楼主 # 2021-08-15 17:25:41
ubuntu
已发帖子: 335
TSC2007 I2C触摸驱动有个地方没搞明白, 为什么IRQ引脚和GPIO检测PEN引脚状态可以是同一个
为什么IRQ引脚和GPIO检测PEN引脚状态可以是同一个,
这样在 IRQ/GPIO 两种复用之间要来回切换吗?
可是驱动代码里面并没有出现这种切换。
https://github.com/torvalds/linux/blob/master/drivers/input/touchscreen/tsc2007_core.c
// SPDX-License-Identifier: GPL-2.0-only
 * drivers/input/touchscreen/tsc2007.c
 * Copyright (c) 2008 MtekVision Co., Ltd.
 *	Kwangwoo Lee <kwlee@mtekvision.com>
 * Using code from:
 *  - ads7846.c
 *	Copyright (c) 2005 David Brownell
 *	Copyright (c) 2006 Nokia Corporation
 *  - corgi_ts.c
 *	Copyright (C) 2004-2005 Richard Purdie
 *  - omap_ts.[hc], ads7846.h, ts_osk.c
 *	Copyright (C) 2002 MontaVista Software
 *	Copyright (C) 2004 Texas Instruments
 *	Copyright (C) 2005 Dirk Behme
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/gpio/consumer.h>
#include <linux/input.h>
#include <linux/interrupt.h>
#include <linux/i2c.h>
#include <linux/mod_devicetable.h>
#include <linux/property.h>
#include <linux/platform_data/tsc2007.h>
#include "tsc2007.h"
int tsc2007_xfer(struct tsc2007 *tsc, u8 cmd)
	s32 data;
	u16 val;
	data = i2c_smbus_read_word_data(tsc->client, cmd);
	if (data < 0) {
		dev_err(&tsc->client->dev, "i2c io error: %d\n", data);
		return data;
	/* The protocol and raw data format from i2c interface:
	 * S Addr Wr [A] Comm [A] S Addr Rd [A] [DataLow] A [DataHigh] NA P
	 * Where DataLow has [D11-D4], DataHigh has [D3-D0 << 4 | Dummy 4bit].
	val = swab16(data) >> 4;
	dev_dbg(&tsc->client->dev, "data: 0x%x, val: 0x%x\n", data, val);
	return val;
static void tsc2007_read_values(struct tsc2007 *tsc, struct ts_event *tc)
	/* y- still on; turn on only y+ (and ADC) */
	tc->y = tsc2007_xfer(tsc, READ_Y);
	/* turn y- off, x+ on, then leave in lowpower */
	tc->x = tsc2007_xfer(tsc, READ_X);
	/* turn y+ off, x- on; we'll use formula #1 */
	tc->z1 = tsc2007_xfer(tsc, READ_Z1);
	tc->z2 = tsc2007_xfer(tsc, READ_Z2);
	/* Prepare for next touch reading - power down ADC, enable PENIRQ */
	tsc2007_xfer(tsc, PWRDOWN);
u32 tsc2007_calculate_resistance(struct tsc2007 *tsc, struct ts_event *tc)
	u32 rt = 0;
	/* range filtering */
	if (tc->x == MAX_12BIT)
		tc->x = 0;
	if (likely(tc->x && tc->z1)) {
		/* compute touch resistance using equation #1 */
		rt = tc->z2 - tc->z1;
		rt *= tc->x;
		rt *= tsc->x_plate_ohms;
		rt /= tc->z1;
		rt = (rt + 2047) >> 12;
	return rt;
bool tsc2007_is_pen_down(struct tsc2007 *ts)
	 * NOTE: We can't rely on the pressure to determine the pen down
	 * state, even though this controller has a pressure sensor.
	 * The pressure value can fluctuate for quite a while after
	 * lifting the pen and in some cases may not even settle at the
	 * expected value.
	 * The only safe way to check for the pen up condition is in the
	 * work function by reading the pen signal state (it's a GPIO
	 * and IRQ). Unfortunately such callback is not always available,
	 * in that case we assume that the pen is down and expect caller
	 * to fall back on the pressure reading.
	if (!ts->get_pendown_state)
		return true;
	return ts->get_pendown_state(&ts->client->dev);
static irqreturn_t tsc2007_soft_irq(int irq, void *handle)
	struct tsc2007 *ts = handle;
	struct input_dev *input = ts->input;
	struct ts_event tc;
	u32 rt;
	while (!ts->stopped && tsc2007_is_pen_down(ts)) {
		/* pen is down, continue with the measurement */
		mutex_lock(&ts->mlock);
		tsc2007_read_values(ts, &tc);
		mutex_unlock(&ts->mlock);
		rt = tsc2007_calculate_resistance(ts, &tc);
		if (!rt && !ts->get_pendown_state) {
			 * If pressure reported is 0 and we don't have
			 * callback to check pendown state, we have to
			 * assume that pen was lifted up.
