楼主 # 2022-01-02 17:07:47
leefei
已发帖子: 53
V3x控制PC4-PC10的GPIO
坑站上好像有不少人像我一样,去linux官网下载的kernel。然后使用荔枝派的设备树文件,发现控制不了PC口。
那是因为V3s的GPIO是阉割了的。由于V3x只是S3换了封装,所以得用S3的dts设备树文件 。再打开内核文件夹看一下S3的dts文件包含的是V3的dtsi文件,V3的dtsi文件包含的是V3S.dtsi,V3的dtsi文件是在V3S.dtsi的基础上把pio换成sun8i-v3-pinctrl,把ccu也换成了sun8i-v3-ccu
这是sun8i-v3.dtsi文件
#include "sun8i-v3s.dtsi"
&ccu {
	compatible = "allwinner,sun8i-v3-ccu";
&emac {
	/delete-property/ phy-handle;
	/delete-property/ phy-mode;
&mdio_mux {
	external_mdio: mdio@2 {
		reg = <2>;
		#address-cells = <1>;
		#size-cells = <0>;
&pio {
	compatible = "allwinner,sun8i-v3-pinctrl";
说了一大堆,我自己都绕晕了,直接上代码验证,其实很简单,把荔枝派的设备树文件包含的#include "sun8i-v3s.dtsi"换成#include "sun8i-v3.dtsi"就行了
	model = "Lichee Pi Zero";
	compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	aliases {
		serial0 = &uart0;
	chosen {
	leds {
		compatible = "gpio-leds";
		green_led {
			label = "green";
			linux,default-trigger = "heartbeat";
			gpios = <&pio 4 22 GPIO_ACTIVE_HIGH>;
&spi0 {
    st7789v@0 {
            compatible = "sitronix,st7789v";
            reg = <0>;
            spi-max-frequency = <96000000>;
            rotate = <0>;
            rgb;
            width=<240>;
            height=<320>;
            fps = <30>;
            buswidth = <8>;
            led-gpios = <&pio 1 5 GPIO_ACTIVE_LOW>;
            reset-gpios = <&pio 1 6 GPIO_ACTIVE_HIGH>;
            dc-gpios = <&pio 1 7 GPIO_ACTIVE_HIGH>;
            debug = <0>;
&codec {
	allwinner,audio-routing =
		"Headphone", "HP",
		"Headphone", "HPCOM";
&ehci0 {
&mmc0 {
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
&mmc1 {
	broken-cd;
	bus-width = <4>;
&i2c0 {
	status = "disabled";
	ns2009: ns2009@48 {
		compatible = "nsiway,ns2009";
		reg = <0x48>;
&ohci0 {
&uart0 {
	pinctrl-0 = <&uart0_pb_pins>;
	pinctrl-names = "default";
&uart1 {
	pinctrl-0 = <&uart1_pins_a>;
&uart2 {
	pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
	dr_mode = "otg";
&usbphy {
	usb0_id_det-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>;
&lradc {
	vref-supply = <&reg_vcc3v3>;
	button@200 {
		label = "Volume Up";
		linux,code = <KEY_L>;
		channel = <0>;
		//voltage = <500000>;
		voltage = <550000>;
	button@400 {
		label = "Volume Down";
		linux,code = <KEY_ENTER>;
		channel = <0>;
		//voltage = <1060000>;
		voltage = <1270000>;
	button@600 {
		label = "Select";
		linux,code = <KEY_S>;
		channel = <0>;
		//voltage = <1560000>;
		voltage = <2030000>;
编译并拷贝新设备树文件到TF卡启动系统
控制PC4方法:
导出GPIO
echo 68 > /sys/class/gpio/export
设置GPIO为输出
echo out > /sys/class/gpio/gpio68/direction
设置GPIO输出高电平
echo 1 >/sys/class/gpio/gpio68/value
同理设置GPIO输出低电平
echo 0 >/sys/class/gpio/gpio68/value
最近编辑记录 leefei (2022-01-02 17:08:16)
#1 2022-01-02 22:39:34
twzy
已发帖子: 205
Re: V3x控制PC4-PC10的GPIO
感谢分享,看来我那个板子又可以填一个坑了
