楼主 # 2021-11-29 21:30:11
mysteryli
已发帖子: 481
V3S Uboot启动失败问题
各位大佬好,本人刚开始搭建自己的V3S环境,按照荔枝派官网的教程编译了Uboot但是启动内核失败,报错如下,,如果用别人编译好的uboot bin文件就可以,麻烦大佬帮忙看看是配置不对还是什么原因?
另外附上配置文件
# U-Boot 2017.01-rc2 Configuration
CONFIG_CREATE_ARCH_SYMLINK=y
# CONFIG_ARC is not set
CONFIG_ARM=y
# CONFIG_AVR32 is not set
# CONFIG_BLACKFIN is not set
# CONFIG_M68K is not set
# CONFIG_MICROBLAZE is not set
# CONFIG_MIPS is not set
# CONFIG_NDS32 is not set
# CONFIG_NIOS2 is not set
# CONFIG_OPENRISC is not set
# CONFIG_PPC is not set
# CONFIG_SANDBOX is not set
# CONFIG_SH is not set
# CONFIG_SPARC is not set
# CONFIG_X86 is not set
# CONFIG_XTENSA is not set
CONFIG_SYS_ARCH="arm"
CONFIG_SYS_CPU="armv7"
CONFIG_SYS_SOC="sunxi"
CONFIG_SYS_BOARD="sunxi"
CONFIG_SYS_CONFIG_NAME="sun8i"
# ARM architecture
CONFIG_HAS_VBAR=y
CONFIG_HAS_THUMB2=y
CONFIG_CPU_V7=y
CONFIG_SYS_ARM_ARCH=7
CONFIG_SYS_CACHE_SHIFT_6=y
CONFIG_SYS_CACHELINE_SIZE=64
# CONFIG_SEMIHOSTING is not set
# CONFIG_SYS_L2CACHE_OFF is not set
# CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
# CONFIG_ARM64_SUPPORT_AARCH32 is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_TARGET_EDB93XX is not set
# CONFIG_TARGET_ASPENITE is not set
# CONFIG_TARGET_GPLUGD is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_KIRKWOOD is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_TARGET_DEVKIT3250 is not set
# CONFIG_TARGET_WORK_92105 is not set
# CONFIG_TARGET_MX25PDK is not set
# CONFIG_TARGET_ZMX25 is not set
# CONFIG_TARGET_APF27 is not set
# CONFIG_TARGET_APX4DEVKIT is not set
# CONFIG_TARGET_XFI3 is not set
# CONFIG_TARGET_M28EVK is not set
# CONFIG_TARGET_MX23EVK is not set
# CONFIG_TARGET_MX28EVK is not set
# CONFIG_TARGET_MX23_OLINUXINO is not set
# CONFIG_TARGET_BG0900 is not set
# CONFIG_TARGET_SANSA_FUZE_PLUS is not set
# CONFIG_TARGET_SC_SPS_1 is not set
# CONFIG_ORION5X is not set
# CONFIG_TARGET_SPEAR300 is not set
# CONFIG_TARGET_SPEAR310 is not set
# CONFIG_TARGET_SPEAR320 is not set
# CONFIG_TARGET_SPEAR600 is not set
# CONFIG_TARGET_STV0991 is not set
# CONFIG_TARGET_X600 is not set
# CONFIG_TARGET_IMX31_PHYCORE is not set
# CONFIG_TARGET_MX31ADS is not set
# CONFIG_TARGET_MX31PDK is not set
# CONFIG_TARGET_WOODBURN is not set
# CONFIG_TARGET_WOODBURN_SD is not set
# CONFIG_TARGET_FLEA3 is not set
# CONFIG_TARGET_MX35PDK is not set
# CONFIG_ARCH_BCM283X is not set
# CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set
# CONFIG_TARGET_VEXPRESS_CA5X2 is not set
# CONFIG_TARGET_VEXPRESS_CA9X4 is not set
# CONFIG_TARGET_BRXRE1 is not set
# CONFIG_TARGET_BRPPT1 is not set
# CONFIG_TARGET_DRACO is not set
# CONFIG_TARGET_THUBAN is not set
# CONFIG_TARGET_RASTABAN is not set
# CONFIG_TARGET_ETAMIN