG_CMD_FUSE is not set
CONFIG_CMD_GPIO=y
CONFIG_CMD_GPT=y
CONFIG_RANDOM_UUID=y
# CONFIG_CMD_GPT_RENAME is not set
# CONFIG_CMD_IDE is not set
# CONFIG_CMD_IO is not set
# CONFIG_CMD_IOTRACE is not set
# CONFIG_CMD_I2C is not set
CONFIG_CMD_LOADB=y
CONFIG_CMD_LOADS=y
# CONFIG_CMD_LSBLK is not set
# CONFIG_CMD_MBR is not set
CONFIG_CMD_MMC=y
# CONFIG_CMD_BKOPS_ENABLE is not set
# CONFIG_CMD_MMC_SWRITE is not set
# CONFIG_CMD_CLONE is not set
# CONFIG_CMD_OSD is not set
CONFIG_CMD_PART=y
# CONFIG_CMD_PCI is not set
# CONFIG_CMD_POWEROFF is not set
# CONFIG_CMD_READ is not set
# CONFIG_CMD_SATA is not set
# CONFIG_CMD_SAVES is not set
# CONFIG_CMD_SCSI is not set
# CONFIG_CMD_SDRAM is not set
# CONFIG_CMD_TSI148 is not set
# CONFIG_CMD_UNIVERSE is not set
CONFIG_CMD_USB=y
# CONFIG_CMD_USB_SDP is not set
# CONFIG_CMD_USB_MASS_STORAGE is not set
# Shell scripting commands
CONFIG_CMD_ECHO=y
CONFIG_CMD_ITEST=y
CONFIG_CMD_SOURCE=y
CONFIG_CMD_SETEXPR=y
# Android support commands
CONFIG_CMD_NET=y
CONFIG_CMD_BOOTP=y
CONFIG_CMD_DHCP=y
CONFIG_BOOTP_BOOTPATH=y
CONFIG_BOOTP_DNS=y
# CONFIG_BOOTP_DNS2 is not set
CONFIG_BOOTP_GATEWAY=y
CONFIG_BOOTP_HOSTNAME=y
# CONFIG_BOOTP_PREFER_SERVERIP is not set
CONFIG_BOOTP_SUBNETMASK=y
# CONFIG_BOOTP_NTPSERVER is not set
# CONFIG_CMD_PCAP is not set
CONFIG_BOOTP_PXE=y
CONFIG_BOOTP_PXE_CLIENTARCH=0x15
CONFIG_BOOTP_VCI_STRING="U-Boot.armv7"
CONFIG_CMD_TFTPBOOT=y
# CONFIG_CMD_TFTPPUT is not set
# CONFIG_CMD_TFTPSRV is not set
CONFIG_NET_TFTP_VARS=y
# CONFIG_CMD_RARP is not set
CONFIG_CMD_NFS=y
CONFIG_CMD_MII=y
CONFIG_CMD_PING=y
# CONFIG_CMD_CDP is not set
# CONFIG_CMD_SNTP is not set
# CONFIG_CMD_DNS is not set
# CONFIG_CMD_LINK_LOCAL is not set
# CONFIG_CMD_ETHSW is not set
CONFIG_CMD_PXE=y
# CONFIG_CMD_WOL is not set
# Misc commands
# CONFIG_CMD_BSP is not set
CONFIG_CMD_BLOCK_CACHE=y
# CONFIG_CMD_CACHE is not set
# CONFIG_CMD_CONITRACE is not set
# CONFIG_CMD_EFIDEBUG is not set
# CONFIG_CMD_EXCEPTION is not set
# CONFIG_CMD_DATE is not set
# CONFIG_CMD_TIME is not set
# CONFIG_CMD_GETTIME is not set
CONFIG_CMD_SLEEP=y
# CONFIG_MP is not set
# CONFIG_CMD_TIMER is not set
CONFIG_CMD_SYSBOOT=y
# CONFIG_CMD_QFW is not set
# CONFIG_CMD_PSTORE is not set
# CONFIG_CMD_TERMINAL is not set
# CONFIG_CMD_UUID is not set
# TI specific command line interface
# CONFIG_CMD_DDR3 is not set
# Power commands
# Security commands
# CONFIG_CMD_AES is not set
# CONFIG_CMD_BLOB is not set
# CONFIG_CMD_HASH is not set
# Firmware commands
# Filesystem commands
# CONFIG_CMD_BTRFS is not set
CONFIG_CMD_EXT2=y
CONFIG_CMD_EXT4=y
# CONFIG_CMD_EXT4_WRITE is not set
CONFIG_CMD_FAT=y
# CONFIG_CMD_SQUASHFS is not set
CONFIG_CMD_FS_GENERIC=y
# CONFIG_CMD_FS_UUID is not set
# CONFIG_CMD_JFFS2 is not set
# CONFIG_CMD_REISER is not set
# CONFIG_CMD_ZFS is not set
# Debug commands
# CONFIG_CMD_BEDBUG is not set
# CONFIG_CMD_DIAG is not set
# CONFIG_CMD_LOG is not set
# CONFIG_CMD_TRACE is not set
# CONFIG_CMD_UBI is not set
# Partition Types
CONFIG_PARTITIONS=y
# CONFIG_MAC_PARTITION is not set
# CONFIG_SPL_MAC_PARTITION is not set
CONFIG_DOS_PARTITION=y
# CONFIG_SPL_DOS_PARTITION is not set
CONFIG_ISO_PARTITION=y
# CONFIG_SPL_ISO_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_SPL_AMIGA_PARTITION is not set
CONFIG_EFI_PARTITION=y
CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=56
CONFIG_EFI_PARTITION_ENTRIES_OFF=0
