spi flash 手册: https://www.winbond.com/resource-files/w25n01gv%20revg%20032116.pdf
立创商城链接: https://item.szlcsc.com/90048.html (有点小贵)
同求
主线好像不支持,需要加驱动
全志的sunxi-tools不支持spi nand的烧写吧,你们是怎么把程序烧到flash里面的呢,不用烧片机
晕哥加油,要是2片不够的话我再给你支援几片 ~ ~
话说荔枝群里有位仁兄上传过spi nand flash从sunxitools到kernel的全套驱动支持,我没v3s的板子,你们有移植调试过木有呢
awfans 说:spi flash 手册: https://www.winbond.com/resource-files/w25n01gv%20revg%20032116.pdf
上传到哪了啊?我也想参考参考
就在代码模块里面有
wind 说:话说荔枝群里有位仁兄上传过spi nand flash从sunxitools到kernel的全套驱动支持,我没v3s的板子,你们有移植调试过木有呢
上传到哪了啊?我也想参考参考
@晕哥
按照http://nano.lichee.pro/build_sys/build_flash.html里的参考编译出内核
给出的正常的打印信息会有
[    0.834964] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.839694] spi0.0: parsing partitions cmdlinepart
[    0.845501] spi0.0: got parser (null)
[    0.849182] spi0.0: parsing partitions ofpart
[    0.853652] spi0.0: got parser ofpart
[    0.857374] spi0.0: parser ofpart: 4
[    0.860949] 4 ofpart partitions found on MTD device spi0.0
[    0.866491] Creating 4 MTD partitions on "spi0.0":
[    0.871304] 0x000000000000-0x000000100000 : "u-boot"
[    0.878962] 0x000000100000-0x000000110000 : "dtb"
[    0.886404] 0x000000110000-0x000000510000 : "kernel"
[    0.894027] 0x000000510000-0x000001000000 : "rootfs"
我自己使用主线4.15.0的内核,从spi-flash 启动出现
[    0.827100] SCSI Media Changer driver v0.25
后不会出现上面信息,看样子不能正确识别到spiflash里的分区信息。
最终挂在Waiting for root device /dev/mtdblock3
U-Boot SPL 2018.01-05676-g00188782ee-dirty (May 19 2018 - 15:47:49)
DRAM: 32 MiB
SPL: Unsupported Boot Device!
Trying to boot from sunxi SPI
U-Boot 2018.01-05676-g00188782ee-dirty (May 19 2018 - 15:47:49 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM:  32 MiB
Using default environment
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
SF: Detected w25q128bv with page size 256 Bytes, erase size 64 KiB, total 16 MiB
   Loading Device Tree to 80e4c000, end 80e50f0e ... OK
[    0.000000] Linux version 4.15.0-rc8-next-20180202-licheepi-nano++ (root@gx-Ubuntu) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #10 Fri Aug 24 17:24:38 CST 2018
[    0.000000] Memory: 24780K/32768K available (4096K kernel code, 205K rwdata, 1156K rodata, 1024K init, 218K bss, 7988K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (5088 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 206 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 219 kB)
[    0.000051] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000120] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000714] Console: colour dummy device 80x30
[    0.000812] Calibrating delay loop... 239.61 BogoMIPS (lpj=1198080)
[    0.070234] pid_max: default: 32768 minimum: 301
[    0.070545] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070591] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072036] CPU: Testing write buffer coherency: ok
[    0.073930] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076382] devtmpfs: initialized
[    0.081822] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.081896] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.082170] pinctrl core: initialized pinctrl subsystem
[    0.084820] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.086629] cpuidle: using governor menu
[    0.106993] SCSI subsystem initialized
[    0.107335] usbcore: registered new interface driver usbfs
[    0.107483] usbcore: registered new interface driver hub
[    0.107686] usbcore: registered new device driver usb
[    0.108175] pps_core: LinuxPPS API ver. 1 registered
[    0.108204] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.108717] Advanced Linux Sound Architecture Driver Initialized.