is not set
# CONFIG_TARGET_PXM2 is not set
# CONFIG_TARGET_RUT is not set
# CONFIG_TARGET_TI814X_EVM is not set
# CONFIG_TARGET_TI816X_EVM is not set
# CONFIG_TARGET_BCM23550_W1D is not set
# CONFIG_TARGET_BCM28155_AP is not set
# CONFIG_TARGET_BCMCYGNUS is not set
# CONFIG_TARGET_BCMNSP is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_S5PC1XX is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MX7 is not set
# CONFIG_ARCH_MX6 is not set
# CONFIG_ARCH_MX5 is not set
# CONFIG_TARGET_M53EVK is not set
# CONFIG_TARGET_MX51EVK is not set
# CONFIG_TARGET_MX53ARD is not set
# CONFIG_TARGET_MX53EVK is not set
# CONFIG_TARGET_MX53LOCO is not set
# CONFIG_TARGET_MX53SMD is not set
# CONFIG_OMAP34XX is not set
# CONFIG_OMAP44XX is not set
# CONFIG_OMAP54XX is not set
# CONFIG_AM43XX is not set
# CONFIG_AM33XX is not set
# CONFIG_ARCH_RMOBILE is not set
# CONFIG_TARGET_S32V234EVB is not set
# CONFIG_ARCH_SNAPDRAGON is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_TARGET_CM_T43 is not set
CONFIG_ARCH_SUNXI=y
# CONFIG_TARGET_TS4600 is not set
# CONFIG_TARGET_TS4800 is not set
# CONFIG_TARGET_VF610TWR is not set
# CONFIG_TARGET_COLIBRI_VF is not set
# CONFIG_TARGET_PCM052 is not set
# CONFIG_TARGET_BK4R1 is not set
# CONFIG_ARCH_ZYNQ is not set
# CONFIG_ARCH_ZYNQMP is not set
# CONFIG_TEGRA is not set
# CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
# CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
# CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM is not set
# CONFIG_TARGET_VEXPRESS64_JUNO is not set
# CONFIG_TARGET_LS2080A_EMU is not set
# CONFIG_TARGET_LS2080A_SIMU is not set
# CONFIG_TARGET_LS2080AQDS is not set
# CONFIG_TARGET_LS2080ARDB is not set
# CONFIG_TARGET_HIKEY is not set
# CONFIG_TARGET_LS1012AQDS is not set
# CONFIG_TARGET_LS1012ARDB is not set
# CONFIG_TARGET_LS1012AFRDM is not set
# CONFIG_TARGET_LS1021AQDS is not set
# CONFIG_TARGET_LS1021ATWR is not set
# CONFIG_TARGET_LS1021AIOT is not set
# CONFIG_TARGET_LS1043AQDS is not set
# CONFIG_TARGET_LS1043ARDB is not set
# CONFIG_TARGET_LS1046AQDS is not set
# CONFIG_TARGET_LS1046ARDB is not set
# CONFIG_TARGET_H2200 is not set
# CONFIG_TARGET_ZIPITZ2 is not set
# CONFIG_TARGET_COLIBRI_PXA270 is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_STM32 is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_TARGET_THUNDERX_88XX is not set
CONFIG_SPL_GPIO_SUPPORT=y
CONFIG_SPL_LIBCOMMON_SUPPORT=y
CONFIG_SPL_LIBGENERIC_SUPPORT=y
CONFIG_SYS_MALLOC_F_LEN=0x400
# CONFIG_SPL_EXT_SUPPORT is not set
# CONFIG_SPL_FAT_SUPPORT is not set
# CONFIG_SPL_I2C_SUPPORT is not set
CONFIG_SPL_LIBDISK_SUPPORT=y
CONFIG_SPL_MMC_SUPPORT=y
# CONFIG_SPL_NAND_SUPPORT is not set
CONFIG_SPL_POWER_SUPPORT=y
