楼主 #1 2018-07-18 10:27:25
有人关注MicroChi的SAMA5D2系列吗?内嵌DDR2,128Mbit ~1Gbit 都有。参考设计以及驱动等资料非常完善
Summary
The SAMA5D225C-D1M System in Package (SiP) integrates the ARM® Cortex®-A5 processor-based SAMA5D22C MPU with 128 Mbit (16 Mbytes) of DDR2-SDRAM in a single package.  By combining the high-performance, ultra-low-power SAMA5D2 with DDR2-SDRAM in a single package, PCB routing complexity, area and number of layers is reduced in the majority of cases.  This makes board design easier and more robust by facilitating design for EMI, ESD and signal integrity.  This SiP targets applications using an Linux, RTOS or bare metal for development and is available in a BGA196 package.
Additional Features
ARM Cortex-A5 core:
Up to 500 MHz, ARMv7-A architecture, ARM TrustZone, NEON™ Media Processing Engine, 8 Kbyte Embedded Trace Buffer (ETB)
Memory Architecture
Memory Management Unit
32-Kbyte L1 data cache, 32-Kbyte L1 instruction cache
128-Kbyte L2 cache configurable to be used as an internal SRAM
128 Mbit DDR2-SDRAM
One 128-Kbyte scrambled internal SRAM
One 160-Kbyte internal ROM, 64-Kbyte scrambled and maskable ROM embedding boot loader/Secure boot loader, 96-Kbyte unscrambled, unmaskable ROM for NAND Flash BCH ECC table
High-bandwidth scramblable 16-bit Double Data Rate (DDR) multiport dynamic RAM controller supporting the internal DDR2-SDRAM, including the “on-the-fly” encryption/decryption path
8-bit SLC/MLC NAND controller, with up to 32-bit Error Correcting Code (PMECC)
Low-Power Modes
Ultra Low-power mode with fast wakeup capability
Low-power Backup mode with 5-Kbyte SRAM and Sleep Walking™ features, Wakeup from up to nine wakeup pins, UART reception, analog comparison, Fast wakeup capability, Extended Backup mode with DDR2-SDRAM in Self-Refresh mode
Peripherals
LCD TFT controller up to 1024x768, with four overlays, rotation, post-processing and alpha blending, 24-bit parallel RGB
ITU-R BT. 601/656/1120 Image Sensor Controller (ISC) supporting up to 5 M-pixel sensors with a parallel 12-bit interface for Raw Bayer, YCbCr, Monochrome and JPEG-compressed sensor interface
Two Synchronous Serial Controllers (SSC), two Inter-IC Sound Controllers (I2SC), and one Stereo Class D amplifier
One Peripheral Touch Controller (PTC) with up to 4 X-lines and 8 Y-lines (32-channel capacitive touch)
One Pulse Density Modulation Interface Controller (PDMIC)
One USB high-speed device port (UDPHS) and one USB high-speed host port or two USB high-speed host ports (UHPHS), plus one High-Speed Inter-Chip (HSIC) host port.
