楼主 # 2021-09-09 11:18:14
jkl
已发帖子: 269
请问一下,rk3399Android10.0,系统跑到这个部分一直反复重启,但是看启动logo没有看到明显的错误在哪里??
启动logo:
DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
OUT
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 346
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 69150
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x2000, size:0x2000
GPT part: 1, name: trust, start:0x4000, size:0x2000
GPT part: 2, name: misc, start:0x6000, size:0x2000
GPT part: 3, name: dtbo, start:0xc000, size:0x2000
GPT part: 4, name: vbmeta, start:0xe000, size:0x800
GPT part: 5, name: resource, start:0x8000, size:0x8000
GPT part: 6, name: kernel, start:0x10000, size:0xc000
GPT part: 7, name: boot, start:0xe800, size:0x10000
GPT part: 8, name: recovery, start:0x1e800, size:0x30000
GPT part: 9, name: backup, start:0x4e800, size:0x38000
GPT part: 10, name: security, start:0x86800, size:0x2000
GPT part: 11, name: cache, start:0x88800, size:0xc0000
GPT part: 12, name: metadata, start:0x148800, size:0x8000
GPT part: 13, name: frp, start:0x150800, size:0x400
GPT part: 14, name: super, start:0x150c00, size:0x714000
GPT part: 15, name: oem, start:0x864c00, size:0x100000
GPT part: 16, name: userdata, start:0x964c00, size:0x52b3df
find part:uboot OK. first_lba:0x2000.
find part:trust OK. first_lba:0x4000.
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xfb1c8
RunBL31 0x40000 @ 116000 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Aug 31 2021 - 17:48:37 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbc8000, fdt: 7bdbc358
Using default environment
dwmmc@fe320000: 1, sdhci@fe330000: 0
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
Android 10.0, Build 2020.11
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: fdt overlay OK
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1000000 uV
Model: ROC-RK3399-PC-PLUS HDMI+DP(Android)
no recovery key node
Rockchip UBOOT DRM driver version: v1.0.1
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
ANDROID: reboot reason: "recovery"
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_slot_verify.c:757: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition...
Could not find "system" partition
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000...
Fdt Ramdisk skip relocation
Booting Android Image at 0x0027f800 ...
Kernel load addr 0x00280000 size 19241 KiB
RAM disk load addr 0x0a200000 size 7949 KiB
Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 ... OK
'reserved-memory' ramoops@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831dd60
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x0a200000 - 0x80000000 (size: 0x75e00000)
Total: 588.660 ms
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.111 (le@le-desktop) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #3 SMP PREEMPT Wed Sep 8 15:24:24 CST 2021
[ 0.000000] Machine model: ROC-RK3399-PC-PLUS HDMI+DP(Android)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 23 pages/cpu s57304 r8192 d28712 u94208
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 507912
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.slot_suffix= androidboot.serialno=PEC0V81TLG console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.wificountrycode=US androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 firmware_class.path=/vendor/etc/firmware init=/init root=PARTUUID=af01642c-9b84-11e8-9b2a-234eb5e198a0 earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m androidboot.boot_devices=fe330000.sdhci,fe320000.dwmmc
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1979292K/2064384K available (11006K kernel code, 1256K rwdata, 3932K rodata, 3008K init, 2175K bss, 68708K reserved, 16384K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @7b880000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x000000007b820000
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x000000007b830000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4ec with crng_init=0
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002095] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003084] pid_max: default: 32768 minimum: 301
[ 0.003646] Security Framework initialized
[ 0.004042] SELinux: Initializing.
[ 0.004504] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005148] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.007415] ASID allocator initialised with 32768 entries
[ 0.008041] rcu: Hierarchical SRCU implementation.
[ 0.008918] Platform MSI: interrupt-controller@fee20000 domain created
[ 0.010072] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.011721] smp: Bringing up secondary CPUs ...
[ 0.012793] Detected VIPT I-cache on CPU1
[ 0.012830] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.012869] CPU1: using LPI pending table @0x000000007ba10000
[ 0.012913] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.013807] Detected VIPT I-cache on CPU2
[ 0.013842] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.013880] CPU2: using LPI pending table @0x000000007ba60000
[ 0.013923] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.014758] Detected VIPT I-cache on CPU3
[ 0.014791] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.014830] CPU3: using LPI pending table @0x000000007ba80000
[ 0.014873] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.015742] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.015748] CPU features: enabling workaround for EL2 vector hardening
[ 0.015757] Detected PIPT I-cache on CPU4
[ 0.015781] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.015833] CPU4: using LPI pending table @0x000000007bad0000
[ 0.015862] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.016584] Detected PIPT I-cache on CPU5
[ 0.016612] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.016664] CPU5: using LPI pending table @0x000000007bae0000
[ 0.016694] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.016803] smp: Brought up 1 node, 6 CPUs
[ 0.029427] SMP: Total of 6 processors activated.