# CONFIG_SPL_EFI_PARTITION is not set
CONFIG_PARTITION_UUIDS=y
# CONFIG_SPL_PARTITION_UUIDS is not set
# CONFIG_PARTITION_TYPE_GUID is not set
CONFIG_SUPPORT_OF_CONTROL=y
CONFIG_DTC=y
CONFIG_PYLIBFDT=y
CONFIG_DTOC=y
CONFIG_BINMAN=y
# Device Tree Control
CONFIG_OF_CONTROL=y
# CONFIG_SPL_OF_CONTROL is not set
# CONFIG_OF_LIVE is not set
CONFIG_OF_SEPARATE=y
# CONFIG_OF_EMBED is not set
# CONFIG_OF_BOARD is not set
# CONFIG_OF_PRIOR_STAGE is not set
# CONFIG_MULTI_DTB_FIT is not set
# CONFIG_OF_DTB_PROPS_REMOVE is not set
# Environment
CONFIG_ENV_SUPPORT=y
CONFIG_SAVEENV=y
# CONFIG_ENV_OVERWRITE is not set
# CONFIG_ENV_IS_NOWHERE is not set
# CONFIG_ENV_IS_IN_EEPROM is not set
CONFIG_ENV_IS_IN_FAT=y
# CONFIG_ENV_IS_IN_EXT4 is not set
# CONFIG_ENV_IS_IN_FLASH is not set
CONFIG_ENV_IS_IN_MMC=y
# CONFIG_ENV_IS_IN_NAND is not set
# CONFIG_ENV_IS_IN_NVRAM is not set
# CONFIG_ENV_IS_IN_ONENAND is not set
# CONFIG_ENV_IS_IN_REMOTE is not set
# CONFIG_SYS_REDUNDAND_ENVIRONMENT is not set
CONFIG_ENV_FAT_INTERFACE="mmc"
CONFIG_ENV_FAT_FILE="uboot.env"
CONFIG_SYS_RELOC_GD_ENV_ADDR=y
CONFIG_SYS_MMC_ENV_DEV=0
CONFIG_SYS_MMC_ENV_PART=0
# CONFIG_USE_DEFAULT_ENV_FILE is not set
# CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set
# CONFIG_ENV_IMPORT_FDT is not set
# CONFIG_ENV_APPEND is not set
# CONFIG_ENV_WRITEABLE_LIST is not set
# CONFIG_ENV_ACCESS_IGNORE_FORCE is not set
# CONFIG_VERSION_VARIABLE is not set
CONFIG_NET=y
# CONFIG_PROT_UDP is not set
# CONFIG_BOOTP_SEND_HOSTNAME is not set
# CONFIG_NET_RANDOM_ETHADDR is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_IP_DEFRAG is not set
CONFIG_TFTP_BLOCKSIZE=1468
CONFIG_TFTP_WINDOWSIZE=1
# CONFIG_SERVERIP_FROM_PROXYDHCP is not set
CONFIG_SERVERIP_FROM_PROXYDHCP_DELAY_MS=100
# Device Drivers
# Generic Driver Options
CONFIG_DM=y
# CONFIG_SPL_DM is not set
CONFIG_DM_WARN=y
# CONFIG_DM_DEBUG is not set
CONFIG_DM_DEVICE_REMOVE=y
CONFIG_DM_STDIO=y
CONFIG_DM_SEQ_ALIAS=y
# CONFIG_DM_DMA is not set
# CONFIG_REGMAP is not set
# CONFIG_DEVRES is not set
CONFIG_SIMPLE_BUS=y
# CONFIG_SIMPLE_BUS_CORRECT_RANGE is not set
CONFIG_OF_TRANSLATE=y
# CONFIG_OF_TRANSLATE_ZERO_SIZE_CELLS is not set
# CONFIG_TRANSLATION_OFFSET is not set
CONFIG_DM_DEV_READ_INLINE=y
# CONFIG_ACPIGEN is not set
# CONFIG_BOUNCE_BUFFER is not set
# CONFIG_ADC is not set
# CONFIG_ADC_EXYNOS is not set
# CONFIG_ADC_SANDBOX is not set
# CONFIG_SARADC_MESON is not set
# CONFIG_SARADC_ROCKCHIP is not set
# CONFIG_SATA is not set
# CONFIG_SCSI_AHCI is not set
# SATA/SCSI device support
# CONFIG_DWC_AHSATA is not set
# CONFIG_FSL_SATA is not set
# CONFIG_SATA_MV is not set
# CONFIG_SATA_SIL is not set
# CONFIG_SATA_SIL3114 is not set
# CONFIG_AXI is not set
# Bus devices
CONFIG_BLK=y
CONFIG_HAVE_BLOCK_DEVICE=y
CONFIG_BLOCK_CACHE=y
# CONFIG_IDE is not set
# CONFIG_BOOTCOUNT_LIMIT is not set
# Button Support
# CONFIG_BUTTON is not set
# Cache Controller drivers
# CONFIG_CACHE is not set
# CONFIG_L2X0_CACHE is not set
# CONFIG_NCORE_CACHE is not set
# Clock
CONFIG_CLK=y
# CONFIG_SPL_CLK_CCF is not set
# CONFIG_CLK_CCF is not set
# CONFIG_CLK_CDCE9XX is not set
# CONFIG_CLK_AT91 is not set
CONFIG_CLK_SUNXI=y
# CONFIG_CLK_SUN4I_A10 is not set
# CONFIG_CLK_SUN5I_A10S is not set
# CONFIG_CLK_SUN6I_A31 is not set
# CONFIG_CLK_SUN8I_A23 is not set
# CONFIG_CLK_SUN8I_A83T is not set
# CONFIG_CLK_SUN8I_R40 is not set
# CONFIG_CLK_SUN8I_V3S is not set
# CONFIG_CLK_SUN9I_A80 is not set
CONFIG_CLK_SUN8I_H3=y
