楼主 # 2021-10-12 10:30:18
小智跑腿
已发帖子: 60
(V3s/V3x/S3/S3L/R11通吃)小智V3x开发板smallwitpi lite u-boot/linux/buildroot测试
git clone https://github.com/u-boot/u-boot -b v2021.07
补丁包下载: smallwitpi_lite_v3x_uboot_patch_for_202107.diff
进入u-boot目录打上补丁:
patch -p1 < smallwitpi_lite_v3x_uboot_patch_for_202107.diff
现在的目录结构:
u-boot$ git status .
Not currently on any branch.
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git checkout -- <file>..." to discard changes in working directory)
        modified:   arch/arm/dts/Makefile
        modified:   arch/arm/dts/sun8i-v3s.dtsi
        modified:   arch/arm/include/asm/arch-sunxi/gpio.h
        modified:   arch/arm/mach-sunxi/Kconfig
        modified:   arch/arm/mach-sunxi/board.c
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        arch/arm/dts/sun8i-v3x-smallwitpi-lite-debug-uart0.dts
        arch/arm/dts/sun8i-v3x-smallwitpi-lite-debug-uart1.dts
        arch/arm/dts/sun8i-v3x-smallwitpi-lite-debug-uart2.dts
        configs/smallwitpi_lite_v3s_ddr2_debug_uart0_pb8_pb9_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart0_pf2_pf4_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart1_pe21_pe22_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart1_pg6_pg7_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart2_pb0_pb1_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart0_pb8_pb9_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart0_pf2_pf4_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart1_pe21_pe22_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart1_pg6_pg7_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart2_pb0_pb1_defconfig
no changes added to commit (use "git add" and/or "git commit -a")
u-boot$
V3s u-boot 配置(五组串口随意选择):
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart0_pb8_pb9_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart0_pf2_pf4_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart1_pe21_pe22_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart1_pg6_pg7_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart2_pb0_pb1_defconfig
V3x u-boot 配置(五组串口随意选择):
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart0_pb8_pb9_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart0_pf2_pf4_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart1_pe21_pe22_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart1_pg6_pg7_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart2_pb0_pb1_defconfig
如果还需要其他 u-boot 配置执行:
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make menuconfig
编译:
请注意!!!如果使用pf2/pf4作为串口输出,那么不支持tf卡启动!!!
楼主 #1 2021-10-17 17:32:47
小智跑腿
已发帖子: 60
Re: (V3s/V3x/S3/S3L/R11通吃)小智V3x开发板smallwitpi lite u-boot/linux/buildroot测试
克隆:
git clone https://github.com/buildroot/buildroot -b 2020.02.4
patch 下载: br2_v3_uart0_pf2_pf4.tgz
使用方法,直接解压到buildroot根目录:
tar xvf br2_v3_uart0_pf2_pf4.tgz
编译指令:
make br2_v3_uart0_pf2_pf4_defconfig
flash固件下载: firmware-smallwitpi-lite-v1-spinor-20211017173200.7z (用于V3s,串口UART0 PF2/PF4)
最近编辑记录 小智跑腿 (2021-10-17 17:33:52)
楼主 #2 2021-10-17 20:15:27
小智跑腿
已发帖子: 60
patch 下载: br2_v3_uart0_pb8_pb9-spinor-tfcard-20211017201000.tgz
编译指令: make br2_v3_uart0_pb8_pb9_defconfig
tf卡固件下载: firmware-smallwitpi-lite-v1-sdcard-uart0-pb8-pb9-tfcard-20211017201400.7z (用于V3s,串口UART0 PB8/9)
spi nor 固件: firmware-smallwitpi-lite-v1-spinor-uart0-pb8-pb9-spinor-20211024174500.7z  (用于V3s,串口UART0 PB8/9,16M spinor)
楼主 #3 2021-10-18 16:58:55
小智跑腿
已发帖子: 60
小智V3x开发板16M SPI NOR /TFCARD 固件,分辨率480x272:
firmware-smallwitpi-lite-v1-spinor-uart0-pb8-pb9-480x272-开机显示一朵荷花.7z
小智V3x开发板TFCard 固件,分辨率480x272:
firmware-smallwitpi-lite-v1-sdcard-uart0-pb8-pb9-480x272-开机显示一朵荷花.7z
克隆:
buildroot patch: br2_v3_uart0_pb8_pb9-spinor-tfcard-20211026132800.tgz
解压:
tar xvf br2_v3_uart0_pb8_pb9-spinor-tfcard-20211026132800.tgz
生成 V3s / S3L 固件:
make br2_smallwitpi_lite_v3_ddr2_uart0_pb8_pb9_tfcard_spinor_defconfig
生成 V3x / S3 固件:
make br2_smallwitpi_lite_v3_ddr3_uart0_pb8_pb9_tfcard_spinor_defconfig
电阻触摸屏触摸校正与测试(NS2009 I2C PB8/9, 中断: PB0 ):
TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
TSLIB_TSDEVICE=/dev/input/event0 ts_test
楼主 #4 2021-10-18 16:58:59
小智跑腿
已发帖子: 60
占位
楼主 #5 2021-10-18 16:59:02
小智跑腿
已发帖子: 60
占位
楼主 #6 2021-10-18 16:59:07
小智跑腿
已发帖子: 60
占位
楼主 #7 2021-10-18 16:59:12
小智跑腿
已发帖子: 60
占位
楼主 #8 2021-10-18 16:59:25
小智跑腿
已发帖子: 60
占位
#9 2021-10-25 14:17:58
zjm3712
已发帖子: 0
  • 不通过:其他
楼主 #10 2021-10-27 17:41:54
小智跑腿
已发帖子: 60
picogl / tinygl软件渲染,段错误死机了,只能看到一帧。
#11 2021-11-21 15:02:34
leefei
已发帖子: 27
请问如果配置RGB的cd屏幕
#12 2021-11-24 17:05:57
chenzh
已发帖子: 24
  • 不通过:其他