[    0.109052] clocksource: Switched to clocksource timer
[    0.136835] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.138666] Initialise system trusted keyrings
[    0.139421] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.152097] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
[    0.166488] Key type asymmetric registered
[    0.166532] Asymmetric key parser 'x509' registered
[    0.166738] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.166770] io scheduler noop registered
[    0.166786] io scheduler deadline registered
[    0.167556] io scheduler cfq registered (default)
[    0.167597] io scheduler mq-deadline registered
[    0.167616] io scheduler kyber registered
[    0.168667] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[    0.178461] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.355585] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.362605] console [ttyS0] disabled
[    0.382925] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[    0.774091] console [ttyS0] enabled
[    0.782422] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc05363d8)
[    0.790288] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.796896] [drm] No driver support for vblank timestamp query.
[    0.802892] sun4i-drm display-engine: Failed to initialize drm fb helper.
[    0.809734] sun4i-drm display-engine: Couldn't create our framebuffer
[    0.816478] sun4i-drm display-engine: master bind failed: -22
[    0.822615] sun4i-backend: probe of 1e60000.display-backend failed with error -22
[    0.832319] panel-simple panel: panel supply power not found, using dummy regulator
[    0.841778] SCSI Media Changer driver v0.25
[    0.847086] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.853753] ehci-platform: EHCI generic platform driver
[    0.859343] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.865560] ohci-platform: OHCI generic platform driver
[    0.871239] usbcore: registered new interface driver usb-storage
[    0.878100] i2c /dev entries driver
[    0.939172] sunxi-mmc 1c0f000.mmc: base:0xfa88f1b6 irq:18
[    0.946561] usbcore: registered new interface driver usbhid
[    0.952278] usbhid: USB HID core driver
[    0.975320] Loading compiled-in X.509 certificates
[    0.990022] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.001887] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.007739] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.018219] hub 1-0:1.0: USB hub found
[    1.022654] hub 1-0:1.0: 1 port detected
[    1.030385] vcc3v3: disabling
[    1.033379] ALSA device list:
[    1.036344]   #0: Loopback 1
[    1.040519] Waiting for root device /dev/mtdblock3...离线
@晕哥
使用Nano_pub_V2里面的编译好的内核,能够正常从spiflash启动,但是编译出来的.ko 文件不能正常insmod
DRAM: 32 MiB
DRAM:  32 MiB
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
   Loading Device Tree to 80e4c000, end 80e51326 ... OK
[    0.000000] Linux version 4.15.0-next-20180202-licheepi-nano+ (biglion@biglion-MRC-WX0) (gcc version 7.2.0 (Ubuntu/Linaro 7.2.0-6ubuntu1)) #107 Sat May 19 11:56:16 CST 2018
[    0.000000] Memory: 23752K/32768K available (5120K kernel code, 203K rwdata, 1148K rodata, 1024K init, 227K bss, 9016K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (6112 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 204 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 228 kB)
[    0.000117] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000727] Console: colour dummy device 80x30
[    0.000824] Calibrating delay loop... 239.61 BogoMIPS (lpj=1198080)
[    0.070235] pid_max: default: 32768 minimum: 301
[    0.070674] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070727] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072178] CPU: Testing write buffer coherency: ok
[    0.074032] Setting up static identity map for 0x80100000 - 0x80100058
[    0.076500] devtmpfs: initialized
[    0.082938] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.083003] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.083316] pinctrl core: initialized pinctrl subsystem
[    0.085541] NET: Registered protocol family 16
[    0.087310] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.089152] cpuidle: using governor menu
[    0.109587] SCSI subsystem initialized
[    0.109873] pps_core: LinuxPPS API ver. 1 registered
