楼主 # 2021-06-07 23:05:06
scy251147
已发帖子: 31
uboot无法引导进入系统
uboot编译完毕后,烧录完毕,设备树和根文件系统都装好了,但是uboot无法引导进入系统:
DRAM: 32 MiB
Trying to boot from MMC1
U-Boot 2018.01 (Jun 06 2021 - 07:18:09 -0700) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
reading /suniv-f1c100s-licheepi-nano.dtb
7583 bytes read in 25 ms (295.9 KiB/s)
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
想问问各位,上面的uboot引导是不是有问题呀?
楼主 #1 2021-06-07 23:05:32
scy251147
已发帖子: 31
Re: uboot无法引导进入系统
=> print
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${pre}
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};i
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddrf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=fel mmc0 usb0 pxe dhcp
bootcmd=run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp};
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo 'i
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=2
bootfstype=fat
bootm_size=0x1700000
console=ttyS0,115200
cpu=arm926ejs
devnum=0
devplist=1
devtype=mmc
dfu_alt_info_ram=kernel ram 0x80500000 0x1000000;fdt ram 0x80C00000 0x100000;r0
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr_r=0x80C00000
fdtcontroladdr=81e55da8
fdtfile=suniv-f1c100s-licheepi-nano.dtb
fel_booted=1
fileaddr=80c00000
filesize=1d9f
kernel_addr_r=0x80500000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${pref}
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_i
partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader;
preboot=usb start
pxefile_addr_r=0x80D00000
ramdisk_addr_r=0x80D50000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; fo;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env e
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n e
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prei
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} $e
scriptaddr=0x80C50000
soc=sunxi
stderr=serial@1c25000
stdin=serial@1c25000
stdout=serial@1c25000
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dei
uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b
uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3
Environment size: 4545/131068 bytes
楼主 #2 2021-06-07 23:05:46
scy251147
已发帖子: 31
Re: uboot无法引导进入系统
=> bdinfo
arch_number = 0x00000000
boot_params = 0x80000100
DRAM bank = 0x00000000
-> start = 0x80000000
-> size = 0x02000000
baudrate = 115200 bps
TLB addr = 0x81FF0000
relocaddr = 0x81F78000
reloc off = 0x00878000
irq_sp = 0x81E55D90
sp start = 0x81E55D80
Early malloc usage: 118 / 400
fdt_blob = 81e55da8
楼主 #3 2021-06-07 23:06:17
scy251147
已发帖子: 31
Re: uboot无法引导进入系统
print信息和dbinfo信息打印如上
楼主 #4 2021-06-07 23:09:57
scy251147
已发帖子: 31
Re: uboot无法引导进入系统
是uboot哪里编译的有问题吗? 烧写命令是:sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdb bs=1024 seek=8
楼主 #5 2021-06-08 05:46:42
scy251147
已发帖子: 31
Re: uboot无法引导进入系统
说一下,我是使用tf卡启动的。
楼主 #6 2021-06-08 06:36:15
scy251147
已发帖子: 31
Re: uboot无法引导进入系统
结贴, 是因为suniv.h中需要配置
/ bootcmd 保存着 uboot 默认命令, uboot 倒计时结束以后就会执行 bootcmd 中的命令 /
/ bootargs 保存着 uboot 传递给 Linux 内核的参数/
sudo nano /include/configs/suniv.h
/ 添加以下代码(mmc 0为TF卡,1是第一分区,文件系统为fat32,把zImage和dtb文件拷入DRAM)/
#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x80800000 zImage; " \
"fatload mmc 0:1 0x83000000 suniv-f1c100s-licheepi-nano.dtb; " \
"bootz 0x80800000 - 0x83000000;"
/ 继续添加(linux将使用uart0进行交互,死机5s重启,根文件系统在mmc0(tf卡)第二分区(EXT4),等待 mmc 设备初始化完成以后再挂载,开启读写权限) /
#define CONFIG_BOOTARGS "console=ttyS0,115200 panic=5 root=/dev/mmcblk0p2 rootwait rw "
/ 回到u-boot目录进行编译 /
make ARCH=arm menuconfig
/ 取消勾选 [] Enable a default value for bootcmd /
/ 勾选 [v] Enable boot arguments;/
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j16
#7 2021-06-08 09:16:18
已发帖子: 3,410
Re: uboot无法引导进入系统
感谢楼主分享
