V3s 在openwrt上, usb 无法正常工作 ,搞了2周没有搞好,插usb没反应,各位兄弟帮忙看看.
硬件没问题, 用其它固件插usb设备进去会有提示, 但是编译这个openwrt固件usb搞不出来, 不知道是不是哪里没有配置好,
从 @zhangjink 的固件编译.
https://whycan.com/t_6980.html
https://github.com/zhangjinke/openwrt.git
驱动配置[usb] -- ehci + ohci
内核配置[kod-usb-core]
启动日志
[    0.000000] Linux version 4.14.221 (my@my_ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11306-c4a6851c72)) #0 SMP PREEMPT Mon Feb 15 15:22:37 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c5387d
[    0.000000] OF: fdt: Machine model: CAN Gateway 4
[    0.000000] random: get_random_bytes called from start_kernel+0x88/0x3c0 with crng_init=0
[    0.000000] percpu: Embedded 15 pages/cpu s30732 r8192 d22516 u61440
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[    0.000000] Memory: 53948K/65536K available (5288K kernel code, 344K rwdata, 1488K rodata, 2048K init, 242K bss, 11588K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .text : 0xc0008000 - 0xc072a008   (7305 kB)
[    0.000000]       .init : 0xc0a00000 - 0xc0c00000   (2048 kB)
[    0.000000]       .data : 0xc0c00000 - 0xc0c56040   ( 345 kB)
[    0.000000]        .bss : 0xc0c5d154 - 0xc0c99a48   ( 243 kB)
[    0.000000]  Tasks RCU enabled.
[    0.000227] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000448] Console: colour dummy device 80x30
[    0.000495] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000513] pid_max: default: 32768 minimum: 301
[    0.000657] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000672] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001252] CPU: Testing write buffer coherency: ok
[    0.001685] /cpus/cpu@0 missing clock-frequency property
[    0.001711] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.040129] Setting up static identity map for 0x40200000 - 0x40200060
[    0.060129] Hierarchical SRCU implementation.
[    0.100234] smp: Bringing up secondary CPUs ...
[    0.100259] smp: Brought up 1 node, 1 CPU
[    0.100268] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.100276] CPU: All CPU(s) started in HYP mode.
[    0.100282] CPU: Virtualization extensions available.
[    0.103341] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.103918] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.103955] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.104111] pinctrl core: initialized pinctrl subsystem
[    0.105253] NET: Registered protocol family 16
[    0.105701] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.106787] No ATAGs?
[    0.162743] SCSI subsystem initialized
[    0.163173] usbcore: registered new interface driver usbfs
[    0.163242] usbcore: registered new interface driver hub
[    0.163324] usbcore: registered new device driver usb
[    0.163461] pps_core: LinuxPPS API ver. 1 registered
[    0.163472] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.163499] PTP clock support registered
[    0.170132] clocksource: Switched to clocksource arch_sys_counter
[    0.195633] NET: Registered protocol family 2
[    0.196344] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.196378] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.196403] TCP: Hash tables configured (established 1024 bind 1024)
[    0.196539] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.196592] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.196851] NET: Registered protocol family 1
[    0.197309] kvm [1]: 8-bit VMID
[    0.198124] kvm [1]: vgic interrupt IRQ16
[    0.198230] kvm [1]: Hyp mode initialized successfully
[    0.201287] No memory allocated for crashlog
[    0.202171] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.219114] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.219646] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.246366] io scheduler noop registered
[    0.246391] io scheduler deadline registered
[    0.246667] io scheduler cfq registered (default)
[    0.253756] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.272321] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.276749] console [ttyS0] disabled
[    0.298093] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[    0.842812] console [ttyS0] enabled
[    0.858298] loop: module loaded
[    0.865685] libphy: Fixed MDIO Bus: probed
[    0.872031] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.877837] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.884342] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 38000 (expect 58000)
[    0.894062] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.899726] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.907059] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.912805] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.920021] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.925003] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.931817] dwmac-sun8i 1c30000.ethernet (unnamed net_device) (uninitialized): device MAC address b2:30:62:94:db:ff
