楼主 # 2021-12-20 22:00:23
vjcmain
双二阶滤波器代码
最近在DIY ECG,涉及到滤波器的设计
1.双二阶滤波器介绍:
   a) https://blog.csdn.net/hunterhuang2013/article/details/62043972
#include "biquad.h"
void calc_biquad(bq_coeff_p coeff_p);
void biquad_set_type(bq_coeff_p coeff_p,uint8_t filter_type)
        coeff_p->type = filter_type;
        calc_biquad(coeff_p);
void biquad_set_Q(bq_coeff_p coeff_p, double Q)
        coeff_p->Q = Q;
void biquad_set_fc(bq_coeff_p coeff_p, double fc)
        coeff_p->fc = fc/coeff_p->sample_rate;
void biquad_set_peak_gain(bq_coeff_p coeff_p, double peak_gainDB)
        coeff_p->peak_gain = peak_gainDB;
        calc_biquad( coeff_p);
void biquad_config(bq_coeff_p coeff_p,uint8_t type, double fc,uint32_t sample_rate,double Q, double peak_gainDB)
        coeff_p->type = type;
        coeff_p->fc = fc/(double)sample_rate;
        coeff_p->sample_rate =sample_rate;
        coeff_p->Q = Q;
        double norm;
        double a0 = 0;
        double a1 = 0;
        double a2 = 0;
        double b1 = 0;
        double b2 = 0;
        double Q = coeff_p->Q;
        double V = pow(10, fabs(coeff_p->peak_gain) / 20.0);
        double K = tan(M_PI * coeff_p->fc);
        switch (coeff_p->type)
        case bq_type_lowpass:
                norm = 1 / (1 + K / Q + K * K);
                a0 = K * K * norm;
                a1 = 2 * a0;
                a2 = a0;
                b1 = 2 * (K * K - 1) * norm;
                b2 = (1 - K / Q + K * K) * norm;
                break;
        case bq_type_highpass:
                a0 = 1 * norm;
                a1 = -2 * a0;
                a2 = a0;
                break;
        case bq_type_bandpass:
                a0 = K / Q * norm;
                a1 = 0;
                a2 = -a0;
                break;
        case bq_type_notch:
                a0 = (1 + K * K) * norm;
                a1 = 2 * (K * K - 1) * norm;
                a2 = a0;
                b1 = a1;
                break;
        case bq_type_peak:
                if (coeff_p->peak_gain >= 0)       // boost
                        norm = 1 / (1 + 1 / Q * K + K * K);
                        a0 = (1 + V / Q * K + K * K) * norm;
                        a2 = (1 - V / Q * K + K * K) * norm;
                        b1 = a1;
                        b2 = (1 - 1 / Q * K + K * K) * norm;
                else      // cut
                        norm = 1 / (1 + V / Q * K + K * K);
                        a0 = (1 + 1 / Q * K + K * K) * norm;
                        a2 = (1 - 1 / Q * K + K * K) * norm;
                        b1 = a1;
                        b2 = (1 - V / Q * K + K * K) * norm;
                break;
        case bq_type_lowshelf:
                        norm = 1 / (1 + sqrt(2) * K + K * K);
                        a0 = (1 + sqrt(2 * V) * K + V * K * K) * norm;
                        a1 = 2 * (V * K * K - 1) * norm;
                        a2 = (1 - sqrt(2 * V) * K + V * K * K) * norm;
                        b2 = (1 - sqrt(2) * K + K * K) * norm;
                else      // cut
                        norm = 1 / (1 + sqrt(2 * V) * K + V * K * K);
                        a0 = (1 + sqrt(2) * K + K * K) * norm;
                        a2 = (1 - sqrt(2) * K + K * K) * norm;
                        b1 = 2 * (V * K * K - 1) * norm;
                        b2 = (1 - sqrt(2 * V) * K + V * K * K) * norm;
                break;
        case bq_type_highshelf:
                        a0 = (V + sqrt(2 * V) * K + K * K) * norm;
                        a1 = 2 * (K * K - V) * norm;
                        a2 = (V - sqrt(2 * V) * K + K * K) * norm;
                else      // cut
                        norm = 1 / (V + sqrt(2 * V) * K + K * K);
                        b1 = 2 * (K * K - V) * norm;
                        b2 = (V - sqrt(2 * V) * K + K * K) * norm;
                break;
        coeff_p->a0 = a0;
        coeff_p->a1 = a1;
        coeff_p->a2 = a2;
        coeff_p->b1 = b1;
        coeff_p->b2 = b2;
        return;
float  biquad_process(bq_coeff_p coeff_p,float in)
        double out = in *  coeff_p->a0 +  coeff_p->z1;
        coeff_p->z1 = in * coeff_p->a1 + coeff_p->z2 - coeff_p->b1 * out;
        coeff_p->z2 = in * coeff_p->a2 - coeff_p->b2 * out;
        return out;
3 例子:
        bq_coeff_t bsf;
        bq_coeff_t hpf;
        bq_coeff_t lpf;
        biquad_config(&bsf,bq_type_notch, 50,250,0.7071, 6.0);//配置一个陷波器,FC 50Hz,采样频率250Hz,Q=0.7071,Gain=6
        biquad_config(&hpf,bq_type_highpass, 0.6,250,0.7071, 6.0);//配置一个高通滤波器,FC 0.6Hz,采样频率250Hz,Q=0.7071,Gain=6
        biquad_config(&lpf,bq_type_lowpass, 35,250,0.7071, 6.0);//配置一个低通滤波器,FC35Hz,采样频率250Hz,Q=0.7071,Gain=6
        calc_biquad(&bsf);
        calc_biquad(&hpf);
        calc_biquad(&lpf);
        for(int idx=0;idx<LEN;idx++)
        bsf_out[idx]=biquad_process(&bsf,raw_in[idx]);
        hpf_out[idx]=biquad_process(&hpf,bsf_out[idx]);
        lpf_out[idx]=biquad_process(&lpf,hpf_out[idx]);
        printf("raw=%6d,bsf=%6d,hpf=%6d,lpf=%6d\r\n",raw_in[idx],(int)bsf_out[idx],(int)hpf_out[idx],(int)lpf_out[idx]);
biquad_c  .rar
#1 2021-12-21 04:43:05
unturned3
已发帖子: 272
Re: 双二阶滤波器代码
大佬是用什么算法消除基线漂移的?
#2 2021-12-21 09:39:14
dgtg
已发帖子: 267
Re: 双二阶滤波器代码
虽然看不懂,但是很厉害的样子!
膜拜!
#3 2021-12-25 01:42:28
dave
已发帖子: 35
Re: 双二阶滤波器代码
  • 不通过:其他
