坑站上好像有不少人像我一样,去linux官网下载的kernel。然后使用荔枝派的设备树文件,发现控制不了PC口。
那是因为V3s的GPIO是阉割了的。由于V3x只是S3换了封装,所以得用S3的dts设备树文件 。再打开内核文件夹看一下S3的dts文件包含的是V3的dtsi文件,V3的dtsi文件包含的是V3S.dtsi,V3的dtsi文件是在V3S.dtsi的基础上把pio换成sun8i-v3-pinctrl,把ccu也换成了sun8i-v3-ccu
这是sun8i-v3.dtsi文件
#include "sun8i-v3s.dtsi"
&ccu {
compatible = "allwinner,sun8i-v3-ccu";
&emac {
/delete-property/ phy-handle;
/delete-property/ phy-mode;
&mdio_mux {
external_mdio: mdio@2 {
reg = <2>;
#address-cells = <1>;
#size-cells = <0>;
&pio {
compatible = "allwinner,sun8i-v3-pinctrl";
说了一大堆,我自己都绕晕了,直接上代码验证,其实很简单,把荔枝派的设备树文件包含的#include "sun8i-v3s.dtsi"换成#include "sun8i-v3.dtsi"就行了
model = "Lichee Pi Zero";
compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
aliases {
serial0 = &uart0;
chosen {
leds {
compatible = "gpio-leds";
green_led {
label = "green";
linux,default-trigger = "heartbeat";
gpios = <&pio 4 22 GPIO_ACTIVE_HIGH>;
&spi0 {
st7789v@0 {
compatible = "sitronix,st7789v";
reg = <0>;
spi-max-frequency = <96000000>;
rotate = <0>;
rgb;
width=<240>;
height=<320>;
fps = <30>;
buswidth = <8>;
led-gpios = <&pio 1 5 GPIO_ACTIVE_LOW>;
reset-gpios = <&pio 1 6 GPIO_ACTIVE_HIGH>;
dc-gpios = <&pio 1 7 GPIO_ACTIVE_HIGH>;
debug = <0>;
&codec {
allwinner,audio-routing =
"Headphone", "HP",
"Headphone", "HPCOM";
&ehci0 {
&mmc0 {
broken-cd;
bus-width = <4>;
vmmc-supply = <®_vcc3v3>;
&mmc1 {
broken-cd;
bus-width = <4>;
&i2c0 {
status = "disabled";
ns2009: ns2009@48 {
compatible = "nsiway,ns2009";
reg = <0x48>;
&ohci0 {
&uart0 {
pinctrl-0 = <&uart0_pb_pins>;
pinctrl-names = "default";
&uart1 {
pinctrl-0 = <&uart1_pins_a>;
&uart2 {
pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
dr_mode = "otg";
&usbphy {
usb0_id_det-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>;
&lradc {
vref-supply = <®_vcc3v3>;
button@200 {
label = "Volume Up";
linux,code = <KEY_L>;
channel = <0>;
//voltage = <500000>;
voltage = <550000>;
button@400 {
label = "Volume Down";
linux,code = <KEY_ENTER>;
channel = <0>;
//voltage = <1060000>;
voltage = <1270000>;
button@600 {
label = "Select";
linux,code = <KEY_S>;
channel = <0>;
//voltage = <1560000>;
voltage = <2030000>;
编译并拷贝新设备树文件到TF卡启动系统
控制PC4方法:
导出GPIO
echo 68 > /sys/class/gpio/export
设置GPIO为输出
echo out > /sys/class/gpio/gpio68/direction
设置GPIO输出高电平
echo 1 >/sys/class/gpio/gpio68/value
同理设置GPIO输出低电平
echo 0 >/sys/class/gpio/gpio68/value
最近编辑记录 leefei (2022-01-02 17:08:16)