CONFIG_SPL_SERIAL_SUPPORT=y
# CONFIG_SPL_DISPLAY_PRINT is not set
# CONFIG_SPL_ENV_SUPPORT is not set
# CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set
# CONFIG_SPL_SPI_FLASH_SUPPORT is not set
# CONFIG_SPL_SPI_SUPPORT is not set
# CONFIG_SPL_WATCHDOG_SUPPORT is not set
CONFIG_CPU_V7_HAS_NONSEC=y
CONFIG_CPU_V7_HAS_VIRT=y
# CONFIG_ARMV7_NONSEC is not set
# CONFIG_ARMV7_LPAE is not set
CONFIG_IDENT_STRING=" Allwinner Technology"
CONFIG_PRE_CONSOLE_BUFFER=y
CONFIG_SUNXI_DE2=y
CONFIG_SUNXI_GEN_SUN6I=y
CONFIG_SUNXI_H3_DW_DRAM=y
# CONFIG_MACH_SUN4I is not set
# CONFIG_MACH_SUN5I is not set
# CONFIG_MACH_SUN6I is not set
# CONFIG_MACH_SUN7I is not set
# CONFIG_MACH_SUN8I_A23 is not set
# CONFIG_MACH_SUN8I_A33 is not set
# CONFIG_MACH_SUN8I_A83T is not set
# CONFIG_MACH_SUN8I_H3 is not set
CONFIG_MACH_SUN8I_V3S=y
# CONFIG_MACH_SUN9I is not set
# CONFIG_MACH_SUN50I is not set
CONFIG_MACH_SUN8I=y
CONFIG_DRAM_CLK=360
CONFIG_DRAM_ZQ=14779
# CONFIG_DRAM_ODT_EN is not set
CONFIG_SUNXI_H3_DRAM_DDR2=y
CONFIG_SYS_CLK_FREQ=1008000000
# CONFIG_UART0_PORT_F is not set
# CONFIG_OLD_SUNXI_KERNEL_COMPAT is not set
CONFIG_MMC=y
CONFIG_MMC0_CD_PIN=""
CONFIG_MMC1_CD_PIN=""
CONFIG_MMC2_CD_PIN=""
CONFIG_MMC3_CD_PIN=""
CONFIG_MMC1_PINS=""
CONFIG_MMC2_PINS=""
CONFIG_MMC3_PINS=""
CONFIG_MMC_SUNXI_SLOT_EXTRA=-1
CONFIG_INITIAL_USB_SCAN_DELAY=0
CONFIG_USB0_VBUS_PIN=""
CONFIG_USB0_VBUS_DET=""
CONFIG_USB0_ID_DET=""
CONFIG_USB1_VBUS_PIN=""
CONFIG_USB2_VBUS_PIN=""
CONFIG_USB3_VBUS_PIN=""
# CONFIG_I2C0_ENABLE is not set
# CONFIG_I2C1_ENABLE is not set
# CONFIG_I2C2_ENABLE is not set
# CONFIG_R_I2C_ENABLE is not set
# CONFIG_AXP_GPIO is not set
CONFIG_VIDEO=y
# CONFIG_VIDEO_VGA_VIA_LCD is not set
CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0"
CONFIG_VIDEO_LCD_DCLK_PHASE=1
CONFIG_VIDEO_LCD_POWER=""
CONFIG_VIDEO_LCD_RESET=""
CONFIG_VIDEO_LCD_BL_EN=""
CONFIG_VIDEO_LCD_BL_PWM="PB4"
# CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW is not set
# CONFIG_VIDEO_LCD_PANEL_I2C is not set
CONFIG_VIDEO_LCD_IF_PARALLEL=y
CONFIG_VIDEO_LCD_PANEL_PARALLEL=y
# CONFIG_VIDEO_LCD_PANEL_LVDS is not set
# CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828 is not set
# CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804 is not set
# CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM is not set
# CONFIG_VIDEO_LCD_TL059WV5C0 is not set
CONFIG_GMAC_TX_DELAY=0
CONFIG_SPL_STACK_R_ADDR=0x4fe00000
# CONFIG_SPL_YMODEM_SUPPORT is not set
# ARM debug
# CONFIG_DEBUG_LL is not set
CONFIG_DEFAULT_DEVICE_TREE="sun8i-v3s-licheepi-zero"
CONFIG_SMBIOS_PRODUCT_NAME="sunxi"
# CONFIG_AHCI is not set
# General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_DISTRO_DEFAULTS=y
CONFIG_SYS_MALLOC_F=y