[ 0.029877] CPU features: detected: GIC system register CPU interface
[ 0.030501] CPU features: detected: 32-bit EL0 Support
[ 0.035368] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.036186] CPU: All CPU(s) started at EL2
[ 0.036612] alternatives: patching kernel code
[ 0.038458] devtmpfs: initialized
[ 0.052771] Trying to unpack rootfs image as initramfs...
[ 0.053304] Registered cp15_barrier emulation handler
[ 0.053321] Registered setend emulation handler
[ 0.054616] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.055566] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.056611] pinctrl core: initialized pinctrl subsystem
[ 0.057724] NET: Registered protocol family 16
[ 0.058746] schedtune: configured to support 6 boost groups
[ 0.059500] audit: initializing netlink subsys (disabled)
[ 0.061145] audit: type=2000 audit(0.053:1): state=initialized audit_enabled=0 res=1
[ 0.061925] cpuidle: using governor menu
[ 0.062681] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.071189] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.073677] console [pstore-1] enabled
[ 0.074224] pstore: Registered ramoops as persistent store backend
[ 0.074817] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.089668] rockchip-pinctrl pinctrl: wrong pins number or pins and configs should be by 4
[ 0.090471] rockchip-pinctrl pinctrl: failed to parse function
[ 0.091903] rockchip-pinctrl: probe of pinctrl failed with error -22
[ 0.100853] cryptd: max_cpu_qlen set to 1000
[ 0.102766] vcc_sys: supplied by dc_12v
[ 0.104099] rk_iommu ff650800.iommu: version = 1
[ 0.104921] rk_iommu ff660480.iommu: version = 1
[ 0.105603] rk_iommu ff670800.iommu: version = 1
[ 0.106323] rk_iommu ff8f3f00.iommu: version = 1
[ 0.106957] rk_iommu ff903f00.iommu: version = 1
[ 0.107597] rk_iommu ff914000.iommu: version = 1
[ 0.108270] rk_iommu ff924000.iommu: version = 1
[ 0.109231] SCSI subsystem initialized
[ 0.109899] usbcore: registered new interface driver usbfs
[ 0.110449] usbcore: registered new interface driver hub
[ 0.111039] usbcore: registered new device driver usb
[ 0.111788] pps_core: LinuxPPS API ver. 1 registered
[ 0.112276] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.113155] PTP clock support registered
[ 0.116012] rockchip-cpuinfo cpuinfo: SoC : 0
[ 0.116447] rockchip-cpuinfo cpuinfo: Serial : 7d9418e5de243167
[ 0.117459] clocksource: Switched to clocksource arch_sys_counter
[ 0.160794] VFS: Disk quotas dquot_6.6.0
[ 0.161221] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.163056] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.164053] NET: Registered protocol family 2
[ 0.164890] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[ 0.165690] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.166519] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.167392] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.168147] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.168787] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.169573] NET: Registered protocol family 1
[ 0.171602] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.172684] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.174866] Initialise system trusted keyrings
[ 0.175439] workingset: timestamp_bits=45 max_order=19 bucket_order=0
[ 0.179796] Registering sdcardfs 0.1
[ 0.181033] fuse init (API version 7.27)
[ 0.182480]
[ 0.182480] TEE Core Framework initialization (ver 1:0.1)
[ 0.183165] TEE armv7 Driver initialization
[ 0.183905] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 0.184553] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 0.185281] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=63)
[ 0.187051] Key type asymmetric registered
[ 0.187457] Asymmetric key parser 'x509' registered
[ 0.187948] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.188663] io scheduler noop registered
[ 0.189135] io scheduler cfq registered (default)
[ 0.189600] io scheduler mq-deadline registered
[ 0.190034] io scheduler kyber registered
[ 0.190500] io scheduler bfq registered
[ 0.192423] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.195296] iommu: Adding device ff670000.iep to group 2
[ 0.195837] iep ff670000.iep: Linked as a consumer to ff670800.iommu
[ 0.196606] iep: failed to find iep power down clock source.
