楼主 # 2021-12-05 20:26:44
mysteryli
已发帖子: 493
V3S没有出现eth0网卡
各位大佬,RT,感觉我的内核配置有错误,晒上config文件与设备树,麻烦大神们帮忙看看是哪个配置项没有开
硬件应该是没有问题的 用别人的镜像网络可以通
配置
# Linux/arm 5.2.0 Kernel Configuration
# Compiler: arm-linux-gnueabihf-gcc (Linaro GCC 6.3-2017.02) 6.3.1 20170109
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=60301
CONFIG_CLANG_VERSION=0
CONFIG_CC_CAN_LINK=y
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_CC_HAS_WARN_MAYBE_UNINITIALIZED=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
# CONFIG_HEADER_TEST is not set
CONFIG_LOCALVERSION="-licheepi-zero"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
# CONFIG_POSIX_MQUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_GENERIC_IRQ_MIGRATION=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_PSI is not set
# end of CPU/Task time and stats accounting
CONFIG_CPU_ISOLATION=y
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
# end of RCU Subsystem
# CONFIG_IKCONFIG is not set
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# end of Scheduler features
CONFIG_CGROUPS=y
# CONFIG_MEMCG is not set
# CONFIG_BLK_CGROUP is not set
# CONFIG_CGROUP_SCHED is not set
# CONFIG_CGROUP_PIDS is not set
# CONFIG_CGROUP_RDMA is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CPUSETS is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CGROUP_CPUACCT is not set
# CONFIG_CGROUP_PERF is not set
# CONFIG_CGROUP_DEBUG is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
# CONFIG_USER_NS is not set
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_CHECKPOINT_RESTORE is not set
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
# CONFIG_EXPERT is not set
CONFIG_UID16=y
CONFIG_MULTIUSER=y
CONFIG_SYSFS_SYSCALL=y
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
# CONFIG_BPF_SYSCALL is not set
# CONFIG_USERFAULTFD is not set
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_RSEQ=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
CONFIG_SLUB_CPU_PARTIAL=y
CONFIG_SYSTEM_DATA_VERIFICATION=y
# CONFIG_PROFILING is not set
# end of General setup
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# end of Multiple platform selection
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCM is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MILBEAUT is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_NPCM is not set
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
# CONFIG_SOC_AM33XX is not set
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
# end of TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_SIRF is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_RDA is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32 is not set
CONFIG_ARCH_SUNXI=y
# CONFIG_MACH_SUN4I is not set
# CONFIG_MACH_SUN5I is not set
# CONFIG_MACH_SUN6I is not set
# CONFIG_MACH_SUN7I is not set
CONFIG_MACH_SUN8I=y
# CONFIG_MACH_SUN9I is not set
CONFIG_ARCH_SUNXI_MC_SMP=y
# CONFIG_ARCH_TANGO is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZX is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARM_LPAE is not set
CONFIG_ARM_THUMB=y
# CONFIG_ARM_THUMBEE is not set
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_ICACHE_MISMATCH_WORKAROUND is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_CPU_SPECTRE=y
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_OUTER_CACHE=y
CONFIG_OUTER_CACHE_SYNC=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
CONFIG_CACHE_L2X0=y
# CONFIG_CACHE_L2X0_PMU is not set
# CONFIG_PL310_ERRATA_588369 is not set
# CONFIG_PL310_ERRATA_727915 is not set
# CONFIG_PL310_ERRATA_753970 is not set
# CONFIG_PL310_ERRATA_769419 is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_HEAVY_MB=y
CONFIG_DEBUG_ALIGN_RODATA=y
# CONFIG_ARM_ERRATA_430973 is not set
CONFIG_ARM_ERRATA_643719=y
# CONFIG_ARM_ERRATA_720789 is not set
# CONFIG_ARM_ERRATA_754322 is not set
# CONFIG_ARM_ERRATA_754327 is not set
# CONFIG_ARM_ERRATA_764369 is not set
# CONFIG_ARM_ERRATA_775420 is not set
# CONFIG_ARM_ERRATA_798181 is not set
# CONFIG_ARM_ERRATA_773022 is not set
# CONFIG_ARM_ERRATA_818325_852422 is not set
# CONFIG_ARM_ERRATA_821420 is not set
# CONFIG_ARM_ERRATA_825619 is not set
# CONFIG_ARM_ERRATA_857271 is not set
# CONFIG_ARM_ERRATA_852421 is not set
# CONFIG_ARM_ERRATA_852423 is not set
# CONFIG_ARM_ERRATA_857272 is not set
# end of System Type
# Bus support
# CONFIG_ARM_ERRATA_814220 is not set
# end of Bus support
# Kernel Features
CONFIG_HAVE_SMP=y
CONFIG_SMP=y
CONFIG_SMP_ON_UP=y
CONFIG_ARM_CPU_TOPOLOGY=y
# CONFIG_SCHED_MC is not set
# CONFIG_SCHED_SMT is not set
CONFIG_HAVE_ARM_ARCH_TIMER=y
# CONFIG_MCPM is not set
# CONFIG_BIG_LITTLE is not set
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_NR_CPUS=8
CONFIG_HOTPLUG_CPU=y
CONFIG_ARM_PSCI=y
CONFIG_ARCH_NR_GPIO=416
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
# CONFIG_THUMB2_KERNEL is not set
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_ARM_MODULE_PLTS=y
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_SECCOMP is not set
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# CONFIG_XEN is not set
# end of Kernel Features
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0
CONFIG_ZBOOT_ROM_BSS=0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
CONFIG_CMDLINE=""
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# end of Boot options
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
# CONFIG_CPU_FREQ_STAT is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_GOV_SCHEDUTIL is not set
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set
# CONFIG_QORIQ_CPUFREQ is not set
# end of CPU Frequency scaling
# CPU Idle
# CONFIG_CPU_IDLE is not set
# end of CPU Idle
# end of CPU Power Management
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
# CONFIG_KERNEL_MODE_NEON is not set
# end of Floating point emulation
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_HIBERNATION is not set
CONFIG_PM_SLEEP=y
CONFIG_PM_SLEEP_SMP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_CPU_PM=y
# CONFIG_ENERGY_MODEL is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# end of Power management options
# Firmware Drivers
# CONFIG_FW_CFG_SYSFS is not set
# CONFIG_TRUSTED_FOUNDATIONS is not set
CONFIG_HAVE_ARM_SMCCC=y
CONFIG_ARM_PSCI_FW=y