One 10/100 Ethernet MAC (GMAC)
Energy efficiency support (IEEE 802.3az standard), Ethernet AVB support with IEEE802.1AS time stamping, IEEE802.1Qav credit-based traffic-shaping hardware support, IEEE1588 Precision Time Protocol (PTP)
Two high-speed memory card hosts:
SDMMC0: SD 3.0, eMMC 4.51, 8 bits
SDMMC1: SD 2.0, eMMC 4.41, 4 bits only
Many other serial, timer and A/D modules
Up to 90 I/Os
Safety and Security:
Integrity Check Monitor based on SHA256, Crypto engine (SHA512, AES256, TDES), TRNG, tamper pins, Secure Boot Loader, Programmable fuse box, On-the-fly AES   encryption/decryption on DDR2-SDRAM and QSPI, 5 Kbytes of internal scrambled SRAM, 256 bits of scrambled and erasable registers, Independent watchdog, Main crystal clock failure detector
https://www.microchip.com/wwwproducts/en/ATSAMA5D225C-D1M
#2 2018-07-18 10:31:17
已发帖子: 9,440
Re: 有人关注MicroChi的SAMA5D2系列吗?内嵌DDR2,128Mbit ~1Gbit 都有。参考设计以及驱动等资料非常完善
资源确实不错,但是
自从那次缺货后,感觉atmel离群众越来越远了
#3 2018-07-18 16:14:57
kaokao
已发帖子: 30
晕哥涉猎面真广。
#4 2018-07-18 16:48:33
tom
已发帖子: 128
手册写的很完善,远超nuvoton、全志了。
就是,图形 图像加速相关的模块没有
楼主 #5 2018-07-18 18:32:05
tom 说:
就是,图形 图像加速相关的模块没有
我看好像有多层alpha blending等叠加功能
#6 2018-07-18 19:17:16
jlau
已发帖子: 214
价格差5倍,差评
楼主 #7 2018-07-18 21:20:51
jlau 说:
价格差5倍,差评
10美金还好吧
你是和f1c100比差5倍吗?microchip的芯片是工业级的,而且资料丰富不具有可比性
#8 2018-07-19 11:14:29
zpyws
已发帖子: 33
一片10美金?那我选择国产U
楼主 #9 2018-07-19 15:19:54
Microchip官网买了个ATSAMA5D27-SOM1 核心板,没想到官网对中国购买很友好,支持支付宝,一周内上海发货
Device Total:
312.57
Shipping:
22.50
Value Add:
0.00
Import Duty or VAT:
53.61
Total (CNY): 388.68
到时候写个入坑过程
最近编辑记录 达克罗德 (2018-07-19 15:20:30)
#10 2018-07-19 15:29:08
已发帖子: 9,440
坐等大神入坑
#11 2018-07-19 16:15:06
10刀的话还可以,偏贵了。不过atmel你是知道的,随随便便就缺货了能搞死你。
#12 2018-07-19 17:12:27
Mitko
已发帖子: 219
ATSAMA5D21更便宜,可能制造廉价的电路板。我对Allwinner H2/H3更感兴趣,有一些不太昂贵的电路板,如Orange Pi Zero,但没有很多I/O和集成ADC。
楼主 #13 2018-07-19 18:13:06
mango 说:
microchip官网我试了,可以随便下单,一周内从上海发货,感觉很好买呀
楼主 #14 2018-07-19 18:14:29
Mitko 说:
ATSAMA5D21不带DDR,自己做板要难一点
#15 2018-07-19 18:51:29
Mitko
已发帖子: 219
达克罗德 说:
布局建议:
ATSAMA5D21 - 4-layer PCB, SAMA5D2 Layout Recommendations
#16 2018-07-19 19:08:34
sindy
已发帖子: 146
看到BGA封装我就瑟瑟发抖。
楼主 #17 2018-07-25 09:16:01
这么快就收到som,不到5天,赞。包装很专业,很仔细,也赞一个
#18 2018-07-25 09:19:21
sindy
已发帖子: 146
看起来不错。
泰国制造.
#19 2018-07-26 08:57:34
lcfmax
已发帖子: 329
效率很高, 这么快就到手了
#20 2021-08-05 09:51:11
XIVN1987
已发帖子: 271
达克罗德 说:
https://whycan.cn/files/members/729/20180725_085750.jpeg
既然DDR已经叠封在芯片里面了,,芯片的封装为什么还是BGA??完全没体现出叠封DDR的优势啊!
#21 2021-08-05 10:03:41
XIVN1987
已发帖子: 271
我上贴说错了,,不是ATSAMA5D27C-D1G叠封DDR没优势,,而是ATSAMA5D27-SOM1没把优势发挥出来
下面这个SOM就充分发挥了ATSAMA5D27C-D1G叠封DDR的优势
看起来SOM长宽只比芯片大了20%,,相当紧凑
https://www.cnx-software.com/2021/06/14/hanesom-is-a-4-cm2-arm-linux-module-powered-by-microchip-sama5d2-sip/
#22 2021-08-05 15:03:43
szchen2006
已发帖子: 216
  • 不通过:其他
楼主 #23 2021-08-10 22:36:31
@XIVN1987
这个我喜欢
#24 2021-08-11 08:00:59
jiangchun9981
已发帖子: 170
不到50块钱,工业级,目前形势下,已经很良心了
直接原厂购买上海发货过来,非常好买,原厂资源太齐全啦随便下载!
F1C100现在30块钱了而且不好找货源
