用这个大佬的openwrt SDK
https://github.com/zhangjinke/openwrt.git
https://whycan.com/t_6980.html
我想启用USB功能,发现 启动内核出现这个错误,请问是我那个部分没有弄好呢.
sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
root@OpenWrt:/# dmesg |grep usb
[    0.163184] usbcore: registered new interface driver usbfs
[    0.163263] usbcore: registered new interface driver hub
[    0.163347] usbcore: registered new device driver usb
[    0.248143] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    1.082629] usbcore: registered new interface driver usb-storage
最近编辑记录 kwongwo (2021-12-15 19:20:16)
内核的设备树上看到这个部分了:
&usb_otg {
	dr_mode = "otg";
&usbphy {
	usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
};uboot的设备树:
&usb_otg {
	dr_mode = "otg";
&usbphy {
};硬件是荔枝派, usb 用的是自带的micro-usb转usb 然后接u盘.
好的,我看看,
我把dts 改了一下 dr_mode ---> host 也一样.
&usb_otg {
	dr_mode = "host";
};离线
崩溃啊,搞了3天,尽然搞不出一个USB,硬件没问题, 荔枝派主线 usb 可以正常识别...
openwt上搞不出来,郁闷的去...
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c5387d
[    0.000000] OF: fdt: Machine model: CAN Gateway 4
[    0.000000] random: get_random_bytes called from start_kernel+0x88/0x3c0 with crng_init=0
[    0.000000] percpu: Embedded 15 pages/cpu s30732 r8192 d22516 u61440
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[    0.000000] Memory: 53940K/65536K available (5517K kernel code, 346K rwdata, 1544K rodata, 2048K init, 244K bss, 11596K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .text : 0xc0008000 - 0xc0763408   (7534 kB)
[    0.000000]       .init : 0xc0a00000 - 0xc0c00000   (2048 kB)
[    0.000000]       .data : 0xc0c00000 - 0xc0c56a00   ( 347 kB)
[    0.000000]        .bss : 0xc0c5d250 - 0xc0c9a450   ( 245 kB)
[    0.000000]  Tasks RCU enabled.
[    0.000230] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000470] Console: colour dummy device 80x30
[    0.000519] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000535] pid_max: default: 32768 minimum: 301
[    0.000678] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000692] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001263] CPU: Testing write buffer coherency: ok
[    0.001695] /cpus/cpu@0 missing clock-frequency property
[    0.001721] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.040129] Setting up static identity map for 0x40200000 - 0x40200060
[    0.060125] Hierarchical SRCU implementation.
[    0.100225] smp: Bringing up secondary CPUs ...
[    0.100249] smp: Brought up 1 node, 1 CPU
[    0.100259] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.100267] CPU: All CPU(s) started in HYP mode.
[    0.100272] CPU: Virtualization extensions available.
[    0.103735] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.104331] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.104367] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.104524] pinctrl core: initialized pinctrl subsystem
[    0.105654] NET: Registered protocol family 16
[    0.106113] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.107240] No ATAGs?
[    0.162437] vcc3v0: Failed to create debugfs directory
[    0.162694] vcc3v3: Failed to create debugfs directory
[    0.162938] vcc5v0: Failed to create debugfs directory
[    0.163538] SCSI subsystem initialized
[    0.163971] usbcore: registered new interface driver usbfs
[    0.164045] usbcore: registered new interface driver hub
[    0.164128] usbcore: registered new device driver usb
[    0.164319] pps_core: LinuxPPS API ver. 1 registered
[    0.164332] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.164362] PTP clock support registered
[    0.164687] Advanced Linux Sound Architecture Driver Initialized.