CONFIG_EXPERT=y
CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y
# CONFIG_TOOLS_DEBUG is not set
# CONFIG_PHYS_64BIT is not set
# Boot images
# CONFIG_FIT is not set
CONFIG_OF_BOARD_SETUP=y
# CONFIG_OF_SYSTEM_SETUP is not set
# CONFIG_OF_STDOUT_VIA_ALIAS is not set
CONFIG_SYS_EXTRA_OPTIONS=""
CONFIG_ARCH_FIXUP_FDT_MEMORY=y
# Boot timing
# CONFIG_BOOTSTAGE is not set
CONFIG_BOOTSTAGE_USER_COUNT=20
CONFIG_BOOTSTAGE_STASH_ADDR=0
CONFIG_BOOTSTAGE_STASH_SIZE=4096
# Boot media
# CONFIG_NAND_BOOT is not set
# CONFIG_ONENAND_BOOT is not set
# CONFIG_QSPI_BOOT is not set
# CONFIG_SATA_BOOT is not set
# CONFIG_SD_BOOT is not set
# CONFIG_SPI_BOOT is not set
CONFIG_BOOTDELAY=2
# Console
CONFIG_MENU=y
# CONFIG_CONSOLE_RECORD is not set
# CONFIG_SILENT_CONSOLE is not set
CONFIG_PRE_CON_BUF_SZ=4096
CONFIG_PRE_CON_BUF_ADDR=0x4f000000
# CONFIG_CONSOLE_MUX is not set
# CONFIG_SYS_CONSOLE_IS_IN_ENV is not set
# CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set
# CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set
# CONFIG_SYS_CONSOLE_INFO_QUIET is not set
CONFIG_SYS_STDIO_DEREGISTER=y
CONFIG_DEFAULT_FDT_FILE=""
# CONFIG_SYS_NO_FLASH is not set
# CONFIG_VERSION_VARIABLE is not set
CONFIG_DISPLAY_CPUINFO=y
CONFIG_DISPLAY_BOARDINFO=y
# SPL / TPL
CONFIG_SUPPORT_SPL=y
CONFIG_SPL=y
CONFIG_SPL_SYS_MALLOC_SIMPLE=y
CONFIG_SPL_STACK_R=y
CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000
# CONFIG_SPL_SEPARATE_BSS is not set
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x50
# CONFIG_SPL_CRYPTO_SUPPORT is not set
# CONFIG_SPL_HASH_SUPPORT is not set
# CONFIG_SPL_DMA_SUPPORT is not set
# CONFIG_SPL_FPGA_SUPPORT is not set
# CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set
# CONFIG_SPL_MTD_SUPPORT is not set
# CONFIG_SPL_MUSB_NEW_SUPPORT is not set
# CONFIG_SPL_NET_SUPPORT is not set
# CONFIG_SPL_NO_CPU_SUPPORT is not set
# CONFIG_SPL_NOR_SUPPORT is not set
# CONFIG_SPL_ONENAND_SUPPORT is not set
# CONFIG_SPL_OS_BOOT is not set
# CONFIG_SPL_POST_MEM_SUPPORT is not set
# CONFIG_SPL_SATA_SUPPORT is not set
# CONFIG_SPL_USB_HOST_SUPPORT is not set
# CONFIG_SPL_USB_GADGET_SUPPORT is not set
# Command line interface
CONFIG_CMDLINE=y
CONFIG_HUSH_PARSER=y
CONFIG_SYS_PROMPT="=> "
# Autoboot options
CONFIG_AUTOBOOT=y
# CONFIG_AUTOBOOT_KEYED is not set
# FASTBOOT
# CONFIG_FASTBOOT is not set
# Commands
# Info commands
CONFIG_CMD_BDI=y
CONFIG_CMD_CONSOLE=y
# CONFIG_CMD_CPU is not set
# CONFIG_CMD_LICENSE is not set
# Boot commands
CONFIG_CMD_BOOTD=y
CONFIG_CMD_BOOTM=y
CONFIG_CMD_BOOTZ=y
CONFIG_CMD_BOOTEFI=y
CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
