很强大,不知道资料开放程度如何
Sorry for english..
The SSD26X is interesting. The SDK is still using a 32bit compiler I think.
Most of the hardware of the SSD201 and SSD202D is reverse engineered now. All of the sigmastar chips use the same hardware so it should be possible to make them all work.
I even have the LCD controller working in Linux 5.14: https://twitter.com/linux_chenxing/status/1415308882918797323
I need to finish reverse engineering the sound but it is pretty difficult.
芯片挺好,,可惜没资料
这货的USB终于有device?