# CONFIG_GOOGLE_FIRMWARE is not set
# Tegra firmware driver
# end of Tegra firmware driver
# end of Firmware Drivers
# CONFIG_ARM_CRYPTO is not set
# CONFIG_VIRTUALIZATION is not set
# General architecture-dependent options
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
# CONFIG_JUMP_LABEL is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_KEEPINITRD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_ARCH_32BIT_OFF_T=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS=8
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
CONFIG_64BIT_TIME=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_ARCH_HAS_PHYS_TO_DMA=y
CONFIG_REFCOUNT_FULL=y
# CONFIG_LOCK_EVENT_COUNTS is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_PLUGIN_HOSTCC=""
CONFIG_HAVE_GCC_PLUGINS=y
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# CONFIG_BLK_WBT is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# end of Partition Types
CONFIG_BLK_PM=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
# end of IO Schedulers
CONFIG_ASN1=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_ARCH_KEEP_MEMBLOCK=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
# CONFIG_CMA is not set
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
# CONFIG_ZSMALLOC is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_FRAME_VECTOR=y
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
# end of Memory Management options
CONFIG_NET=y
CONFIG_SKB_EXTENSIONS=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_DIAG=y
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
CONFIG_UNIX_DIAG=y
CONFIG_TLS=y
CONFIG_TLS_DEVICE=y
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=y
CONFIG_XFRM_USER=y
CONFIG_XFRM_SUB_POLICY=y
CONFIG_XFRM_MIGRATE=y
CONFIG_XFRM_STATISTICS=y
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
# CONFIG_IP_FIB_TRIE_STATS is not set
# CONFIG_IP_MULTIPLE_TABLES is not set
CONFIG_IP_ROUTE_MULTIPATH=y
# CONFIG_IP_ROUTE_VERBOSE is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
# CONFIG_IP_PNP_BOOTP is not set
CONFIG_IP_PNP_RARP=y
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
CONFIG_IP_MROUTE_COMMON=y
CONFIG_IP_MROUTE=y
# CONFIG_IP_MROUTE_MULTIPLE_TABLES is not set
# CONFIG_IP_PIMSM_V1 is not set
# CONFIG_IP_PIMSM_V2 is not set
CONFIG_SYN_COOKIES=y
# CONFIG_NET_IPVTI is not set
# CONFIG_NET_FOU is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
CONFIG_INET_UDP_DIAG=m
# CONFIG_INET_RAW_DIAG is not set
# CONFIG_INET_DIAG_DESTROY is not set
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
# CONFIG_TCP_CONG_HSTCP is not set
# CONFIG_TCP_CONG_HYBLA is not set
# CONFIG_TCP_CONG_VEGAS is not set
# CONFIG_TCP_CONG_NV is not set
# CONFIG_TCP_CONG_SCALABLE is not set
# CONFIG_TCP_CONG_LP is not set
# CONFIG_TCP_CONG_VENO is not set
# CONFIG_TCP_CONG_YEAH is not set
# CONFIG_TCP_CONG_ILLINOIS is not set
# CONFIG_TCP_CONG_DCTCP is not set
# CONFIG_TCP_CONG_CDG is not set
# CONFIG_TCP_CONG_BBR is not set
CONFIG_DEFAULT_CUBIC=y
# CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
CONFIG_STP=y
CONFIG_BRIDGE=y
CONFIG_BRIDGE_IGMP_SNOOPING=y
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
CONFIG_LLC=y
# CONFIG_LLC2 is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# CONFIG_DNS_RESOLVER is not set
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_NET_NSH is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_NET_NCSI is not set
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_XPS=y
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
CONFIG_NET_FLOW_LIMIT=y
# Network testing
# CONFIG_NET_PKTGEN is not set
# end of Network testing
# end of Networking options
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
CONFIG_STREAM_PARSER=y
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=m
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
# CONFIG_CFG80211_WEXT is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
# CONFIG_MAC80211_MESH is not set
# CONFIG_MAC80211_LEDS is not set
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
CONFIG_GRO_CELLS=y
CONFIG_SOCK_VALIDATE_XMIT=y
CONFIG_NET_SOCK_MSG=y
# CONFIG_FAILOVER is not set
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_HAVE_PCI=y
# CONFIG_PCI is not set
# CONFIG_PCCARD is not set
# Generic Driver Options
# CONFIG_UEVENT_HELPER is not set
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER is not set
# CONFIG_FW_LOADER_COMPRESS is not set
# end of Firmware loader
CONFIG_ALLOW_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# end of Generic Driver Options
# Bus devices
CONFIG_ARM_CCI=y
CONFIG_ARM_CCI400_COMMON=y
CONFIG_ARM_CCI400_PORT_CTRL=y
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_SIMPLE_PM_BUS is not set
# CONFIG_SUN50I_DE2_BUS is not set
CONFIG_SUNXI_RSB=y
# CONFIG_VEXPRESS_CONFIG is not set
# end of Bus devices
# CONFIG_CONNECTOR is not set
# CONFIG_GNSS is not set
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AR7_PARTS is not set
# Partition parsers
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# end of Partition parsers
# User Modules And Translation Layers
# CONFIG_MTD_BLOCK is not set
# CONFIG_MTD_BLOCK_RO is not set
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
CONFIG_MTD_M25P80=y
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# CONFIG_MTD_ONENAND is not set
# CONFIG_MTD_RAW_NAND is not set
# CONFIG_MTD_SPI_NAND is not set
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
# end of LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_SPI_NOR=y
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_SPI_CADENCE_QUADSPI is not set
# CONFIG_SPI_MTK_QUADSPI is not set
# CONFIG_MTD_UBI is not set
# CONFIG_MTD_HYPERBUS is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=m
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_RBD is not set
# NVME Support
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# end of NVME Support
# Misc devices
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_XILINX_SDFEC is not set
# CONFIG_PVPANIC is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# Intel MIC & related support
# Intel MIC Bus Driver
# SCIF Bus Driver
# VOP Bus Driver
# CONFIG_VOP_BUS is not set
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# VOP Driver