# CONFIG_CMD_BOOTEFI_HELLO is not set
CONFIG_CMD_BOOTMENU=y
CONFIG_CMD_ELF=y
CONFIG_CMD_FDT=y
CONFIG_CMD_GO=y
CONFIG_CMD_RUN=y
CONFIG_CMD_IMI=y
# CONFIG_CMD_IMLS is not set
CONFIG_CMD_XIMG=y
# Environment commands
# CONFIG_CMD_ASKENV is not set
CONFIG_CMD_EXPORTENV=y
CONFIG_CMD_IMPORTENV=y
CONFIG_CMD_EDITENV=y
# CONFIG_CMD_GREPENV is not set
CONFIG_CMD_SAVEENV=y
CONFIG_CMD_ENV_EXISTS=y
# Memory commands
CONFIG_CMD_MEMORY=y
CONFIG_CMD_CRC32=y
# CONFIG_LOOPW is not set
# CONFIG_CMD_MEMTEST is not set
# CONFIG_CMD_MX_CYCLIC is not set
CONFIG_CMD_MEMINFO=y
# Device access commands
CONFIG_CMD_DM=y
# CONFIG_CMD_DEMO is not set
CONFIG_CMD_LOADB=y
CONFIG_CMD_LOADS=y
# CONFIG_CMD_FLASH is not set
# CONFIG_CMD_ARMFLASH is not set
CONFIG_CMD_MMC=y
# CONFIG_CMD_NAND is not set
# CONFIG_CMD_SF is not set
# CONFIG_CMD_SPI is not set
# CONFIG_CMD_I2C is not set
CONFIG_CMD_USB=y
# CONFIG_CMD_DFU is not set
# CONFIG_CMD_USB_MASS_STORAGE is not set
# CONFIG_CMD_FPGA is not set
CONFIG_CMD_GPIO=y
# Shell scripting commands
CONFIG_CMD_ECHO=y
CONFIG_CMD_ITEST=y
CONFIG_CMD_SOURCE=y
CONFIG_CMD_SETEXPR=y
# Network commands
CONFIG_CMD_NET=y
# CONFIG_CMD_TFTPPUT is not set
# CONFIG_CMD_TFTPSRV is not set
# CONFIG_CMD_RARP is not set
CONFIG_CMD_DHCP=y
CONFIG_CMD_PXE=y
CONFIG_CMD_NFS=y
CONFIG_CMD_MII=y
CONFIG_CMD_PING=y
# CONFIG_CMD_CDP is not set
# CONFIG_CMD_SNTP is not set
# CONFIG_CMD_DNS is not set
# CONFIG_CMD_LINK_LOCAL is not set
# Misc commands
# CONFIG_CMD_BKOPS_ENABLE is not set
# CONFIG_CMD_CACHE is not set
# CONFIG_CMD_TIME is not set
CONFIG_CMD_MISC=y
# CONFIG_CMD_TIMER is not set
# CONFIG_CMD_QFW is not set
# Power commands
# Security commands
# Firmware commands
# Filesystem commands
CONFIG_CMD_EXT2=y
CONFIG_CMD_EXT4=y
# CONFIG_CMD_EXT4_WRITE is not set
CONFIG_CMD_FAT=y
CONFIG_CMD_FS_GENERIC=y
# CONFIG_CMD_UBI is not set
CONFIG_SUPPORT_OF_CONTROL=y
# Device Tree Control
CONFIG_OF_CONTROL=y
# CONFIG_SPL_OF_CONTROL is not set
CONFIG_OF_SEPARATE=y
# CONFIG_OF_EMBED is not set
CONFIG_NET=y
# CONFIG_NET_RANDOM_ETHADDR is not set
# CONFIG_NETCONSOLE is not set
CONFIG_NET_TFTP_VARS=y
CONFIG_BOOTP_PXE_CLIENTARCH=0x15
CONFIG_BOOTP_VCI_STRING="U-Boot.armv7"
# Device Drivers
# Generic Driver Options
CONFIG_DM=y
# CONFIG_SPL_DM is not set
CONFIG_DM_WARN=y
CONFIG_DM_DEVICE_REMOVE=y
CONFIG_DM_STDIO=y
CONFIG_DM_SEQ_ALIAS=y
# CONFIG_SPL_DM_SEQ_ALIAS is not set
# CONFIG_REGMAP is not set
# CONFIG_SPL_REGMAP is not set
# CONFIG_DEVRES is not set
CONFIG_SIMPLE_BUS=y
CONFIG_OF_TRANSLATE=y