# CONFIG_CLK_SUN50I_H6 is not set
# CONFIG_CLK_SUN50I_H616 is not set
# CONFIG_CLK_SUN50I_A64 is not set
# CONFIG_CLK_SIFIVE is not set
# CONFIG_CLK_TI_AM3_DPLL is not set
# CONFIG_CLK_TI_CTRL is not set
# CONFIG_CLK_TI_GATE is not set
# CONFIG_ICS8N3QV01 is not set
# CONFIG_CLK_MPC83XX is not set
# CONFIG_CPU is not set
# Hardware crypto devices
# CONFIG_FSL_CAAM is not set
# CONFIG_SYS_FSL_SEC_BE is not set
# CONFIG_SYS_FSL_SEC_LE is not set
# Demo for driver model
# CONFIG_DM_DEMO is not set
# DFU support
# DMA Support
# CONFIG_DMA is not set
# CONFIG_TI_EDMA3 is not set
# Fastboot support
# CONFIG_USB_FUNCTION_FASTBOOT is not set
# CONFIG_UDP_FUNCTION_FASTBOOT is not set
# CONFIG_FIRMWARE is not set
# CONFIG_ZYNQMP_FIRMWARE is not set
# FPGA support
# CONFIG_FPGA_ALTERA is not set
# CONFIG_FPGA_SOCFPGA is not set
# CONFIG_FPGA_XILINX is not set
# GPIO Support
# CONFIG_GPIO_HOG is not set
# CONFIG_DM_GPIO_LOOKUP_LABEL is not set
# CONFIG_ALTERA_PIO is not set
# CONFIG_DWAPB_GPIO is not set
# CONFIG_AT91_GPIO is not set
# CONFIG_ATMEL_PIO4 is not set
# CONFIG_DA8XX_GPIO is not set
# CONFIG_INTEL_BROADWELL_GPIO is not set
# CONFIG_INTEL_GPIO is not set
# CONFIG_INTEL_ICH6_GPIO is not set
# CONFIG_IMX_RGPIO2P is not set
# CONFIG_IPROC_GPIO is not set
# CONFIG_HSDK_CREG_GPIO is not set
# CONFIG_LPC32XX_GPIO is not set
# CONFIG_MSM_GPIO is not set
# CONFIG_MXC_GPIO is not set
# CONFIG_MXS_GPIO is not set
# CONFIG_CMD_PCA953X is not set
# CONFIG_PCF8575_GPIO is not set
# CONFIG_ROCKCHIP_GPIO is not set
CONFIG_SUNXI_GPIO=y
# CONFIG_XILINX_GPIO is not set
# CONFIG_CMD_TCA642X is not set
# CONFIG_TEGRA_GPIO is not set
# CONFIG_TEGRA186_GPIO is not set
# CONFIG_VYBRID_GPIO is not set
# CONFIG_SIFIVE_GPIO is not set
# CONFIG_ZYNQ_GPIO is not set
# CONFIG_DM_74X164 is not set
# CONFIG_DM_PCA953X is not set
# CONFIG_SPL_DM_PCA953X is not set
# CONFIG_MPC8XXX_GPIO is not set
# CONFIG_NX_GPIO is not set
# Hardware Spinlock Support
# CONFIG_DM_HWSPINLOCK is not set
# I2C support
CONFIG_DM_I2C=y
# CONFIG_I2C_SET_DEFAULT_BUS_NUM is not set
# CONFIG_DM_I2C_GPIO is not set
# CONFIG_SYS_I2C_IPROC is not set
# CONFIG_SYS_I2C_FSL is not set
# CONFIG_SYS_I2C_CADENCE is not set
# CONFIG_SYS_I2C_DW is not set
# CONFIG_SYS_I2C_INTEL is not set
# CONFIG_SYS_I2C_IMX_LPI2C is not set
# CONFIG_SYS_I2C_MXC is not set
# CONFIG_SYS_I2C_NEXELL is not set
# CONFIG_SYS_I2C_OCORES is not set
# CONFIG_SYS_I2C_ROCKCHIP is not set
# CONFIG_SYS_I2C_MVTWSI is not set
# CONFIG_SYS_I2C_XILINX_XIIC is not set
# CONFIG_SYS_I2C_IHS is not set
# CONFIG_I2C_MUX is not set
CONFIG_INPUT=y
CONFIG_DM_KEYBOARD=y
# CONFIG_CROS_EC_KEYB is not set
# CONFIG_I8042_KEYB is not set
# CONFIG_TEGRA_KEYBOARD is not set
# CONFIG_TWL4030_INPUT is not set
# LED Support
# CONFIG_LED is not set
# CONFIG_LED_STATUS is not set
# Mailbox Controller Support
# CONFIG_DM_MAILBOX is not set
# Memory Controller drivers
# Multifunction device drivers
# CONFIG_MISC is not set
# CONFIG_CROS_EC is not set
# CONFIG_SPL_CROS_EC is not set
# CONFIG_DS4510 is not set
# CONFIG_FSL_SEC_MON is not set
# CONFIG_IRQ is not set
# CONFIG_NUVOTON_NCT6102D is not set
# CONFIG_PWRSEQ is not set
# CONFIG_PCA9551_LED is not set
# CONFIG_TEST_DRV is not set
# CONFIG_TWL4030_LED is not set
# CONFIG_WINBOND_W83627 is not set
# CONFIG_FS_LOADER is not set
# MMC Host controller Support
CONFIG_MMC=y
CONFIG_MMC_WRITE=y
