楼主 # 2021-09-20 18:51:39
tlxfif
已发帖子: 36
请问下f1c100s使用xboot如何配置st7789呢?
本来打算使用linux的,可惜linux太难了(需要系统学习一下)
后来看见xboot不错,因为配置文件是用json的方式(老java程序员狂喜)
下线xboot
找到mach-f1c100s
在driver中没有发现st7789的驱动
但是在mach-h3/driver中有[fb-st7789v.c]便复制到mach-f1c100s/driver目录下
在[fb-st7789v.c]中发现有配置样例如下:
 * LCD - Sitronix ST7789V Lcd Driver
 * Example:
 *	"fb-st7789v@0": {
 *		"spi-bus": "spi-h3.1",
 *		"chip-select": 0,
 *		"type": 0,
 *		"mode": 0,
 *		"speed": 50000000,
 *		"reset-gpio": 9,
 *		"reset-gpio-config": 1,
 *		"cd-gpio": 16,
 *		"cd-gpio-config": 1,
 *		"width": 240,
 *		"height": 320,
 *		"physical-width": 30,
 *		"physical-height": 40,
 *		"backlight": null
我照着改成了下面这样
	"fb-st7789v@0": {
		"spi-bus": "spi-f1c100s.1",
		"chip-select": 0,
		"type": 0,
		"mode": 0,
		"speed": 50000000,
		"reset-gpio": 134,
		"cd-gpio": 138,
		"width": 240,
		"height": 320,
		"backlight": null
下面是仿照spi0弄的spi1的接线
PC0(sclk64) - PA2(sclk2)
PC1(cs65) - PA0(cs0)
PC2(miso66) - PA3(miso3)
PC3(mosi67) - PA1(mosi1)
我把第二个spi也改了下
	"spi-f1c100s@0x01c06000": {
		"clock-name": "link-spi1",
		"reset": 21,
		"sclk-gpio": 2,
		"sclk-gpio-config": 4,
		"mosi-gpio": 1,
		"mosi-gpio-config": 4,
		"miso-gpio": 3,
		"miso-gpio-config": 4,
		"cs-gpio": 0,
		"cs-gpio-config": 4
然后屏幕啥也没有
就不知道咋搞了
