楼主 #1 2018-09-15 14:56:37
john78
已发帖子: 222
有没有“”设备树, Linux“”配置说明
[    0.155184] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
[    0.752102] console [ttyS0] enabled
[    0.756960] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE0
[    0.764627] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE1
[    0.772346] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE2
[    0.780022] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE3
[    0.787685] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE4
[    0.795334] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE5
[    0.802994] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE6
[    0.810654] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE7
[    0.818313] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE8
[    0.825962] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE9
[    0.833622] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE10
[    0.841369] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE11
[    0.849115] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE12
[    0.856861] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE13
[    0.864597] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE14
[    0.872343] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE15
[    0.880090] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE16
[    0.887836] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE17
[    0.895571] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE18
[    0.903317] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE19
[    0.911064] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE23
[    0.918811] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE24
[    0.928098] panel-simple panel: panel supply power not found, using dummy regulator
[    0.938322] m25p80 spi32766.0: w25q128 (16384 Kbytes)
不知道怎么修改.
#2 2018-09-15 15:24:08
路人甲
已发帖子: 202
Re: 有没有“”设备树, Linux“”配置说明
看起来是V3s吧,
版本是多少,有没有改过设备树?
现在显示屏没有显示?
#3 2018-09-15 15:42:06
已发帖子: 9,417
你试一试改过 sun8i-v3s.dtsi 文件 里面的:
pio: pinctrl@01c20800 {
            compatible = "allwinner,sun8i-v3s-pinctrl";
            reg = <0x01c20800 0x400>;
            interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
                     <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
            gpio-controller;
            #gpio-cells = <3>;
            interrupt-controller;
            #interrupt-cells = <3>;
#4 2019-12-16 22:57:52
nuvoton
已发帖子: 59
[    0.737656] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE0
[    0.745355] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE1
[    0.753111] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE2
[    0.760807] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE3
[    0.768498] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE4
[    0.776183] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE5
[    0.783852] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE6
[    0.791534] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE7
[    0.799216] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE8
[    0.806898] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE9
[    0.814567] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE10
[    0.822335] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE11
[    0.830104] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE12
[    0.837873] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE13
[    0.845630] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE14
[    0.853397] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE15
[    0.861166] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE16
[    0.868935] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE17
[    0.876703] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE18
[    0.884460] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE19
[    0.892229] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE23
[    0.899999] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE24
[    0.909232] panel-simple panel: panel supply power not found, using dummy regulator
[    0.918433] libphy: Fixed MDIO Bus: probed
[    0.922919] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.929548] ehci-platform: EHCI generic platform driver
[    0.935056] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.940750] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.948708] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.976198] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.983421] hub 1-0:1.0: USB hub found
[    0.987387] hub 1-0:1.0: 1 port detected
[    0.991932] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.998268] ohci-platform: OHCI generic platform driver
[    1.003831] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.010578] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.018569] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.091257] hub 2-0:1.0: USB hub found
[    1.095106] hub 2-0:1.0: 1 port detected
[    1.102667] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.112464] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.119389] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.123952] i2c /dev entries driver
[    1.129356] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.196198] sunxi-mmc 1c0f000.mmc: base:0xc4069000 irq:24
[    1.203269] usbcore: registered new interface driver usbhid
[    1.208972] usbhid: USB HID core driver
[    1.215210] NET: Registered protocol family 17
[    1.219929] Key type dns_resolver registered
[    1.224233] Registering SWP/SWPB emulation handler
[    1.234652] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4380000
[    1.245394] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    1.263856] Console: switching to colour frame buffer device 100x30
[    1.279863] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    1.291578] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    1.304838] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE0
[    1.316442] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE1
[    1.327813] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE2
[    1.339070] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE3
[    1.350214] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE4
[    1.361301] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE5
[    1.372247] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE6
[    1.383077] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE7
[    1.393803] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE8
[    1.404508] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE9
[    1.415093] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE10
[    1.425638] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE11
[    1.436055] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE12
[    1.446410] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE13
[    1.456706] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE14
[    1.466890] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE15
[    1.476926] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE16
[    1.486853] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE17
[    1.496688] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE18
[    1.506444] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE19
[    1.516136] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE23
[    1.525751] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE24
[    1.535739] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.544309] [drm] No driver support for vblank timestamp query.