[    0.942659] libphy: stmmac: probed
[    0.947399] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    0.954273] libphy: mdio_mux: probed
[    0.957896] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    0.964537] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    0.971981] libphy: mdio_mux: probed
[    0.976562] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.983515] ehci-platform: EHCI generic platform driver
[    0.989507] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.995550] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.003735] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[    1.030145] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.036481] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.043317] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.050548] usb usb1: Product: EHCI Host Controller
[    1.055421] usb usb1: Manufacturer: Linux 4.14.221 ehci_hcd
[    1.060999] usb usb1: SerialNumber: 1c1a000.usb
[    1.066425] hub 1-0:1.0: USB hub found
[    1.070589] hub 1-0:1.0: 1 port detected
[    1.075693] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.082410] ohci-platform: OHCI generic platform driver
[    1.088057] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.094882] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.103022] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[    1.174419] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.181781] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.189000] usb usb2: Product: Generic Platform OHCI controller
[    1.194957] usb usb2: Manufacturer: Linux 4.14.221 ohci_hcd
[    1.200539] usb usb2: SerialNumber: 1c1a400.usb
[    1.205984] hub 2-0:1.0: USB hub found
[    1.210062] hub 2-0:1.0: 1 port detected
[    1.215598] usbcore: registered new interface driver usb-storage
[    1.222622] usbcore: registered new interface driver usbserial
[    1.228903] usbcore: registered new interface driver usbserial_generic
[    1.235883] usbserial: USB Serial support registered for generic
[    1.242503] usbcore: registered new interface driver ftdi_sio
[    1.248598] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.257128] mousedev: PS/2 mouse device common for all mice
[    1.264701] i2c /dev entries driver
[    1.270669] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.340201] sunxi-mmc 1c0f000.mmc: base:0xc48c5000 irq:23
[    1.352586] NET: Registered protocol family 10
[    1.370042] Segment Routing with IPv6
[    1.374289] NET: Registered protocol family 17
[    1.378847] 8021q: 802.1Q VLAN Support v1.8
[    1.383500] Registering SWP/SWPB emulation handler
[    1.394601] hctosys: unable to open rtc device (rtc0)
[    1.400096] vcc3v0: disabling
[    1.403358] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.411536] vcc5v0: disabling
[    1.415038] Waiting for root device /dev/mmcblk0p2...
[    1.422259] mmc0: new high speed SD card at address 2101
[    1.428364] mmcblk0: mmc0:2101 APPSD 240 MiB
[    1.434760]  mmcblk0: p1 p2
[    1.456490] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[    1.466215] Freeing unused kernel memory: 2048K
[    1.911521] init: Console is alive
[    1.915269] init: - watchdog -
[    2.134075] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    2.178225] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    2.196291] init: - preinit -
[    2.872210] random: jshn: uninitialized urandom read (4 bytes read)
[    2.943308] random: jshn: uninitialized urandom read (4 bytes read)
[    2.974134] random: jshn: uninitialized urandom read (4 bytes read)
[    3.138029] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[    3.149344] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    3.157193] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    3.165907] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    6.723496] random: fast init done
[    6.784108] EXT4-fs (loop0): recovery complete
[    6.834883] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
[    6.843712] mount_root: switching to ext4 overlay
[    7.022755] urandom-seed: Seeding with /etc/urandom.seed
[    7.161471] procd: - early -
[    7.164603] procd: - watchdog -
[    7.912688] procd: - watchdog -
[    7.916229] procd: - ubus -
[    7.996792] urandom_read: 1 callbacks suppressed
[    7.996805] random: ubusd: uninitialized urandom read (4 bytes read)
[    8.037185] random: ubusd: uninitialized urandom read (4 bytes read)
[    8.044277] random: ubusd: uninitialized urandom read (4 bytes read)
[    8.051835] procd: - init -
Please press Enter to activate this console.
[    8.574800] kmodloader: loading kernel modules from /etc/modules.d/*
[    8.607401] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    8.633461] urngd: v1.0.2 started.