# CONFIG_ADC is not set
# CONFIG_ADC_EXYNOS is not set
# CONFIG_ADC_SANDBOX is not set
# CONFIG_BLK is not set
# CONFIG_BLOCK_CACHE is not set
# SATA/SCSI device support
# Clock
# CONFIG_CLK is not set
# CONFIG_CPU is not set
# Hardware crypto devices
# CONFIG_FSL_CAAM is not set
# Demo for driver model
# CONFIG_DM_DEMO is not set
# DFU support
# DMA Support
# CONFIG_DMA is not set
# CONFIG_TI_EDMA3 is not set
# FPGA support
# CONFIG_FPGA_ALTERA is not set
# CONFIG_FPGA_XILINX is not set
# GPIO Support
CONFIG_DM_GPIO=y
# CONFIG_ALTERA_PIO is not set
# CONFIG_DWAPB_GPIO is not set
# CONFIG_ATMEL_PIO4 is not set
# CONFIG_INTEL_BROADWELL_GPIO is not set
# CONFIG_LPC32XX_GPIO is not set
# CONFIG_MSM_GPIO is not set
# CONFIG_ROCKCHIP_GPIO is not set
# CONFIG_TEGRA_GPIO is not set
# CONFIG_TEGRA186_GPIO is not set
# CONFIG_VYBRID_GPIO is not set
# CONFIG_DM_74X164 is not set
# CONFIG_DM_PCA953X is not set
# CONFIG_MPC85XX_GPIO is not set
# I2C support
# CONFIG_DM_I2C is not set
# CONFIG_DM_I2C_COMPAT is not set
# CONFIG_SYS_I2C_DW is not set
CONFIG_DM_KEYBOARD=y
# CONFIG_CROS_EC_KEYB is not set
# CONFIG_I8042_KEYB is not set
# LED Support
# CONFIG_LED is not set
# Mailbox Controller Support
# CONFIG_DM_MAILBOX is not set
# Memory Controller drivers
# Multifunction device drivers
# CONFIG_MISC is not set
# CONFIG_CROS_EC is not set
# CONFIG_FSL_SEC_MON is not set
# CONFIG_MXC_OCOTP is not set
# CONFIG_NUVOTON_NCT6102D is not set
# CONFIG_PWRSEQ is not set
# CONFIG_PCA9551_LED is not set
# CONFIG_WINBOND_W83627 is not set
# MMC Host controller Support
# CONFIG_DM_MMC is not set
# CONFIG_SPL_MMC_TINY is not set
# MTD Support
# CONFIG_MTD is not set
# NAND Device Support
# CONFIG_NAND_DENALI is not set
# CONFIG_NAND_VF610_NFC is not set
# CONFIG_NAND_PXA3XX is not set
# CONFIG_NAND_ARASAN is not set
# CONFIG_NAND_ZYNQ is not set
# Generic NAND options
# CONFIG_SYS_NAND_U_BOOT_LOCATIONS is not set
# CONFIG_SPL_NAND_DENALI is not set
# SPI Flash Support
# CONFIG_SPI_FLASH is not set
# UBI support
# CONFIG_MTD_UBI is not set
CONFIG_DM_ETH=y
# CONFIG_PHYLIB is not set
# CONFIG_NETDEVICES is not set
# CONFIG_PCI is not set
# CONFIG_MVEBU_COMPHY_SUPPORT is not set
# Pin controllers
# CONFIG_PINCTRL is not set
# Power
# Power Domain Support
# CONFIG_POWER_DOMAIN is not set
# CONFIG_DM_PMIC is not set
# CONFIG_DM_REGULATOR is not set
CONFIG_SUNXI_NO_PMIC=y
# CONFIG_DM_PWM is not set
# CONFIG_RAM is not set
# Remote Processor drivers
# Reset Controller Support
# CONFIG_DM_RESET is not set
# Real Time Clock
# CONFIG_DM_RTC is not set
# Serial drivers
CONFIG_REQUIRE_SERIAL_CONSOLE=y
CONFIG_SERIAL_PRESENT=y
CONFIG_SPL_SERIAL_PRESENT=y
CONFIG_DM_SERIAL=y
# CONFIG_DEBUG_UART is not set
# CONFIG_DEBUG_UART_SKIP_INIT is not set
# CONFIG_ALTERA_JTAG_UART is not set
# CONFIG_ALTERA_UART is not set
# CONFIG_ATMEL_USART is not set
# CONFIG_FSL_LPUART is not set
# CONFIG_MVEBU_A3700_UART is not set
CONFIG_SYS_NS16550=y