# end of Intel MIC & related support
# CONFIG_ECHO is not set
# CONFIG_MISC_RTSX_USB is not set
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=m
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_TEAM is not set
# CONFIG_MACVLAN is not set
# CONFIG_IPVLAN is not set
# CONFIG_VXLAN is not set
# CONFIG_GENEVE is not set
# CONFIG_GTP is not set
# CONFIG_MACSEC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_TUN is not set
# CONFIG_TUN_VNET_CROSS_LE is not set
# CONFIG_VETH is not set
# CONFIG_NLMON is not set
# CAIF transport drivers
# Distributed Switch Architecture drivers
# end of Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
# CONFIG_NET_VENDOR_ALACRITECH is not set
CONFIG_NET_VENDOR_ALLWINNER=y
CONFIG_SUN4I_EMAC=m
# CONFIG_ALTERA_TSE is not set
# CONFIG_NET_VENDOR_AMAZON is not set
# CONFIG_NET_VENDOR_AQUANTIA is not set
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_AURORA is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
# CONFIG_NET_VENDOR_CADENCE is not set
# CONFIG_NET_VENDOR_CAVIUM is not set
# CONFIG_NET_VENDOR_CIRRUS is not set
# CONFIG_NET_VENDOR_CORTINA is not set
CONFIG_DM9000=m
# CONFIG_DM9000_FORCE_SIMPLE_PHY_POLL is not set
# CONFIG_DNET is not set
# CONFIG_NET_VENDOR_EZCHIP is not set
# CONFIG_NET_VENDOR_FARADAY is not set
# CONFIG_NET_VENDOR_GOOGLE is not set
# CONFIG_NET_VENDOR_HISILICON is not set
# CONFIG_NET_VENDOR_HUAWEI is not set
# CONFIG_NET_VENDOR_INTEL is not set
CONFIG_NET_VENDOR_MARVELL=y
# CONFIG_MVMDIO is not set
# CONFIG_NET_VENDOR_MELLANOX is not set
# CONFIG_NET_VENDOR_MICREL is not set
# CONFIG_NET_VENDOR_MICROCHIP is not set
# CONFIG_NET_VENDOR_MICROSEMI is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
# CONFIG_NET_VENDOR_NETRONOME is not set
# CONFIG_NET_VENDOR_NI is not set
# CONFIG_ETHOC is not set
# CONFIG_NET_VENDOR_QUALCOMM is not set
# CONFIG_NET_VENDOR_RENESAS is not set
# CONFIG_NET_VENDOR_ROCKER is not set
# CONFIG_NET_VENDOR_SAMSUNG is not set
# CONFIG_NET_VENDOR_SEEQ is not set
# CONFIG_NET_VENDOR_SOLARFLARE is not set
# CONFIG_NET_VENDOR_SMSC is not set
# CONFIG_NET_VENDOR_SOCIONEXT is not set
# CONFIG_NET_VENDOR_STMICRO is not set
# CONFIG_NET_VENDOR_SYNOPSYS is not set
# CONFIG_NET_VENDOR_VIA is not set
# CONFIG_NET_VENDOR_WIZNET is not set
# CONFIG_NET_VENDOR_XILINX is not set
CONFIG_MDIO_DEVICE=m
CONFIG_MDIO_BUS=m
# CONFIG_MDIO_BCM_UNIMAC is not set
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_MSCC_MIIM is not set
CONFIG_MDIO_SUN4I=m
CONFIG_PHYLIB=m
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
# MII PHY device drivers
# CONFIG_AMD_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AX88796B_PHY is not set
# CONFIG_AT803X_PHY is not set
# CONFIG_BCM7XXX_PHY is not set
# CONFIG_BCM87XX_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_DP83822_PHY is not set
# CONFIG_DP83TC811_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
CONFIG_FIXED_PHY=m
# CONFIG_ICPLUS_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MICREL_PHY is not set
# CONFIG_MICROCHIP_PHY is not set
# CONFIG_MICROCHIP_T1_PHY is not set
# CONFIG_MICROSEMI_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_RENESAS_PHY is not set
# CONFIG_ROCKCHIP_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
CONFIG_USB_NET_DRIVERS=y
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_RTL8152 is not set
# CONFIG_USB_LAN78XX is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_IPHETH is not set
CONFIG_WLAN=y
# CONFIG_WLAN_VENDOR_ADMTEK is not set
# CONFIG_WLAN_VENDOR_ATH is not set
# CONFIG_WLAN_VENDOR_ATMEL is not set
# CONFIG_WLAN_VENDOR_BROADCOM is not set
# CONFIG_WLAN_VENDOR_CISCO is not set
# CONFIG_WLAN_VENDOR_INTEL is not set
# CONFIG_WLAN_VENDOR_INTERSIL is not set
# CONFIG_WLAN_VENDOR_MARVELL is not set
# CONFIG_WLAN_VENDOR_MEDIATEK is not set
# CONFIG_WLAN_VENDOR_RALINK is not set
# CONFIG_WLAN_VENDOR_REALTEK is not set
# CONFIG_WLAN_VENDOR_RSI is not set
# CONFIG_WLAN_VENDOR_ST is not set
# CONFIG_WLAN_VENDOR_TI is not set
# CONFIG_WLAN_VENDOR_ZYDAS is not set
# CONFIG_WLAN_VENDOR_QUANTENNA is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# CONFIG_VIRT_WIFI is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
CONFIG_WAN=y
# CONFIG_HDLC is not set
# CONFIG_DLCI is not set
# CONFIG_NETDEVSIM is not set
# CONFIG_NET_FAILOVER is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
CONFIG_INPUT_FF_MEMLESS=y
CONFIG_INPUT_POLLDEV=y
# CONFIG_INPUT_SPARSEKMAP is not set
# CONFIG_INPUT_MATRIXKMAP is not set
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=m
# CONFIG_INPUT_MOUSEDEV_PSAUX is not set
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_GPIO is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_SUN4I_LRADC=y
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
CONFIG_MOUSE_PS2_ALPS=y
CONFIG_MOUSE_PS2_BYD=y
CONFIG_MOUSE_PS2_LOGIPS2PP=y
CONFIG_MOUSE_PS2_SYNAPTICS=y
CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y
CONFIG_MOUSE_PS2_CYPRESS=y
CONFIG_MOUSE_PS2_TRACKPOINT=y
# CONFIG_MOUSE_PS2_ELANTECH is not set
# CONFIG_MOUSE_PS2_SENTELIC is not set
# CONFIG_MOUSE_PS2_TOUCHKIT is not set
CONFIG_MOUSE_PS2_FOCALTECH=y
CONFIG_MOUSE_PS2_SMBUS=y
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_APPLETOUCH is not set
# CONFIG_MOUSE_BCM5974 is not set
# CONFIG_MOUSE_CYAPA is not set
# CONFIG_MOUSE_ELAN_I2C is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_MOUSE_GPIO is not set
# CONFIG_MOUSE_SYNAPTICS_I2C is not set
# CONFIG_MOUSE_SYNAPTICS_USB is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
# CONFIG_TOUCHSCREEN_ADS7846 is not set
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
# CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_EXC3000 is not set
# CONFIG_TOUCHSCREEN_FUJITSU is not set
# CONFIG_TOUCHSCREEN_GOODIX is not set
# CONFIG_TOUCHSCREEN_HIDEEP is not set
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_S6SY761 is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
# CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
CONFIG_TOUCHSCREEN_NS2009=y
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