[    0.172296] clocksource: Switched to clocksource arch_sys_counter
[    0.197875] NET: Registered protocol family 2
[    0.199634] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.199671] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.199696] TCP: Hash tables configured (established 1024 bind 1024)
[    0.199838] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.199886] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.200138] NET: Registered protocol family 1
[    0.200589] kvm [1]: 8-bit VMID
[    0.201150] kvm [1]: vgic interrupt IRQ16
[    0.201225] kvm [1]: Hyp mode initialized successfully
[    0.204221] No memory allocated for crashlog
[    0.205141] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.221732] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.222238] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.248993] io scheduler noop registered
[    0.249018] io scheduler deadline registered
[    0.249293] io scheduler cfq registered (default)
[    0.250066] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.254966] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.274903] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.280175] console [ttyS0] disabled
[    0.301095] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[    0.873188] console [ttyS0] enabled
[    0.898530] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 34, base_baud = 1500000) is a U6_16550A
[    0.931307] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 35, base_baud = 1500000) is a U6_16550A
[    0.953827] loop: module loaded
[    0.961364] libphy: Fixed MDIO Bus: probed
[    0.967731] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.974351] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.980167] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 38000 (expect 58000)
[    0.989896] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.995722] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    1.003011] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    1.008666] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    1.015920] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    1.020880] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    1.027696] dwmac-sun8i 1c30000.ethernet (unnamed net_device) (uninitialized): device MAC address 1e:73:d9:45:37:c1
[    1.038520] libphy: stmmac: probed
[    1.043382] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    1.050146] libphy: mdio_mux: probed
[    1.053927] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    1.060285] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    1.067607] libphy: mdio_mux: probed
[    1.072757] usbcore: registered new interface driver rtl8150
[    1.078975] usbcore: registered new interface driver r8152
[    1.084960] usbcore: registered new interface driver lan78xx
[    1.091013] usbcore: registered new interface driver asix
[    1.096887] usbcore: registered new interface driver ax88179_178a
[    1.103785] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.110317] ehci-platform: EHCI generic platform driver
[    1.116363] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.122913] ohci-platform: OHCI generic platform driver
[    1.128898] usbcore: registered new interface driver cdc_wdm
[    1.135254] usbcore: registered new interface driver usb-storage
[    1.141873] usbcore: registered new interface driver usbserial
[    1.148239] usbcore: registered new interface driver usbserial_generic
[    1.155220] usbserial: USB Serial support registered for generic
[    1.162175] mousedev: PS/2 mouse device common for all mice
[    1.169436] i2c /dev entries driver
[    1.175414] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.242344] sunxi-mmc 1c0f000.mmc: base:0xc48ac000 irq:23
[    1.248761] OF: /leds/blue_led: could not get #gpio-cells for /soc/phy@01c19400
[    1.256492] leds-gpio: probe of leds failed with error -22
[    1.270072] NET: Registered protocol family 10
[    1.290845] Segment Routing with IPv6
[    1.295148] NET: Registered protocol family 17
[    1.299698] can: controller area network core (rev 20170425 abi 9)
[    1.306473] NET: Registered protocol family 29
[    1.310965] 8021q: 802.1Q VLAN Support v1.8
[    1.315453] Registering SWP/SWPB emulation handler
[    1.327645] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.333412] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.342139] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.350279] mmc0: new high speed SD card at address 2101
[    1.355987] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[    1.363240] mmcblk0: mmc0:2101 APPSD 240 MiB
[    1.369315]  mmcblk0: p1 p2
[    1.382400] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.388822] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.395828] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.403114] usb usb1: Product: EHCI Host Controller
[    1.407988] usb usb1: Manufacturer: Linux 4.14.221 ehci_hcd
[    1.413599] usb usb1: SerialNumber: 1c1a000.usb
[    1.419056] hub 1-0:1.0: USB hub found
[    1.423234] hub 1-0:1.0: 1 port detected
[    1.428683] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.435865] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.443975] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[    1.516539] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.523373] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.530588] usb usb2: Product: Generic Platform OHCI controller
[    1.536526] usb usb2: Manufacturer: Linux 4.14.221 ohci_hcd
[    1.542094] usb usb2: SerialNumber: 1c1a400.usb
[    1.547538] hub 2-0:1.0: USB hub found
[    1.551623] hub 2-0:1.0: 1 port detected
[    1.556681] hctosys: unable to open rtc device (rtc0)
[    1.562154] vcc3v0: disabling
[    1.566352] vcc3v3: disabling
[    1.569330] vcc5v0: disabling
[    1.572513] vcc3v0: disabling
[    1.575490] vcc5v0: disabling
[    1.578457] ALSA device list:
[    1.581421]   No soundcards found.
[    1.592986] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[    1.602586] Freeing unused kernel memory: 2048K
[    2.054618] init: Console is alive
[    2.058366] init: - watchdog -
[    2.583742] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    2.633354] exFAT: Version 1.2.9
[    2.638123] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    2.656138] init: - preinit -
[    3.394026] random: jshn: uninitialized urandom read (4 bytes read)
[    3.472235] random: jshn: uninitialized urandom read (4 bytes read)
[    3.503841] random: jshn: uninitialized urandom read (4 bytes read)
[    3.671120] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[    3.682582] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    3.690255] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    3.698970] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    6.966148] mount_root: loading kmods from internal overlay
[    6.993481] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[    7.001536] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[    7.137086] block: attempting to load /etc/config/fstab
[    7.142982] block: unable to load configuration (fstab: Entry not found)
[    7.149786] block: no usable configuration
[    7.218530] JBD2: no valid journal superblock found
[    7.223574] EXT4-fs (loop0): error loading journal
[    7.252582] mount_root: failed to mount -t ext4 /dev/loop0 /tmp/overlay: Invalid argument
[    7.311494] block: attempting to load /etc/config/fstab
[    7.317230] block: unable to load configuration (fstab: Entry not found)
[    7.324194] block: no usable configuration
[    7.329584] mount_root: overlay filesystem has not been fully initialized yet
[    7.337834] mount_root: switching to ext4 overlay
[    7.343056] mount_root: switching to ext4 failed - fallback to ramoverlay
[    7.445926] urandom-seed: Seed file not found (/etc/urandom.seed)
[    7.529210] procd: - early -
[    7.532896] procd: - watchdog -
[    8.285460] procd: - watchdog -
[    8.289015] procd: - ubus -
[    8.340218] urandom_read: 1 callbacks suppressed
[    8.340231] random: ubusd: uninitialized urandom read (4 bytes read)
[    8.387132] random: ubusd: uninitialized urandom read (4 bytes read)
[    8.394231] random: ubusd: uninitialized urandom read (4 bytes read)
[    8.401588] procd: - init -
Please press Enter to activate this console.