# CONFIG_MMC_BROKEN_CD is not set
CONFIG_DM_MMC=y
# CONFIG_ARM_PL180_MMCI is not set
CONFIG_MMC_QUIRKS=y
CONFIG_MMC_HW_PARTITIONING=y
# CONFIG_SUPPORT_EMMC_RPMB is not set
CONFIG_SUPPORT_EMMC_BOOT=y
# CONFIG_MMC_IO_VOLTAGE is not set
# CONFIG_SPL_MMC_IO_VOLTAGE is not set
# CONFIG_MMC_HS400_ES_SUPPORT is not set
# CONFIG_SPL_MMC_HS400_ES_SUPPORT is not set
# CONFIG_MMC_HS400_SUPPORT is not set
# CONFIG_SPL_MMC_HS400_SUPPORT is not set
# CONFIG_MMC_HS200_SUPPORT is not set
# CONFIG_SPL_MMC_HS200_SUPPORT is not set
CONFIG_MMC_VERBOSE=y
# CONFIG_MMC_TRACE is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_MXC is not set
# CONFIG_PXA_MMC_GENERIC is not set
# CONFIG_MMC_OMAP_HS is not set
# CONFIG_MMC_SDHCI is not set
CONFIG_MMC_SUNXI=y
# CONFIG_STM32_SDMMC2 is not set
# CONFIG_FTSDC010 is not set
# CONFIG_FSL_ESDHC is not set
# CONFIG_FSL_ESDHC_IMX is not set
# MTD Support
# CONFIG_MTD is not set
# CONFIG_DM_MTD is not set
# CONFIG_MTD_NOR_FLASH is not set
# CONFIG_FLASH_CFI_DRIVER is not set
# CONFIG_MTD_RAW_NAND is not set
# SPI Flash Support
# CONFIG_SPI_FLASH is not set
# UBI support
# CONFIG_UBI_SILENCE_MSG is not set
# CONFIG_MTD_UBI is not set
# Multiplexer drivers
# CONFIG_MULTIPLEXER is not set
# CONFIG_BITBANGMII is not set
# CONFIG_MV88E6352_SWITCH is not set
# CONFIG_PHYLIB is not set
# CONFIG_FSL_PFE is not set
CONFIG_DM_ETH=y
# CONFIG_DM_ETH_PHY is not set
CONFIG_NETDEVICES=y
# CONFIG_PHY_GIGE is not set
# CONFIG_ALTERA_TSE is not set
# CONFIG_BCM_SF2_ETH is not set
# CONFIG_BCMGENET is not set
# CONFIG_CALXEDA_XGMAC is not set
# CONFIG_DWC_ETH_QOS is not set
# CONFIG_EEPRO100 is not set
# CONFIG_ETH_DESIGNWARE is not set
# CONFIG_ETH_DESIGNWARE_MESON8B is not set
# CONFIG_ETHOC is not set
# CONFIG_FMAN_ENET is not set
# CONFIG_FTMAC100 is not set
# CONFIG_FTGMAC100 is not set
# CONFIG_MCFFEC is not set
# CONFIG_FSLDMAFEC is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_MACB is not set
# CONFIG_RGMII is not set
# CONFIG_MII is not set
# CONFIG_PCNET is not set
# CONFIG_QE_UEC is not set
# CONFIG_RTL8139 is not set
# CONFIG_RTL8169 is not set
# CONFIG_SMC911X is not set
# CONFIG_SUN7I_GMAC is not set
# CONFIG_SUN4I_EMAC is not set
# CONFIG_SUN8I_EMAC is not set
# CONFIG_SH_ETHER is not set
# CONFIG_DRIVER_TI_CPSW is not set
# CONFIG_DRIVER_TI_EMAC is not set
# CONFIG_DRIVER_TI_KEYSTONE_NET is not set
# CONFIG_XILINX_AXIEMAC is not set
# CONFIG_XILINX_EMACLITE is not set
# CONFIG_ZYNQ_GEM is not set
# CONFIG_SYS_DPAA_QBMAN is not set
# CONFIG_TSEC_ENET is not set
# CONFIG_MEDIATEK_ETH is not set
# CONFIG_HIGMACV300_ETH is not set
# CONFIG_PCI is not set
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# CONFIG_X86_PCH7 is not set
# CONFIG_X86_PCH9 is not set
# PHY Subsystem
CONFIG_PHY=y
# CONFIG_SPL_PHY is not set
# CONFIG_NOP_PHY is not set
# CONFIG_MIPI_DPHY_HELPERS is not set
# CONFIG_BCM_SR_PCIE_PHY is not set
# CONFIG_MSM8916_USB_PHY is not set
# Rockchip PHY driver
CONFIG_PHY_SUN4I_USB=y
# CONFIG_MVEBU_COMPHY_SUPPORT is not set
# Pin controllers
# CONFIG_PINCTRL is not set
# Power
# CONFIG_ACPI_PMC is not set
# CONFIG_SPL_ACPI_PMC is not set
# CONFIG_TPL_ACPI_PMC is not set
# Power Domain Support
# CONFIG_POWER_DOMAIN is not set
# CONFIG_DM_PMIC is not set
# CONFIG_PMIC_AS3722 is not set
# CONFIG_POWER_MC34VR500 is not set
# CONFIG_DM_REGULATOR is not set
CONFIG_SUNXI_NO_PMIC=y
