开发板: LicheePi Nano
u-boot版本: LicheePi-nano-u-boot-v2018.1
内核版本:Linux-5.7.1
SPI屏:st7789v
suniv-f1c100s.dtsi源代码
#define SUN4I_DMA_NORMAL 0
#address-cells = <1>;
#size-cells = <1>;
interrupt-parent = <&intc>;
clocks {
osc24M: clk-24M {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
osc32k: clk-32k {
#clock-cells = <0>;
clock-frequency = <32768>;
cpus {
cpu {
device_type = "cpu";
/* de: display-engine {
compatible = "allwinner,suniv-f1c100s-display-engine";
allwinner,pipelines = <&fe0>;
status = "disabled";
soc {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
sram-controller@1c00000 {
compatible = "allwinner,suniv-f1c100s-system-control",
"allwinner,sun4i-a10-system-control";
reg = <0x01c00000 0x30>;
#size-cells = <1>;
ranges;
sram_d: sram@10000 {
compatible = "mmio-sram";
reg = <0x00010000 0x1000>;
#size-cells = <1>;
otg_sram: sram-section@0 {
compatible = "allwinner,suniv-f1c100s-sram-d",
"allwinner,sun4i-a10-sram-d";
reg = <0x0000 0x1000>;
/* tcon0: lcd-controller@1c0c000 {
compatible = "allwinner,suniv-f1c100s-tcon";
reg = <0x01c0c000 0x1000>;
interrupts = <29>;
clocks = <&ccu CLK_BUS_LCD>,
<&ccu CLK_TCON>;
clock-names = "ahb",
"tcon-ch0";
clock-output-names = "tcon-pixel-clock";
resets = <&ccu RST_BUS_LCD>;
reset-names = "lcd";
ports {
#size-cells = <0>;
tcon0_in: port@0 {
#size-cells = <0>;
reg = <0>;
tcon0_in_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_out_tcon0>;
tcon0_out: port@1 {
#size-cells = <0>;
reg = <1>;
ccu: clock@1c20000 {
compatible = "allwinner,suniv-f1c100s-ccu";
reg = <0x01c20000 0x400>;
clock-names = "hosc", "losc";
#clock-cells = <1>;
#reset-cells = <1>;
compatible = "allwinner,suniv-f1c100s-ic";
reg = <0x01c20400 0x400>;
interrupt-controller;
#interrupt-cells = <1>;
pio: pinctrl@1c20800 {
compatible = "allwinner,suniv-f1c100s-pinctrl";
reg = <0x01c20800 0x400>;
gpio-controller;
#interrupt-cells = <3>;
#gpio-cells = <3>;
uart0_pe_pins: uart0-pe-pins {
pins = "PE0", "PE1";
function = "uart0";
lcd_rgb666_pins: lcd-rgb666-pins {
pins = "PD0", "PD1", "PD2", "PD3", "PD4",
"PD5", "PD6", "PD7", "PD8", "PD9",
"PD10", "PD11", "PD12", "PD13", "PD14",
"PD15", "PD16", "PD17", "PD18", "PD19",
"PD20", "PD21";
function = "lcd";
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
function = "mmc0";
spi0_pins: spi0-pins{
function = "spi0";
spi1_pins: spi1-pins{
pins = "PA2","PA0","PA3","PA1";
function = "spi1";
timer@1c20c00 {
compatible = "allwinner,suniv-f1c100s-timer";
reg = <0x01c20c00 0x90>;
interrupts = <13>;
clocks = <&osc24M>;
mmc0: mmc@1c0f000 {
compatible = "allwinner,suniv-f1c100s-mmc",
"allwinner,sun7i-a20-mmc";
reg = <0x01c0f000 0x1000>;
clocks = <&ccu CLK_BUS_MMC0>,
