V3s 在openwrt上, usb 无法正常工作 ,搞了2周没有搞好,插usb没反应,各位兄弟帮忙看看.
硬件没问题, 用其它固件插usb设备进去会有提示, 但是编译这个openwrt固件usb搞不出来, 不知道是不是哪里没有配置好,
从 @zhangjink 的固件编译.
https://whycan.com/t_6980.html
https://github.com/zhangjinke/openwrt.git
驱动配置[usb] -- ehci + ohci
内核配置[kod-usb-core]
启动日志
[ 0.000000] Linux version 4.14.221 (my@my_ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11306-c4a6851c72)) #0 SMP PREEMPT Mon Feb 15 15:22:37 2021
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c5387d
[ 0.000000] OF: fdt: Machine model: CAN Gateway 4
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] random: get_random_bytes called from start_kernel+0x88/0x3c0 with crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s30732 r8192 d22516 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[ 0.000000] Memory: 53948K/65536K available (5288K kernel code, 344K rwdata, 1488K rodata, 2048K init, 242K bss, 11588K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .text : 0xc0008000 - 0xc072a008 (7305 kB)
[ 0.000000] .init : 0xc0a00000 - 0xc0c00000 (2048 kB)
[ 0.000000] .data : 0xc0c00000 - 0xc0c56040 ( 345 kB)
[ 0.000000] .bss : 0xc0c5d154 - 0xc0c99a48 ( 243 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.000227] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000448] Console: colour dummy device 80x30
[ 0.000495] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000513] pid_max: default: 32768 minimum: 301
[ 0.000657] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000672] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001252] CPU: Testing write buffer coherency: ok
[ 0.001685] /cpus/cpu@0 missing clock-frequency property
[ 0.001711] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.040129] Setting up static identity map for 0x40200000 - 0x40200060
[ 0.060129] Hierarchical SRCU implementation.
[ 0.100234] smp: Bringing up secondary CPUs ...
[ 0.100259] smp: Brought up 1 node, 1 CPU
[ 0.100268] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.100276] CPU: All CPU(s) started in HYP mode.
[ 0.100282] CPU: Virtualization extensions available.
[ 0.103341] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.103918] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.103955] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.104111] pinctrl core: initialized pinctrl subsystem
[ 0.105253] NET: Registered protocol family 16
[ 0.105701] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106787] No ATAGs?
[ 0.162743] SCSI subsystem initialized
[ 0.163173] usbcore: registered new interface driver usbfs
[ 0.163242] usbcore: registered new interface driver hub
[ 0.163324] usbcore: registered new device driver usb
[ 0.163461] pps_core: LinuxPPS API ver. 1 registered
[ 0.163472] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.163499] PTP clock support registered
[ 0.170132] clocksource: Switched to clocksource arch_sys_counter
[ 0.195633] NET: Registered protocol family 2
[ 0.196344] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.196378] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.196403] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.196539] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.196592] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.196851] NET: Registered protocol family 1
[ 0.197309] kvm [1]: 8-bit VMID
[ 0.198124] kvm [1]: vgic interrupt IRQ16
[ 0.198230] kvm [1]: Hyp mode initialized successfully
[ 0.201287] No memory allocated for crashlog
[ 0.202171] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.219114] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.219646] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.246366] io scheduler noop registered
[ 0.246391] io scheduler deadline registered
[ 0.246667] io scheduler cfq registered (default)
[ 0.253756] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.272321] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.276749] console [ttyS0] disabled
[ 0.298093] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[ 0.842812] console [ttyS0] enabled
[ 0.858298] loop: module loaded
[ 0.865685] libphy: Fixed MDIO Bus: probed
[ 0.872031] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.877837] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.884342] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 38000 (expect 58000)
[ 0.894062] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.899726] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.907059] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.912805] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.920021] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.925003] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.931817] dwmac-sun8i 1c30000.ethernet (unnamed net_device) (uninitialized): device MAC address b2:30:62:94:db:ff