[    8.991928] urngd: v1.0.2 started.
[    9.032835] kmodloader: loading kernel modules from /etc/modules.d/*
[    9.064384] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    9.098402] random: crng init done
[    9.101828] random: 3 urandom warning(s) missed due to ratelimiting
[    9.116028] hidraw: raw HID events driver (C) Jiri Kosina
[    9.126233] can: broadcast manager protocol (rev 20170425 t)
[    9.144046] CAN device driver interface
[    9.153714] can: netlink gateway (rev 20170425) max_hops=1
[    9.174023] can: raw protocol (rev 20170425)
[    9.180115] Loading modules backported from Linux version v4.19.161-0-gdaefdc9eb24b
[    9.202455] Backport generated by backports.git v4.19.161-1-0-g4bb568fe
[    9.215868] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.252800] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
[    9.333431] usbcore: registered new interface driver ums-alauda
[    9.352762] usbcore: registered new interface driver ums-cypress
[    9.362704] usbcore: registered new interface driver ums-datafab
[    9.384045] usbcore: registered new interface driver ums-freecom
[    9.392723] usbcore: registered new interface driver ums-isd200
[    9.414101] usbcore: registered new interface driver ums-jumpshot
[    9.424169] usbcore: registered new interface driver ums-karma
[    9.444290] usbcore: registered new interface driver ums-sddr09
[    9.462768] usbcore: registered new interface driver ums-sddr55
[    9.470977] usbcore: registered new interface driver ums-usbat
[    9.495477] usbcore: registered new interface driver usbhid
[    9.501064] usbhid: USB HID core driver
[    9.513736] vcan: Virtual CAN interface driver
[    9.557226] xt_time: kernel timezone is -0000
[    9.649081] PPP generic driver version 2.4.2
[    9.665833] NET: Registered protocol family 24
[    9.685360] usbcore: registered new interface driver rtl8187
[    9.739211] usbcore: registered new interface driver rtl8192cu
[    9.753053] usbcore: registered new interface driver ath9k_htc
[    9.759706] kmodloader: done loading kernel modules from /etc/modules.d/*
[   28.485545] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[   28.504926] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[   28.522843] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[   28.551478] br-lan: port 1(eth0) entered blocking state
[   28.561076] br-lan: port 1(eth0) entered disabled state
[   28.583217] device eth0 entered promiscuous mode
[   28.605815] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready离线
sun8i-v3s.dtsi
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/clock/sun8i-v3s-ccu.h>
#include <dt-bindings/reset/sun8i-v3s-ccu.h>
	#address-cells = <1>;
	#size-cells = <1>;
	interrupt-parent = <&gic>;
	cpus {
		#size-cells = <0>;
		cpu@0 {
			compatible = "arm,cortex-a7";
			device_type = "cpu";
			reg = <0>;
			clocks = <&ccu CLK_CPU>;
	de: display-engine {
		compatible = "allwinner,sun8i-v3s-display-engine";
		allwinner,pipelines = <&mixer0>;
		status = "disabled";
	timer {
		compatible = "arm,armv7-timer";
		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>;
	clocks {
		#size-cells = <1>;
		ranges;
		osc24M: osc24M_clk {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
		osc32k: osc32k_clk {
			#clock-cells = <0>;
			clock-frequency = <32768>;
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		display_clocks: clock@1000000 {
			compatible = "allwinner,sun8i-v3s-de2-clk";
			reg = <0x01000000 0x100000>;
			clocks = <&ccu CLK_DE>,
				 <&ccu CLK_BUS_DE>;
			clock-names = "mod",
				      "bus";
			resets = <&ccu RST_BUS_DE>;
			#clock-cells = <1>;
			#reset-cells = <1>;
		mixer0: mixer@1100000 {
			compatible = "allwinner,sun8i-v3s-de2-mixer";
			reg = <0x01100000 0x100000>;
			clocks = <&display_clocks 0>,
				 <&display_clocks 6>;
			clock-names = "bus",
				      "mod";
			resets = <&display_clocks 0>;
			assigned-clocks = <&display_clocks 6>;
			assigned-clock-rates = <150000000>;
			ports {
				#size-cells = <0>;
				mixer0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					mixer0_out_tcon0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&tcon0_in_mixer0>;
		syscon: syscon@1c00000 {
			compatible = "allwinner,sun8i-v3s-system-controller",
				"syscon";
			reg = <0x01c00000 0x1000>;
		tcon0: lcd-controller@1c0c000 {