<&ccu CLK_MMC0>,
<&ccu CLK_MMC0_OUTPUT>,
<&ccu CLK_MMC0_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC0>;
reset-names = "ahb";
interrupts = <23>;
pinctrl-names = "default";
pinctrl-0 = <&mmc0_pins>;
#size-cells = <0>;
wdt: watchdog@1c20ca0 {
compatible = "allwinner,suniv-f1c100s-wdt",
"allwinner,sun4i-a10-wdt";
reg = <0x01c20ca0 0x20>;
uart0: serial@1c25000 {
reg = <0x01c25000 0x400>;
interrupts = <1>;
reg-shift = <2>;
reg-io-width = <4>;
uart1: serial@1c25400 {
reg = <0x01c25400 0x400>;
interrupts = <2>;
reg-shift = <2>;
reg-io-width = <4>;
uart2: serial@1c25800 {
reg = <0x01c25800 0x400>;
interrupts = <3>;
reg-shift = <2>;
reg-io-width = <4>;
usb_otg: usb@1c13000 {
reg = <0x01c13000 0x0400>;
clocks = <&ccu CLK_BUS_OTG>;
resets = <&ccu RST_BUS_OTG>;
interrupts = <26>;
interrupt-names = "mc";
phys = <&usbphy 0>;
phy-names = "usb";
extcon = <&usbphy 0>;
usbphy: phy@1c13400 {
reg = <0x01c13400 0x10>;
reg-names = "phy_ctrl";
clocks = <&ccu CLK_USB_PHY0>;
clock-names = "usb0_phy";
resets = <&ccu RST_USB_PHY0>;
reset-names = "usb0_reset";
#phy-cells = <1>;
fe0: display-frontend@1e00000 {
compatible = "allwinner,suniv-f1c100s-display-frontend";
reg = <0x01e00000 0x20000>;
interrupts = <30>;
clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
<&ccu CLK_DRAM_DE_FE>;
clock-names = "ahb", "mod",
"ram";
resets = <&ccu RST_BUS_DE_FE>;
ports {
#size-cells = <0>;
fe0_out: port@1 {
#size-cells = <0>;
reg = <1>;
fe0_out_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_in_fe0>;
be0: display-backend@1e60000 {
compatible = "allwinner,suniv-f1c100s-display-backend";
reg = <0x01e60000 0x10000>;
reg-names = "be";
interrupts = <31>;
clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
<&ccu CLK_DRAM_DE_BE>;
"ram";
resets = <&ccu RST_BUS_DE_BE>;
reset-names = "be";
assigned-clocks = <&ccu CLK_DE_BE>;
assigned-clock-rates = <300000000>;
ports {
#size-cells = <0>;
be0_in: port@0 {
#size-cells = <0>;
reg = <0>;
be0_in_fe0: endpoint@0 {
reg = <0>;
remote-endpoint = <&fe0_out_be0>;
be0_out: port@1 {
#size-cells = <0>;
reg = <1>;
be0_out_tcon0: endpoint@0 {
reg = <0>;
remote-endpoint = <&tcon0_in_be0>;
spi0:spi@1c05000 {
compatible = "allwinner,suniv-spi", "allwinner,sun8i-h3-spi";
reg = <0x1c05000 0x1000>;
interrupts = <0xa>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
#size-cells = <0>;
pinctrl-0 = <&spi0_pins>;
spi1:spi@1c06000 {
reg = <0x1c06000 0x1000>;
interrupts = <0xb>;
clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
resets = <&ccu RST_BUS_SPI1>;
#size-cells = <0>;
bias-pull-up;
pinctrl-0 = <&spi1_pins>;
dma: dma-controller@1c02000 {
compatible = "allwinner,suniv-f1c100s-dma";
reg = <0x01c02000 0x1000>;
