楼主 # 2022-01-26 16:20:51
996054544
全志A33 Android4.4 mmc报错
小弟刚入坑Android系统开发,使用的是全志A33的芯片,从百度云盘将源码下下来,编译烧录.无法开机,接上串口将日志打印出来
烧录百度云的img使能正常开机的,说明板子没问题
楼主 #1 2022-01-26 16:21:22
996054544
Re: 全志A33 Android4.4 mmc报错
[      0.264]
U-Boot 2011.09-rc1 (Jan 24 2022 - 10:21:23) Allwinner Technology
[      0.272]version: 2.1.0
[      0.358]pmbus:   ready
[      0.360]PMU: AXP221
[      0.362]PMU: AXP22x found
[      0.366]PMU: dcdc3 1200
[      0.369]PMU: pll1 1008 Mhz,PLL6=600 Mhz
AXI=336 Mhz,AHB=200 Mhz, APB1=100 Mhz
set power on vol to default
dcdc1_vol = 3000
dcdc2_vol = 1100
dcdc3_vol = 1200
dcdc4_vol = 0
dcdc5_vol = 1500
aldo2_vol = 2500
aldo3_vol = 3000
eldo1_vol = 3300
find power_sply to end
vbus pc exist, limit to pc
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[      0.997]DRAM:  1 GiB
relocation Offset is: 35af1000
fetch script data fail
huangn uboot disp_lcd_init [PWM]backlight_bright=192,period_ns=100000,duty_ns=15469
huangn PWM _TEST: duty_ns=15469, period_ns=100000, freq=10000, per_scal=0, period_reg=0xf
smcl's set manager is NULL
<axp22, dc1sw>
BOOT_POWER22_OUTPUT_CTL2 = 129
workmode = 0
[      1.221]NAND: NAND_UbootInit
NAND_UbootInit start
NB1 : enter NAND_LogicInit
uboot:nand version: 2 33 20170405 1103
nand : get id_number_ctl fail, 1
uboot:nand info: a714dead ffff4a42 318c 40704 5
nand : get sorting_flag fail, a
nand : get CapacityLevel fail, 7fb8d0a1
not burn nand partition table!
NB1 : nftl num: 2
 init nftl: 0
 huangn uboot disp_lcd_set_brightlcd  bright=  192
huangn uboot disp_lcd_set_brightlcd [PWM]bright=192, bright_modify=193, backlight_dimming=129, period_ns=100000, duty_ns=15469
huangn PWM _TEST: duty_ns=15469, period_ns=100000, freq=10000, per_scal=0, period_reg=0x1000000f
sunxi_pwm_enable,pwm = 0!
NB1 : NAND_LogicInit ok, result = 0x0
[      2.179]sunxi flash init ok
out of usb burn from boot: not enough energy
In:    serial
Out:   serial
Err:   serial
-total partitions:10-
bootloader  : 1000000       2000000
env         : 3000000       1000000
boot        : 4000000       1000000
system      : 5000000       40000000
misc        : 45000000      1000000
recovery    : 46000000      2000000
cache       : 48000000      c000000
metadata    : 54000000      1000000
private     : 55000000      1000000
UDISK       : 56000000      0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_nand
key 0
recovery key high 5, low 3
cant find fstbt value
misc partition found
misc_message->command = ff
to be run cmd=run setargs_nand boot_normal
mount part name bootloader
cant open script.bin, maybe it is not exist
WORK_MODE_BOOT
board_status_probe
stage1 resule 2
[      2.283]key trigger
stage2 resule 0
huangn board_status_probe 2222222222222222
sunxi_bmp_logo_display
screen_id =0, screen_width =1024, screen_height =600
[      2.321]Hit any key to stop autoboot:  0
read boot or recovery all
[      2.813]sunxi flash read :offset 4000000, 13091466 bytes OK
no signature
[      2.823]ready to boot
para err in disp_ioctl, cmd = 0xa,screen id = 1
[      2.829][mmc]: MMC Device 2 not found
[      2.833][mmc]:  mmc  not find,so not exit
NAND_UbootExit
NB1 : NAND_LogicExit
nand release dma:0
[      2.837]
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.39 (wyh@wyh-BoDE) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #776 SMP PREEMPT Mon Jan 24 11:21:19 CST 2022
[    0.000000] Machine: sun8i
[    0.000000] cma: CMA: reserved 176 MiB at 75000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 262144
[    0.000000] free_area_init_node: node 0, pgdat c09a7b40, node_mem_map c11ca000