[ 0.942659] libphy: stmmac: probed
[ 0.947399] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[ 0.954273] libphy: mdio_mux: probed
[ 0.957896] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[ 0.964537] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[ 0.971981] libphy: mdio_mux: probed
[ 0.976562] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.983515] ehci-platform: EHCI generic platform driver
[ 0.989507] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.995550] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.003735] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[ 1.030145] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.036481] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.043317] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.050548] usb usb1: Product: EHCI Host Controller
[ 1.055421] usb usb1: Manufacturer: Linux 4.14.221 ehci_hcd
[ 1.060999] usb usb1: SerialNumber: 1c1a000.usb
[ 1.066425] hub 1-0:1.0: USB hub found
[ 1.070589] hub 1-0:1.0: 1 port detected
[ 1.075693] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.082410] ohci-platform: OHCI generic platform driver
[ 1.088057] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.094882] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.103022] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[ 1.174419] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.181781] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.189000] usb usb2: Product: Generic Platform OHCI controller
[ 1.194957] usb usb2: Manufacturer: Linux 4.14.221 ohci_hcd
[ 1.200539] usb usb2: SerialNumber: 1c1a400.usb
[ 1.205984] hub 2-0:1.0: USB hub found
[ 1.210062] hub 2-0:1.0: 1 port detected
[ 1.215598] usbcore: registered new interface driver usb-storage
[ 1.222622] usbcore: registered new interface driver usbserial
[ 1.228903] usbcore: registered new interface driver usbserial_generic
[ 1.235883] usbserial: USB Serial support registered for generic
[ 1.242503] usbcore: registered new interface driver ftdi_sio
[ 1.248598] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.257128] mousedev: PS/2 mouse device common for all mice
[ 1.264701] i2c /dev entries driver
[ 1.270669] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.340201] sunxi-mmc 1c0f000.mmc: base:0xc48c5000 irq:23
[ 1.352586] NET: Registered protocol family 10
[ 1.370042] Segment Routing with IPv6
[ 1.374289] NET: Registered protocol family 17
[ 1.378847] 8021q: 802.1Q VLAN Support v1.8
[ 1.383500] Registering SWP/SWPB emulation handler
[ 1.394601] hctosys: unable to open rtc device (rtc0)
[ 1.400096] vcc3v0: disabling
[ 1.403358] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.411536] vcc5v0: disabling
[ 1.415038] Waiting for root device /dev/mmcblk0p2...
[ 1.422259] mmc0: new high speed SD card at address 2101
[ 1.428364] mmcblk0: mmc0:2101 APPSD 240 MiB
[ 1.434760] mmcblk0: p1 p2
[ 1.456490] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[ 1.466215] Freeing unused kernel memory: 2048K
[ 1.911521] init: Console is alive
[ 1.915269] init: - watchdog -
[ 2.134075] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 2.178225] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 2.196291] init: - preinit -
[ 2.872210] random: jshn: uninitialized urandom read (4 bytes read)
[ 2.943308] random: jshn: uninitialized urandom read (4 bytes read)
[ 2.974134] random: jshn: uninitialized urandom read (4 bytes read)
[ 3.138029] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[ 3.149344] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[ 3.157193] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[ 3.165907] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 6.723496] random: fast init done
[ 6.784108] EXT4-fs (loop0): recovery complete
[ 6.834883] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
[ 6.843712] mount_root: switching to ext4 overlay
[ 7.022755] urandom-seed: Seeding with /etc/urandom.seed
[ 7.161471] procd: - early -
[ 7.164603] procd: - watchdog -
[ 7.912688] procd: - watchdog -
[ 7.916229] procd: - ubus -
[ 7.996792] urandom_read: 1 callbacks suppressed
[ 7.996805] random: ubusd: uninitialized urandom read (4 bytes read)
[ 8.037185] random: ubusd: uninitialized urandom read (4 bytes read)
[ 8.044277] random: ubusd: uninitialized urandom read (4 bytes read)
[ 8.051835] procd: - init -
Please press Enter to activate this console.
[ 8.574800] kmodloader: loading kernel modules from /etc/modules.d/*
[ 8.607401] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 8.633461] urngd: v1.0.2 started.