# CONFIG_SY8106A_POWER is not set
# CONFIG_POWER_MT6323 is not set
# CONFIG_DM_PWM is not set
# CONFIG_PWM_IMX is not set
# CONFIG_PWM_SANDBOX is not set
# CONFIG_U_QE is not set
# CONFIG_RAM is not set
# Remote Processor drivers
# Reset Controller Support
CONFIG_DM_RESET=y
# CONFIG_RESET_AST2500 is not set
# CONFIG_RESET_AST2600 is not set
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_HISILICON is not set
# CONFIG_RESET_SYSCON is not set
# CONFIG_RESET_SCMI is not set
# CONFIG_DM_RNG is not set
# Real Time Clock
# CONFIG_DM_RTC is not set
# CONFIG_RTC_ENABLE_32KHZ_OUTPUT is not set
# CONFIG_RTC_PCF8563 is not set
# CONFIG_RTC_RX8025 is not set
# CONFIG_RTC_PL031 is not set
# CONFIG_RTC_S35392A is not set
# CONFIG_RTC_MC146818 is not set
# CONFIG_RTC_M41T62 is not set
# CONFIG_SCSI is not set
# CONFIG_DM_SCSI is not set
# Serial drivers
CONFIG_BAUDRATE=115200
CONFIG_REQUIRE_SERIAL_CONSOLE=y
CONFIG_SPECIFY_CONSOLE_INDEX=y
CONFIG_SERIAL_PRESENT=y
CONFIG_SPL_SERIAL_PRESENT=y
CONFIG_CONS_INDEX=1
CONFIG_DM_SERIAL=y
# CONFIG_SERIAL_RX_BUFFER is not set
# CONFIG_SERIAL_SEARCH_ALL is not set
# CONFIG_SERIAL_PROBE_ALL is not set
# CONFIG_ALTERA_JTAG_UART is not set
# CONFIG_ALTERA_UART is not set
# CONFIG_ARC_SERIAL is not set
# CONFIG_ARM_DCC is not set
# CONFIG_ATMEL_USART is not set
# CONFIG_BCM6345_SERIAL is not set
# CONFIG_COREBOOT_SERIAL is not set
# CONFIG_CORTINA_UART is not set
# CONFIG_FSL_LINFLEXUART is not set
# CONFIG_FSL_LPUART is not set
# CONFIG_MVEBU_A3700_UART is not set
# CONFIG_MCFUART is not set
# CONFIG_NULLDEV_SERIAL is not set
CONFIG_SYS_NS16550=y
# CONFIG_NS16550_DYNAMIC is not set
# CONFIG_PL01X_SERIAL is not set
# CONFIG_XILINX_UARTLITE is not set
# CONFIG_MSM_SERIAL is not set
# CONFIG_OMAP_SERIAL is not set
# CONFIG_PXA_SERIAL is not set
# CONFIG_SIFIVE_SERIAL is not set
# CONFIG_ZYNQ_SERIAL is not set
# CONFIG_MTK_SERIAL is not set
# CONFIG_MT7620_SERIAL is not set
# CONFIG_SMEM is not set
# Sound support
# CONFIG_SOUND is not set
# SOC (System On Chip) specific Drivers
# CONFIG_SOC_DEVICE is not set
# CONFIG_SOC_TI is not set
# CONFIG_SPI is not set
# SPMI support
# CONFIG_SPMI is not set
# CONFIG_SYSINFO is not set
# System reset device drivers
# CONFIG_SYSRESET is not set
# CONFIG_SYSRESET_SYSCON is not set
# CONFIG_SYSRESET_WATCHDOG is not set
# CONFIG_SYSRESET_RESETCTL is not set
# CONFIG_SYSRESET_MPC83XX is not set
# CONFIG_TEE is not set
# CONFIG_OPTEE is not set
# CONFIG_DM_THERMAL is not set
# Timer Support
# CONFIG_TIMER is not set
# TPM support
CONFIG_USB=y
CONFIG_DM_USB=y
# CONFIG_DM_USB_GADGET is not set
# USB Host Controller Drivers
CONFIG_USB_HOST=y
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_MSM is not set
# CONFIG_USB_EHCI_PCI is not set
# CONFIG_USB_EHCI_ZYNQ is not set
CONFIG_USB_EHCI_GENERIC=y
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_OHCI_HCD=y
# CONFIG_USB_OHCI_PCI is not set
CONFIG_USB_OHCI_GENERIC=y
# CONFIG_USB_OHCI_DA8XX is not set
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_CDNS3 is not set
# CONFIG_USB_DWC3 is not set
# Legacy MUSB Support
# CONFIG_USB_MUSB_HCD is not set
# CONFIG_USB_MUSB_UDC is not set
# MUSB Controller Driver
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
# CONFIG_USB_MUSB_DA8XX is not set
# CONFIG_USB_MUSB_TI is not set
# CONFIG_USB_MUSB_AM35X is not set
# CONFIG_USB_MUSB_DSPS is not set
# CONFIG_USB_MUSB_PIO_ONLY is not set
# USB Phy
# CONFIG_TWL4030_USB is not set
# CONFIG_OMAP_USB_PHY is not set
# CONFIG_ROCKCHIP_USB2_PHY is not set
# ULPI drivers
# USB peripherals
CONFIG_USB_STORAGE=y