			compatible = "allwinner,sun8i-v3s-tcon";
			reg = <0x01c0c000 0x1000>;
			interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_TCON0>,
				 <&ccu CLK_TCON0>;
			clock-names = "ahb",
				      "tcon-ch0";
			clock-output-names = "tcon-pixel-clock";
			resets = <&ccu RST_BUS_TCON0>;
			reset-names = "lcd";
			ports {
				#size-cells = <0>;
				tcon0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					tcon0_in_mixer0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&mixer0_out_tcon0>;
				tcon0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
		dma: dma-controller@01c02000 {
			compatible = "allwinner,sun8i-v3s-dma";
			reg = <0x01c02000 0x1000>;
			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_DMA>;
			resets = <&ccu RST_BUS_DMA>;
			#dma-cells = <1>;
		mmc0: mmc@01c0f000 {
			compatible = "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
		mmc1: mmc@01c10000 {
			reg = <0x01c10000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC1>,
				 <&ccu CLK_MMC1>,
				 <&ccu CLK_MMC1_OUTPUT>,
				 <&ccu CLK_MMC1_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC1>;
			interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-names = "default";
			pinctrl-0 = <&mmc1_pins>;
			#size-cells = <0>;
		mmc2: mmc@01c11000 {
			reg = <0x01c11000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC2>,
				 <&ccu CLK_MMC2>,
				 <&ccu CLK_MMC2_OUTPUT>,
				 <&ccu CLK_MMC2_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC2>;
			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
		usb_otg: usb@01c19000 {
			compatible = "allwinner,sun8i-h3-musb";
			reg = <0x01c19000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
			dr_mode = "otg";
		usbphy: phy@01c19400 {
			compatible = "allwinner,sun8i-v3s-usb-phy";
			reg = <0x01c19400 0x2c>,
			      <0x01c1a800 0x4>;
			reg-names = "phy_ctrl",
				    "pmu0";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		ehci0: usb@01c1a000 {
			compatible = "allwinner,sun8i-v3s-ehci", "generic-ehci";
			reg = <0x01c1a000 0x100>;
			interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>;
			resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>;
			phys = <&usbphy 0>;
			phy-names = "usb";
		ohci0: usb@01c1a400 {
			compatible = "allwinner,sun8i-v3s-ohci", "generic-ohci";
			reg = <0x01c1a400 0x100>;
			interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>;
			phys = <&usbphy 0>;
			phy-names = "usb";
		ccu: clock@01c20000 {
			compatible = "allwinner,sun8i-v3s-ccu";
			reg = <0x01c20000 0x400>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
		rtc: rtc@01c20400 {
			compatible = "allwinner,sun6i-a31-rtc";
			reg = <0x01c20400 0x54>;
			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
		pio: pinctrl@01c20800 {
			compatible = "allwinner,sun8i-v3s-pinctrl";
			reg = <0x01c20800 0x400>;
			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
			gpio-controller;
			#gpio-cells = <3>;
			interrupt-controller;
			#interrupt-cells = <3>;
			i2c0_pins: i2c0-pins {
				pins = "PB6", "PB7";
				function = "i2c0";
			uart0_pb_pins: uart0-pb-pins {
				pins = "PB8", "PB9";
				function = "uart0";
			uart1_pb_pins: uart1-pb-pins {
				pins = "PE21", "PE22";
				function = "uart1";
			uart2_pb_pins: uart2-pb-pins {
				pins = "PB0", "PB1";
				function = "uart2";
			mmc0_pins: mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3",
				       "PF4", "PF5";
				function = "mmc0";
				drive-strength = <30>;
				bias-pull-up;
			mmc1_pins: mmc1-pins {
				pins = "PG0", "PG1", "PG2", "PG3",
				       "PG4", "PG5";
				function = "mmc1";
				bias-pull-up;
			spi0_pins: spi0-pins {
				function = "spi0";
		timer@01c20c00 {
			compatible = "allwinner,sun4i-a10-timer";
			reg = <0x01c20c00 0xa0>;
			interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&osc24M>;
		wdt0: watchdog@01c20ca0 {
			reg = <0x01c20ca0 0x20>;
			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
		lradc: lradc@1c22800 {
			compatible = "allwinner,sun4i-a10-lradc-keys";
			reg = <0x01c22800 0x400>;
			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
		uart0: serial@01c28000 {
			reg = <0x01c28000 0x400>;
			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart1: serial@01c28400 {
			reg = <0x01c28400 0x400>;
			interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart2: serial@01c28800 {