[ 8.648096] hidraw: raw HID events driver (C) Jiri Kosina
[ 8.670543] usbcore: registered new interface driver ch341
[ 8.680485] usbserial: USB Serial support registered for ch341-uart
[ 8.701918] usbcore: registered new interface driver cp210x
[ 8.708183] usbserial: USB Serial support registered for cp210x
[ 8.725046] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.739870] random: crng init done
[ 8.751526] random: 3 urandom warning(s) missed due to ratelimiting
[ 8.760483] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
[ 8.826276] usbcore: registered new interface driver ums-alauda
[ 8.852270] usbcore: registered new interface driver ums-cypress
[ 8.870426] usbcore: registered new interface driver ums-datafab
[ 8.878597] usbcore: registered new interface driver ums-freecom
[ 8.900556] usbcore: registered new interface driver ums-isd200
[ 8.908683] usbcore: registered new interface driver ums-jumpshot
[ 8.932231] usbcore: registered new interface driver ums-karma
[ 8.940513] usbcore: registered new interface driver ums-sddr09
[ 8.962064] usbcore: registered new interface driver ums-sddr55
[ 8.980450] usbcore: registered new interface driver ums-usbat
[ 8.989582] usbcore: registered new interface driver usbhid
[ 9.000458] usbhid: USB HID core driver
[ 9.061621] xt_time: kernel timezone is -0000
[ 9.086938] PPP generic driver version 2.4.2
[ 9.103474] NET: Registered protocol family 24
[ 9.120875] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 14.640284] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[ 14.676171] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[ 14.731265] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[ 14.789443] br-lan: port 1(eth0) entered blocking state
[ 14.818150] br-lan: port 1(eth0) entered disabled state
[ 14.877399] device eth0 entered promiscuous mode
[ 14.921080] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not readydts
&ehci0 {
phys = <&usbphy 0>;
phy-names = "usb";
&ohci0 {
phys = <&usbphy 0>;
phy-names = "usb";
&usb_otg {
dr_mode = "host";
&usbphy {
usb0_id_det = <&pio 5 6 GPIO_ACTIVE_HIGH>;
usb0_vbus-supply = <®_vcc5v0>;
};离线
把其他固件dts 解析出来看看,v3s 好多openwrt版本的
谢谢哈, 核对了好多次.... 太郁闷了.
&ehci0 {
&ohci0 {
另外驱动配置[usb] -- ehci + ohci 这个你是怎么配的
大概是这样的,不知道是不是我哪里缺了啥...
那位兄弟有空帮忙测试一下,谢谢.
make kernel_menuconfig
Device Drivers --->
[*] USB support --->
| | --- USB support | |
| | <*> Support for Host-side USB | |
| | [*] USB announce new devices | |
| | *** Miscellaneous USB options *** | |
| | [ ] Enable USB persist by default | |
| | [ ] Dynamic USB minor allocation | |
| | [*] OTG support | |
| | [ ] Rely on OTG and EH Targeted Peripherals List | |
| | [ ] Disable external hubs | |
| | < > USB 2.0 OTG FSM implementation | |
| | < > USB port LED trigger | |
| | < > USB Monitor | |
| | < > Support WUSB Cable Based Association (CBA) | |
| | *** USB Host Controller Drivers *** | |
| | < > Cypress C67x00 HCD support | |
| | < > xHCI HCD (USB 3.0) support | |
| | <*> EHCI HCD (USB 2.0) support | |
| | [*] Root Hub Transaction Translators | |
| | [ ] Improved Transaction Translator scheduling | |
| | <*> Generic EHCI driver for a platform device | |
| | < > OXU210HP HCD support | |
| | < > ISP116X HCD support | |
| | < > ISP1362 HCD support | |
| | < > FOTG210 HCD support | |
| | <*> OHCI HCD (USB 1.1) support | |
| | <*> Generic OHCI driver for a platform device | |
| | < > SL811HS HCD support | |
| | < > R8A66597 HCD support | |
| | [ ] HCD test mode support | |
| | *** USB Device Class drivers *** | |
| | < > USB Modem (CDC ACM) support | |
| | < > USB Printer support | |
| | < > USB Wireless Device Management support | |
| | < > USB Test and Measurement Class support | |
| | *** NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may *** | |
