楼主 #1 2020-11-22 14:39:08
powerpan
已发帖子: 47
S3 I2S问题逐步排查
S3/V3s insmod sun4i-i2s.ko,i2s probe正常,
但是dai probe没有被执行
请问下,dai probe是什么时候触发的?
#2 2020-11-22 15:34:12
孤星泪
已发帖子: 232
Re: S3 I2S问题逐步排查
有没有添加声卡,记得至少要添加一张声卡吧
楼主 #3 2020-11-22 16:32:05
powerpan
已发帖子: 47
Re: S3 I2S问题逐步排查
pcm5102: pcm510x {
		compatible = "ti,pcm5102a";
		pcm510x,format = "i2s";
		#sound-dai-cells = <0>;
	sound_i2s {
		compatible = "simple-audio-card";
        simple-audio,name="s3-i2s";
		simple-audio-card,format = "i2s";
		simple-audio-card,mclk-fs = <256>;
        simple-audio-card,routing = "Playback", "DAI0 Playback",
			                        "DAI0 Capture", "Capture";
		simple-audio-card,cpu {
			sound-dai = <&i2s0>;
			dai-tdm-slot-num = <2>;
			dai-tdm-slot-width = <32>;
		simple-audio-card,codec {
			sound-dai = <&pcm5102>;
最近编辑记录 powerpan (2020-11-22 22:03:47)
楼主 #4 2020-11-22 16:33:40
powerpan
已发帖子: 47
Re: S3 I2S问题逐步排查
i2s0: i2s@1c22000 {
			compatible = "allwinner,sun8i-h3-i2s";
			reg = <0x01c22000 0x400>;
			interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
            clocks = <&ccu CLK_BUS_I2S0>, <&ccu CLK_I2S0>;
			clock-names = "apb", "mod";
			dmas = <&dma 3>, <&dma 3>;
			resets = <&ccu RST_BUS_I2S0>;
            pinctrl-names = "default";
            pinctrl-0 = <&i2s0_pins>;
			dma-names = "rx", "tx";
			status = "disabled";
            //status = "okay";
都加了,dai_probe死活没有调用
或者说我怎么查这个?
#5 2020-11-22 16:43:36
九重天
已发帖子: 20
Re: S3 I2S问题逐步排查
sound/soc/sunxi/sun4i-i2s.c
static int sun4i_i2s_dai_probe(struct snd_soc_dai *dai)
这个没有调用?
楼主 #6 2020-11-22 18:42:34
powerpan
已发帖子: 47
Re: S3 I2S问题逐步排查
九重天 说:
这个没有调用?
没有,百思不得其解,连时钟和i2s寄存器都没有初始化(可能是dai probe才初始化的)
https://www.kernel.org/doc/Documentation/devicetree/bindings/sound/simple-card.txt
从这里看dts应该是没错
另外sun4i-i2s.c代码测试过从 4.13开始到5.10都不行
最近编辑记录 powerpan (2020-11-23 15:25:39)
楼主 #7 2020-11-23 18:48:08
powerpan
已发帖子: 47
Re: S3 I2S问题逐步排查
最新进展了
[   50.462795] asoc-simple-card sound_i2s: pcm5102a-hifi <-> 1c22000.i2s0 mapping ok
[   85.650446] sun4i-i2s 1c22000.i2s0: Unsupported BCLK divider: -22
[   85.659638] sun4i-i2s 1c22000.i2s0: ASoC: can't set 1c22000.i2s0 hw params: -22
aplay: set_params:1363: Unable to install hw params:
ACCESS:  RW_INTERLEAVED
FORMAT:  S16_LE
SUBFORMAT:  STD
SAMPLE_BITS: 16
FRAME_BITS: 32
CHANNELS: 2
RATE: 44100
PERIOD_TIME: (125011 125012)
PERIOD_SIZE: 5513
PERIOD_BYTES: 22052
PERIODS: 4
BUFFER_TIME: (500045 500046)
BUFFER_SIZE: 22052
BUFFER_BYTES: 88208
TICK_TIME: 0
已经能够挂上了。剩下的问题可以跟踪了。
最近编辑记录 powerpan (2020-11-23 18:49:31)
#8 2020-11-23 19:14:20
redstar
Re: S3 I2S问题逐步排查
请教是怎么搞定的?
楼主 #9 2020-11-23 19:30:23
powerpan
已发帖子: 47
Re: S3 I2S问题逐步排查
redstar 说:
请教是怎么搞定的?
一个很愚蠢的失误。基本解决了
最近编辑记录 powerpan (2020-11-23 23:10:05)
楼主 #10 2020-11-24 10:13:43
powerpan
已发帖子: 47
Re: S3 I2S问题逐步排查
之前要从最新的kernel拷贝对应的代码:pinctrl-sun8i-v3s.c, sunxi-ng/ccu-sun8i-v3s.c 注意拷贝完成,如果有PGxx找不到,补充下(代码拷贝更改而已,不解释)
解决过程如下:(拷贝的代码记得是 5.10的 sun4i-i2s.c)
1. 开始没有看见dai_probe是因为没有加载simple-audio-card的ko,蠢死算了,后来跟踪代码发现的。跟踪代码还是si比较好,容易跟踪
2. 跟着就是各种坑了,上面dts的 simple-audio-card,routing 去掉,默认的就好了,否则出错。
3. MCLK设置有问题,理论上是应该 22576000的,结果是2256000了,导致 LRCK计算出来是 7.99导致上面设置出错,sun4i_i2s_get_bclk_div函数,改改
    int div = (parent_rate+sampling_rate*word_size) / sampling_rate / word_size / channels;
4. 上面好了就可以用了,但是LRCK不对,因为DTS dai-tdm-slot-width = <32>; 这个没鬼用,要改 sun8i_i2s_set_chan_cfg函数
        //lrck_period = params_physical_width(params);
        lrck_period = 32;
好了,结束了。
数字音响的一些知识,可以关注下微信公众号:全数字化音响
最近编辑记录 powerpan (2020-11-24 11:46:40)
#11 2021-11-09 17:44:49
migu
Re: S3 I2S问题逐步排查
@powerpan
楼主知道这个routing属性如何指定吗,我也是由于routing的问题导致声卡无法注册,之后按照楼主的说法注释掉了此部分,结果就可以了,但是也不明白这个是什么原因