			break;
		if (rt <= ts->max_rt) {
			dev_dbg(&ts->client->dev,
				"DOWN point(%4d,%4d), resistance (%4u)\n",
				tc.x, tc.y, rt);
			rt = ts->max_rt - rt;
			input_report_key(input, BTN_TOUCH, 1);
			input_report_abs(input, ABS_X, tc.x);
			input_report_abs(input, ABS_Y, tc.y);
			input_report_abs(input, ABS_PRESSURE, rt);
			input_sync(input);
		} else {
			 * Sample found inconsistent by debouncing or pressure is
			 * beyond the maximum. Don't report it to user space,
			 * repeat at least once more the measurement.
			dev_dbg(&ts->client->dev, "ignored pressure %d\n", rt);
		wait_event_timeout(ts->wait, ts->stopped, ts->poll_period);
	dev_dbg(&ts->client->dev, "UP\n");
	input_report_key(input, BTN_TOUCH, 0);
	input_report_abs(input, ABS_PRESSURE, 0);
	input_sync(input);
	if (ts->clear_penirq)
		ts->clear_penirq();
	return IRQ_HANDLED;
static irqreturn_t tsc2007_hard_irq(int irq, void *handle)
	if (tsc2007_is_pen_down(ts))
		return IRQ_WAKE_THREAD;
		ts->clear_penirq();
	return IRQ_HANDLED;
static void tsc2007_stop(struct tsc2007 *ts)
	ts->stopped = true;
	mb();
	wake_up(&ts->wait);
	disable_irq(ts->irq);
static int tsc2007_open(struct input_dev *input_dev)
	struct tsc2007 *ts = input_get_drvdata(input_dev);
	int err;
	ts->stopped = false;
	mb();
	enable_irq(ts->irq);
	/* Prepare for touch readings - power down ADC and enable PENIRQ */
	err = tsc2007_xfer(ts, PWRDOWN);
	if (err < 0) {
		tsc2007_stop(ts);
		return err;
static void tsc2007_close(struct input_dev *input_dev)
	tsc2007_stop(ts);
static int tsc2007_get_pendown_state_gpio(struct device *dev)
	struct i2c_client *client = to_i2c_client(dev);
	struct tsc2007 *ts = i2c_get_clientdata(client);
	return gpiod_get_value(ts->gpiod);
static int tsc2007_probe_properties(struct device *dev, struct tsc2007 *ts)
	u32 val32;
	u64 val64;
	if (!device_property_read_u32(dev, "ti,max-rt", &val32))
		ts->max_rt = val32;
		ts->max_rt = MAX_12BIT;
	if (!device_property_read_u32(dev, "ti,fuzzx", &val32))
		ts->fuzzx = val32;
	if (!device_property_read_u32(dev, "ti,fuzzy", &val32))
		ts->fuzzy = val32;
	if (!device_property_read_u32(dev, "ti,fuzzz", &val32))
		ts->fuzzz = val32;
	if (!device_property_read_u64(dev, "ti,poll-period", &val64))
		ts->poll_period = msecs_to_jiffies(val64);
		ts->poll_period = msecs_to_jiffies(1);
	if (!device_property_read_u32(dev, "ti,x-plate-ohms", &val32)) {
		ts->x_plate_ohms = val32;
	} else {
		dev_err(dev, "Missing ti,x-plate-ohms device property\n");
		return -EINVAL;
	ts->gpiod = devm_gpiod_get_optional(dev, NULL, GPIOD_IN);
	if (IS_ERR(ts->gpiod))
		return PTR_ERR(ts->gpiod);
	if (ts->gpiod)
		ts->get_pendown_state = tsc2007_get_pendown_state_gpio;
		dev_warn(dev, "Pen down GPIO is not specified in properties\n");
static int tsc2007_probe_pdev(struct device *dev, struct tsc2007 *ts,
			      const struct tsc2007_platform_data *pdata,
			      const struct i2c_device_id *id)
	ts->model             = pdata->model;
	ts->x_plate_ohms      = pdata->x_plate_ohms;
	ts->max_rt            = pdata->max_rt ? : MAX_12BIT;
	ts->poll_period       = msecs_to_jiffies(pdata->poll_period ? : 1);
	ts->get_pendown_state = pdata->get_pendown_state;
	ts->clear_penirq      = pdata->clear_penirq;
	ts->fuzzx             = pdata->fuzzx;
	ts->fuzzy             = pdata->fuzzy;
	ts->fuzzz             = pdata->fuzzz;
	if (pdata->x_plate_ohms == 0) {
		dev_err(dev, "x_plate_ohms is not set up in platform data\n");
		return -EINVAL;
static void tsc2007_call_exit_platform_hw(void *data)
	struct device *dev = data;
	const struct tsc2007_platform_data *pdata = dev_get_platdata(dev);
