楼主 # 2021-09-12 21:28:08
niyazfattahov
已发帖子: 21
V3S ISP support in mainline
I found ISP support recently added for v3s, but I cannot understand where to find patch and how to apply it.
Does anybody interested in ISP module for v3s?(Image Signal Processing)
https://www.spinics.net/lists/arm-kernel/msg919938.html
#1 2021-09-12 22:02:01
unturned3
已发帖子: 272
Re: V3S ISP support in mainline
Oh wow, thanks for the info. I think Paul Kocialkowski is a maintainer at Bootlin, who did a ton of work mainlining Allwinner stuff.
This patch adds the device tree nodes for the ISP. If you check out the previous patch (https://www.spinics.net/lists/arm-kernel/msg919937.html), you can see the code added to drivers/staging/media/sunxi/sun6i-isp
I don't think a kernel has been released with these staging patches yet, so you have to apply these patches yourself if you'd like to test these new functions out. The patches are included in each of these commit messages.
最近编辑记录 unturned3 (2021-09-12 22:03:50)