CONFIG_USB_KEYBOARD=y
CONFIG_USB_KEYBOARD_FN_KEYS=y
# CONFIG_SYS_USB_EVENT_POLL is not set
CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
# CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP is not set
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology"
CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a
CONFIG_USB_GADGET_PRODUCT_NUM=0x1010
# CONFIG_USB_GADGET_ATMEL_USBA is not set
# CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set
# CONFIG_USB_GADGET_DWC2_OTG is not set
# CONFIG_USB_GADGET_OS_DESCRIPTORS is not set
# CONFIG_CI_UDC is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_SDP_LOADADDR=0
# CONFIG_USB_GADGET_DOWNLOAD is not set
# CONFIG_USB_ETHER is not set
# CONFIG_USB_HOST_ETHER is not set
# UFS Host Controller Support
# CONFIG_TI_J721E_UFS is not set
# Graphics support
# CONFIG_DM_VIDEO is not set
CONFIG_SYS_WHITE_ON_BLACK=y
# CONFIG_NO_FB_CLEAR is not set
# TrueType Fonts
# CONFIG_VIDEO_VESA is not set
# CONFIG_VIDEO_LCD_ANX9804 is not set
# CONFIG_VIDEO_LCD_SSD2828 is not set
# CONFIG_VIDEO_MVEBU is not set
# CONFIG_I2C_EDID is not set
# CONFIG_DISPLAY is not set
# CONFIG_ATMEL_HLCD is not set
# CONFIG_AM335X_LCD is not set
# CONFIG_VIDEO_TEGRA20 is not set
# CONFIG_VIDEO_BRIDGE is not set
# CONFIG_VIDEO is not set
# CONFIG_LCD is not set
# CONFIG_VIDEO_SIMPLE is not set
# CONFIG_VIDEO_DT_SIMPLEFB is not set
# CONFIG_OSD is not set
# CONFIG_SPLASH_SCREEN is not set
# CONFIG_VIDEO_VCXK is not set
# VirtIO Drivers
# CONFIG_VIRTIO_MMIO is not set
# 1-Wire support
# CONFIG_W1 is not set
# 1-wire EEPROM support
# CONFIG_W1_EEPROM is not set
# Watchdog Timer Support
# CONFIG_WATCHDOG is not set
CONFIG_WATCHDOG_TIMEOUT_MSECS=60000
# CONFIG_IMX_WATCHDOG is not set
# CONFIG_ULP_WATCHDOG is not set
# CONFIG_DESIGNWARE_WATCHDOG is not set
# CONFIG_WDT is not set
# CONFIG_PVBLOCK is not set
# CONFIG_PHYS_TO_BUS is not set
# File systems
# CONFIG_FS_BTRFS is not set
# CONFIG_FS_CBFS is not set
# CONFIG_SPL_FS_CBFS is not set
CONFIG_FS_EXT4=y
# CONFIG_EXT4_WRITE is not set
CONFIG_FS_FAT=y
CONFIG_FAT_WRITE=y
CONFIG_FS_FAT_MAX_CLUSTSIZE=65536
# CONFIG_FS_JFFS2 is not set
# CONFIG_UBIFS_SILENCE_MSG is not set
# CONFIG_FS_CRAMFS is not set
# CONFIG_YAFFS2 is not set
# CONFIG_FS_SQUASHFS is not set
# Library routines
# CONFIG_ADDR_MAP is not set
# CONFIG_BCH is not set
CONFIG_BINMAN_FDT=y
# CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
# CONFIG_DYNAMIC_CRC_TABLE is not set
CONFIG_HAVE_PRIVATE_LIBGCC=y
CONFIG_LIB_UUID=y
CONFIG_PRINTF=y
CONFIG_SPL_PRINTF=y
CONFIG_SPRINTF=y
CONFIG_SPL_SPRINTF=y
CONFIG_STRTO=y
CONFIG_SPL_STRTO=y
CONFIG_USE_PRIVATE_LIBGCC=y
CONFIG_SYS_HZ=1000
CONFIG_SPL_USE_TINY_PRINTF=y
# CONFIG_PANIC_HANG is not set
CONFIG_REGEX=y
CONFIG_LIB_RAND=y
# CONFIG_LIB_HW_RAND is not set
# CONFIG_SPL_TINY_MEMSET is not set
# CONFIG_TPL_TINY_MEMSET is not set
# CONFIG_BITREVERSE is not set
# CONFIG_TRACE is not set
# CONFIG_CMD_DHRYSTONE is not set
# Security support
# CONFIG_AES is not set
# CONFIG_RSA is not set
# CONFIG_ASYMMETRIC_KEY_TYPE is not set
# CONFIG_TPM is not set
# Android Verified Boot
# Hashing Support
CONFIG_SHA1=y
CONFIG_SHA256=y
# CONFIG_SHA512_ALGO is not set
# CONFIG_SHA_HW_ACCEL is not set
CONFIG_MD5=y