# CONFIG_TOUCHSCREEN_SUR40 is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
# CONFIG_TOUCHSCREEN_IQS5XX is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MSM_VIBRATOR is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
CONFIG_INPUT_AXP20X_PEK=y
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_PWM_VIBRA is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_SUN4I_PS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
# CONFIG_NULL_TTY is not set
CONFIG_LDISC_AUTOLOAD=y
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=8
CONFIG_SERIAL_8250_RUNTIME_UARTS=8
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_FSL=y
CONFIG_SERIAL_8250_DW=y
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# end of Character devices
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
# CONFIG_I2C_MUX_GPIO is not set
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
# CONFIG_I2C_MUX_PCA954x is not set
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
# end of Multiplexer I2C Chip support
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
CONFIG_I2C_MV64XXX=y
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BITBANG=y
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
# CONFIG_SPI_NXP_FLEXSPI is not set
CONFIG_SPI_GPIO=y
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
# CONFIG_SPI_SUN4I is not set
CONFIG_SPI_SUN6I=y
# CONFIG_SPI_MXIC is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
# CONFIG_SPI_SPIDEV is not set
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
# CONFIG_PPS is not set
# PTP clock support
# CONFIG_PTP_1588_CLOCK is not set
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AXP209 is not set
# CONFIG_PINCTRL_AMD is not set
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_OCELOT is not set
CONFIG_PINCTRL_SUNXI=y
CONFIG_PINCTRL_SUN4I_A10=y
# CONFIG_PINCTRL_SUN5I is not set
# CONFIG_PINCTRL_SUN6I_A31 is not set
# CONFIG_PINCTRL_SUN6I_A31_R is not set
CONFIG_PINCTRL_SUN8I_A23=y
CONFIG_PINCTRL_SUN8I_A33=y
CONFIG_PINCTRL_SUN8I_A83T=y
CONFIG_PINCTRL_SUN8I_A83T_R=y
CONFIG_PINCTRL_SUN8I_A23_R=y
CONFIG_PINCTRL_SUN8I_H3=y
CONFIG_PINCTRL_SUN8I_H3_R=y
CONFIG_PINCTRL_SUN8I_V3S=y
# CONFIG_PINCTRL_SUN9I_A80 is not set
# CONFIG_PINCTRL_SUN9I_A80_R is not set
# CONFIG_PINCTRL_SUN50I_A64 is not set
# CONFIG_PINCTRL_SUN50I_A64_R is not set
# CONFIG_PINCTRL_SUN50I_H5 is not set
# CONFIG_PINCTRL_SUN50I_H6 is not set
# CONFIG_PINCTRL_SUN50I_H6_R is not set
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
# CONFIG_HTC_EGPIO is not set
# end of MFD GPIO expanders
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# USB GPIO expanders
# end of USB GPIO expanders
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_W1 is not set
# CONFIG_POWER_AVS is not set
# CONFIG_POWER_RESET is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_UCS1002 is not set
# CONFIG_HWMON is not set
CONFIG_THERMAL=y
# CONFIG_THERMAL_STATISTICS is not set
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
CONFIG_CPU_THERMAL=y
# CONFIG_CLOCK_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_THERMAL_MMIO is not set
# CONFIG_QORIQ_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
# CONFIG_WATCHDOG_SYSFS is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_FTWDT010_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
CONFIG_SUNXI_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_IMX_SC_WDT is not set
# CONFIG_MEN_A21_WDT is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_SUN4I_GPADC is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AC100 is not set
CONFIG_MFD_AXP20X=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_AXP20X_RSB=y
# CONFIG_MFD_CROS_EC is not set
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SUN6I_PRCM=y
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
CONFIG_REGULATOR_AXP20X=y
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_SLG51000 is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
# CONFIG_RC_CORE is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
CONFIG_MEDIA_CAMERA_SUPPORT=y
# CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
# CONFIG_MEDIA_RADIO_SUPPORT is not set
# CONFIG_MEDIA_SDR_SUPPORT is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
CONFIG_MEDIA_CONTROLLER=y
# CONFIG_MEDIA_CONTROLLER_DVB is not set
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_VIDEO_V4L2=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_VIDEO_TUNER=m
CONFIG_V4L2_FWNODE=m
CONFIG_DVB_CORE=y
# CONFIG_DVB_MMAP is not set
CONFIG_DVB_NET=y
CONFIG_DVB_MAX_ADAPTERS=16
# CONFIG_DVB_DYNAMIC_MINORS is not set
# CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
# CONFIG_DVB_ULE_DEBUG is not set
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
# CONFIG_USB_M5602 is not set
# CONFIG_USB_STV06XX is not set
# CONFIG_USB_GL860 is not set
# CONFIG_USB_GSPCA_BENQ is not set
# CONFIG_USB_GSPCA_CONEX is not set
# CONFIG_USB_GSPCA_CPIA1 is not set
# CONFIG_USB_GSPCA_DTCS033 is not set
# CONFIG_USB_GSPCA_ETOMS is not set
# CONFIG_USB_GSPCA_FINEPIX is not set
# CONFIG_USB_GSPCA_JEILINJ is not set
# CONFIG_USB_GSPCA_JL2005BCD is not set
# CONFIG_USB_GSPCA_KINECT is not set
# CONFIG_USB_GSPCA_KONICA is not set
# CONFIG_USB_GSPCA_MARS is not set
# CONFIG_USB_GSPCA_MR97310A is not set
# CONFIG_USB_GSPCA_NW80X is not set
# CONFIG_USB_GSPCA_OV519 is not set
# CONFIG_USB_GSPCA_OV534 is not set
# CONFIG_USB_GSPCA_OV534_9 is not set
# CONFIG_USB_GSPCA_PAC207 is not set
# CONFIG_USB_GSPCA_PAC7302 is not set
# CONFIG_USB_GSPCA_PAC7311 is not set
# CONFIG_USB_GSPCA_SE401 is not set
# CONFIG_USB_GSPCA_SN9C2028 is not set
# CONFIG_USB_GSPCA_SN9C20X is not set
# CONFIG_USB_GSPCA_SONIXB is not set
# CONFIG_USB_GSPCA_SONIXJ is not set
# CONFIG_USB_GSPCA_SPCA500 is not set
# CONFIG_USB_GSPCA_SPCA501 is not set
# CONFIG_USB_GSPCA_SPCA505 is not set
# CONFIG_USB_GSPCA_SPCA506 is not set
# CONFIG_USB_GSPCA_SPCA508 is not set
# CONFIG_USB_GSPCA_SPCA561 is not set
# CONFIG_USB_GSPCA_SPCA1528 is not set
# CONFIG_USB_GSPCA_SQ905 is not set
# CONFIG_USB_GSPCA_SQ905C is not set
# CONFIG_USB_GSPCA_SQ930X is not set
# CONFIG_USB_GSPCA_STK014 is not set
# CONFIG_USB_GSPCA_STK1135 is not set
# CONFIG_USB_GSPCA_STV0680 is not set
# CONFIG_USB_GSPCA_SUNPLUS is not set
# CONFIG_USB_GSPCA_T613 is not set
# CONFIG_USB_GSPCA_TOPRO is not set
# CONFIG_USB_GSPCA_TOUPTEK is not set
# CONFIG_USB_GSPCA_TV8532 is not set
# CONFIG_USB_GSPCA_VC032X is not set
# CONFIG_USB_GSPCA_VICAM is not set
# CONFIG_USB_GSPCA_XIRLINK_CIT is not set
# CONFIG_USB_GSPCA_ZC3XX is not set
# CONFIG_USB_PWC is not set
# CONFIG_VIDEO_CPIA2 is not set
# CONFIG_USB_ZR364XX is not set
# CONFIG_USB_STKWEBCAM is not set
# CONFIG_USB_S2255 is not set
# CONFIG_VIDEO_USBTV is not set
# Analog/digital TV USB devices
# CONFIG_VIDEO_AU0828 is not set
# CONFIG_VIDEO_CX231XX is not set
# Digital TV USB devices
# CONFIG_DVB_USB_V2 is not set
# CONFIG_SMS_USB_DRV is not set
# CONFIG_DVB_B2C2_FLEXCOP_USB is not set
# CONFIG_DVB_AS102 is not set
# Webcam, TV (analog/digital) USB devices
CONFIG_VIDEO_EM28XX=m