[ 0.199668] iep: IEP Power ON
[ 0.199983] iep: IEP Power OFF
[ 0.200335] iep: IEP Driver loaded succesfully
[ 0.200924] iep: Module initialized.
[ 0.201397] mpp_service mpp-srv: probe start
[ 0.202170] iommu: Adding device ff660000.rkvdec to group 1
[ 0.202734] mpp_rkvdec ff660000.rkvdec: Linked as a consumer to ff660480.iommu
[ 0.203599] mpp_rkvdec ff660000.rkvdec: probing start
[ 0.207712] rkvdec_init:1178: failed on clk_get clk_hevc_cabac
[ 0.208314] mpp_rkvdec ff660000.rkvdec: shared_video_hevc_cabac is not found!
[ 0.209009] rkvdec_init:1206: No hevc cabac reset resource define
[ 0.209845] mpp_rkvdec ff660000.rkvdec: probing finish
[ 0.211147] iommu: Adding device ff650400.vdpu to group 0
[ 0.211692] mpp_vdpu2 ff650400.vdpu: Linked as a consumer to ff650800.iommu
[ 0.212534] mpp_vdpu2 ff650400.vdpu: probe device
[ 0.213349] mpp_vdpu2 ff650400.vdpu: reset_group->rw_sem_on=0
[ 0.213926] mpp_vdpu2 ff650400.vdpu: reset_group->rw_sem_on=0
[ 0.214684] mpp_vdpu2 ff650400.vdpu: probing finish
[ 0.215537] iommu: Adding device ff650000.vepu to group 0
[ 0.216067] mpp_vepu2 ff650000.vepu: Linked as a consumer to ff650800.iommu
[ 0.216770] mpp_vepu2 ff650000.vepu: probe device
[ 0.217561] mpp_vepu2 ff650000.vepu: reset_group->rw_sem_on=0
[ 0.218116] mpp_vepu2 ff650000.vepu: reset_group->rw_sem_on=0
[ 0.218883] mpp_vepu2 ff650000.vepu: probing finish
[ 0.219558] mpp_service mpp-srv: probe success
[ 0.222293] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.223035] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.224991] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.225734] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.227642] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.228637] pwm-regulator vdd-log: Failed to get PWM: -517
[ 0.229466] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.233075] iommu: Adding device ff8f0000.vop to group 3
[ 0.233620] rockchip-vop ff8f0000.vop: Linked as a consumer to ff8f3f00.iommu
[ 0.234668] iommu: Adding device ff900000.vop to group 4
[ 0.235191] rockchip-vop ff900000.vop: Linked as a consumer to ff903f00.iommu
[ 0.237492] random: fast init done
[ 0.238109] random: crng init done
[ 0.238436] rockchip-drm display-subsystem: Linked as a consumer to ff8f0000.vop
[ 0.238468] rockchip-drm display-subsystem: Linked as a consumer to ff900000.vop
[ 0.240690] rockchip-drm display-subsystem: Linked as a consumer to ff940000.hdmi
[ 0.245354] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.251671] brd: module loaded
[ 0.264643] loop: module loaded
[ 0.265263] zram: Added device: zram0
[ 0.265866] SCSI Media Changer driver v0.25
[ 0.268604] register firefly_spi_init spi return v = :0
[ 0.269857] dwc3 fe800000.dwc3: Failed to get clk 'ref': -2
[ 0.271210] dwc3 fe900000.dwc3: Failed to get clk 'ref': -2
[ 0.273076] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.273716] ehci-pci: EHCI PCI platform driver
[ 0.274183] ehci-platform: EHCI generic platform driver
[ 0.275136] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.275754] ohci-platform: OHCI generic platform driver
[ 0.277038] usbcore: registered new interface driver cdc_acm
[ 0.277593] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.278393] usbcore: registered new interface driver usblp
[ 0.278953] usbcore: registered new interface driver cdc_wdm
[ 0.279534] usbcore: registered new interface driver uas
[ 0.280066] usbcore: registered new interface driver usb-storage
[ 0.280669] usbcore: registered new interface driver ums-alauda
[ 0.281252] usbcore: registered new interface driver ums-cypress
[ 0.281860] usbcore: registered new interface driver ums-datafab
[ 0.282461] usbcore: registered new interface driver ums_eneub6250
[ 0.283071] usbcore: registered new interface driver ums-freecom
[ 0.283674] usbcore: registered new interface driver ums-isd200
[ 0.284257] usbcore: registered new interface driver ums-jumpshot
[ 0.284870] usbcore: registered new interface driver ums-karma
[ 0.285456] usbcore: registered new interface driver ums-onetouch
[ 0.286059] usbcore: registered new interface driver ums-sddr09
[ 0.286653] usbcore: registered new interface driver ums-sddr55