			reg = <0x01c28800 0x400>;
			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		i2c0: i2c@01c2ac00 {
			compatible = "allwinner,sun6i-a31-i2c";
			reg = <0x01c2ac00 0x400>;
			interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_I2C0>;
			resets = <&ccu RST_BUS_I2C0>;
			pinctrl-0 = <&i2c0_pins>;
			#size-cells = <0>;
		i2c1: i2c@01c2b000 {
			reg = <0x01c2b000 0x400>;
			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_I2C1>;
			resets = <&ccu RST_BUS_I2C1>;
			#size-cells = <0>;
		emac: ethernet@1c30000 {
			compatible = "allwinner,sun8i-h3-emac";
			syscon = <&syscon>;
			reg = <0x01c30000 0x10000>;
			interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "macirq";
			resets = <&ccu RST_BUS_EMAC>;
			reset-names = "stmmaceth";
			clocks = <&ccu CLK_BUS_EMAC>;
			clock-names = "stmmaceth";
			#size-cells = <0>;
			mdio: mdio {
				#size-cells = <0>;
				compatible = "snps,dwmac-mdio";
			mdio-mux {
				compatible = "allwinner,sun8i-h3-mdio-mux";
				#size-cells = <0>;
				mdio-parent-bus = <&mdio>;
				/* Only one MDIO is usable at the time */
				internal_mdio: mdio@1 {
					compatible = "allwinner,sun8i-h3-mdio-internal";
					reg = <1>;
					#size-cells = <0>;
					int_mii_phy: ethernet-phy@1 {
						compatible = "ethernet-phy-ieee802.3-c22";
						reg = <1>;
						clocks = <&ccu CLK_BUS_EPHY>;
						resets = <&ccu RST_BUS_EPHY>;
				external_mdio: mdio@2 {
					reg = <2>;
					#size-cells = <0>;
		spi0: spi@1c68000 {
			compatible = "allwinner,sun8i-h3-spi";
			reg = <0x01c68000 0x1000>;
			interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
			clock-names = "ahb", "mod";
			pinctrl-0 = <&spi0_pins>;
			resets = <&ccu RST_BUS_SPI0>;
			#size-cells = <0>;
    ahci-5v {
        regulator-name = "ahci-5v";
        regulator-min-microvolt = <0x004c4b40>;
        regulator-max-microvolt = <0x004c4b40>;
        regulator-boot-on;
        enable-active-high;
        gpio = <0x0000000b 0x00000001 0x00000008 0x00000000>;
    usb0-vbus {
        regulator-name = "usb0-vbus";
        enable-active-high;
        gpio = <0x0000000b 0x00000001 0x00000009 0x00000000>;
    usb1-vbus {
        regulator-name = "usb1-vbus";
        regulator-boot-on;
        enable-active-high;
        gpio = <0x0000000b 0x00000007 0x00000006 0x00000000>;
    usb2-vbus {
        regulator-name = "usb2-vbus";
        regulator-boot-on;
        enable-active-high;
        gpio = <0x0000000b 0x00000007 0x00000003 0x00000000>;
    vcc3v0 {
        regulator-name = "vcc3v0";
        regulator-min-microvolt = <0x002dc6c0>;
        regulator-max-microvolt = <0x002dc6c0>;
    vcc3v3 {
        regulator-name = "vcc3v3";
        regulator-min-microvolt = <0x00325aa0>;
        regulator-max-microvolt = <0x00325aa0>;
        linux,phandle = <0x00000008>;
    vcc5v0 {
        regulator-name = "vcc5v0";
		gic: interrupt-controller@01c81000 {
			compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic";
			reg = <0x01c81000 0x1000>,
			      <0x01c82000 0x1000>,
			      <0x01c84000 0x2000>,
			      <0x01c86000 0x2000>;
			interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
};离线
sun8i-v3s-can-gateway-4.dts
 * whole.
 *     conditions:
/dts-v1/;
#include "sun8i-v3s.dtsi"
	model = "CAN Gateway 4";
	compatible = "peace,can-gatewat-4", "allwinner,sun8i-v3s";
	aliases {
		serial0 = &uart0;
		serial1 = &uart1;
		serial2 = &uart2;
		ethernet0 = &emac;
	chosen {
    leds {
        compatible = "gpio-leds";
        blue_led {
            label = "licheepi:blue:usr";
            gpios = <0x0000000b 0x00000006 0x00000001 0x00000001>;
        green_led {
            label = "licheepi:green:usr";
            gpios = <0x0000000b 0x00000006 0x00000000 0x00000001>;
            default-state = "on";
        red_led {
            label = "licheepi:red:usr";
            gpios = <0x0000000b 0x00000006 0x00000002 0x00000001>;
&mmc0 {
	pinctrl-0 = <&mmc0_pins>;
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <®_vcc3v3>;
&uart0 {
	pinctrl-0 = <&uart0_pb_pins>;
&uart1 {
	pinctrl-0 = <&uart1_pb_pins>;
&uart2 {
	pinctrl-0 = <&uart2_pb_pins>;
&ehci0 {
&ohci0 {
&usb_otg {
	dr_mode = "otg";
&usbphy {
&emac {
	phy-handle = <&int_mii_phy>;
	phy-mode = "mii";
	allwinner,leds-active-high;
};离线
sun8i-v3s-licheepi-zero.dts
 * whole.
 *     conditions:
/dts-v1/;
	model = "Lichee Pi Zero";
	compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	aliases {
		serial0 = &uart0;
	chosen {
	leds {
		blue_led {
			gpios = <&pio 6 1 GPIO_ACTIVE_LOW>; /* PG1 */
		green_led {
			gpios = <&pio 6 0 GPIO_ACTIVE_LOW>; /* PG0 */
		red_led {
			gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; /* PG2 */
&mmc0 {
	broken-cd;
	bus-width = <4>;
&uart0 {
&ehci0 {
&ohci0 {
&usb_otg {
	dr_mode = "otg";
&usbphy {
};麻烦晕哥帮忙研究一下,谢谢:)
好的, 我觉得 dts, 内核配置啥的 应该没问题了吧,
难不成 uboot还要管这个 ID?
看了一下源代码, 发现 dts和源代码的node不一致....
&usbphy {
};	data->id_det_gpio = devm_gpiod_get_optional(dev, "usb0_id_det",
						    GPIOD_IN);
	if (IS_ERR(data->id_det_gpio)) {
		dev_err(dev, "Couldn't request ID GPIO\n");
		return PTR_ERR(data->id_det_gpio);
	}明天继续测试:)
标题的错误没有了,但是 openwrt的usb还是不能用,
荔枝派的sdk就可以,继续排查....
[    0.000000] Linux version 4.13.0-licheepi-zero+ (root@jbo-VirtualBox) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #11 SMP Thu May 24 06:05:27 EDT 2018
[    0.000000] percpu: Embedded 16 pages/cpu @c3de6000 s33868 r8192 d23476 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[    0.000000] Memory: 53580K/64036K available (6144K kernel code, 218K rwdata, 1440K rodata, 1024K init, 262K bss, 10456K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a36980   ( 219 kB)
[    0.000000]        .bss : 0xc0a3d844 - 0xc0a7f06c   ( 263 kB)
[    0.000182] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000420] Console: colour dummy device 80x30
[    0.000457] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000471] pid_max: default: 32768 minimum: 301
[    0.000595] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000611] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001210] CPU: Testing write buffer coherency: ok
[    0.001595] /cpus/cpu@0 missing clock-frequency property
[    0.001616] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002058] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002232] Hierarchical SRCU implementation.
[    0.002744] smp: Bringing up secondary CPUs ...
[    0.002756] smp: Brought up 1 node, 1 CPU
[    0.002765] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002773] CPU: All CPU(s) started in SVC mode.
[    0.003530] devtmpfs: initialized
[    0.006616] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.006896] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.006924] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007087] pinctrl core: initialized pinctrl subsystem
[    0.007954] random: get_random_u32 called from bucket_table_alloc+0xfc/0x224 with crng_init=0
[    0.008094] NET: Registered protocol family 16
[    0.008552] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.009636] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.009653] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.022963] SCSI subsystem initialized
[    0.023242] usbcore: registered new interface driver usbfs
[    0.023308] usbcore: registered new interface driver hub
[    0.023402] usbcore: registered new device driver usb
[    0.023683] pps_core: LinuxPPS API ver. 1 registered
[    0.023693] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.023715] PTP clock support registered
[    0.023926] Advanced Linux Sound Architecture Driver Initialized.
[    0.025746] clocksource: Switched to clocksource arch_sys_counter
[    0.036453] NET: Registered protocol family 2
[    0.037036] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.037070] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.037092] TCP: Hash tables configured (established 1024 bind 1024)
[    0.037226] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.037276] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.037493] NET: Registered protocol family 1
[    0.038100] RPC: Registered named UNIX socket transport module.
[    0.038116] RPC: Registered udp transport module.
[    0.038122] RPC: Registered tcp transport module.
[    0.038127] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.040180] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.049054] NFS: Registering the id_resolver key type
[    0.049108] Key type id_resolver registered
[    0.049114] Key type id_legacy registered
[    0.050190] random: fast init done
[    0.053101] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.053122] io scheduler noop registered
[    0.053130] io scheduler deadline registered
[    0.053369] io scheduler cfq registered (default)
[    0.053382] io scheduler mq-deadline registered
[    0.053388] io scheduler kyber registered
[    0.057752] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.128245] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.131564] console [ttyS0] disabled
[    0.151843] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.728964] console [ttyS0] enabled
[    0.753995] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 37, base_baud = 1500000) is a U6_16550A
[    0.766705] libphy: Fixed MDIO Bus: probed
[    0.771253] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.777150] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.782861] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.789048] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.794711] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.801994] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.807675] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.814889] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.819860] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.826854] libphy: stmmac: probed
[    0.832094] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.838751] ehci-platform: EHCI generic platform driver
[    0.844306] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.849998] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.857939] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.885754] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.892937] hub 1-0:1.0: USB hub found
[    0.896878] hub 1-0:1.0: 1 port detected
[    0.901369] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.907673] ohci-platform: OHCI generic platform driver
