楼主 # 2021-06-11 17:38:44
cube
已发帖子: 288
Risc-V Assembly Language Hello World
https://www.google.com/amp/s/smist08.wordpress.com/2019/09/07/risc-v-assembly-language-hello-world/amp/
Hello World
First let’s present the program and then we’ll discuss it. This program works by making Linux system calls and like all Linux programs starts execution at the globally exported _start label. The program uses the Assembly directives specified in the GCC documentation.
# Risc-V Assembler program to print "Hello World!"
# to stdout.
# a0-a2 - parameters to linux function services
# a7 - linux function number
.global _start      # Provide program starting address to linker
# Setup the parameters to print hello world
# and then call Linux to do it.
_start: addi  a0, x0, 1      # 1 = StdOut
        la    a1, helloworld # load address of helloworld
        addi  a2, x0, 13     # length of our string
        addi  a7, x0, 64     # linux write system call
        ecall                # Call linux to output the string
# Setup the parameters to exit the program
        addi    a0, x0, 0   # Use 0 return code
        addi    a7, x0, 93  # Service command code 93 terminates
        ecall               # Call linux to terminate the program
.data
helloworld:      .ascii "Hello World!\n"
The ‘#’ character is the comment character and anything after it on a line is a comment.