[ 0.287233] usbcore: registered new interface driver ums-usbat
[ 0.287852] usbcore: registered new interface driver usbserial_generic
[ 0.288499] usbserial: USB Serial support registered for generic
[ 0.289089] usbcore: registered new interface driver option
[ 0.289642] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.290328] usbcore: registered new interface driver trancevibrator
[ 0.290978] sensor_register_slave:kxtj9,id=11
[ 0.291398] sensor_register_slave:mma8452,id=17
[ 0.291842] sensor_register_slave:lis3dh,id=7
[ 0.292261] sensor_register_slave:mma7660,id=18
[ 0.292703] sensor_register_slave:gs_mxc6655xa,id=24
[ 0.293178] sensor_register_slave:lsm303d,id=26
[ 0.293620] sensor_register_slave:gs_mc3230,id=27
[ 0.294069] [Gsensor] gsensor_init
[ 0.294412] sensor_register_slave:mpu6880_acc,id=28
[ 0.294886] sensor_register_slave:mpu6500_acc,id=29
[ 0.295355] sensor_register_slave:lsm330_acc,id=30
[ 0.295821] sensor_register_slave:bma2xx_acc,id=31
[ 0.296279] sensor_register_slave:akm8975,id=35
[ 0.296720] sensor_register_slave:akm8963,id=36
[ 0.297153] sensor_register_slave:l3g4200d,id=50
[ 0.297603] sensor_register_slave:l3g20d,id=51
[ 0.298028] sensor_register_slave:ewtsa,id=52
[ 0.298454] sensor_register_slave:lsm330_gyro,id=56
[ 0.298921] sensor_register_slave:cm3217,id=58
[ 0.299347] sensor_register_slave:cm3218,id=59
[ 0.299780] sensor_register_slave:ls_stk3410,id=67
[ 0.300239] sensor_register_slave:ps_stk3410,id=72
[ 0.301349] i2c /dev entries driver
[ 0.303086] __power_supply_register: Expected proper parent device for 'test_ac'
[ 0.303929] __power_supply_register: Expected proper parent device for 'test_battery'
[ 0.304874] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.305661] __power_supply_register: Expected proper parent device for 'test_usb'
[ 0.307158] device-mapper: uevent: version 1.0.3
[ 0.307857] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 0.308839] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 0.309833] cpu cpu0: bin=1
[ 0.310124] cpu cpu0: leakage=28
[ 0.310465] cpu cpu0: Failed to get reg
[ 0.310842] cpu cpu0: bin-scale=34
[ 0.311205] cpu cpu4: bin=1
[ 0.311503] cpu cpu4: leakage=50
[ 0.311827] cpu cpu4: Failed to get reg
[ 0.312202] cpu cpu4: bin-scale=17
[ 0.313603] sdhci: Secure Digital Host Controller Interface driver
[ 0.314193] sdhci: Copyright(c) Pierre Ossman
[ 0.314677] Synopsys Designware Multimedia Card Interface Driver
[ 0.315642] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.342905] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 0.344405] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.347495] usbcore: registered new interface driver usbhid
[ 0.348079] usbhid: USB HID core driver
[ 0.348959] rockchip-dmc dmc: Cannot get the regulator "center"
[ 0.351704] rockchip-saradc ff100000.saradc: Linked as a consumer to regulator.6
[ 0.353510] optee: probing for conduit method from DT.
[ 0.354020] optee: revision 1.1
[ 0.354515] optee: initialized driver
[ 0.355169] rknandbase v1.2 2018-05-08
[ 0.355850] netem: version 1.3
[ 0.356148] u32 classifier
[ 0.356410] Actions configured
[ 0.357390] xt_time: kernel timezone is -0000
[ 0.357927] gre: GRE over IPv4 demultiplexor driver
[ 0.358394] IPv4 over IPsec tunneling driver
[ 0.359483] Initializing XFRM netlink socket
[ 0.359913] IPsec XFRM device driver
[ 0.360585] NET: Registered protocol family 10
[ 0.361848] Segment Routing with IPv6
[ 0.362274] mip6: Mobile IPv6
[ 0.363201] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.364444] NET: Registered protocol family 17
[ 0.364904] NET: Registered protocol family 15
[ 0.365371] Bridge firewalling registered
[ 0.365853] l2tp_core: L2TP core driver, V2.0
[ 0.366601] sensor_register_slave:mpu6500_gyro,id=54
[ 0.367079] sensor_register_slave:mpu6880_gyro,id=55
[ 0.369085] registered taskstats version 1
[ 0.369495] Loading compiled-in X.509 certificates
[ 0.370346] Key type ._fscrypt registered
[ 0.370779] Key type .fscrypt registered
[ 0.371158] Key type fscrypt-provisioning registered
[ 0.371892] pstore: Using compression: deflate
[ 0.372703] rga2: Module initialized.