[    1.561466] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc073ed78)
[    1.570649] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073dbf8)
[    1.580115] fb: switching to sun4i-drm-fb from simple
[    1.586955] Console: switching to colour dummy device 80x30
奇怪, 我的也出现这个问题了.
#5 2019-12-16 23:11:43
nuvoton
已发帖子: 59
大概知道了,
这里并没有注册PE引脚
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/drivers/pinctrl/sunxi/pinctrl-sun8i-v3s.c
 * Allwinner V3s SoCs pinctrl driver.
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * Based on pinctrl-sun8i-h3.c, which is:
 * Copyright (C) 2015 Jens Kuske <jenskuske@gmail.com>
 * Based on pinctrl-sun8i-a23.c, which is:
 * Copyright (C) 2014 Chen-Yu Tsai <wens@csie.org>
 * Copyright (C) 2014 Maxime Ripard <maxime.ripard@free-electrons.com>
 * This file is licensed under the terms of the GNU General Public
 * License version 2.  This program is licensed "as is" without any
 * warranty of any kind, whether express or implied.
#include <linux/module.h>
#include <linux/platform_device.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/pinctrl/pinctrl.h>
#include "pinctrl-sunxi.h"
static const struct sunxi_desc_pin sun8i_v3s_pins[] = {
	/* Hole */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 0),
		  SUNXI_FUNCTION(0x0, "gpio_in"),
		  SUNXI_FUNCTION(0x1, "gpio_out"),
		  SUNXI_FUNCTION(0x2, "uart2"),		/* TX */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 0)),	/* PB_EINT0 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 1),
		  SUNXI_FUNCTION(0x2, "uart2"),		/* RX */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 1)),	/* PB_EINT1 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 2),
		  SUNXI_FUNCTION(0x2, "uart2"),		/* RTS */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 2)),	/* PB_EINT2 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 3),
		  SUNXI_FUNCTION(0x2, "uart2"),		/* D1 */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 3)),	/* PB_EINT3 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 4),
		  SUNXI_FUNCTION(0x2, "pwm0"),
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 4)),	/* PB_EINT4 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 5),
		  SUNXI_FUNCTION(0x2, "pwm1"),
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 5)),	/* PB_EINT5 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 6),
		  SUNXI_FUNCTION(0x2, "i2c0"),		/* SCK */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 6)),	/* PB_EINT6 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 7),
		  SUNXI_FUNCTION(0x2, "i2c0"),		/* SDA */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 7)),	/* PB_EINT7 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 8),
		  SUNXI_FUNCTION(0x2, "i2c1"),		/* SDA */
		  SUNXI_FUNCTION(0x3, "uart0"),		/* TX */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 8)),	/* PB_EINT8 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 9),
		  SUNXI_FUNCTION(0x2, "i2c1"),		/* SCK */
		  SUNXI_FUNCTION(0x3, "uart0"),		/* RX */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 9)),	/* PB_EINT9 */
	/* Hole */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(C, 0),
		  SUNXI_FUNCTION(0x2, "mmc2"),		/* CLK */
		  SUNXI_FUNCTION(0x3, "spi0")),		/* MISO */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(C, 1),
		  SUNXI_FUNCTION(0x2, "mmc2"),		/* CMD */
		  SUNXI_FUNCTION(0x3, "spi0")),		/* CLK */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(C, 2),
		  SUNXI_FUNCTION(0x2, "mmc2"),		/* RST */
		  SUNXI_FUNCTION(0x3, "spi0")),		/* CS */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(C, 3),
		  SUNXI_FUNCTION(0x2, "mmc2"),		/* D0 */
		  SUNXI_FUNCTION(0x3, "spi0")),		/* MOSI */
	/* Hole */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 0),
		  SUNXI_FUNCTION(0x2, "csi"),		/* PCLK */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* CLK */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 1),
		  SUNXI_FUNCTION(0x2, "csi"),		/* MCLK */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* DE */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 2),
		  SUNXI_FUNCTION(0x2, "csi"),		/* HSYNC */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* HSYNC */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 3),