| | *** also be needed; see USB_STORAGE Help for more info *** | |
| | <*> USB Mass Storage support | |
| | [*] USB Mass Storage verbose debug | |
| | < > Realtek Card Reader support | |
| | < > Datafab Compact Flash Reader support | |
| | < > Freecom USB/ATAPI Bridge support | |
| | < > ISD-200 USB/ATA Bridge support | |
| | < > USBAT/USBAT02-based storage support | |
| | < > SanDisk SDDR-09 (and other SmartMedia, including DPCM) support | |
| | < > SanDisk SDDR-55 SmartMedia support | |
| | < > Lexar Jumpshot Compact Flash Reader | |
| | < > Olympus MAUSB-10/Fuji DPC-R1 support | |
| | < > Support OneTouch Button on Maxtor Hard Drives | |
| | < > Support for Rio Karma music player | |
| | < > SAT emulation on Cypress USB/ATA Bridge with ATACB | |
| | < > USB ENE card reader support | |
| | < > USB Attached SCSI | |
| | *** USB Imaging devices *** | |
| | < > USB Mustek MDC800 Digital Camera support | |
| | < > Microtek X6USB scanner support | |
| | < > USB/IP support | |
| | <*> Inventra Highspeed Dual Role Controller (TI, ADI, AW, ...) | |
| | MUSB Mode Selection (Host only mode) ---> | |
| | *** Platform Glue Layer *** | |
| | *** MUSB DMA mode *** | |
| | [ ] Disable DMA (always use PIO) | |
| | < > DesignWare USB3 DRD Core Support | |
| | < > DesignWare USB2 DRD Core Support | |
| | < > ChipIdea Highspeed Dual Role Controller | |
| | < > NXP ISP 1760/1761 support | |
| | *** USB port drivers *** | |
| | <*> USB Serial Converter support ---> | |
| | *** USB Miscellaneous drivers *** | |
| | < > EMI 6|2m USB Audio interface support | |
| | < > EMI 2|6 USB Audio interface support | |
| | < > ADU devices from Ontrak Control Sy
USB Physical Layer drivers --->
| +------------------+(+)------------------------------------------------------------------------------------+ 离线
仅供参考
--- USB support │ │
│ │ <*> Support for Host-side USB │ │
│ │ [ ] USB announce new devices │ │
│ │ *** Miscellaneous USB options *** │ │
│ │ [*] Enable USB persist by default │ │
│ │ [ ] Dynamic USB minor allocation │ │
│ │ [ ] OTG support │ │
│ │ [ ] Rely on OTG and EH Targeted Peripherals List │ │
│ │ [ ] Disable external hubs │ │
│ │ < > USB port LED trigger │ │
│ │ < > USB Monitor │ │
│ │ < > Support WUSB Cable Based Association (CBA) │ │
│ │ *** USB Host Controller Drivers *** │ │
│ │ < > Cypress C67x00 HCD support │ │
│ │ < > xHCI HCD (USB 3.0) support │ │
│ │ <*> EHCI HCD (USB 2.0) support │ │
│ │ [ ] Root Hub Transaction Translators │ │
│ │ [*] Improved Transaction Translator scheduling │ │
│ │ <*> Generic EHCI driver for a platform device │ │
│ │ < > OXU210HP HCD support │ │
│ │ < > ISP116X HCD support │ │
│ │ < > ISP1362 HCD support │ │
│ │ < > FOTG210 HCD support │ │
│ │ < > MAX3421 HCD (USB-over-SPI) support │ │
│ │ <*> OHCI HCD (USB 1.1) support │ │
│ │ <*> Generic OHCI driver for a platform device │ │
│ │ < > SL811HS HCD support │ │
│ │ < > R8A66597 HCD support │ │
│ │ [ ] HCD test mode support │ │
│ │ *** USB Device Class drivers *** │ │
│ │ < > USB Modem (CDC ACM) support │ │
│ │ < > USB Printer support │ │
│ │ <*> USB Wireless Device Management support │ │
│ │ < > USB Test and Measurement Class support │ │
│ │ *** NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may *** │ │
│ │ *** also be needed; see USB_STORAGE Help for more info ***
<*> USB Mass Storage support │ │
│ │ [ ] USB Mass Storage verbose debug │ │
│ │ < > Realtek Card Reader support │ │
│ │ < > Datafab Compact Flash Reader support │ │
│ │ < > Freecom USB/ATAPI Bridge support │ │
│ │ < > ISD-200 USB/ATA Bridge support │ │
│ │ < > USBAT/USBAT02-based storage support │ │
│ │ < > SanDisk SDDR-09 (and other SmartMedia, including DPCM) support │ │
│ │ < > SanDisk SDDR-55 SmartMedia support │ │