CONFIG_VIDEO_EM28XX_V4L2=m
# CONFIG_VIDEO_EM28XX_ALSA is not set
# CONFIG_VIDEO_EM28XX_DVB is not set
CONFIG_V4L_PLATFORM_DRIVERS=y
# CONFIG_VIDEO_CADENCE is not set
# CONFIG_VIDEO_ASPEED is not set
CONFIG_VIDEO_MUX=m
# CONFIG_VIDEO_XILINX is not set
CONFIG_VIDEO_SUN6I_CSI=m
CONFIG_V4L_MEM2MEM_DRIVERS=y
# CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
# CONFIG_VIDEO_SH_VEU is not set
CONFIG_V4L_TEST_DRIVERS=y
# CONFIG_VIDEO_VIMC is not set
# CONFIG_VIDEO_VIVID is not set
# CONFIG_VIDEO_VIM2M is not set
# CONFIG_VIDEO_VICODEC is not set
# CONFIG_DVB_PLATFORM_DRIVERS is not set
# Supported MMC/SDIO adapters
# CONFIG_SMS_SDIO_DRV is not set
CONFIG_VIDEO_TVEEPROM=m
# CONFIG_CYPRESS_FIRMWARE is not set
CONFIG_VIDEOBUF2_CORE=m
CONFIG_VIDEOBUF2_V4L2=m
CONFIG_VIDEOBUF2_MEMOPS=m
CONFIG_VIDEOBUF2_DMA_CONTIG=m
CONFIG_VIDEOBUF2_VMALLOC=m
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
CONFIG_MEDIA_SUBDRV_AUTOSELECT=y
CONFIG_MEDIA_ATTACH=y
# Audio decoders, processors and mixers
CONFIG_VIDEO_MSP3400=m
# RDS decoders
# Video decoders
CONFIG_VIDEO_SAA711X=m
CONFIG_VIDEO_TVP5150=m
# Video and audio decoders
# Video encoders
# Camera sensor devices
CONFIG_VIDEO_OV2640=m
CONFIG_VIDEO_MT9V011=m
# Lens drivers
# Flash devices
# Video improvement chips
# Audio/Video compression chips
# SDR tuner chips
# Miscellaneous helper chips
# Media SPI Adapters
CONFIG_CXD2880_SPI_DRV=y
# end of Media SPI Adapters
CONFIG_MEDIA_TUNER=y
CONFIG_MEDIA_TUNER_SIMPLE=y
CONFIG_MEDIA_TUNER_TDA8290=y
CONFIG_MEDIA_TUNER_TDA827X=y
CONFIG_MEDIA_TUNER_TDA18271=y
CONFIG_MEDIA_TUNER_TDA9887=y
CONFIG_MEDIA_TUNER_MT20XX=y
CONFIG_MEDIA_TUNER_XC2028=y
CONFIG_MEDIA_TUNER_XC5000=y
CONFIG_MEDIA_TUNER_XC4000=y
CONFIG_MEDIA_TUNER_MC44S803=y
# Multistandard (satellite) frontends
# Multistandard (cable + terrestrial) frontends
# DVB-S (satellite) frontends
# DVB-T (terrestrial) frontends
# DVB-C (cable) frontends
# ATSC (North American/Korean Terrestrial/Cable DTV) frontends
# ISDB-T (terrestrial) frontends
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
# Digital terrestrial only tuners/PLL
# SEC control devices for DVB-S
# Common Interface (EN50221) controller drivers
# Tools to develop new frontends
# Graphics support
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=y
CONFIG_DRM_MIPI_DSI=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_MM is not set
# CONFIG_DRM_DEBUG_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# CONFIG_DRM_KOMEDA is not set
# end of ARM devices
# ACP (Audio CoProcessor) Configuration
# end of ACP (Audio CoProcessor) Configuration
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_EXYNOS is not set
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
CONFIG_DRM_SUN4I=y
CONFIG_DRM_SUN4I_HDMI=y
# CONFIG_DRM_SUN4I_HDMI_CEC is not set
CONFIG_DRM_SUN4I_BACKEND=y
CONFIG_DRM_SUN6I_DSI=y
# CONFIG_DRM_SUN8I_DW_HDMI is not set
CONFIG_DRM_SUN8I_MIXER=y
CONFIG_DRM_SUN8I_TCON_TOP=y
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=y
# CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
# CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
# CONFIG_DRM_PANEL_ROCKTECH_JH057N00900 is not set
# CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
# CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
# CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_CDNS_DSI is not set
CONFIG_DRM_DUMB_VGA_DAC=y
# CONFIG_DRM_LVDS_ENCODER is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_SII9234 is not set
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_TI_SN65DSI86 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# end of Display Interface Bridges
# CONFIG_DRM_STI is not set
# CONFIG_DRM_ETNAVIV is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
# CONFIG_DRM_TINYDRM is not set
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_LIMA is not set
# CONFIG_DRM_PANFROST is not set
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_BACKLIGHT=y
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
CONFIG_FB_SIMPLE=y
CONFIG_FB_SSD1307=y
# end of Frame buffer Devices
# Backlight & LCD device support
CONFIG_LCD_CLASS_DEVICE=m
# CONFIG_LCD_L4F00242T03 is not set
# CONFIG_LCD_LMS283GF05 is not set
# CONFIG_LCD_LTV350QV is not set
# CONFIG_LCD_ILI922X is not set
# CONFIG_LCD_ILI9320 is not set
# CONFIG_LCD_TDO24M is not set
# CONFIG_LCD_VGG2432A4 is not set
# CONFIG_LCD_PLATFORM is not set
# CONFIG_LCD_AMS369FG06 is not set
# CONFIG_LCD_LMS501KF03 is not set
# CONFIG_LCD_HX8357 is not set
# CONFIG_LCD_OTM3225A is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_BACKLIGHT_GENERIC=y
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_PM8941_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
# end of Console display driver support
# CONFIG_LOGO is not set
# end of Graphics support
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
# CONFIG_SND_OSSEMUL is not set
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_SEQUENCER is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_ALOOP is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# HD-Audio
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_AUDMIX is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_FSL_MICFIL is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# Allwinner SoC Audio support
CONFIG_SND_SUN4I_CODEC=y
# CONFIG_SND_SUN8I_CODEC is not set
CONFIG_SND_SUN8I_CODEC_ANALOG=y
# CONFIG_SND_SUN4I_I2S is not set
# CONFIG_SND_SUN4I_SPDIF is not set
CONFIG_SND_SUN8I_ADDA_PR_REGMAP=y
# end of Allwinner SoC Audio support
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
