楼主 # 2021-08-03 01:48:14
tlxfif
已发帖子: 36
F1C100S启动报错,请问下是什么原因呢?谢谢啦
[    1.320542] ALSA device list:
[    1.323508]   #0: Loopback 1
[    1.327367] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.336034] cfg80211: failed to load regulatory.db
[    1.495011] random: crng init done
[    1.669350] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    1.677439] devtmpfs: mounted
[    1.685066] Freeing unused kernel memory: 1024K
[    3.674210] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00174638: read 0xaef6bc4b, calculated 0xc0422ad9.
[    3.739940] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x001543b8: read 0x7b3a36a, calculated 0xc980d2a1.
[    3.757017] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x001521a4: read 0x5bf8d398, calculated 0xae1c5f1d.
[    3.792323] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00142490: read 0x3b920e78, calculated 0x249e22a5.
[    3.812870] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0013ddb8: read 0xc4426a3b, calculated 0x2d1e784a.
[    3.836468] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00136de4: read 0xe74ffdfa, calculated 0x38ff6b86.
[    3.850908] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x001361cc: read 0xe329d8d7, calculated 0xac33b755.
[    3.932120] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00104194: read 0xa5bde6fe, calculated 0xb4a578c2.
[    3.951239] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00100790: read 0x8fa0c553, calculated 0x51119f4c.
[    3.969329] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000fdfdc: read 0xf7108889, calculated 0xeeb9d36c.
[    3.984180] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000fd54c: read 0x63bd04f1, calculated 0x7a28642a.
/bin/sh: symbol 'stdout': can't resolve symbol
/bin/sh: symbol 'optarg': can't resolve symbol
/bin/sh: symbol 'opterr': can't resolve symbol
/bin/sh: symbol '__environ': can't resolve symbol
/bin/sh: symbol 'optind': can't resolve symbol
/bin/sh: symbol '__stdin': can't resolve symbol
/bin/sh: symbol 'stdin': can't resolve symbol
/bin/sh: symbol 'timezone': can't resolve symbol
/bin/sh: symbol 'stderr': can't resolve symbol
/bin/sh: symbol '__stdout': can't resolve symbol
[    4.086796] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000ff00
[    4.086796]
[    4.095945] CPU: 0 PID: 1 Comm: sh Not tainted 4.15.0-rc8-licheepi-nano #5
[    4.102800] Hardware name: Allwinner suniv Family
[    4.107576] [<c010e550>] (unwind_backtrace) from [<c010b6a8>] (show_stack+0x10/0x14)
[    4.115332] [<c010b6a8>] (show_stack) from [<c0116878>] (panic+0xb8/0x230)
[    4.122209] [<c0116878>] (panic) from [<c0118034>] (do_exit+0x96c/0x9a4)
[    4.128908] [<c0118034>] (do_exit) from [<c0118b78>] (SyS_exit+0x10/0x14)
[    4.135698] [<c0118b78>] (SyS_exit) from [<c0107ce0>] (ret_fast_syscall+0x0/0x50)
[    4.143172] Rebooting in 5 seconds..
[   10.122405] Reboot failed -- System halted
#1 2021-08-03 08:17:17
已发帖子: 3,408
Re: F1C100S启动报错,请问下是什么原因呢?谢谢啦
JFFS2 文件系统有问题:
