楼主 #1 2021-05-18 17:52:30
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
全志在线 D1哪吒开发板开机连接wifi热点, 启动 sshd 服务
1. 下载 dropbear-D1.tgz源码, 解压, 编译:
根据实际情况修改 gcc 路径
CROSS=/opt/D1/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/riscv64-unknown-linux-gnu- make
2. 修改 wifi 热点配置 package/allwinner/wifimanager/files/wpa_supplicant_overlay.conf
disable_scan_offload=1
network={
    ssid="whycan"
    psk="13800138000"
3. 修改文件系统, 添加文件 allwinner/d1-nezha/base-files/etc/init.d/S51dropbear
# Allow a few customizations from a config file
test -r /etc/default/dropbear && . /etc/default/dropbear
start() {
        DROPBEAR_ARGS="$DROPBEAR_ARGS -R"
        # If /etc/dropbear is a symlink to /var/run/dropbear, and
        #   - the filesystem is RO (i.e. we can not rm the symlink),
        #     create the directory pointed to by the symlink.
        #   - the filesystem is RW (i.e. we can rm the symlink),
        #     replace the symlink with an actual directory
        if [ -L /etc/dropbear \
             -a "$(readlink /etc/dropbear)" = "/var/run/dropbear" ]
        then
                if rm -f /etc/dropbear >/dev/null 2>&1; then
                        mkdir -p /etc/dropbear
                        echo "No persistent location to store SSH host keys. New keys will be"
                        echo "generated at each boot. Are you sure this is what you want to do?"
                        mkdir -p "$(readlink /etc/dropbear)"
                fi
        fi
        printf "Starting dropbear sshd: "
        umask 077
        start-stop-daemon -S -q -p /var/run/dropbear.pid \
                --exec /usr/sbin/dropbear -- $DROPBEAR_ARGS
        [ $? = 0 ] && echo "OK" || echo "FAIL"
stop() {
        printf "Stopping dropbear sshd: "
        start-stop-daemon -K -q -p /var/run/dropbear.pid
restart() {
        stop
        start
case "$1" in
  start)
        start
  stop)
        stop
  restart|reload)
        restart
        echo "Usage: $0 {start|stop|restart}"
        exit 1
esac
exit $?
把前面编译的 dropbear 复制到 allwinner/d1-nezha/base-files/usr/sbin/
4. 执行编译/打包/烧录:
source build/envsetup.sh;lunch d1_nezha-tina;make;pack
5. 启动手动执行 (因为还不会自动执行, 折腾了很多次也没搞定)
#获取IP
udhcpc -i wlan0
#启动ssh服务
/etc/init.d/S51dropbear restart
root@TinaLinux:/# udhcpc -i wlan0
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: sending select for 192.168.43.224
udhcpc: lease of 192.168.43.224 obtained, lease time 3599
udhcpc: ifconfig wlan0 192.168.43.224 netmask 255.255.255.0 broadcast 192.168.43.255
udhcpc: setting default routers: 192.168.43.1
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# /etc/init.d/S51dropbear restart
Stopping dropbear sshd: OK
Starting dropbear sshd: OK
6. 给板子的root设置一个密码 passwd
7. 用 Xshell, mobaxterm, putty, ssh命令行等都可以连接到 192.168.43.224
参考链接:
全志 A33 官方 dragonboard SDK  建立 SSHD 服务器, 电脑通过WIFI连接A33 SSHD服务器 [分享]
http://whycan.com/t_6312.html
#2 2023-05-22 00:17:11
Copper
已发帖子: 30
Re: 全志在线 D1哪吒开发板开机连接wifi热点, 启动 sshd 服务
这个是在tina系统下的教程么?适用于哪吒开发板的debian么?