# CONFIG_SPL_MD5 is not set
# Compression Support
# CONFIG_LZ4 is not set
# CONFIG_LZMA is not set
# CONFIG_LZO is not set
CONFIG_GZIP=y
# CONFIG_ZLIB_UNCOMPRESS is not set
# CONFIG_BZIP2 is not set
CONFIG_ZLIB=y
# CONFIG_ZSTD is not set
# CONFIG_SPL_LZ4 is not set
# CONFIG_SPL_LZMA is not set
# CONFIG_SPL_LZO is not set
# CONFIG_SPL_GZIP is not set
# CONFIG_SPL_ZSTD is not set
# CONFIG_ERRNO_STR is not set
# CONFIG_HEXDUMP is not set
# CONFIG_GETOPT is not set
CONFIG_OF_LIBFDT=y
CONFIG_OF_LIBFDT_ASSUME_MASK=0
CONFIG_OF_LIBFDT_OVERLAY=y
# CONFIG_SPL_OF_LIBFDT is not set
CONFIG_SPL_OF_LIBFDT_ASSUME_MASK=0xff
# CONFIG_TPL_OF_LIBFDT is not set
CONFIG_TPL_OF_LIBFDT_ASSUME_MASK=0xff
# System tables
CONFIG_GENERATE_SMBIOS_TABLE=y
# CONFIG_SMBIOS_PARSER is not set
CONFIG_EFI_LOADER=y
CONFIG_CMD_BOOTEFI_BOOTMGR=y
CONFIG_EFI_VARIABLE_FILE_STORE=y
# CONFIG_EFI_VARIABLES_PRESEED is not set
CONFIG_EFI_VAR_BUF_SIZE=16384
# CONFIG_EFI_RUNTIME_UPDATE_CAPSULE is not set
# CONFIG_EFI_CAPSULE_ON_DISK is not set
CONFIG_EFI_DEVICE_PATH_TO_TEXT=y
CONFIG_EFI_DEVICE_PATH_UTIL=y
CONFIG_EFI_DT_FIXUP=y
CONFIG_EFI_LOADER_HII=y
CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2=y
CONFIG_EFI_UNICODE_CAPITALIZATION=y
CONFIG_EFI_PLATFORM_LANG_CODES="en-US"
# CONFIG_EFI_GRUB_ARM32_WORKAROUND is not set
CONFIG_EFI_LOAD_FILE2_INITRD=y
# CONFIG_EFI_SECURE_BOOT is not set
# CONFIG_TEST_FDTDEC is not set
CONFIG_LIB_ELF=y
CONFIG_LMB=y
CONFIG_LMB_USE_MAX_REGIONS=y
CONFIG_LMB_MAX_REGIONS=8
# CONFIG_PHANDLE_CHECK_SEQ is not set
# CONFIG_UNIT_TEST is not set
# CONFIG_SPL_UNIT_TEST is not set
# Tools options
CONFIG_MKIMAGE_DTC_PATH="dtc"
#9 2021-05-18 10:34:17
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
插TF卡进uboot命令行, 用 mmc dev 命令测试.
楼主 #10 2021-05-18 11:01:39
electronic_s
=> mmc dev
switch to partitions #0, OK
mmc0 is current device
=> mmc list
mmc@1c0f000: 0 (SD)
mmc@1c10000: 3
mmc@1c11000: 2
楼主 #11 2021-05-18 11:05:26
electronic_s
=> printenv
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_efi_bootmgr=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=fel mmc0 usb0 pxe dhcp
bootcmd=run distro_bootcmd
bootcmd_dhcp=setenv devtype dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=devnum=0; run usb_boot
bootdelay=2
bootm_size=0xa000000
console=ttyS0,115200
cpu=armv7
dfu_alt_info_ram=kernel ram 0x42000000 0x1000000;fdt ram 0x43000000 0x100000;ramdisk ram 0x43400000 0x4000000
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr_r=0x43000000
fdtcontroladdr=5bf662f0
fdtfile=sun8i-h3-nanopi-neo-air.dtb
fdtoverlay_addr_r=0x43300000
kernel_addr_r=0x42000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mmc_bootdev=0
partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system};
preboot=usb start
pxefile_addr_r=0x43200000
ramdisk_addr_r=0x43400000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x43100000
serial#=02c0018124be1fe4
soc=sunxi
stderr=serial
stdin=serial,usbkbd
stdout=serial
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b
uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3
Environment size: 4455/131068 bytes
#12 2021-05-18 11:21:21
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
mmc dev 1
mmc dev 2
mmc dev 3
试一试
楼主 #13 2021-05-18 11:35:34
electronic_s
=> mmc dev 1
no mmc device at slot 1
=> mmc dev 2
Card did not respond to voltage select! : -110
=> mmc dev 3
像是沒電了
#14 2021-05-18 11:39:13
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
linux 下面可以访问 eMMC ?
