楼主 # 2021-10-14 17:15:12
john78
已发帖子: 222
还是USB-WIFI问题 wpa_supplicant.conf中的/var/run/wpa_supplicant 这个是什么?
我的文件系统只读,如果文件系统中有var/run/wpa_supplicant文件夹
wpa_supplicant v2.6
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/bkup5/wpa_supplicant.conf' driver 'default                                                               ' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/bkup5/wpa_supplicant.conf' -> '/bkup5/wpa_supplicant.conf'
Reading configuration file '/bkup5/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
ctrl_interface_group='wheel'
update_config=1
eapol_version=1
ap_scan=1
fast_reauth=1
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:10
nl80211: Supported cipher 00-0f-ac:8
nl80211: Supported cipher 00-0f-ac:9
nl80211: Using driver-based off-channel TX
nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 00        00 00 00 00 00 00 40
nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8)                                                               : 00 00 00 00 00 00 00 40
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 5 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0x196798
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0104
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=040a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=040b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=040c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=040d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=090a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=090b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=090c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=090d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0409506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=7f506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0801
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0a07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0a11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0a1a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=1101
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=1102
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0505
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x196798 matc                                                               h=0500
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
netlink: Operstate: ifindex=5 linkmode=1 (userspace-control), operstate=5 (IF_OP                                                               ER_DORMANT)
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
wlan0: Own MAC address: 00:e0:4d:2d:14:c5
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=                                                               0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=                                                               0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=                                                               0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=                                                               0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=                                                               0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=                                                               0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
wlan0: State: DISCONNECTED -> INACTIVE
wlan0: WPS: UUID based on MAC address: f3eb3f2e-b98e-5c83-bbd3-09e26c9771e9
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Skip set_supp_port(unauthorized) while not associated
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Using existing control interface directory.
ctrl_interface_group=10 (from group name 'wheel')
chown[ctrl_interface=/var/run/wpa_supplicant,gid=10]: Read-only file system
Failed to initialize control interface '/var/run/wpa_supplicant'.
You may have another wpa_supplicant process already running or the file was
left by an unclean termination of wpa_supplicant in which case you will need
to manually remove this file before starting wpa_supplicant again.
Failed to add interface wlan0
wlan0: Request to deauthenticate - bssid=00:00:00:00:00:00 pending_bssid=00:00:0                                                               0:00:00:00 reason=3 state=INACTIVE
nl80211: Data frame filter flags=0x0
nl80211: Failed to open /proc/sys/net/ipv6/conf/wlan0/drop_unicast_in_l2_multica                                                               st: No such file or directory
nl80211: Failed to set IPv6 unicast in multicast filter
wlan0: State: INACTIVE -> DISCONNECTED
nl80211: Set wlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=5 linkmode=-1 (no change), operstate=5 (IF_OPER_DORM                                                               ANT)
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
wlan0: WPA: Clear old PMK and PTK
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
Off-channel: Clear pending Action frame TX (pending_action_tx=(nil)
Remove interface wlan0 from radio phy0
Remove radio phy0
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=5 linkmode=0 (kernel-control), operstate=6 (IF_OPER_                                                               UP)
nl80211: Unsubscribe mgmt frames handle 0x8891ef11 (mode change)
/var/run/wpa_supplicant 改成其他可读写目录页没有成功
wpa_supplicant -i wlan0 -c /bkup5/wpa_supplicant.conf
后出现
就一直停在这里了
最近编辑记录 john78 (2021-10-14 17:45:07)
楼主 #1 2021-10-14 17:20:10
john78
已发帖子: 222
Re: 还是USB-WIFI问题 wpa_supplicant.conf中的/var/run/wpa_supplicant 这个是什么?
