楼主 #1 2019-08-06 14:41:49
danile
已发帖子: 76
请教ST7789V,不显示,发现波形完全不对!请高手指点一二!!
请教ST7789V,不显示,发现波形完全不对!仔细防照
http://zero.lichee.pro/%E8%B4%A1%E7%8C%AE/article%203.html?highlight=fbtft
LicheePizero_SPI_LCD_st7789.pdf
操作,还是没有效果!!!
dts文件: /files/members/1808/dts.zip
sun8i-v3s-licheepi-zero-dock.dts 文件:
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
#include "sun8i-v3s-licheepi-zero.dts"
	model = "Lichee Pi Zero with Dock";
	compatible = "licheepi,licheepi-zero-dock", "licheepi,licheepi-zero",
		     "allwinner,sun8i-v3s";
	aliases {
		ethernet0 = &emac;
	leds {
		/* The LEDs use PG0~2 pins, which conflict with MMC1 */
		status = "disbaled";
	chosen {
		/delete-node/ framebuffer@0;
&spi0 {
	st7789v@0 {
		compatible = "sitronix,st7789v";
		reg = <0>;
		reset-gpios = <&pio 4 20 GPIO_ACTIVE_LOW>;
		dc-gpios = <&pio 4 1 GPIO_ACTIVE_LOW>;
		/*backlight = <&pwm_bl>;*/
		spi-max-frequency = <15000000>;
		spi-cpol;
		spi-cpha;
		bgr;
		buswidth = <8>;
		rotate = <270>;
		fps = <10>;
&codec {
	allwinner,audio-routing =
		"Headphone", "HP",
		"Headphone", "HPCOM",
		"MIC1", "Mic",
		"Mic",  "HBIAS";
&emac {
&mmc1 {
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
&lradc {
	vref-supply = <&reg_vcc3v0>;
	button@200 {
		label = "Volume Up";
		linux,code = <KEY_VOLUMEUP>;
		channel = <0>;
		voltage = <200000>;
	button@400 {
		label = "Volume Down";
		linux,code = <KEY_VOLUMEDOWN>;
		channel = <0>;
		voltage = <400000>;
	button@600 {
		label = "Select";
		linux,code = <KEY_SELECT>;
		channel = <0>;
		voltage = <600000>;
	button@800 {
		label = "Start";
		linux,code = <KEY_OK>;
		channel = <0>;
		voltage = <800000>;
加载驱动时候的波形如下:
文件:saleae 1.1.18版本以上可以打开 /files/members/1808/none.zip
加载驱动时候的波形如下:
文件:saleae 1.1.18版本以上可以打开 /files/members/1808/fb.zip
#2 2019-08-06 15:19:06
已发帖子: 9,492
楼主 #3 2019-08-06 15:35:19
danile
已发帖子: 76
Re: 请教ST7789V,不显示,发现波形完全不对!请高手指点一二!!
下面的那个,好像复位引脚没有变高,也没有复位电平
最近编辑记录 danile (2019-08-06 15:36:04)
#4 2019-08-06 15:37:09
已发帖子: 9,492
spi 的时序能对上吗?
楼主 #5 2019-08-06 15:44:07
danile
已发帖子: 76
spi 的时序能对上吗?
除了设备驱动加载时候,SPI发送的全是0,感觉不正常,加载完,我cat xxx>/dev/fb0 ,SPI前面一段杂乱的波形,后面数据是对的
#6 2019-08-06 16:07:37
已发帖子: 9,492
https://whycan.cn/t_2740.html
/spi-cpol;/
/spi-cpha;/
频率降低到 6M, 开启 cpol, cpha:
spi-max-frequency = <6000000>;
spi-cpol;
spi-cpha;
这样试一试.
https://github.com/torvalds/linux/blob/master/Documentation/devicetree/bindings/display/panel/sitronix%2Cst7789v.txt
楼主 #7 2019-08-06 16:16:01
danile
已发帖子: 76
/spi-cpol;/
/spi-cpha;/
spi-cpol;
spi-cpha;
这样试一试.
还是不行呢 /files/members/1808/none_20190806-1615.zip
楼主 #8 2019-08-06 16:29:21
danile
已发帖子: 76
/spi-cpol;/
/spi-cpha;/
spi-cpol;
spi-cpha;
这样试一试.
好像有点正常了,晚上试试,感谢晕哥
#9 2019-08-06 16:35:55
已发帖子: 9,492
等你好消息 ^_^
楼主 #10 2019-08-06 16:42:24
danile
已发帖子: 76
等你好消息 ^_^
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/drivers/staging/fbtft/fb_st7789v.c
源代码里面没看到 复位的操作呢,为什么 Documentation\devicetree\bindings\display\panel\sitronix,st7789v.txt 文件里面有复位引脚!!