# CONFIG_SND_SOC_ADAU7002 is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4118 is not set
# CONFIG_SND_SOC_AK4458 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
# CONFIG_SND_SOC_DMIC is not set
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
# CONFIG_SND_SOC_MAX98357A is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM186X_I2C is not set
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
# CONFIG_SND_SOC_SPDIF is not set
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
# CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8904 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8822 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
# end of CODEC drivers
# CONFIG_SND_SIMPLE_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=y
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
CONFIG_HID_APPLE=y
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_ASUS is not set
# CONFIG_HID_AUREAL is not set
CONFIG_HID_BELKIN=y
# CONFIG_HID_BETOP_FF is not set
# CONFIG_HID_BIGBEN_FF is not set
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_MACALLY is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
CONFIG_HID_CYPRESS=y
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELAN is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
CONFIG_HID_EZKEY=y
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_GT683R is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_VIEWSONIC is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
CONFIG_HID_ITE=y
# CONFIG_HID_JABRA is not set
# CONFIG_HID_TWINHAN is not set
CONFIG_HID_KENSINGTON=y
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LED is not set
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=y
# CONFIG_HID_LOGITECH_HIDPP is not set
# CONFIG_LOGITECH_FF is not set
# CONFIG_LOGIRUMBLEPAD2_FF is not set
# CONFIG_LOGIG940_FF is not set
# CONFIG_LOGIWHEELS_FF is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MALTRON is not set
# CONFIG_HID_MAYFLASH is not set
CONFIG_HID_REDRAGON=y
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THINGM is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# end of Special HID drivers
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# end of USB HID support
# I2C HID support
# CONFIG_I2C_HID is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
CONFIG_USB_OTG_FSM=m
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
CONFIG_USB_AUTOSUSPEND_DELAY=2
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_EHCI_HCD_PLATFORM=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
CONFIG_USB_WDM=m
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_REALTEK is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_STORAGE_ENE_UB6250 is not set
# CONFIG_USB_UAS is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
CONFIG_USB_MUSB_HDRC=y
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
CONFIG_USB_MUSB_DUAL_ROLE=y
# Platform Glue Layer
CONFIG_USB_MUSB_SUNXI=y
# MUSB DMA mode
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_SIMPLE=m
# CONFIG_USB_SERIAL_AIRCABLE is not set
# CONFIG_USB_SERIAL_ARK3116 is not set
# CONFIG_USB_SERIAL_BELKIN is not set
# CONFIG_USB_SERIAL_CH341 is not set
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
CONFIG_USB_SERIAL_CP210X=m
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
# CONFIG_USB_SERIAL_FTDI_SIO is not set
# CONFIG_USB_SERIAL_VISOR is not set
# CONFIG_USB_SERIAL_IPAQ is not set
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_F81232 is not set
# CONFIG_USB_SERIAL_F8153X is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_IUU is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_METRO is not set
# CONFIG_USB_SERIAL_MOS7720 is not set
# CONFIG_USB_SERIAL_MOS7840 is not set
# CONFIG_USB_SERIAL_MXUPORT is not set
# CONFIG_USB_SERIAL_NAVMAN is not set
# CONFIG_USB_SERIAL_PL2303 is not set
# CONFIG_USB_SERIAL_OTI6858 is not set
# CONFIG_USB_SERIAL_QCAUX is not set
# CONFIG_USB_SERIAL_QUALCOMM is not set
# CONFIG_USB_SERIAL_SPCP8X5 is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
# CONFIG_USB_SERIAL_SYMBOL is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
# CONFIG_USB_SERIAL_XIRCOM is not set
# CONFIG_USB_SERIAL_OPTION is not set
# CONFIG_USB_SERIAL_OMNINET is not set
# CONFIG_USB_SERIAL_OPTICON is not set
# CONFIG_USB_SERIAL_XSENS_MT is not set
# CONFIG_USB_SERIAL_WISHBONE is not set
# CONFIG_USB_SERIAL_SSU100 is not set
# CONFIG_USB_SERIAL_QT2 is not set
# CONFIG_USB_SERIAL_UPD78F0730 is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
# CONFIG_AM335X_PHY_USB is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
# end of USB Physical Layer drivers
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# USB Peripheral Controller
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_DUMMY_HCD is not set
# end of USB Peripheral Controller
# CONFIG_USB_CONFIGFS is not set
# CONFIG_TYPEC is not set
# CONFIG_USB_ROLE_SWITCH is not set
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_UWB is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_SUNXI=y
# CONFIG_MMC_CQHCI is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_AN30259A is not set
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_CR0014114 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3532 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_LM3692X is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_MLXREG is not set
# CONFIG_LEDS_USER is not set
# CONFIG_LEDS_SPI_BYTE is not set
# CONFIG_LEDS_TI_LMU_COMMON is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
# CONFIG_LEDS_TRIGGER_TIMER is not set
# CONFIG_LEDS_TRIGGER_ONESHOT is not set
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
# CONFIG_LEDS_TRIGGER_CPU is not set
# CONFIG_LEDS_TRIGGER_ACTIVITY is not set
# CONFIG_LEDS_TRIGGER_GPIO is not set
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_LEDS_TRIGGER_TRANSIENT is not set
# CONFIG_LEDS_TRIGGER_CAMERA is not set
# CONFIG_LEDS_TRIGGER_PANIC is not set
# CONFIG_LEDS_TRIGGER_NETDEV is not set
# CONFIG_LEDS_TRIGGER_PATTERN is not set
# CONFIG_LEDS_TRIGGER_AUDIO is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
# CONFIG_RTC_INTF_SYSFS is not set
# CONFIG_RTC_INTF_PROC is not set
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