另外用 iw dev wlan0 scan 能扫描到周围的WIFI。但是用  iw wlan0 connect 没有成功
楼主 #2 2021-10-16 16:53:17
john78
已发帖子: 222
这个日志是否成功了???
wpa_supplicant -B -d -i wlan0 -c /bkup5/wpa_supplicant.conf
wpa_supplicant v2.6
ctrl_interface='/tmp/wpa_supplicant'
update_config=1
eapol_version=1
ap_scan=1
fast_reauth=1
nl80211: Set mode ifindex 6 iftype 2 (STATION)
netlink: Operstate: ifindex=6 linkmode=1 (userspace-control), operstate=5 (IF_OP        ER_DORMANT)
wpa_driver_nl80211_set_key: ifindex=6 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=        0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=6 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=        0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=6 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=        0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=6 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=        0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=6 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=        0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=6 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=        0 seq_len=0 key_len=0
wlan0: Added interface wlan0
netlink: Operstate: ifindex=6 linkmode=-1 (no change), operstate=5 (IF_OPER_DORM        ANT)
Daemonize..
 wpa_cli -i wlan0 scan
Failed to connect to non-global ctrl_ifname: wlan0  error: No such file or directory
这个又是什么??
楼主 #3 2021-10-19 16:51:25
john78
已发帖子: 222
# strace wpa_cli -i wlan0
execve("/usr/sbin/wpa_cli", ["wpa_cli", "-i", "wlan0"], [/* 22 vars */]) = 0
brk(NULL)                               = 0x33000
uname({sysname="Linux", nodename="DYHMI", ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f13000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/lib/tls/v7l/neon/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l/neon/vfp", 0xbee564f8) = -1 ENOENT (No such file or directory)
open("/lib/tls/v7l/neon/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l/neon", 0xbee564f8) = -1 ENOENT (No such file or directory)
open("/lib/tls/v7l/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l/vfp", 0xbee564f8)  = -1 ENOENT (No such file or directory)
open("/lib/tls/v7l/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v7l", 0xbee564f8)      = -1 ENOENT (No such file or directory)
open("/lib/tls/neon/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/neon/vfp", 0xbee564f8) = -1 ENOENT (No such file or directory)
open("/lib/tls/neon/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/neon", 0xbee564f8)     = -1 ENOENT (No such file or directory)
open("/lib/tls/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/vfp", 0xbee564f8)      = -1 ENOENT (No such file or directory)
open("/lib/tls/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/tls", 0xbee564f8)          = -1 ENOENT (No such file or directory)
open("/lib/v7l/neon/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l/neon/vfp", 0xbee564f8) = -1 ENOENT (No such file or directory)
open("/lib/v7l/neon/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l/neon", 0xbee564f8)     = -1 ENOENT (No such file or directory)
open("/lib/v7l/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l/vfp", 0xbee564f8)      = -1 ENOENT (No such file or directory)
open("/lib/v7l/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/v7l", 0xbee564f8)          = -1 ENOENT (No such file or directory)
open("/lib/neon/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/neon/vfp", 0xbee564f8)     = -1 ENOENT (No such file or directory)
open("/lib/neon/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/neon", 0xbee564f8)         = -1 ENOENT (No such file or directory)
open("/lib/vfp/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/lib/vfp", 0xbee564f8)          = -1 ENOENT (No such file or directory)
open("/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0000\27\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=22432, ...}) = 0
mmap2(NULL, 86544, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ed7000
mprotect(0xb6edc000, 61440, PROT_NONE)  = 0
mmap2(0xb6eeb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0xb6eeb000
close(3)                                = 0
open("/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\331i\1\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=894624, ...}) = 0
mmap2(NULL, 963912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6deb000
mprotect(0xb6ec2000, 61440, PROT_NONE)  = 0
mmap2(0xb6ed1000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd6000) = 0xb6ed1000
mmap2(0xb6ed4000, 9544, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6ed4000
close(3)                                = 0
open("/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\245F\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=107280, ...}) = 0
mmap2(NULL, 143948, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6dc7000
mprotect(0xb6dd8000, 61440, PROT_NONE)  = 0
mmap2(0xb6de7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0xb6de7000
mmap2(0xb6de9000, 4684, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6de9000
close(3)                                = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f12000
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f11000
set_tls(0xb6f12920, 0xb6f11008, 0xb6f15050, 0xb6f12920, 0xb6f15050) = 0
mprotect(0xb6ed1000, 8192, PROT_READ)   = 0
mprotect(0xb6de7000, 4096, PROT_READ)   = 0
mprotect(0xb6eeb000, 4096, PROT_READ)   = 0
mprotect(0xb6f14000, 4096, PROT_READ)   = 0
set_tid_address(0xb6f124c8)             = 158
set_robust_list(0xb6f124d0, 12)         = 0
rt_sigaction(SIGRTMIN, {sa_handler=0xb6dcb1f5, sa_mask=[], sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0xb6e10151}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {sa_handler=0xb6dcb295, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0xb6e10151}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
ugetrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(NULL)                               = 0x33000
brk(0x54000)                            = 0x54000
fstat64(1, {st_mode=S_IFCHR|0600, st_rdev=makedev(5, 1), ...}) = 0
ioctl(1, TCGETS, {B115200 opost isig icanon echo ...}) = 0
write(1, "wpa_cli v2.6\n", 13wpa_cli v2.6
)          = 13
write(1, "Copyright (c) 2004-2016, Jouni M"..., 67Copyright (c) 2004-2016, Jouni Malinen <j@w1.fi> and contributors
) = 67
write(1, "This software may be distributed"..., 98This software may be distributed under the terms of the BSD license.
See README for more details.
) = 98
write(1, "\n\n", 2
)                     = 2
rt_sigaction(SIGINT, {sa_handler=0x19130, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0xb6e10141}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGTERM, {sa_handler=0x19130, sa_mask=[TERM], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0xb6e10141}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
write(1, "\nInteractive mode\n", 18
Interactive mode
)    = 18
write(1, "\n", 1
)                       = 1
clock_gettime(CLOCK_BOOTTIME, {tv_sec=33, tv_nsec=69344224}) = 0
clock_gettime(CLOCK_BOOTTIME, {tv_sec=33, tv_nsec=69523890}) = 0
_newselect(1, [], [], [], {tv_sec=0, tv_usec=0}) = 0 (Timeout)
clock_gettime(CLOCK_BOOTTIME, {tv_sec=33, tv_nsec=69838640}) = 0
socket(AF_UNIX, SOCK_DGRAM, 0)          = 3
bind(3, {sa_family=AF_UNIX, sun_path="/tmp/wpa_ctrl_158-1"}, 110) = 0
connect(3, {sa_family=AF_UNIX, sun_path="/var/run/wpa_supplicant/wlan0"}, 110) = -1 ENOENT (No such file or directory)
close(3)                                = 0
unlink("/tmp/wpa_ctrl_158-1")           = 0
write(1, "Could not connect to wpa_supplic"..., 55Could not connect to wpa_supplicant: wlan0 - re-trying
) = 55
clock_gettime(CLOCK_BOOTTIME, {tv_sec=33, tv_nsec=72056932}) = 0
clock_gettime(CLOCK_BOOTTIME, {tv_sec=33, tv_nsec=72172724}) = 0
_newselect(1, [], [], [], {tv_sec=0, tv_usec=999884}) = 0 (Timeout)
clock_gettime(CLOCK_BOOTTIME, {tv_sec=34, tv_nsec=73611016}) = 0
bind(3, {sa_family=AF_UNIX, sun_path="/tmp/wpa_ctrl_158-2"}, 110) = 0
close(3)                                = 0
unlink("/tmp/wpa_ctrl_158-2")           = 0
clock_gettime(CLOCK_BOOTTIME, {tv_sec=34, tv_nsec=75266516}) = 0
clock_gettime(CLOCK_BOOTTIME, {tv_sec=34, tv_nsec=75406224}) = 0
_newselect(1, [], [], [], {tv_sec=0, tv_usec=999860}) = 0 (Timeout)
clock_gettime(CLOCK_BOOTTIME, {tv_sec=35, tv_nsec=76781391}) = 0
bind(3, {sa_family=AF_UNIX, sun_path="/tmp/wpa_ctrl_158-3"}, 110) = 0
close(3)                                = 0
unlink("/tmp/wpa_ctrl_158-3")           = 0
clock_gettime(CLOCK_BOOTTIME, {tv_sec=35, tv_nsec=78360350}) = 0
clock_gettime(CLOCK_BOOTTIME, {tv_sec=35, tv_nsec=78544808}) = 0
_newselect(1, [], [], [], {tv_sec=0, tv_usec=999816}^Cstrace: Process 158 detached
<detached ...>