[    0.000000]   Normal zone: 1710 pages used for memmap
[    0.000000]   Normal zone: 192850 pages, LIFO batch:31
[    0.000000]   HighMem zone: 594 pages used for memmap
[    0.000000]   HighMem zone: 66990 pages, LIFO batch:15
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c1ae3000 s10688 r8192 d13888 u32768
[    0.000000] pcpu-alloc: s10688 r8192 d13888 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259840
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/nandd init=/init ion_cma_512m=120m ion_cma_1g=176m ion_carveout_512m=96m ion_carveout_1g=150m coherent_pool=4m loglevel=8 partitions=bootloader@nanda:env@nandb:boot@nandc:system@nandd:misc@nande:recovery@nandf:cache@nandg:metadata@nandh:private@nandi:UDISK@nandj boot_type=0 config_size=41700
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 844688k/844688k available, 203888k reserved, 90112K highmem
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08ea3d4   (9097 kB)
[    0.000000]       .init : 0xc08eb000 - 0xc093d9c0   ( 331 kB)
[    0.000000]       .data : 0xc093e000 - 0xc09b8b08   ( 491 kB)
[    0.000000]        .bss : 0xc09ba098 - 0xc0b41708   (1566 kB)
[    0.000000] NR_IRQS:416
[    0.000000] try to syncboot of clk ats
[    0.000000] try to syncboot of clk sdmmc2mod
[    0.000000] try to syncboot of clk uart0
[    0.000000] try to syncboot of clk pll_ddr1
[    0.000000] try to syncboot of clk debe0
[    0.000000] try to syncboot of clk nand
[    0.000000] try to syncboot of clk dma
[    0.000000] try to syncboot of clk sat
[    0.000000] try to syncboot of clk pio
[    0.000000] try to syncboot of clk mbus
[    0.000000] try to syncboot of clk drc0
[    0.000000] try to syncboot of clk lcd0ch0
[    0.000000] try to syncboot of clk axi
[    0.000259] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000286] pid_max: default: 32768 minimum: 301
[    0.000514] Security Framework initialized
[    0.000567] SELinux:  Initializing.
[    0.000637] SELinux:  Starting in permissive mode
[    0.000651] AppArmor: AppArmor disabled by boot time parameter
[    0.000758] Mount-cache hash table entries: 512
[    0.001897] Initializing cgroup subsys debug
[    0.001917] Initializing cgroup subsys cpuacct
[    0.001929] Initializing cgroup subsys freezer
[    0.001974] CPU: Testing write buffer coherency: ok
[    0.002024] ftrace: allocating 23540 entries in 70 pages
[    0.030357] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030379] [sunxi_smp_prepare_cpus] enter
[    0.030428] Setting up static identity map for 0x406395f0 - 0x40639648
[    0.010000] CPU1: Booted secondary processor
[    0.010000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.010000] CPU2: Booted secondary processor
[    0.010000] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.010000] CPU3: Booted secondary processor
<6>[    0.010000] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.210196] Brought up 4 CPUs
[    0.210196] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.210452] devtmpfs: initialized
[    0.220319] pinctrl core: initialized pinctrl subsystem
[    0.220467] dummy:
[    0.227974] NET: Registered protocol family 16
[    0.245039] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.245128] script_sysfs_init success
[    0.245163] sunxi_dump_init success
[    0.245467] sunxi pinctrl probe enter
[    0.246194] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.247521] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.247746] axp_pinctrl_probe enter...