[    8.648096] hidraw: raw HID events driver (C) Jiri Kosina
[    8.670543] usbcore: registered new interface driver ch341
[    8.680485] usbserial: USB Serial support registered for ch341-uart
[    8.701918] usbcore: registered new interface driver cp210x
[    8.708183] usbserial: USB Serial support registered for cp210x
[    8.725046] ip_tables: (C) 2000-2006 Netfilter Core Team
[    8.739870] random: crng init done
[    8.751526] random: 3 urandom warning(s) missed due to ratelimiting
[    8.760483] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
[    8.826276] usbcore: registered new interface driver ums-alauda
[    8.852270] usbcore: registered new interface driver ums-cypress
[    8.870426] usbcore: registered new interface driver ums-datafab
[    8.878597] usbcore: registered new interface driver ums-freecom
[    8.900556] usbcore: registered new interface driver ums-isd200
[    8.908683] usbcore: registered new interface driver ums-jumpshot
[    8.932231] usbcore: registered new interface driver ums-karma
[    8.940513] usbcore: registered new interface driver ums-sddr09
[    8.962064] usbcore: registered new interface driver ums-sddr55
[    8.980450] usbcore: registered new interface driver ums-usbat
[    8.989582] usbcore: registered new interface driver usbhid
[    9.000458] usbhid: USB HID core driver
[    9.061621] xt_time: kernel timezone is -0000
[    9.086938] PPP generic driver version 2.4.2
[    9.103474] NET: Registered protocol family 24
[    9.120875] kmodloader: done loading kernel modules from /etc/modules.d/*
[   14.640284] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[   14.676171] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[   14.731265] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[   14.789443] br-lan: port 1(eth0) entered blocking state
[   14.818150] br-lan: port 1(eth0) entered disabled state
[   14.877399] device eth0 entered promiscuous mode
[   14.921080] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not readydts
&ehci0 {
	 phys = <&usbphy 0>;
	 phy-names = "usb";
&ohci0 {
	 phys = <&usbphy 0>;
	 phy-names = "usb";
&usb_otg {
	dr_mode = "host";
&usbphy {
	usb0_id_det = <&pio 5 6 GPIO_ACTIVE_HIGH>;
	usb0_vbus-supply = <®_vcc5v0>;
};离线
把其他固件dts 解析出来看看,v3s 好多openwrt版本的
谢谢哈, 核对了好多次.... 太郁闷了.
&ehci0 {
&ohci0 {
另外驱动配置[usb] -- ehci + ohci 这个你是怎么配的
大概是这样的,不知道是不是我哪里缺了啥...
那位兄弟有空帮忙测试一下,谢谢.
make kernel_menuconfig
 Device Drivers  --->
     [*] USB support  --->
  | |                  --- USB support        | |
  | |                  <*>   Support for Host-side USB                                                         | |
  | |                  [*]   USB announce new devices                                                          | |
  | |                        *** Miscellaneous USB options ***                                                 | |
  | |                  [ ]   Enable USB persist by default                                                     | |
  | |                  [ ]   Dynamic USB minor allocation                                                      | |
  | |                  [*]   OTG support        | |
  | |                  [ ]   Rely on OTG and EH Targeted Peripherals List                                      | |
  | |                  [ ]   Disable external hubs                                                             | |
  | |                  < >   USB 2.0 OTG FSM implementation                                                    | |
  | |                  < >   USB port LED trigger                                                              | |
  | |                  < >   USB Monitor        | |
  | |                  < >   Support WUSB Cable Based Association (CBA)                                        | |
  | |                        *** USB Host Controller Drivers ***                                               | |
  | |                  < >   Cypress C67x00 HCD support                                                        | |
  | |                  < >   xHCI HCD (USB 3.0) support                                                        | |
  | |                  <*>   EHCI HCD (USB 2.0) support                                                        | |
  | |                  [*]     Root Hub Transaction Translators                                                | |
  | |                  [ ]     Improved Transaction Translator scheduling                                      | |
  | |                  <*>     Generic EHCI driver for a platform device                                       | |