而且我发现ili9341里面有复位的相关操作:
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/drivers/staging/fbtft/fb_ili9341.c
par->fbtftops.reset(par);
#11 2019-08-06 16:49:14
已发帖子: 9,492
可能是在别的文件实现了:
$ grep reset-gpios -r drivers/staging/
drivers/staging/fbtft/fbtft-core.c: ret = fbtft_request_one_gpio(par, "reset-gpios", 0, &par->gpio.reset);
drivers/staging/greybus/arche-apb-ctrl.c: apb->resetn_gpio = of_get_named_gpio(np, "reset-gpios", 0);
楼主 #12 2019-08-06 17:19:40
danile
已发帖子: 76
可能是在别的文件实现了:
这个复位Io应该不是屏幕的复位,而是系统的复位
楼主 #13 2019-08-06 17:42:33
danile
已发帖子: 76
可能是在别的文件实现了:
可以了,我加了那句就可以了,感谢
#14 2019-08-06 18:23:58
已发帖子: 9,492
现在可以显示了吗?
楼主 #15 2019-08-06 20:57:38
danile
已发帖子: 76
现在可以显示了吗?
可以的,其实就是那个复位问题,至于波形很乱,是因为spi时钟超过了逻辑分析仪的上限了
#16 2019-08-06 21:35:19
已发帖子: 9,492
danile wrote:
现在可以显示了吗?
那代码是怎么改的呢?方便传个液晶显示的图片吗?
楼主 #17 2019-08-06 22:07:48
danile
已发帖子: 76
把复位代码加载初始化之前:
#18 2019-08-06 22:50:33
已发帖子: 649
屏幕看起来不错,还带触摸
#19 2019-08-06 23:02:14
已发帖子: 9,492
屏幕看起来效果挺好,在哪里买的?
楼主 #20 2019-08-07 08:22:03
danile
已发帖子: 76
屏幕看起来效果挺好,在哪里买的?
是以前给客户开发产品,给的几片,厂家好像叫做华宇彩晶
#21 2019-11-25 18:55:19
liopen88
群主,你这边可以提供一下驱动代码吗?
#22 2020-04-27 11:19:36
拉轰的脚踏车
已发帖子: 288
正在用 A33 点 ST7789, 关注一下,感谢楼主分享。
#23 2020-04-27 11:57:45
歌以咏志
已发帖子: 219
果然有两个一样名字的驱动:
$ grep "sitronix,st7789v" -r drivers/
drivers/gpu/drm/panel/panel-sitronix-st7789v.c: { .compatible = "sitronix,st7789v" },
drivers/staging/fbtft/fb_st7789v.c:FBTFT_REGISTER_DRIVER(DRVNAME, "sitronix,st7789v", &display);
#24 2020-04-27 16:09:48
拉轰的脚踏车
已发帖子: 288
&pio {
        spi0_cs_pins: spi0_cs_pins {
                pins = "PC3", "PH6";
                function = "gpio_out";
&spi0 {
        status ="okay";
        pinctrl-names = "default";
        pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
        cs-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>, <&pio 7 6 GPIO_ACTIVE_HIGH>;
        mx25l25635e:mx25l25635e@0 {
                compatible = "jedec,spi-nor";
                reg = <0x0>;
                #address-cells = <1>;
                #size-cells = <1>;
    panel@0 {
            reg = <1>;
            reset-gpios = <&pio 2 4 GPIO_ACTIVE_LOW>;//PC4
            dc-gpios = <&pio 2 7 GPIO_ACTIVE_LOW>;//PC7
            spi-cpol;
            spi-cpha;
            buswidth = <8>;
            rotate = <270>;
            bgr;
            fps = <10>;
            debug = <1>;
log:
[    1.435253] fbtft_of_value: buswidth = 8
[    1.439213] fbtft_of_value: debug = 1
[    1.442881] fbtft_of_value: rotate = 270
[    1.446828] fbtft_of_value: fps = 10
[    1.451240] fb_st7789v spi0.1: fbtft_request_one_gpio: 'reset-gpios' = GPIO68
[    1.458478] fb_st7789v spi0.1: fbtft_request_one_gpio: 'dc-gpios' = GPIO71
[    1.803443] graphics fb1: fb_st7789v frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=10, spi0.1 at 6 MHz
但是 cat /dev/urandom > /dev/fb1 屏幕没有反应。
#25 2020-04-28 07:31:03
rick lou
所在地: 中国北京海淀
#26 2020-11-13 01:59:44
avb
This driver uses 9 bit spi mode.
v3s hardware spi controller supports only wordlen with multiples of 8 bits length.
Use spi-gpio bus driver instead.
#27 2021-10-30 14:46:23
HongSang
晕哥请问下这两个驱动程序有什么区别 都是生成fb设备的吗
#28 2021-10-30 15:51:16
已发帖子: 3,409
@HongSang
前面是drm架构驱动,后面的是传统fb的驱动。
#29 2021-10-31 09:51:07
HongSang
哇酷小二 wrote:
@HongSang
drm也是能共和fbfbt驱动一样在/dev/下生成fb设备的么
#30 2021-11-03 11:58:29
树莓学LINUX
已发帖子: 133
好像是5.x内核自带的7789驱动有问题,需要修改
#31 2022-03-13 10:33:57
11小白11
4.13和4.9.88的内核用网上的修改fb_st7789v.c和tbtft-core.c文件再编译报错定义之类的错,可以换5.几的内核,我感觉4.13和4.9.88的内核不太支持,小白经验发言,错了,大佬踹一脚