[    0.109901] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.109971] PTP clock support registered
[    0.111961] clocksource: Switched to clocksource timer
[    0.139494] NET: Registered protocol family 2
[    0.140958] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[    0.141038] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.141097] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.141142] TCP: Hash tables configured (established 1024 bind 1024)
[    0.141516] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.141581] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.142296] NET: Registered protocol family 1
[    0.144053] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.145951] Initialise system trusted keyrings
[    0.146546] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    0.160477] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.174402] Key type asymmetric registered
[    0.174444] Asymmetric key parser 'x509' registered
[    0.174693] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.174728] io scheduler noop registered
[    0.174746] io scheduler deadline registered
[    0.175583] io scheduler cfq registered (default)
[    0.175622] io scheduler mq-deadline registered
[    0.175639] io scheduler kyber registered
[    0.186827] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.359475] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.366534] console [ttyS0] disabled
[    0.386822] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 25, base_baud = 6250000) is a 16550A
[    0.806912] console [ttyS0] enabled
[    0.817624] panel-simple panel: panel supply power not found, using dummy regulator
[    0.902128] i2c /dev entries driver
[    0.936637] sunxi-mmc 1c0f000.mmc: base:0x007adfe2 irq:21
[    0.945378] NET: Registered protocol family 17
[    0.949936] Key type dns_resolver registered
[    0.956554] Loading compiled-in X.509 certificates
[    0.971557] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0633630)
[    0.979609] sun4i-tcon 1c0c000.lcd-controller: Missing LVDS properties, Please upgrade your DT
[    0.988294] sun4i-tcon 1c0c000.lcd-controller: LVDS output disabled
[    0.995507] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0632848)
[    1.003299] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.009903] [drm] No driver support for vblank timestamp query.
[    1.192437] Console: switching to colour frame buffer device 100x30
[    1.232171] sun4i-drm display-engine: fb0:  frame buffer device
[    1.239382] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.247953] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.264379] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.271157] vcc3v3: disabling
[    1.275145] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.283874] cfg80211: failed to load regulatory.db
[    1.361516] random: crng init done
[    3.789591] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    3.797536] devtmpfs: mounted
[    3.807051] Freeing unused kernel memory: 1024K
Starting logging: OK
Welcome to Lichee Pi
gxhost login: root
Password:
# cd /lib/modules/4.15.0-next-20180202-licheepi-nano\+/kernel/drivers/led/
# ls
app          misc_led.ko
# insmod misc_led.ko
[   57.131163] misc_led: loading out-of-tree module taints kernel.
[   57.137773] misc_led: Unknown symbol __memzero (err 0)
[   57.145822] misc_led: Unknown symbol __memzero (err 0)
insmod: can't insert 'misc_led.ko': unknown symbol in module, or unknown parameter
# 我的.ko文件工程f1c100s_leds_tar.gz
root@gx-Ubuntu:/git/apps/f1c100s_leds# ls
app  Makefile  make.sh  misc_led.c  misc_led.h  misc_led.ko
root@gx-Ubuntu:/git/apps/f1c100s_leds# modinfo misc_led.ko
filename:       /git/apps/f1c100s_leds/misc_led.ko
alias:          platform:f1c100s_led
license:        GPL
description:    led driver
author:         gx
depends:
vermagic:       4.15.0-next-20180202-licheepi-nano+ mod_unload ARMv5 p2v8最近编辑记录 include_h (2018-08-26 14:03:15)
@晕哥,今天逛论坛,找到问题了,参考这个 https://whycan.cn/t_1180.html
是的,18楼的
几乎熬了个通宵,终于找到原因了并解决问题了:官网下载的config文件,开错了全志的spi控制器开关,正确的配置是# CONFIG_SPI_SUN4I is not set
CONFIG_SPI_SUN6I=y(看来f1c100s用的是新版本的spi控制器)。修改后内核可以正确识别到spi flash了。另外,官网页面上还有个问题, uboot的bootargs 参数设置中, root=/dev/mtdblock3必须要修改为root=31:3,否则无法正确加载rootfs。修改以上两点后可以正确启动到控制台了。云盘中的sdk包4.13和docker中的4.15版本均是如此修改。
感谢 @三贪猪 坛友分享
附件下载要几分怎么办??
