楼主 #1 2018-07-27 11:49:15
hydys
已发帖子: 30
准备弄下gadget驱动,各种问题
晕哥,这是什么情况,要怎么处理:
ubuntu:~/linux/linux-zero-4.10.y$ ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CC kernel/bounds.s
CHK include/generated/bounds.h
CHK include/generated/timeconst.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CC init/main.o
In file included from init/main.c:15:0:
./include/linux/module.h:21:73: fatal error: linux/extable.h: No such file or directory
#include <linux/extable.h> / only as arch move module.h -> extable.h /
compilation terminated.
make[1]: *** [init/main.o] Error 1
make: *** [init] Error 2
ubuntu:~/linux/linux-zero-4.10.y$ clear
#2 2018-07-27 11:55:42
Re: 准备弄下gadget驱动,各种问题
arm-linux-gnueabihf-gcc -v
看下什么版本?
楼主 #3 2018-07-27 13:06:08
hydys
已发帖子: 30
gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1)
#4 2018-07-27 13:43:26
licheepi/u-boot$ arm-linux-gnueabihf-gcc -v
Using built-in specs.
COLLECT_GCC=arm-linux-gnueabihf-gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc-cross/arm-linux-gnueabihf/4.8/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/arm-linux-gnueabihf/include/c++/4.8.4 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libmudflap --disable-libitm --disable-libquadmath --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-armhf-cross/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-armhf-cross --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-armhf-cross --with-arch-directory=arm --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libgcj --enable-objc-gc --enable-multiarch --enable-multilib --disable-sjlj-exceptions --with-arch=armv7-a --with-fpu=vfpv3-d16 --with-float=hard --with-mode=thumb --disable-werror --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=arm-linux-gnueabihf --program-prefix=arm-linux-gnueabihf- --includedir=/usr/arm-linux-gnueabihf/include
Thread model: posix
我的也是这个版本,
你是不是在 Windows上面解压后拷贝到Linux ?
#5 2018-07-27 13:45:29
debugdump@ubuntu:linux/$ ls include/linux/module.h -l
-rw-rw-r-- 1 hexing hexing 22468 Dec 23 2017 ../linux/include/linux/module.h
看下文件是否存在?
楼主 #6 2018-07-27 14:00:21
hydys
已发帖子: 30
有的:
ubuntu:~/linux-zero-4.10.y/include/linux$ ls -l module.h
-rw-rw-r-- 1 22299 May 11 2017 module.h
楼主 #7 2018-07-27 14:01:36
hydys
已发帖子: 30
直接在windows下载的zip格式,直接git一直失败。在linux(Ubuntu14.04)下解压。可能是版本问题,我再确认下!
最近编辑记录 hydys (2018-07-27 14:10:41)
#8 2018-07-27 14:08:44
这段日子github 是不太好用, 速度感人.
你可以去下载荔枝派已经有的本地 git 仓库,
然后执行
git checkout -b 你要的分支
再执行
git pull master 你要的分支
这样速度会很快,只会下载叠加包.
楼主 #9 2018-07-27 14:22:31
hydys
已发帖子: 30
有可能是版本问题,过会确认下。晕哥,4.13对USB支持完善吗,做device是否稳定?
#10 2018-07-27 14:33:30
我一直做HOST用,读U盘很稳定, 目前很少碰到不能读的U盘,
4.13-y,
device 项目没有这个需求,所以基本没有测试。
#11 2018-07-28 19:44:02
ippen
已发帖子: 345
zero用4.13,gadget没问题,我就在用,挺稳定的,建议用4.13,我也曾经用过更新的4.15版本,也是没问题的
最近编辑记录 ippen (2018-07-28 19:45:17)
楼主 #12 2018-08-05 12:34:42
hydys
已发帖子: 30
请教下 为什么我加载g_serial.ko 没有任何反应:
insmod g_serial.ko
[ 543.135588] g_serial gadget: Gadget Serial v2.4
[ 543.143742] g_serial gadget: g_serial ready
加载的模块
lsmod
Module Size Used by Not tainted
g_serial 16384 0
gadgetfs 24576 0
usb_f_acm 16384 1
#13 2018-08-05 18:29:25
ippen
已发帖子: 345
加载驱动后,用usb连接pc机,应该会识别出来,如果有装过驱动,应该会认出驱动的
#14 2018-08-05 18:34:35
我记得 4.13 默认的usb 就是串口,能用,是不是usb_id电平没正常,试一试强制下拉或者上拉试一试。
楼主 #15 2018-08-11 23:40:33
hydys
已发帖子: 30
估计还是配置问题,dev目录下已经有了ttyGS0,但是主机端没反应。你内核怎么配置的?
最近编辑记录 hydys (2018-08-12 00:15:57)
楼主 #16 2018-08-12 13:03:17
hydys
已发帖子: 30
谢谢诸位,增加了几项配置,搞定了。
#17 2019-12-18 16:39:09
atong
hydys wrote:
谢谢诸位,增加了几项配置,搞定了。
请问是怎么解决问题的?
#18 2020-04-23 11:45:00
没事瞎转悠hhh
您的设置是什么样子的,能仔细说下么