# CONFIG_RTC_DRV_ABX80X is not set
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_ISL12026 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF85363 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV3028 is not set
# CONFIG_RTC_DRV_RV8803 is not set
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1302 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6916 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_RX6110 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_SUN6I=y
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_SNVS is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
CONFIG_DMA_SUN6I=y
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_FSL_QDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# end of DMABUF options
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_VIRT_DRIVERS is not set
# CONFIG_VIRTIO_MENU is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
CONFIG_STAGING=y
# CONFIG_PRISM2_USB is not set
# CONFIG_COMEDI is not set
# CONFIG_RTLLIB is not set
CONFIG_RTL8723BS=m
# CONFIG_R8712U is not set
# CONFIG_R8188EU is not set
# CONFIG_VT6656 is not set
# Speakup console speech
# CONFIG_SPEAKUP is not set
# end of Speakup console speech
# CONFIG_STAGING_MEDIA is not set
# Android
# end of Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_UNISYSSPAR is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
# CONFIG_FB_TFT is not set
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
# CONFIG_MOST is not set
# CONFIG_KS7010 is not set
# CONFIG_GREYBUS is not set
# CONFIG_PI433 is not set
# Gasket devices
# end of Gasket devices
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_EROFS_FS is not set
# CONFIG_FIELDBUS_DEV is not set
# CONFIG_GOLDFISH is not set
# CONFIG_CHROME_PLATFORMS is not set
# CONFIG_MELLANOX_PLATFORM is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_CLK_SUNXI=y
CONFIG_CLK_SUNXI_CLOCKS=y
CONFIG_CLK_SUNXI_PRCM_SUN6I=y
CONFIG_CLK_SUNXI_PRCM_SUN8I=y
CONFIG_CLK_SUNXI_PRCM_SUN9I=y
CONFIG_SUNXI_CCU=y
# CONFIG_SUN8I_A23_CCU is not set
# CONFIG_SUN8I_A33_CCU is not set
CONFIG_SUN8I_A83T_CCU=y
# CONFIG_SUN8I_H3_CCU is not set
CONFIG_SUN8I_V3S_CCU=y
CONFIG_SUN8I_DE2_CCU=y
CONFIG_SUN8I_R40_CCU=y
CONFIG_SUN8I_R_CCU=y
# end of Common Clock Framework
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_SUN4I_TIMER=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
# end of Clock Source drivers
# CONFIG_MAILBOX is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# end of Remoteproc drivers
# Rpmsg drivers
# CONFIG_RPMSG_VIRTIO is not set
# end of Rpmsg drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Aspeed SoC drivers
# end of Aspeed SoC drivers
# Broadcom SoC drivers
# CONFIG_SOC_BRCMSTB is not set
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# IXP4xx SoC drivers
# CONFIG_IXP4XX_QMGR is not set
# CONFIG_IXP4XX_NPE is not set
# end of IXP4xx SoC drivers
# Qualcomm SoC drivers
# end of Qualcomm SoC drivers
CONFIG_SUNXI_SRAM=y
# CONFIG_SOC_TI is not set
# Xilinx SoC drivers
# CONFIG_XILINX_VCU is not set
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
# CONFIG_PM_DEVFREQ is not set
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_FSA9480 is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_PTN5150 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_MEMORY is not set
# CONFIG_IIO is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_SUN4I=y
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
# CONFIG_AL_FIC is not set
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_ARCH_HAS_RESET_CONTROLLER=y
CONFIG_RESET_CONTROLLER=y
CONFIG_RESET_SIMPLE=y
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_TI_SYSCON is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_GENERIC_PHY_MIPI_DPHY=y
CONFIG_PHY_SUN4I_USB=y
CONFIG_PHY_SUN6I_MIPI_DPHY=y
# CONFIG_PHY_SUN9I_USB is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_DP is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
# CONFIG_ARM_CCI_PMU is not set
# CONFIG_ARM_CCN is not set
CONFIG_ARM_PMU=y
# end of Performance monitor support
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
# end of Android
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
CONFIG_NVMEM_SUNXI_SID=y
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
# CONFIG_TEE is not set
CONFIG_MULTIPLEXER=m
# Multiplexer drivers
# CONFIG_MUX_ADG792A is not set
# CONFIG_MUX_ADGS1408 is not set
# CONFIG_MUX_GPIO is not set
# CONFIG_MUX_MMIO is not set
# end of Multiplexer drivers
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# CONFIG_INTERCONNECT is not set
# CONFIG_COUNTER is not set
# end of Device Drivers
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
# CONFIG_EXT4_FS_POSIX_ACL is not set
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_AUTOFS_FS is not set
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# end of Caches
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# end of CD-ROM/DVD Filesystems
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
# CONFIG_MSDOS_FS is not set
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_FAT_DEFAULT_UTF8 is not set
# CONFIG_NTFS_FS is not set
# end of DOS/FAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_TMPFS_XATTR is not set
CONFIG_MEMFD_CREATE=y
CONFIG_CONFIGFS_FS=y
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
# CONFIG_NFS_FS is not set
# CONFIG_NFSD is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
# CONFIG_NLS_UTF8 is not set
# CONFIG_DLM is not set
# CONFIG_UNICODE is not set
# end of File systems
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_REQUEST_CACHE is not set
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_FORTIFY_SOURCE is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="yama,loadpin,safesetid,integrity"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_PCRYPT is not set
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Public-key cryptography
CONFIG_CRYPTO_RSA=y
# CONFIG_CRYPTO_DH is not set
# CONFIG_CRYPTO_ECDH is not set
# CONFIG_CRYPTO_ECRDSA is not set
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=y
CONFIG_CRYPTO_GCM=y