# CONFIG_MSM_SERIAL is not set
# CONFIG_PXA_SERIAL is not set
# Sound support
# CONFIG_SOUND is not set
# SPI Support
# CONFIG_DM_SPI is not set
# CONFIG_FSL_ESPI is not set
# CONFIG_FSL_QSPI is not set
# CONFIG_TI_QSPI is not set
# SPMI support
# CONFIG_SPMI is not set
# System reset device drivers
# CONFIG_SYSRESET is not set
# CONFIG_DM_THERMAL is not set
# Timer Support
# CONFIG_TIMER is not set
# TPM support
CONFIG_USB=y
CONFIG_DM_USB=y
# USB Host Controller Drivers
# CONFIG_USB_XHCI_HCD is not set
# CONFIG_USB_EHCI_HCD is not set
# CONFIG_USB_EHCI is not set
# CONFIG_USB_OHCI_HCD is not set
# CONFIG_USB_UHCI_HCD is not set
# MUSB Controller Driver
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
# CONFIG_USB_MUSB_TI is not set
# ULPI drivers
# USB peripherals
CONFIG_USB_STORAGE=y
CONFIG_USB_KEYBOARD=y
# CONFIG_USB_GADGET is not set
# Graphics support
# CONFIG_DM_VIDEO is not set
# TrueType Fonts
# CONFIG_VIDEO_VESA is not set
# CONFIG_VIDEO_LCD_ANX9804 is not set
# CONFIG_VIDEO_LCD_SSD2828 is not set
# CONFIG_VIDEO_LCD_HITACHI_TX18D42VM is not set
# CONFIG_VIDEO_MVEBU is not set
# CONFIG_DISPLAY is not set
# CONFIG_VIDEO_TEGRA20 is not set
# CONFIG_VIDEO_BRIDGE is not set
CONFIG_CFB_CONSOLE=y
# CONFIG_CFB_CONSOLE_ANSI is not set
CONFIG_VGA_AS_SINGLE_DEVICE=y
CONFIG_VIDEO_SW_CURSOR=y
# CONFIG_CONSOLE_EXTRA_INFO is not set
CONFIG_CONSOLE_SCROLL_LINES=1
# CONFIG_VIDEO_CT69000 is not set
CONFIG_SYS_CONSOLE_BG_COL=0x00
CONFIG_SYS_CONSOLE_FG_COL=0xa0
# CONFIG_LCD is not set
# CONFIG_PHYS_TO_BUS is not set
# File systems
# Library routines
# CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
CONFIG_HAVE_PRIVATE_LIBGCC=y
CONFIG_USE_PRIVATE_LIBGCC=y
CONFIG_SYS_HZ=1000
CONFIG_USE_TINY_PRINTF=y
CONFIG_REGEX=y
# CONFIG_LIB_RAND is not set
# CONFIG_CMD_DHRYSTONE is not set
# CONFIG_RSA is not set
# CONFIG_TPM is not set
# Hashing Support
# CONFIG_SHA1 is not set
# CONFIG_SHA256 is not set
# CONFIG_SHA_HW_ACCEL is not set
# Compression Support
# CONFIG_LZ4 is not set
# CONFIG_ERRNO_STR is not set
CONFIG_OF_LIBFDT=y
CONFIG_OF_LIBFDT_OVERLAY=y
# CONFIG_SPL_OF_LIBFDT is not set
# CONFIG_FDT_FIXUP_PARTITIONS is not set
# System tables
CONFIG_GENERATE_SMBIOS_TABLE=y
CONFIG_SMBIOS_MANUFACTURER=""
CONFIG_EFI_LOADER=y
# CONFIG_UNIT_TEST is not set
#1 2021-11-29 21:42:13
wechat微信:whycan_cn
所在地: 你猜
已发帖子: 3,378
Re: V3S Uboot启动失败问题
缺 bootargs,bootcmd两个环境变量。
tf卡的可以用 boot.scr,本站右上角搜这个关键字。
楼主 #2 2021-11-29 21:52:19
mysteryli
已发帖子: 481
Re: V3S Uboot启动失败问题
可以了 感谢
不过这个boot.scr,我尝试了打开,里面有一部分是字符,有一部分直接是二进制文件,查了一下貌似这个东西是用来在uboot和linux之间传递参数的,可以用mkimage,但是没找到具体的生成规则的教程,请问这个在哪里可以学到呢...
最近编辑记录 mysteryli (2021-11-29 22:08:35)
