楼主 #1 2017-09-29 14:57:54
coolesp32
已发帖子: 30
奇怪,我用esp32作为wifi热点, 出现expression: esp_wifi_set_config错误, 而且系统不断复位
[0;32mI (1128) cpu_start: App cpu up.[0m
[0;32mI (1141) heap_alloc_caps: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (1163) heap_alloc_caps: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM[0m
[0;32mI (1184) heap_alloc_caps: At 3FFB7A88 len 00028578 (161 KiB): DRAM[0m
[0;32mI (1205) heap_alloc_caps: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM[0m
[0;32mI (1226) heap_alloc_caps: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (1248) heap_alloc_caps: At 40093160 len 0000CEA0 (51 KiB): IRAM[0m
[0;32mI (1269) cpu_start: Pro cpu start user code[0m
[0;32mI (1326) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (1331) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (1361) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
ESP_ERROR_CHECK failed: esp_err_t 0xb at 0x400df5e8
file: "C:/esp32-tutorial/12_accesspoint/main/main.c" line 168
func: app_main
expression: esp_wifi_set_config(WIFI_IF_AP, &ap_config)
Backtrace: 0x4008687c:0x3ffb88f0 0x40086bf9:0x3ffb8910 0x400df5e8:0x3ffb8930 0x400d08aa:0x3ffb8a00
Rebooting...
ets Jun  8 2016 00:22:57
就酱紫一直重启
最近编辑记录 coolesp32 (2017-09-29 15:05:52)
#2 2017-09-29 14:59:27
jujumao
Re: 奇怪,我用esp32作为wifi热点, 出现expression: esp_wifi_set_config错误, 而且系统不断复位
楼主, 可以贴出你的代码吗?
楼主 #3 2017-09-29 15:00:05
coolesp32
已发帖子: 30
// Main application
void app_main()
	// disable the default wifi logging
	esp_log_level_set("wifi", ESP_LOG_NONE);
	// create the event group to handle wifi events
	event_group = xEventGroupCreate();
	// initialize the tcp stack
	tcpip_adapter_init();
	// stop DHCP server
	ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP));
	// assign a static IP to the network interface
	tcpip_adapter_ip_info_t info;
    memset(&info, 0, sizeof(info));
	IP4_ADDR(&info.ip, 192, 168, 10, 1);
    IP4_ADDR(&info.gw, 192, 168, 10, 1);
    IP4_ADDR(&info.netmask, 255, 255, 255, 0);
	ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &info));
	// start the DHCP server
    ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP));
	// initialize the wifi event handler
	ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
	// initialize the wifi stack in AccessPoint mode with config in RAM
	wifi_init_config_t wifi_init_config = WIFI_INIT_CONFIG_DEFAULT();
	ESP_ERROR_CHECK(esp_wifi_init(&wifi_init_config));
	ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
	ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
	// configure the wifi connection and start the interface
	wifi_config_t ap_config = {
        .ap = {
            .ssid = CONFIG_AP_SSID,
            .password = CONFIG_AP_PASSWORD,
			.ssid_len = 0,
			.channel = CONFIG_AP_CHANNEL,
			.authmode = CONFIG_AP_AUTHMODE,
			.ssid_hidden = CONFIG_AP_SSID_HIDDEN,
			.max_connection = CONFIG_AP_MAX_CONNECTIONS,
			.beacon_interval = CONFIG_AP_BEACON_INTERVAL,
	ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &ap_config));
	// start the wifi interface
	ESP_ERROR_CHECK(esp_wifi_start());
	printf("Starting access point, SSID=%s\n", CONFIG_AP_SSID);
	// start the main task
    xTaskCreate(&monitor_task, "monitor_task", 2048, NULL, 5, NULL);
	xTaskCreate(&station_list_task, "station_list_task", 2048, NULL, 5, NULL);
#4 2017-09-29 19:40:43
已发帖子: 9,436
这个问题我也刚好碰上,
让我想想当时是怎么解决的了