  | |                  < >   OXU210HP HCD support                                                              | |
  | |                  < >   ISP116X HCD support                                                               | |
  | |                  < >   ISP1362 HCD support                                                               | |
  | |                  < >   FOTG210 HCD support                                                               | |
  | |                  <*>   OHCI HCD (USB 1.1) support                                                        | |
  | |                  <*>     Generic OHCI driver for a platform device                                       | |
  | |                  < >   SL811HS HCD support                                                               | |
  | |                  < >   R8A66597 HCD support                                                              | |
  | |                  [ ]   HCD test mode support                                                             | |
  | |                        *** USB Device Class drivers ***                                                  | |
  | |                  < >   USB Modem (CDC ACM) support                                                       | |
  | |                  < >   USB Printer support                                                               | |
  | |                  < >   USB Wireless Device Management support                                            | |
  | |                  < >   USB Test and Measurement Class support                                            | |
  | |                        *** NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may ***                      | |
  | |                        *** also be needed; see USB_STORAGE Help for more info ***                        | |
  | |                  <*>   USB Mass Storage support                                                          | |
  | |                  [*]     USB Mass Storage verbose debug                                                  | |
  | |                  < >     Realtek Card Reader support                                                     | |
  | |                  < >     Datafab Compact Flash Reader support                                            | |
  | |                  < >     Freecom USB/ATAPI Bridge support                                                | |
  | |                  < >     ISD-200 USB/ATA Bridge support                                                  | |
  | |                  < >     USBAT/USBAT02-based storage support                                             | |
  | |                  < >     SanDisk SDDR-09 (and other SmartMedia, including DPCM) support                  | |
  | |                  < >     SanDisk SDDR-55 SmartMedia support                                              | |
  | |                  < >     Lexar Jumpshot Compact Flash Reader                                             | |
  | |                  < >     Olympus MAUSB-10/Fuji DPC-R1 support                                            | |
  | |                  < >     Support OneTouch Button on Maxtor Hard Drives                                   | |
  | |                  < >     Support for Rio Karma music player                                              | |
  | |                  < >     SAT emulation on Cypress USB/ATA Bridge with ATACB                              | |
  | |                  < >     USB ENE card reader support                                                     | |
  | |                  < >     USB Attached SCSI                                                               | |
  | |                        *** USB Imaging devices ***                                                       | |
  | |                  < >   USB Mustek MDC800 Digital Camera support                                          | |
  | |                  < >   Microtek X6USB scanner support                                                    | |
  | |                  < >   USB/IP support        | |
  | |                  <*>   Inventra Highspeed Dual Role Controller (TI, ADI, AW, ...)                        | |
  | |                          MUSB Mode Selection (Host only mode)  --->                                      | |
  | |                          *** Platform Glue Layer ***                                                     | |
  | |                          *** MUSB DMA mode ***                                                           | |
  | |                  [ ]     Disable DMA (always use PIO)                                                    | |