interrupts = <18>;
clocks = <&ccu CLK_BUS_DMA>;
resets = <&ccu RST_BUS_DMA>;
#dma-cells = <2>;
codec: codec@1c23c00 {
compatible = "allwinner,suniv-f1c100s-codec";
reg = <0x01c23c00 0x400>;
interrupts = <21>;
clocks = <&ccu CLK_BUS_CODEC>,
<&ccu CLK_CODEC>;
clock-names = "apb", "codec";
resets = <&ccu RST_BUS_CODEC>;
dmas = <&dma SUN4I_DMA_NORMAL 0x0c>,
<&dma SUN4I_DMA_NORMAL 0x0c>;
dma-names = "rx", "tx";
};suniv-f1c100s.dts源代码
/dts-v1/;
#include "suniv-f1c100s.dtsi"
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s";
aliases {
serial0 = &uart0;
chosen {
reg_vcc3v3: vcc3v3 {
regulator-name = "vcc3v3";
&uart0 {
pinctrl-0 = <&uart0_pe_pins>;
&mmc0 {
vmmc-supply = <®_vcc3v3>;
bus-width = <4>;
broken-cd;
&otg_sram {
&usb_otg {
dr_mode = "otg";
&usbphy {
usb0_id_det-gpio = <&pio 4 2 0>; /* PE2 */
&spi1 {
st7789v@0 {
compatible = "sitronix,st7789v";
reg = <0>;
spi-max-frequency = <32000000>;
rotate = <0>;
spi-cpol;
spi-cpha;
rgb;
fps = <30>;
buswidth = <8>;
reset-gpios=<&pio 4 3 1>;
dc-gpios = <&pio 4 5 1>;
debug = <0>;
&codec {
allwinner,audio-routing =
"Headphone", "HP",
"Headphone", "HPCOM",
"LINEIN", "Line In",
"FMINL", "Left FM In",
"FMINR", "Right FM In",
"MIC", "Mic";
};编译完成后,将suniv-f1c100s.dtb和zImage拷贝到SD卡第一分区boot当中,
连接电脑,串口打印uboot以及linux内核启动信息,
屏幕一开始嘿嘿的,接着雪花花屏一闪而过,最后黑屏,同时左上角光标不停闪烁。
输入以下内容,屏幕有反应,但是都是雪花点点。。。
echo "Hello" > /dev/fb0
cat /dev/random > /dev/fb0
sl > /dev/fb0有图为证:
输入以下内容,屏幕正常显示。。。
echo "Hello" > /dev/tty0
cat /dev/random > /dev/tty0
sl > /dev/tty0有图为证:
测试framebuffer:
root#pi: ~/fb-test
root#pi: ~/mplayer cc.mp4有图为证:
想不明白啊 。
内核启动的时候,屏幕为何没有打印启动信息,偏偏是花屏一闪而过。
输入"echo ‘Hello, World!!!!!!!!!!!‘ > /dev/fb0",屏幕显示若干个光点。。
莫非字符内容全部显示为光点了?
这是什么原因啊。;?
设备树写对了吗??????????????????
请大佬指教。。。。
本人初学linux ,深感亚历山大啊。。。
最近编辑记录 WangLY_Snot (2021-05-03 23:57:32)
bootargs console 改为 fb0才行吧
试过了没用。。。。
bootargs : console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
bootcmd: load mmc 0:1 0x80008000 zImage;load mmc 0:1 0x80c08000 suniv-f1c100s.deb; bootz 0x80008000 - 0x80c08000
试着输入下列代码看看。。。。。
=>setenv bootargs "console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0"
=>saveenv此时编译的linux是可以在SPI屏和串口同时输出log的,但是SPI屏端还不是控制台,无法使用USB键盘进行控制!!!!
关键之处在于这个文件/etc/inittab
我在这里面注释了console这一行语句。
添加了下面两行:;
ttyS0::respawn:-/bin/sh
tty0::respawn:-bin/sh还是不能实现SPI屏被键盘控制字符输入。。。。。
大家有没有办法啊???
最近编辑记录 WangLY_Snot (2021-05-07 09:50:10)
usb键盘? 这个有点复杂吧?
首先确保你的usb键盘工作正常,用evtest测试,然后还要做别的处理才行。
raspberryman wrote:
usb键盘? 这个有点复杂吧?
晚上试试看,,,只有这样,才是一台小电脑啊。。。哈哈。。。。。
楼主有调试好的吗?(我在V3s也碰到这样的问题了)
请教一下如何初始化RGB的?
我的5.2内核修改了设备树 编译不过去
make[1]: *** [scripts/Makefile.lib:294: arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dtb] Error 1
