Exportable Squashfs 4.0 filesystem, xz compressed, data block size 131072
compressed data, compressed metadata, compressed fragments, compressed xattrs
duplicates are removed
Filesystem size 10132.76 Kbytes (9.90 Mbytes)
35.23% of uncompressed filesystem size (28764.44 Kbytes)
Inode table size 14118 bytes (13.79 Kbytes)
21.25% of uncompressed inode table size (66443 bytes)
Directory table size 20186 bytes (19.71 Kbytes)
51.47% of uncompressed directory table size (39217 bytes)
Number of duplicate files found 12
Number of inodes 1816
Number of files 1255
Number of fragments 63
Number of symbolic links 408
Number of device nodes 3
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 150
Number of ids (unique uids + gids) 2
Number of uids 2
root (0)
www-data (33)
Number of gids 2
root (0)
www-data (33)
INFO: packing firmware ...
ERROR: board dir or path do not exist.
All avaiable chips, platforms and boards:
Chip Board
sun8iw8p1
zeta-v3s
zeta-s3l
zeta-s3
zeta-v3
default
For Usage:
pack -h
这步执行到 zmake image的步骤出问题,查看shell脚本发现是 执行ZetaLinux_public_V3S3V3sS3L/tools/pack/pack 这个应用程序输出的
跟踪一下, 看是哪个目录不存在.
脚本我都看了 ,这一步的日志输出 是在一个可执行文件里面。我就看不到了,但是在编译rootfs的时候提示以下问题,但是进度条也百分之百完成了
command exec success.
[zeta] Build squashfs rootfs ...
cp: 无法创建普通文件"/home/qihua/ZetaLinux_public_V3S3V3sS3L/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/etc/sysconfig/clock": 没有那个文件或目录
cp: 无法以目录"/home/qihua/ZetaLinux_public_V3S3V3sS3L/build/hooks/zoneinfo/Asia" 来覆盖非目录"/home/qihua/ZetaLinux_public_V3S3V3sS3L/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/share/zoneinfo/Asia"
chmod: 无法访问"/home/qihua/ZetaLinux_public_V3S3V3sS3L/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/usr/bin/*.sh": 没有那个文件或目录
rootdir=/home/qihua/ZetaLinux_public_V3S3V3sS3L/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target/
table='/home/qihua/ZetaLinux_public_V3S3V3sS3L/build/rootfs_tar/_device_table.txt'
Parallel mksquashfs: Using 4 processors
Creating 4.0 filesystem on /home/qihua/ZetaLinux_public_V3S3V3sS3L/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//images/rootfs.squashfs, block size 131072.
[/ ] 1/1401 0%
llistxattr for /home/qihua/ZetaLinux_public_V3S3V3sS3L/out/sun8iw8p1-linaro-5.3/linux/common/buildroot//target//etc/water[======================================================================================================|] 1401/1401 100%
编译索智(Sochip) S3 SDK (zeta) 【提供DXP格式原理图与PCB,感谢 @playflash】
https://whycan.com/t_1739.html#p10164
(出处:哇酷开发者社区)初始化环境那些软件都装了吗?
是的 按照这个帖子操作的。ubuntu 14.04
记得索智那个文档要求16.04,你换个虚拟机再试一试呗。
还有没有可能是 我这个sdk的包是从csdn的一个链接下载下来的。论坛的分不够。
那我只能再尝试一下16.04版本了
@哇酷小二
目前还没有发精华帖的能力,已经付费下载了。期待能解决问题
xiaoqianxiansheng 说:@哇酷小二
感谢支持, 有问题请到下面跟帖.
大佬,还是问一下编译Zeta linux的问题。
;[spi_board0] spi device configuration
;modalias = spi device name
;max_speed_hz = max transfer speed
;bus_num = bus ID
;chip_select = chip select, 0,1
;mode = SPI transfer mode
; sflash_size- 16 : 16M nor flash size , 8 : 8M nor flash size
[spi_board0]
modalias = "mx25l12835f"
max_speed_hz = 16000000
bus_num = 0
chip_select = 0
mode = 0
sflash_size = 16
这个sys_config里面就是16M flash ,为什么编译出来的固件是32M的。