楼主 #15 2021-05-18 11:41:16
electronic_s
沒問題的, LINUX下就能用mmcblk2
#16 2021-05-18 12:01:04
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
那和硬件没关系了, 感觉还是 uboot配置或者设备树问题, 先用 TF卡启动uboot 能访问到 eMMC才行。
楼主 #17 2021-05-18 12:13:19
electronic_s
感覺是被這個騙了
https://linux-sunxi.org/Bootable_eMMC
First of all, any eMMC can be also used as a regular SD card. Which means that it can be treated as a single large block device representing its full capacity. And the first stage bootloader (U-Boot SPL or Allwinner's boot0) is expected to be stored in a special hardcoded place between the MBR and the first partition, which does not play very nice with GPT partitioning. But if you are happy with this particular setup, then just go to the Bootable SD card page for further information and instructions.
還是要老方法吧,間好partitions 分別方入uboot, dtb, kernel, roots, 但我本身用extlinux.conf, 對老方法boot.scr 完全不明白
楼主 #18 2021-05-18 13:35:29
electronic_s
這個是原來的UBOOT 跑EMMC 情況
U-Boot SPL 2017.11 (Dec 19 2019 - 16:43:16)
DRAM: 512 MiB(408MHz)
CPU Freq: 408MHz
memory test: 1
Pattern 55aa  Writing...Reading...OK
Boot device: emmc
U-Boot 2017.11 (Dec 19 2019 - 16:43:16 +0800) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: FriendlyElec NanoPi H3
DRAM:  512 MiB
CPU Freq: 1008MHz
MMC:   SUNXI SD/MMC: 1, SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
BOARD: nanopi-neo-air
No controllers found
=> mmc list
SUNXI SD/MMC: 1
SUNXI SD/MMC: 0 (eMMC)
=> mmc dev 1
mmc_init: -95, time 22
=> mmc dev 2
MMC Device 2 not found
no mmc device at slot 2
=> mmc dev 3
MMC Device 3 not found
no mmc device at slot 3
=> mmc dev 0
mmc0(part 0) is current device
=> mmc dev
這個是反而把在MMC2 的EMMC 推到MMC0 去跑,太奇怪了
#19 2021-05-18 13:52:04
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
和现在uboot有什么不同?
楼主 #20 2021-05-18 14:26:54
electronic_s
這個不清楚了, 是原來從淘寶回來的uboot, 賣家更不會搞CONFIG
#21 2021-05-18 14:44:26
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
electronic_s 说:
全志芯片主线Linux 启动 eMMC 8-bit 模式测试
http://whycan.com/t_2383.html#p31061
(出处:哇酷开发者社区)
看下这个有没有参考价值。
楼主 #22 2021-05-18 15:55:29
electronic_s
electronic_s 说:
(出处:哇酷开发者社区)
看下这个有没有参考价值。
查看一下, 萬分感激,如成功定必報告
楼主 #23 2021-05-18 17:54:32
electronic_s
對了NANOPI AIR 原理圖, SDC2 是用PC5-6 PC8-16 的PIN, UBOOT 是沒有錯的, 也引證之後的LINUX 能讀寫EMMC
楼主 #24 2021-05-18 19:12:46
electronic_s
有UPDATE 了
加了printf 才發現,dd if=./u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8 完全不會更新EMMC 上的UBOOT
需要用這個才可以
dd if=u-boot-sunxi-with-spl.bin of=/dev/mmcblk1boot0 bs=4k
詳情看
另外UBOOT DEFCONFIG 也加一句
CONFIG_MMC_SUNXI_SLOT_EXTRA=2
U-Boot 2021.07-rc2-g59a2b9e6-dirty (May 18 2021 - 18:44:06 +0800) Allwinner Technology
Model: FriendlyARM NanoPi NEO Air
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 3, mmc@1c11000: 2
Loading Environment from FAT... In:    serial
Out:   serial
Err:   serial
SUNXI_INVALID_BOOT_SOURCE=-1
SUNXI_BOOTED_FROM_MMC0=0
SUNXI_BOOTED_FROM_MMC0_HIGH=16
SUNXI_BOOTED_FROM_NAND=1
SUNXI_BOOTED_FROM_MMC2=2
SUNXI_BOOTED_FROM_MMC2_HIGH=18
SUNXI_BOOTED_FROM_SPI=3
boot_source=2
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
查了MMC INFO 可以見到MMC2
=> mmc list
mmc@1c0f000: 0
mmc@1c10000: 3
mmc@1c11000: 2
=> mmc dev 2
mmc2(part 0) is current device
=> mmcinfo
Device: mmc@1c11000
Manufacturer ID: 15
OEM: 100
Bus Speed: 52000000
Mode: MMC High Speed (52MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 512 KiB ENH
Boot area 0 is not write protected
Boot area 1 is not write protected
#25 2021-05-25 18:14:36
rick lou
所在地: 中国北京海淀
已发帖子: 202
emmc接到sd卡接口
楼主 #26 2021-05-28 09:46:01
electronic_s
rick lou 说:
emmc接到sd卡接口
neo air 上的EMMC 是焊死的