[    0.913206] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.919932] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.927922] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.000886] hub 2-0:1.0: USB hub found
[    1.004709] hub 2-0:1.0: 1 port detected
[    1.012296] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.021840] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.030859] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.037768] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.042309] i2c /dev entries driver
[    1.046842] Add-by-me: info.type:
[    1.050170] Add-by-me: info.type:gt911
[    1.054198] Goodix-TS 0-0014: ser reset pin to low
[    1.175896] Goodix-TS 0-0014: i2c test failed attempt 1: -6
[    1.215870] Goodix-TS 0-0014: i2c test failed attempt 2: -6
[    1.255736] Goodix-TS 0-0014: I2C communication failure: -6
[    1.262189] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.325790] sunxi-mmc 1c0f000.mmc: base:0xc41fc000 irq:23
[    1.373712] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.385767] sunxi-mmc 1c10000.mmc: base:0xc4301000 irq:24
[    1.392280] usbcore: registered new interface driver usbhid
[    1.397933] usbhid: USB HID core driver
[    1.402355] mmc0: new high speed SD card at address 0007
[    1.408494] mmcblk0: mmc0:0007 SD256 242 MiB
[    1.414880] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.422969] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.429464]  mmcblk0: p1 p2
[    1.437556] NET: Registered protocol family 17
[    1.442130] Key type dns_resolver registered
[    1.446654] Registering SWP/SWPB emulation handler
[    1.456002] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4380000
[    1.466629] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    1.482876] Console: switching to colour frame buffer device 100x30
[    1.496365] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    1.504893] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.516358] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.522125] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.531294] hub 3-0:1.0: USB hub found
[    1.535184] hub 3-0:1.0: 1 port detected
[    1.540381] using random self ethernet address
[    1.544834] using random host ethernet address
[    1.550538] usb0: HOST MAC aa:66:4a:ee:10:0a
[    1.554857] usb0: MAC 86:16:c2:df:f8:27
[    1.558841] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.566356] g_cdc gadget: g_cdc ready
[    1.572622] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.582132] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:03 UTC (3)
[    1.590365] vcc5v0: disabling
[    1.593340] ALSA device list:
[    1.596359]   #0: V3s Audio Codec
[    1.602249] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.612265] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.722504] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (80, <SessEnd), retry #0, port1 00000100
[    1.918400] random: crng init done
[    2.012288] EXT4-fs (mmcblk0p2): recovery complete
[    2.060445] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.068652] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.075901] devtmpfs: mounted
[    2.080136] Freeing unused kernel memory: 1024K
[    2.220763] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[    2.296876] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    2.376787] 8188eu: loading out-of-tree module taints kernel.
[    2.392334] usbcore: registered new interface driver r8188eu
numid=12,iface=MIXER,name='Mic1 Capture Switch'
  ; type=BOOLEAN,access=rw------,values=2
  : values=on,on
Simple mixer control 'Headphone',0
  Capabilities: pvolume pvolume-joined pswitch
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 63
  Mono:
  Front Left: Playback 63 [100%] [0.00dB] [on]
  Front Right: Playback 63 [100%] [0.00dB] [on]
Playing WAVE '/root/sound/71711.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
Starting logging: OK
Starting network: Successfully initialized wpa_supplicant
rfkill: Cannot get wiphy information
Could not read interface wlan0 flags: No such device
WEXT: Could not set interface 'wlan0' UP
wlan0: Failed to initialize driver interface
FAIL
Starting sshd: OK
# [   22.915752] usb 1-1: new high-speed USB device number 2 using ehci-platform
[   26.294506] usb 1-1: USB disconnect, device number 2离线
@kwongwo
怎么解决的?
@kwongwo
怎么解决的?
这个错误是因为 usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
usb0_id_det-gpio 和源代码不一致, 改成
usb0_id_det= <&pio 5 6 GPIO_ACTIVE_HIGH>;
这样就好了, 可是usb 还是不行,晚点我再试试,周末happy了一天.
@kwongwo
检查下是不是少这个驱动没编译
CONFIG_AXP20X_POWER
@kwongwo
问题是否解决了,我也遇到同样问题,usb不好用
[    0.000000] Linux version 5.3.5 (root@VirtualBox) (gcc version 10.3.0 (Buildroot 2022.02-rc2)) #2 SMP Wed Mar 23 20:14:16 CST 2022
[    0.000000] cma: Reserved 16 MiB at 0x41c00000
[    0.000000] percpu: Embedded 15 pages/cpu s30412 r8192 d22836 u61440
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[    0.000000] Memory: 37468K/65536K available (7168K kernel code, 454K rwdata, 1704K rodata, 1024K init, 242K bss, 11684K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000000] random: get_random_bytes called from start_kernel+0x2ec/0x490 with crng_init=0
[    0.000206] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000438] Console: colour dummy device 80x30
[    0.000729] printk: console [tty0] enabled
[    0.000784] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000813] pid_max: default: 32768 minimum: 301
[    0.000972] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001001] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001859] CPU: Testing write buffer coherency: ok
[    0.002406] /cpus/cpu@0 missing clock-frequency property
[    0.002455] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003238] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003489] rcu: Hierarchical SRCU implementation.
[    0.003969] smp: Bringing up secondary CPUs ...
[    0.004007] smp: Brought up 1 node, 1 CPU
[    0.004022] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.004035] CPU: All CPU(s) started in HYP mode.
[    0.004046] CPU: Virtualization extensions available.