  | |                  < >   DesignWare USB3 DRD Core Support                                                  | |
  | |                  < >   DesignWare USB2 DRD Core Support                                                  | |
  | |                  < >   ChipIdea Highspeed Dual Role Controller                                           | |
  | |                  < >   NXP ISP 1760/1761 support                                                         | |
  | |                        *** USB port drivers ***                                                          | |
  | |                  <*>   USB Serial Converter support  --->                                                | |
  | |                        *** USB Miscellaneous drivers ***                                                 | |
  | |                  < >   EMI 6|2m USB Audio interface support                                              | |
  | |                  < >   EMI 2|6 USB Audio interface support                                               | |
  | |                  < >   ADU devices from Ontrak Control Sy
   USB Physical Layer drivers  --->
  | +------------------+(+)------------------------------------------------------------------------------------+ 离线
仅供参考
--- USB support        │ │
  │ │        <*>   Support for Host-side USB        │ │
  │ │        [ ]   USB announce new devices        │ │
  │ │        *** Miscellaneous USB options ***        │ │
  │ │        [*]   Enable USB persist by default        │ │
  │ │        [ ]   Dynamic USB minor allocation        │ │
  │ │        [ ]   OTG support        │ │
  │ │        [ ]   Rely on OTG and EH Targeted Peripherals List        │ │
  │ │        [ ]   Disable external hubs        │ │
  │ │        < >   USB port LED trigger        │ │
  │ │        < >   USB Monitor        │ │
  │ │        < >   Support WUSB Cable Based Association (CBA)        │ │
  │ │        *** USB Host Controller Drivers ***        │ │
  │ │        < >   Cypress C67x00 HCD support        │ │
  │ │        < >   xHCI HCD (USB 3.0) support        │ │
  │ │        <*>   EHCI HCD (USB 2.0) support        │ │
  │ │        [ ]     Root Hub Transaction Translators        │ │
  │ │        [*]     Improved Transaction Translator scheduling        │ │
  │ │        <*>     Generic EHCI driver for a platform device        │ │
  │ │        < >   OXU210HP HCD support        │ │
  │ │        < >   ISP116X HCD support        │ │
  │ │        < >   ISP1362 HCD support        │ │
  │ │        < >   FOTG210 HCD support        │ │
  │ │        < >   MAX3421 HCD (USB-over-SPI) support        │ │
  │ │        <*>   OHCI HCD (USB 1.1) support        │ │
  │ │        <*>     Generic OHCI driver for a platform device        │ │
  │ │        < >   SL811HS HCD support        │ │
  │ │        < >   R8A66597 HCD support        │ │
  │ │        [ ]   HCD test mode support        │ │
  │ │        *** USB Device Class drivers ***        │ │
  │ │        < >   USB Modem (CDC ACM) support        │ │
  │ │        < >   USB Printer support        │ │
  │ │        <*>   USB Wireless Device Management support        │ │
  │ │        < >   USB Test and Measurement Class support        │ │
  │ │        *** NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may ***        │ │
  │ │        *** also be needed; see USB_STORAGE Help for more info ***
<*>   USB Mass Storage support        │ │
  │ │        [ ]     USB Mass Storage verbose debug        │ │
  │ │        < >     Realtek Card Reader support        │ │
  │ │        < >     Datafab Compact Flash Reader support        │ │
  │ │        < >     Freecom USB/ATAPI Bridge support        │ │
  │ │        < >     ISD-200 USB/ATA Bridge support        │ │
  │ │        < >     USBAT/USBAT02-based storage support        │ │
  │ │        < >     SanDisk SDDR-09 (and other SmartMedia, including DPCM) support        │ │
  │ │        < >     SanDisk SDDR-55 SmartMedia support        │ │
  │ │        < >     Lexar Jumpshot Compact Flash Reader        │ │
  │ │        < >     Olympus MAUSB-10/Fuji DPC-R1 support        │ │
  │ │        < >     Support OneTouch Button on Maxtor Hard Drives        │ │
  │ │        < >     Support for Rio Karma music player        │ │
  │ │        < >     SAT emulation on Cypress USB/ATA Bridge with ATACB        │ │
  │ │        < >     USB ENE card reader support        │ │
  │ │        <*>     USB Attached SCSI        │ │
  │ │        *** USB Imaging devices ***        │ │
  │ │        < >   USB Mustek MDC800 Digital Camera support        │ │