		  SUNXI_FUNCTION(0x2, "csi"),		/* VSYNC */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* VSYNC */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 4),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D0 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D2 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 5),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D1 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D3 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 6),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D2 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D4 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 7),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D3 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D5 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 8),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D4 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D6 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 9),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D5 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D7 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 10),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D6 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D10 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 11),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D7 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D11 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 12),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D8 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D12 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 13),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D9 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D13 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 14),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D10 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D14 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 15),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D11 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D15 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 16),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D12 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D18 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 17),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D13 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D19 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 18),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D14 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D20 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 19),
		  SUNXI_FUNCTION(0x2, "csi"),		/* D15 */
		  SUNXI_FUNCTION(0x3, "lcd")),		/* D21 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 20),
		  SUNXI_FUNCTION(0x2, "csi"),		/* FIELD */
		  SUNXI_FUNCTION(0x3, "csi_mipi")),	/* MCLK */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 21),
		  SUNXI_FUNCTION(0x2, "csi"),		/* SCK */
		  SUNXI_FUNCTION(0x3, "i2c1"),		/* SCK */
		  SUNXI_FUNCTION(0x4, "uart1")),	/* TX */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 22),
		  SUNXI_FUNCTION(0x2, "csi"),		/* SDA */
		  SUNXI_FUNCTION(0x3, "i2c1"),		/* SDA */
		  SUNXI_FUNCTION(0x4, "uart1")),	/* RX */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 23),
		  SUNXI_FUNCTION(0x3, "lcd"),		/* D22 */
		  SUNXI_FUNCTION(0x4, "uart1")),	/* RTS */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(E, 24),
		  SUNXI_FUNCTION(0x3, "lcd"),		/* D23 */
		  SUNXI_FUNCTION(0x4, "uart1")),	/* CTS */
	/* Hole */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(F, 0),
		  SUNXI_FUNCTION(0x2, "mmc0"),		/* D1 */
		  SUNXI_FUNCTION(0x3, "jtag")),		/* MS */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(F, 1),
		  SUNXI_FUNCTION(0x2, "mmc0"),		/* D0 */
		  SUNXI_FUNCTION(0x3, "jtag")),		/* DI */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(F, 2),
		  SUNXI_FUNCTION(0x2, "mmc0"),		/* CLK */
		  SUNXI_FUNCTION(0x3, "uart0")),	/* TX */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(F, 3),
		  SUNXI_FUNCTION(0x2, "mmc0"),		/* CMD */
		  SUNXI_FUNCTION(0x3, "jtag")),		/* DO */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(F, 4),
		  SUNXI_FUNCTION(0x2, "mmc0"),		/* D3 */
		  SUNXI_FUNCTION(0x3, "uart0")),	/* RX */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(F, 5),
		  SUNXI_FUNCTION(0x2, "mmc0"),		/* D2 */
		  SUNXI_FUNCTION(0x3, "jtag")),		/* CK */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(F, 6),
		  SUNXI_FUNCTION(0x1, "gpio_out")),
	/* Hole */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(G, 0),