[    0.004893] devtmpfs: initialized
[    0.007740] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.008084] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008144] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.008995] pinctrl core: initialized pinctrl subsystem
[    0.010348] NET: Registered protocol family 16
[    0.011480] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.012659] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.012707] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.027662] SCSI subsystem initialized
[    0.028374] usbcore: registered new interface driver usbfs
[    0.028461] usbcore: registered new interface driver hub
[    0.028573] usbcore: registered new device driver usb
[    0.028835] pps_core: LinuxPPS API ver. 1 registered
[    0.028861] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.028895] PTP clock support registered
[    0.029155] Advanced Linux Sound Architecture Driver Initialized.
[    0.030455] clocksource: Switched to clocksource arch_sys_counter
[    0.039940] thermal_sys: Registered thermal governor 'step_wise'
[    0.040463] NET: Registered protocol family 2
[    0.041110] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.041174] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.041209] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.041239] TCP: Hash tables configured (established 1024 bind 1024)
[    0.041398] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.041466] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.041722] NET: Registered protocol family 1
[    0.042883] RPC: Registered named UNIX socket transport module.
[    0.042929] RPC: Registered udp transport module.
[    0.042943] RPC: Registered tcp transport module.
[    0.042954] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.044861] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.053068] NFS: Registering the id_resolver key type
[    0.053148] Key type id_resolver registered
[    0.053162] Key type id_legacy registered
[    0.053294] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.053323] io scheduler mq-deadline registered
[    0.053336] io scheduler kyber registered
[    0.058303] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.120450] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.122801] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.123965] printk: console [ttyS0] disabled
[    0.144289] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 32, base_baud = 1500000) is a U6_16550A
[    0.710167] printk: console [ttyS0] enabled
[    0.737737] libphy: Fixed MDIO Bus: probed
[    0.741954] CAN device driver interface
[    0.746266] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.752863] ehci-platform: EHCI generic platform driver
[    0.758186] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.764432] ohci-platform: OHCI generic platform driver
[    0.769839] usbcore: registered new interface driver usb-storage
[    0.776047] usbcore: registered new interface driver option
[    0.781715] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.789161] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    0.800697] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    0.806484] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    0.815470] hub 1-0:1.0: USB hub found
[    0.819338] hub 1-0:1.0: 1 port detected
[    0.825618] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    0.834858] sun6i-rtc 1c20400.rtc: registered as rtc0
[    0.839942] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.844745] i2c /dev entries driver
[    0.849461] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.858145] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    0.894663] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    0.901976] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    0.936710] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    0.944758] usbcore: registered new interface driver usbhid
[    0.950438] usbhid: USB HID core driver
[    0.956298] NET: Registered protocol family 17
[    0.960923] can: controller area network core (rev 20170425 abi 9)
[    0.967217] NET: Registered protocol family 29
[    0.971716] can: raw protocol (rev 20170425)
[    0.975993] can: broadcast manager protocol (rev 20170425 t)
[    0.981683] can: netlink gateway (rev 20170425) max_hops=1
[    0.987495] Key type dns_resolver registered
[    0.991960] Registering SWP/SWPB emulation handler
[    1.003703] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T01:57:52 UTC (7072)
[    1.012334] ALSA device list:
[    1.015329]   No soundcards found.
[    1.019150] Waiting for root device /dev/mmcblk0p2...
[    1.029394] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.039240] mmc0: Problem switching card into high-speed mode!
[    1.045297] mmc0: new SDHC card at address 0001
[    1.051760] mmcblk0: mmc0:0001 SD16G 3.74 GiB
[    1.058288]  mmcblk0: p1 p2
[    1.096642] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.105005] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.112595] devtmpfs: mounted
[    1.117087] Freeing unused kernel memory: 1024K
[    1.122052] Run /sbin/init as init process
[    1.357173] random: fast init done
[    1.369982] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    1.617928] random: dd: uninitialized urandom read (512 bytes read)
Welcome to Buildroot for the LicheePi Zero
licheepi-zero login:离线
usb 好用了,linux 5.3.5 V3s 增加了独立的OHIC和EHIC驱动节点,需要添加使能后USB才好用
[    0.889514] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.896045] ehci-platform: EHCI generic platform driver
[    0.901630] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.907264] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.915505] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.949415] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.956637] hub 1-0:1.0: USB hub found
[    0.960603] hub 1-0:1.0: 1 port detected
[    0.965183] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.971523] ohci-platform: OHCI generic platform driver
[    0.977110] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.983859] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.991982] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.064498] hub 2-0:1.0: USB hub found
[    1.068376] hub 2-0:1.0: 1 port detected
[    1.075613] usbcore: registered new interface driver usb-storage
[    1.081928] usbcore: registered new interface driver option
[    1.087549] usbserial: USB Serial support registered for GSM modem (1-port)		ehci0: usb@01c1a000 {
		};&ehci0 {
&ohci0 {
};离线
@kircar
请问大侠,linux4.14.111版本的该如何解决呢?谢谢。