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
# CONFIG_CRYPTO_AEGIS128 is not set
# CONFIG_CRYPTO_AEGIS128L is not set
# CONFIG_CRYPTO_AEGIS256 is not set
# CONFIG_CRYPTO_MORUS640 is not set
# CONFIG_CRYPTO_MORUS1280 is not set
CONFIG_CRYPTO_SEQIV=y
# CONFIG_CRYPTO_ECHAINIV is not set
# Block modes
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_CFB is not set
CONFIG_CRYPTO_CTR=y
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_OFB is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_ADIANTUM is not set
# Hash modes
CONFIG_CRYPTO_CMAC=y
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
# CONFIG_CRYPTO_XXHASH is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
CONFIG_CRYPTO_GHASH=y
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_STREEBOG is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_LIB_ARC4=m
# CONFIG_CRYPTO_ARC4 is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_SM4 is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_LZO is not set
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
# CONFIG_CRYPTO_ZSTD is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
CONFIG_CRYPTO_DEV_SUN4I_SS=y
# CONFIG_CRYPTO_DEV_SUN4I_SS_PRNG is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
# CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
# CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
# Library routines
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
# CONFIG_CORDIC is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC64 is not set
# CONFIG_CRC4 is not set
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
# CONFIG_CRC8 is not set
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
CONFIG_DMA_REMAP=y
# CONFIG_DMA_API_DEBUG is not set
CONFIG_SGL_ALLOC=y
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_NLATTR=y
CONFIG_CLZ_TAB=y
# CONFIG_DDR is not set
# CONFIG_IRQ_POLL is not set
CONFIG_MPILIB=y
CONFIG_DIMLIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# end of Library routines
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
# end of printk and dmesg options
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_UNUSED_SYMBOLS is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_INSTALL is not set
# CONFIG_OPTIMIZE_INLINING is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_DEBUG_PER_CPU_MAPS is not set
# CONFIG_DEBUG_HIGHMEM is not set
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_KASAN_STACK=1
# end of Memory Debugging
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
# CONFIG_DEBUG_SHIRQ is not set
# Debug Lockups and Hangs
# CONFIG_SOFTLOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_WQ_WATCHDOG is not set
# end of Debug Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_SCHED_DEBUG=y
# CONFIG_SCHEDSTATS is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_STACKTRACE is not set
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=21
CONFIG_RCU_TRACE=y
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
CONFIG_RUNTIME_TESTING_MENU=y
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_SORT is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_REED_SOLOMON_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_STRSCPY is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_BITFIELD is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_XARRAY is not set
# CONFIG_TEST_OVERFLOW is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_IDA is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_VMALLOC is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_BLACKHOLE_DEV is not set
# CONFIG_FIND_BIT_BENCHMARK is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_TEST_MEMCAT_P is not set
# CONFIG_TEST_STACKINIT is not set
# CONFIG_MEMTEST is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_UBSAN is not set
CONFIG_UBSAN_ALIGNMENT=y
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
# CONFIG_ARM_PTDUMP_DEBUGFS is not set
# CONFIG_DEBUG_WX is not set
# CONFIG_UNWINDER_FRAME_POINTER is not set
CONFIG_UNWINDER_ARM=y
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
# end of Kernel hacking
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
#include "sun8i-v3s-licheepi-zero.dts"
	model = "Lichee Pi Zero with Dock";
	compatible = "licheepi,licheepi-zero-dock", "licheepi,licheepi-zero",
		     "allwinner,sun8i-v3s";
	aliases {
		ethernet0 = &emac;
	leds {
		/* The LEDs use PG0~2 pins, which conflict with MMC1 */
		status = "disabled";
&codec {
	allwinner,audio-routing =
		"Headphone", "HP",
		"Headphone", "HPCOM",
		"MIC1", "Mic",
		"Mic",  "HBIAS";
&emac {
	phy-handle = <&int_mii_phy>;
	phy-mode = "mii";
	allwinner,leds-active-low;
&mmc1 {
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
&lradc {
	vref-supply = <&reg_vcc3v0>;
	button-200 {
		label = "Volume Up";
		linux,code = <KEY_VOLUMEUP>;
		channel = <0>;
		voltage = <200000>;
	button-400 {
		label = "Volume Down";
		linux,code = <KEY_VOLUMEDOWN>;
		channel = <0>;
		voltage = <400000>;
	button-600 {
		label = "Select";
		linux,code = <KEY_SELECT>;
		channel = <0>;
		voltage = <600000>;
	button-800 {
		label = "Start";
		linux,code = <KEY_OK>;
		channel = <0>;
		voltage = <800000>;
&i2c0 {
	gt911: touchscreen@14 {
        compatible = "goodix,gt911";
        reg = <0x5d>;
        interrupt-parent = <&pio>;
        interrupts = <1 5 IRQ_TYPE_EDGE_FALLING>; /* (PB5) */
        pinctrl-names = "default";
        irq-gpios = <&pio 1 5 GPIO_ACTIVE_HIGH>; /* (PB5) */
        reset-gpios = <&pio 2 1 GPIO_ACTIVE_HIGH>; /* RST (PC1) */
        /* touchscreen-swapped-x-y */
 * whole.
 *     conditions:
	aliases {
		ethernet0 = &emac;
	leds {
&codec {
		"Headphone", "HP",
		"MIC1", "Mic",
		"Mic",  "HBIAS";
&emac {
	phy-mode = "mii";
&mmc1 {
	broken-cd;
	bus-width = <4>;
&lradc {
	button-200 {
		channel = <0>;
		voltage = <200000>;
	button-400 {
		channel = <0>;
		voltage = <400000>;
	button-600 {
		label = "Select";
		channel = <0>;
		voltage = <600000>;
	button-800 {
		label = "Start";
		channel = <0>;
		voltage = <800000>;
&i2c0 {
        reg = <0x5d>;
楼主 #1 2021-12-05 21:03:58
mysteryli
已发帖子: 493
Re: V3S没有出现eth0网卡
解决了 内核编译的menuconfig里搜索sun8i就找到了和网卡有关的驱动模块没打开
#2 2024-04-03 21:25:11
sxlyq_666
已发帖子: 76
Re: V3S没有出现eth0网卡
mysteryli 说:
哥们,能说的再详细点吗?
