楼主 # 2022-01-22 22:38:57
cwd502
通用makefile
#   通用makefile
#   ChenWenDong
MINIGUI_DIR = /opt/z1/miniGUI_3.0.12/output
CROSS_DIR = /usr/local/arm_linux_4.2
CROSS        = arm-linux-
SRCDIRS        = ./camera ./hal ./app ./timer
ASFLAGS        =
CFLAGS        = -O2 -Wall
CXXFLAGS    =
LDFLAGS        =
ARFLAGS        =
OCFLAGS        =
ODFLAGS        =
INCDIRS        = -I$(MINIGUI_DIR)/include/freetype2 \
          -I$(MINIGUI_DIR)/include \
          -I$(CROSS_DIR)/arm-linux/include \
          -I$(CROSS_DIR)/arm-none-linux-gnueabi/include
LIBDIRS        = -L$(MINIGUI_DIR)/lib \
          -L$(CROSS_DIR)/arm-none-linux-gnueabi/lib
LIBS         = -lminigui_ths -lfreetype -ljpeg -lpng -ldl -lm -lpthread -muclibc
### You shouldn't need to change anything below this point.
#AS     = $(CROSS)as
CC     = $(CROSS)gcc
CXX     = $(CROSS)g++
LD     = $(CROSS)gcc
AR     = $(CROSS)ar
OC     = $(CROSS)objcopy
OD     = $(CROSS)objdump
RM     = -rm -fr
NAME     := z1 #$(notdir $(CURDIR))
SFILES     := $(foreach dir,$(SRCDIRS),$(wildcard $(dir)/*.s))
CFILES     := $(foreach dir,$(SRCDIRS),$(wildcard $(dir)/*.c))
CPPFILES := $(foreach dir,$(SRCDIRS),$(wildcard $(dir)/*.cpp))
RMFILES     := $(foreach dir,$(SRCDIRS),$(wildcard $(dir)/*~))
RMFILEO     := $(foreach dir,$(SRCDIRS),$(wildcard $(dir)/*.o))
OBJS      := $(SFILES:.s=.o) $(CFILES:.c=.o) $(CPPFILES:.cpp=.o)
DEPS     := $(OBJS:.o=.d)
VPATH     := $(SRCDIRS)
.PHONY: all rebuild clean
all:
    @$(MAKE) $(NAME)
rebuild:
    @$(MAKE) clean
    @$(MAKE) $(NAME)
$(NAME):$(OBJS)
    @echo test linking ...
    $(LD) $(LDFLAGS) $(LIBDIRS) -o $@ $^ $(LIBS)
%.o:    %.s
    @echo assembling $< ...
    $(AS) $(ASFLAGS) $(INCDIRS) $< -o $@
%.o:    %.c
    @echo test compiling $< ...
    $(CC) $(CFLAGS) $(INCDIRS) -c $< -o $@
%.o:    %.cpp
    @echo compiling $< ...
    $(CXX) $(CXXFLAGS) $(INCDIRS) -c $< -o $@
%.d:    %.c
    @$(CC) $(CFLAGS) $(INCDIRS) -MM $^ -o $@.tmp
    @sed 's,$(basename $(notdir $@)).o[ :]*,$(@:.d=.o) $@ : ,g' $@.tmp > $@
    @$(RM) $@.tmp
%.d:    %.cpp
    @$(CXX) $(CXXFLAGS) $(INCDIRS) -MM $^ -o $@.tmp
    @$(RM) $@.tmp
ifeq (mach/mach,)
-include $(DEPS)
endif
clean:
    @$(RM) $(OBJS) $(DEPS) $(NAME) $(RMFILES) $(RMFILEO)
    @echo clean completed
#1 2022-02-10 14:32:41
小熊猫
已发帖子: 71
Re: 通用makefile
  • 不通过:其他