[ 0.381812] mmc0: new HS400 MMC card at address 0001
[ 0.383537] mmcblk0: mmc0:0001 MMC8GB 7.28 GiB
[ 0.384669] mmcblk0boot0: mmc0:0001 MMC8GB partition 1 4.00 MiB
[ 0.385934] mmcblk0boot1: mmc0:0001 MMC8GB partition 2 4.00 MiB
[ 0.386825] mmcblk0rpmb: mmc0:0001 MMC8GB partition 3 4.00 MiB, chardev (241:0)
[ 0.392897] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 0.401970] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.403651] pwm-regulator vdd-log: Failed to get PWM: -517
[ 0.404961] dwc3 fe800000.dwc3: Failed to get clk 'ref': -2
[ 0.406663] dwc3 fe900000.dwc3: Failed to get clk 'ref': -2
[ 0.410234] rockchip-dmc dmc: Cannot get the regulator "center"
[ 0.411115] reg-fixed-voltage vdd3v3-pcie-regulator: ignoring dependency for device, assuming no driver
[ 0.412194] reg-fixed-voltage vcc-sd: ignoring dependency for device, assuming no driver
[ 0.413139] reg-fixed-voltage vcc-wifi-regulator: ignoring dependency for device, assuming no driver
[ 0.414185] reg-fixed-voltage fan-ctl-regulator: ignoring dependency for device, assuming no driver
[ 0.415694] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.416750] rockchip-pwm ff420000.pwm: ignoring dependency for device, assuming no driver
[ 0.417786] rockchip-pwm ff420020.pwm: ignoring dependency for device, assuming no driver
[ 0.418929] pwm-regulator vdd-log: Failed to get PWM: -517
[ 0.419666] dw-apb-uart ff180000.serial: ignoring dependency for device, assuming no driver
[ 0.420698] dwhdmi-rockchip ff940000.hdmi: ignoring dependency for device, assuming no driver
[ 0.421890] dwc3 fe800000.dwc3: Failed to get clk 'ref': -2
[ 0.422947] dwc3 fe900000.dwc3: Failed to get clk 'ref': -2
[ 0.424883] rk3x-i2c ff3c0000.i2c: ignoring dependency for device, assuming no driver
[ 0.426300] rockchip-thermal ff260000.tsadc: ignoring dependency for device, assuming no driver
[ 0.427501] pwrseq_simple sdio-pwrseq: ignoring dependency for device, assuming no driver
[ 0.428624] dwmmc_rockchip fe320000.dwmmc: ignoring dependency for device, assuming no driver
[ 0.430049] rockchip-dmc dmc: Cannot get the regulator "center"
[ 0.430716] reg-fixed-voltage vcc5v0-host-regulator: ignoring dependency for device, assuming no driver
[ 0.432353] Freeing initrd memory: 7948K
[ 0.432976] hctosys: unable to open rtc device (rtc0)
麻烦各位大佬指点一下,看看问题出在哪里????非常感谢!!!
#1 2021-09-09 11:24:18
X3
已发帖子: 85
Re: 请问一下,rk3399Android10.0,系统跑到这个部分一直反复重启,但是看启动logo没有看到明显的错误在哪里??
找个正常机器的日志对比一下。
#2 2021-10-26 16:46:06
arychen
已发帖子: 275
我的也最近在调android11 也是有些莫名其妙内核跑飞了 其中有些是电源控制的gpio没改对。
你有碰的哪些问题 后来跑通了吗
#3 2021-10-27 21:15:32
thank you very much!
封禁
好像rk芯片的启动好复杂的样子,不是安卓的缘故把。
#4 2022-05-22 14:37:12
forever_rainy
已发帖子: 21
某鱼两百来块 买了个拆机板(感觉不是很划算,前面这个板子他卖150,后面加到200,咱也没讲价,电源适配也没有),感觉rk没有v3s这些这么简单啊。。。