  │ │        < >   Microtek X6USB scanner support        │ │
  │ │        < >   USB/IP support        │ │
  │ │        <*>   Inventra Highspeed Dual Role Controller (TI, ADI, AW, ...)        │ │
  │ │        MUSB Mode Selection (Dual Role mode)  --->        │ │
  │ │        *** Platform Glue Layer ***        │ │
  │ │        <*>     Allwinner (sunxi)        │ │
  │ │        *** MUSB DMA mode ***        │ │
  │ │        [ ]     Disable DMA (always use PIO)        │ │
  │ │        < >   DesignWare USB3 DRD Core Support        │ │
  │ │        < >   DesignWare USB2 DRD Core Support        │ │
  │ │        < >   ChipIdea Highspeed Dual Role Controller        │ │
  │ │        < >   NXP ISP 1760/1761 support        │ │
  │ │        *** USB port drivers ***        │ │
  │ │        < >   USB Serial Converter support  ----        │ │
  │ │        *** USB Miscellaneous drivers ***        │ │
  │ │        < >   EMI 6|2m USB Audio interface support        │ │
  │ │        < >   EMI 2|6 USB Audio interface support
< >   ADU devices from Ontrak Control Systems        │ │
  │ │        < >   USB 7-Segment LED Display        │ │
  │ │        < >   USB Lego Infrared Tower support        │ │
  │ │        < >   USB LCD driver support        │ │
  │ │        < >   Cypress CY7C63xxx USB driver support        │ │
  │ │        < >   Cypress USB thermometer driver support        │ │
  │ │        < >   Siemens ID USB Mouse Fingerprint sensor support        │ │
  │ │        < >   Elan PCMCIA CardBus Adapter USB Client        │ │
  │ │        < >   Apple Cinema Display support        │ │
  │ │        < >   USB 2.0 SVGA dongle support (Net2280/SiS315)        │ │
  │ │        < >   USB LD driver        │ │
  │ │        < >   PlayStation 2 Trance Vibrator driver support        │ │
  │ │        < >   IO Warrior driver support        │ │
  │ │        < >   USB testing driver        │ │
  │ │        < >   USB EHSET Test Fixture driver        │ │
  │ │        < >   iSight firmware loading support        │ │
  │ │        < >   USB YUREX driver support        │ │
  │ │        < >   Functions for loading firmware on EZUSB chips        │ │
  │ │        < >   USB251XB Hub Controller Configuration Driver        │ │
  │ │        < >   USB3503 HSIC to USB20 Driver        │ │
  │ │        < >   USB4604 HSIC to USB20 Driver        │ │
  │ │        < >   USB Link Layer Test driver        │ │
  │ │        < >   ChaosKey random number generator driver support        │ │
  │ │        USB Physical Layer drivers  --->        │ │
  │ │        <*>   USB Gadget Support  --->        │ │
  │ │        USB Power Delivery and Type-C drivers  --->        │ │
  │ │        [ ]   USB LED Triggers        │ │
  │ │        < >   USB ULPI PHY interface support离线
@阿黄
好的,感谢,我重新下载再试试:)
兄弟,帮我看看这里, 我的少了红色这个玩意....
 Allwinner (sunxi) ──────────────────────────────────────────────────────────────────────────────────────────────────────────┐
  │ There is no help available for this option.        │
  │ Symbol: USB_MUSB_SUNXI [=y]        │
  │ Type  : tristate        │
  │ Prompt: Allwinner (sunxi)        │
  │   Location:        │
  │     -> Device Drivers        │
  │       -> USB support (USB_SUPPORT [=y])        │
  │         -> Inventra Highspeed Dual Role Controller (TI, ADI, AW, ...) (USB_MUSB_HDRC [=y])        │
  │   Defined at drivers/usb/musb/Kconfig:66        │
  │   Depends on: USB_SUPPORT [=y] && USB_MUSB_HDRC [=y] && ARCH_SUNXI [=y] && NOP_USB_XCEIV [=y] && PHY_SUN4I_USB [=y] && EXTCON [=y] && GENERIC_PHY [=y]        │
  │   Selects: SUNXI_SRAM [=y]        离线
1、usb phy这里改一下,当然你要和udc里面确认id的compatible属性。
&usbphy {
    usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
其他的地方没看出问题,只要你的ID配置不正确,那么默认usb是device模式,当然也要看你的硬件链接,
dr_mode这里改成otg试试。
@阿黄
十分感谢, 漏选了 NOP USB Transceiver Driver
  | |                   <*> NOP USB Transceiver Driver                                                            | |
  | |                   < > AM335x USB PHY Driver        | |
  | |                   < > GPIO based peripheral-only VBUS sensing 'transceiver'                                 | |
  | |                   < > NXP ISP1301 USB transceiver support                                                   | |
  | |                   [ ] Generic ULPI Transceiver Driver                                                       | |
  | |                                                          晚上下班再回去测试,十分感谢哈.
@varzhou
好的哦,谢谢,晚上我回去再测试一下,!
感谢 @阿黄 @varzhou 内核打开 MUSB 可以了:) 我主要是漏了
<*> NOP USB Transceiver Driver离线
楼主测试可以了吗?
楼主测试可以了吗?
测试ok了, musb没有配置好, 按照上面哥们提供的参数,重新配置好了.