		  SUNXI_FUNCTION(0x2, "mmc1"),		/* CLK */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 1, 0)),	/* PG_EINT0 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(G, 1),
		  SUNXI_FUNCTION(0x2, "mmc1"),		/* CMD */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 1, 1)),	/* PG_EINT1 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(G, 2),
		  SUNXI_FUNCTION(0x2, "mmc1"),		/* D0 */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 1, 2)),	/* PG_EINT2 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(G, 3),
		  SUNXI_FUNCTION(0x2, "mmc1"),		/* D1 */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 1, 3)),	/* PG_EINT3 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(G, 4),
		  SUNXI_FUNCTION(0x2, "mmc1"),		/* D2 */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 1, 4)),	/* PG_EINT4 */
	SUNXI_PIN(SUNXI_PINCTRL_PIN(G, 5),
		  SUNXI_FUNCTION(0x2, "mmc1"),		/* D3 */
		  SUNXI_FUNCTION_IRQ_BANK(0x6, 1, 5)),	/* PG_EINT5 */
static const struct sunxi_pinctrl_desc sun8i_v3s_pinctrl_data = {
	.pins = sun8i_v3s_pins,
	.npins = ARRAY_SIZE(sun8i_v3s_pins),
	.irq_banks = 2,
	.irq_bank_base = 1,
	.irq_read_needs_mux = true
static int sun8i_v3s_pinctrl_probe(struct platform_device *pdev)
	return sunxi_pinctrl_init(pdev,
				  &sun8i_v3s_pinctrl_data);
static const struct of_device_id sun8i_v3s_pinctrl_match[] = {
	{ .compatible = "allwinner,sun8i-v3s-pinctrl", },
static struct platform_driver sun8i_v3s_pinctrl_driver = {
	.probe	= sun8i_v3s_pinctrl_probe,
	.driver	= {
		.name		= "sun8i-v3s-pinctrl",
		.of_match_table	= sun8i_v3s_pinctrl_match,
builtin_platform_driver(sun8i_v3s_pinctrl_driver);
而我用的是这个dts:
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/arch/arm/boot/dts/sun8i-v3s-licheepi-zero-with-800x480-lcd.dts
然后我改用这个dts:
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/arch/arm/boot/dts/sun8i-v3s-licheepi-zero-dock.dts
就可以了,
估计是这个:
&panel {
	compatible = "urt,umsh-8596md-t", "simple-panel";
会去初始化panel那组引脚,而没有找到定义.
#6 2019-12-29 19:27:43
泽被苍生
已发帖子: 24
我也遇到这个问题了,我用的是sun8i-v3s-licheepi-zero-with-480x272-lcd.dtb这个设备树
  0.150884] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
[    0.738525] console [ttyS0] enabled
[    0.743241] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE0
[    0.750993] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE1
[    0.758669] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE2
[    0.766333] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE3
[    0.773981] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE4
[    0.781641] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE5
[    0.789303] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE6
[    0.796962] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE7
[    0.804609] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE8
[    0.812269] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE9
[    0.819929] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE10
[    0.827677] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE11
[    0.835422] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE12
[    0.843158] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE13
[    0.850904] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE14
[    0.858651] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE15
[    0.866397] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE16
[    0.874132] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE17
[    0.881879] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE18
[    0.889625] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE19
[    0.897372] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE23
[    0.905108] sun8i-v3s-pinctrl 1c20800.pinctrl: unsupported function lcd0 on pin PE24
[    0.914351] panel-simple panel: panel supply power not found, using dummy regulator
#7 2019-12-29 19:29:44
泽被苍生
已发帖子: 24
我用的480*272的屏幕,应该理论上uboot更换一下,设备树更换一下就可以了吧?
#8 2021-11-26 14:29:47
chenzh
已发帖子: 28
@john78
原因是pinctrl驱动中对pe引脚定义的lcd功能名称和设备树中的不一致导致的,只需要将设备树做如下修改就好了
			lcd_rgb666_pins_a: lcd-rgb666-pe {
				pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5",
				       "PE6", "PE7", "PE8", "PE9", "PE10", "PE11",
				       "PE12", "PE13", "PE14", "PE15", "PE16", "PE17",
				       "PE18", "PE19", "PE23", "PE24";
				function = "lcd";   /*licheepi 4.13y版本的设备树此处为function = "lcd0", 但是驱动中是 "lcd"*/
即:function = "lcd0"; -> function = "lcd";
最近编辑记录 chenzh (2021-11-26 14:30:13)
#9 2021-12-12 15:43:22
how0723
已发帖子: 65
@chenzh
按这个方法还是没有解决
#10 2021-12-12 15:43:54
how0723
已发帖子: 65
@nuvoton
如果使用sun8i-v3s-licheepi-zero-dock.dts,就完全不能驱动屏幕