│ │ < > Lexar Jumpshot Compact Flash Reader │ │
│ │ < > Olympus MAUSB-10/Fuji DPC-R1 support │ │
│ │ < > Support OneTouch Button on Maxtor Hard Drives │ │
│ │ < > Support for Rio Karma music player │ │
│ │ < > SAT emulation on Cypress USB/ATA Bridge with ATACB │ │
│ │ < > USB ENE card reader support │ │
│ │ <*> USB Attached SCSI │ │
│ │ *** USB Imaging devices *** │ │
│ │ < > USB Mustek MDC800 Digital Camera support │ │
│ │ < > Microtek X6USB scanner support │ │
│ │ < > USB/IP support │ │
│ │ <*> Inventra Highspeed Dual Role Controller (TI, ADI, AW, ...) │ │
│ │ MUSB Mode Selection (Dual Role mode) ---> │ │
│ │ *** Platform Glue Layer *** │ │
│ │ <*> Allwinner (sunxi) │ │
│ │ *** MUSB DMA mode *** │ │
│ │ [ ] Disable DMA (always use PIO) │ │
│ │ < > DesignWare USB3 DRD Core Support │ │
│ │ < > DesignWare USB2 DRD Core Support │ │
│ │ < > ChipIdea Highspeed Dual Role Controller │ │
│ │ < > NXP ISP 1760/1761 support │ │
│ │ *** USB port drivers *** │ │
│ │ < > USB Serial Converter support ---- │ │
│ │ *** USB Miscellaneous drivers *** │ │
│ │ < > EMI 6|2m USB Audio interface support │ │
│ │ < > EMI 2|6 USB Audio interface support
< > ADU devices from Ontrak Control Systems │ │
│ │ < > USB 7-Segment LED Display │ │
│ │ < > USB Lego Infrared Tower support │ │
│ │ < > USB LCD driver support │ │
│ │ < > Cypress CY7C63xxx USB driver support │ │
│ │ < > Cypress USB thermometer driver support │ │
│ │ < > Siemens ID USB Mouse Fingerprint sensor support │ │
│ │ < > Elan PCMCIA CardBus Adapter USB Client │ │
│ │ < > Apple Cinema Display support │ │
│ │ < > USB 2.0 SVGA dongle support (Net2280/SiS315) │ │
│ │ < > USB LD driver │ │
│ │ < > PlayStation 2 Trance Vibrator driver support │ │
│ │ < > IO Warrior driver support │ │
│ │ < > USB testing driver │ │
│ │ < > USB EHSET Test Fixture driver │ │
│ │ < > iSight firmware loading support │ │
│ │ < > USB YUREX driver support │ │
│ │ < > Functions for loading firmware on EZUSB chips │ │
│ │ < > USB251XB Hub Controller Configuration Driver │ │
│ │ < > USB3503 HSIC to USB20 Driver │ │
│ │ < > USB4604 HSIC to USB20 Driver │ │
│ │ < > USB Link Layer Test driver │ │
│ │ < > ChaosKey random number generator driver support │ │
│ │ USB Physical Layer drivers ---> │ │
│ │ <*> USB Gadget Support ---> │ │
│ │ USB Power Delivery and Type-C drivers ---> │ │
│ │ [ ] USB LED Triggers │ │
│ │ < > USB ULPI PHY interface support离线
@阿黄
好的,感谢,我重新下载再试试:)
兄弟,帮我看看这里, 我的少了红色这个玩意....
Allwinner (sunxi) ──────────────────────────────────────────────────────────────────────────────────────────────────────────┐
│ There is no help available for this option. │
│ Symbol: USB_MUSB_SUNXI [=y] │
│ Type : tristate │
│ Prompt: Allwinner (sunxi) │
│ Location: │
│ -> Device Drivers │
│ -> USB support (USB_SUPPORT [=y]) │
│ -> Inventra Highspeed Dual Role Controller (TI, ADI, AW, ...) (USB_MUSB_HDRC [=y]) │
│ Defined at drivers/usb/musb/Kconfig:66 │
│ Depends on: USB_SUPPORT [=y] && USB_MUSB_HDRC [=y] && ARCH_SUNXI [=y] && NOP_USB_XCEIV [=y] && PHY_SUN4I_USB [=y] && EXTCON [=y] && GENERIC_PHY [=y] │
│ Selects: SUNXI_SRAM [=y] 离线
1、usb phy这里改一下,当然你要和udc里面确认id的compatible属性。
&usbphy {
usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
其他的地方没看出问题,只要你的ID配置不正确,那么默认usb是device模式,当然也要看你的硬件链接,
dr_mode这里改成otg试试。
@阿黄
十分感谢, 漏选了 NOP USB Transceiver Driver
| | <*> NOP USB Transceiver Driver | |
| | < > AM335x USB PHY Driver | |
| | < > GPIO based peripheral-only VBUS sensing 'transceiver' | |
| | < > NXP ISP1301 USB transceiver support | |
| | [ ] Generic ULPI Transceiver Driver | |
| | 晚上下班再回去测试,十分感谢哈.
@varzhou
好的哦,谢谢,晚上我回去再测试一下,!
感谢 @阿黄 @varzhou 内核打开 MUSB 可以了:) 我主要是漏了
<*> NOP USB Transceiver Driver离线
楼主测试可以了吗?
楼主测试可以了吗?
测试ok了, musb没有配置好, 按照上面哥们提供的参数,重新配置好了.