	pdata->exit_platform_hw();
static int tsc2007_probe(struct i2c_client *client,
		dev_get_platdata(&client->dev);
	struct tsc2007 *ts;
	struct input_dev *input_dev;
	int err;
	if (!i2c_check_functionality(client->adapter,
				     I2C_FUNC_SMBUS_READ_WORD_DATA))
		return -EIO;
	ts = devm_kzalloc(&client->dev, sizeof(struct tsc2007), GFP_KERNEL);
	if (!ts)
		return -ENOMEM;
	if (pdata)
		err = tsc2007_probe_pdev(&client->dev, ts, pdata, id);
		err = tsc2007_probe_properties(&client->dev, ts);
	if (err)
		return err;
	input_dev = devm_input_allocate_device(&client->dev);
	if (!input_dev)
		return -ENOMEM;
	i2c_set_clientdata(client, ts);
	ts->client = client;
	ts->irq = client->irq;
	ts->input = input_dev;
	init_waitqueue_head(&ts->wait);
	mutex_init(&ts->mlock);
	snprintf(ts->phys, sizeof(ts->phys),
		 "%s/input0", dev_name(&client->dev));
	input_dev->name = "TSC2007 Touchscreen";
	input_dev->phys = ts->phys;
	input_dev->id.bustype = BUS_I2C;
	input_dev->open = tsc2007_open;
	input_dev->close = tsc2007_close;
	input_set_drvdata(input_dev, ts);
	input_set_capability(input_dev, EV_KEY, BTN_TOUCH);
	input_set_abs_params(input_dev, ABS_X, 0, MAX_12BIT, ts->fuzzx, 0);
	input_set_abs_params(input_dev, ABS_Y, 0, MAX_12BIT, ts->fuzzy, 0);
	input_set_abs_params(input_dev, ABS_PRESSURE, 0, MAX_12BIT,
			     ts->fuzzz, 0);
	if (pdata) {
		if (pdata->exit_platform_hw) {
			err = devm_add_action(&client->dev,
					      tsc2007_call_exit_platform_hw,
					      &client->dev);
			if (err) {
				dev_err(&client->dev,
					"Failed to register exit_platform_hw action, %d\n",
					err);
				return err;
		if (pdata->init_platform_hw)
			pdata->init_platform_hw();
	err = devm_request_threaded_irq(&client->dev, ts->irq,
					tsc2007_hard_irq, tsc2007_soft_irq,
					IRQF_ONESHOT,
					client->dev.driver->name, ts);
	if (err) {
		dev_err(&client->dev, "Failed to request irq %d: %d\n",
			ts->irq, err);
		return err;
	tsc2007_stop(ts);
	/* power down the chip (TSC2007_SETUP does not ACK on I2C) */
	if (err < 0) {
			"Failed to setup chip: %d\n", err);
		return err;	/* chip does not respond */
	err = input_register_device(input_dev);
	if (err) {
			"Failed to register input device: %d\n", err);
		return err;
	err =  tsc2007_iio_configure(ts);
	if (err) {
			"Failed to register with IIO: %d\n", err);
		return err;
static const struct i2c_device_id tsc2007_idtable[] = {
	{ "tsc2007", 0 },
MODULE_DEVICE_TABLE(i2c, tsc2007_idtable);
static const struct of_device_id tsc2007_of_match[] = {
	{ .compatible = "ti,tsc2007" },
	{ /* sentinel */ }
MODULE_DEVICE_TABLE(of, tsc2007_of_match);
static struct i2c_driver tsc2007_driver = {
	.driver = {
		.name	= "tsc2007",
		.of_match_table = tsc2007_of_match,
	.id_table	= tsc2007_idtable,
	.probe		= tsc2007_probe,
module_i2c_driver(tsc2007_driver);
MODULE_AUTHOR("Kwangwoo Lee <kwlee@mtekvision.com>");
MODULE_DESCRIPTION("TSC2007 TouchScreen Driver");
MODULE_LICENSE("GPL");
buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 * 已支持DVP摄像头 *
https://whycan.com/t_5221.html#p54779
        rtp@48 {
                compatible = "ti,tsc2007";
                reg = <0x48>;
                interrupt-parent = <&pio>;
                interrupts = <4 12 IRQ_TYPE_EDGE_FALLING>;
                gpios = <&pio 4 12 GPIO_ACTIVE_LOW>;
                pendown-gpio = <&pio 4 12 GPIO_ACTIVE_LOW>;
                ti,x-plate-ohms = <660>;
                wakeup-source;
#1 2021-08-15 22:24:16
cube
已发帖子: 288
Re: TSC2007 I2C触摸驱动有个地方没搞明白, 为什么IRQ引脚和GPIO检测PEN引脚状态可以是同一个
从手册看,gpio输入和外部中断属于不同的复用。
只能这么认为了,中断复用的时候也能读?