[    0.247929] gpiochip_add: registered GPIOs 1024 to 1029 on device: axp-pinctrl
[    0.247951] mainkey total count : 79
[    0.247962] mainkey name : product, pin count : 0
[    0.247973] mainkey name : platform, pin count : 0
[    0.247985] mainkey name : target, pin count : 0
[    0.247995] mainkey name : key_detect_en, pin count : 0
[    0.248007] mainkey name : power_sply, pin count : 0
[    0.248017] mainkey name : card_boot, pin count : 0
[    0.248028] mainkey name : card0_boot_para, pin count : 6
[    0.248042] mainkey name : card2_boot_para, pin count : 6
[    0.248054] mainkey name : twi_para, pin count : 2
[    0.248066] mainkey name : uart_para, pin count : 2
[    0.248078] mainkey name : force_uart_para, pin count : 2
[    0.248091] mainkey name : jtag_para, pin count : 4
[    0.248104] mainkey name : clock, pin count : 0
[    0.248115] mainkey name : pm_para, pin count : 0
[    0.248126] mainkey name : dram_para, pin count : 0
[    0.248137] mainkey name : pm_para, pin count : 0
[    0.248148] mainkey name : wakeup_src_para, pin count : 2
[    0.248160] mainkey name : twi0, pin count : 2
[    0.248171] mainkey name : twi1, pin count : 2
[    0.248182] mainkey name : twi2, pin count : 2
[    0.248194] mainkey name : uart0, pin count : 2
[    0.248205] mainkey name : uart1, pin count : 2
[    0.248218] mainkey name : uart2, pin count : 4
[    0.248229] mainkey name : uart3, pin count : 4
[    0.248241] mainkey name : uart4, pin count : 4
[    0.248253] mainkey name : spi0, pin count : 4
[    0.248264] mainkey name : spi1, pin count : 4
[    0.248274] mainkey name : spi_devices, pin count : 0
[    0.248285] mainkey name : spi_board0, pin count : 0
[    0.248295] mainkey name : ws1830, pin count : 1
[    0.248306] mainkey name : ctp_para, pin count : 2
[    0.248316] mainkey name : ctp_list_para, pin count : 0
[    0.248327] mainkey name : tkey_para, pin count : 0
[    0.248337] mainkey name : motor_para, pin count : 1
[    0.248349] map mainkey [motor_para] to pinctrl, map number [2]
[    0.248363] mainkey name : ths_para, pin count : 0
[    0.248373] mainkey name : cooler_table, pin count : 0
[    0.248384] mainkey name : nand0_para, pin count : 19
[    0.248397] mainkey name : disp_init, pin count : 0
[    0.248409] mainkey name : lcd0_para, pin count : 30
[    0.248425] mainkey name : pwm0_para, pin count : 1
[    0.248437] mainkey name : pwm1_para, pin count : 1
[    0.248449] mainkey name : csi0, pin count : 16
[    0.248463] mainkey name : mmc0_para, pin count : 7
[    0.248474] mainkey name : mmc1_para, pin count : 6
[    0.248486] mainkey name : mmc2_para, pin count : 11
[    0.248498] mainkey name : usbc0, pin count : 2
[    0.248509] map mainkey [usbc0] to pinctrl, map number [2]
[    0.248530] mainkey name : usbc1, pin count : 0
[    0.248540] mainkey name : usb_feature, pin count : 0
[    0.248551] mainkey name : msc_feature, pin count : 0
[    0.248561] mainkey name : serial_feature, pin count : 0
[    0.248572] mainkey name : gsensor_para, pin count : 1
[    0.248583] mainkey name : gsensor_list_para, pin count : 0
[    0.248594] mainkey name : gps_para, pin count : 0
[    0.248604] mainkey name : wifi_para, pin count : 6
[    0.248616] map mainkey [wifi_para] to pinctrl, map number [2]
[    0.248628] mainkey name : bt_para, pin count : 0
[    0.248638] mainkey name : 3g_para, pin count : 4
[    0.248649] mainkey name : gy_para, pin count : 0
[    0.248660] mainkey name : gy_list_para, pin count : 0
[    0.248670] mainkey name : ls_para, pin count : 1
[    0.248681] mainkey name : ls_list_para, pin count : 0
[    0.248692] mainkey name : compass_para, pin count : 0
[    0.248703] mainkey name : i2s0, pin count : 4
[    0.248713] mainkey name : i2s1, pin count : 4
[    0.248724] mainkey name : audio0, pin count : 1
[    0.248735] mainkey name : pmu1_para, pin count : 0
[    0.248746] mainkey name : pmu2_para, pin count : 0
[    0.248756] mainkey name : recovery_key, pin count : 0
[    0.248767] mainkey name : dvfs_table, pin count : 0
[    0.248778] mainkey name : Vdevice, pin count : 2
[    0.248789] mainkey name : s_uart0, pin count : 2
[    0.248799] mainkey name : s_rsb0, pin count : 2
[    0.248810] mainkey name : s_jtag0, pin count : 4
[    0.248821] mainkey name : s_powchk, pin count : 0
[    0.248832] mainkey name : mali_para, pin count : 0
[    0.248843] mainkey name : dram_dvfs_table, pin count : 0
[    0.248854] mainkey name : charging_type, pin count : 0
[    0.248865] mainkey name : dram_scene_table, pin count : 0
[    0.248876] mainkey name : leds_para, pin count : 2
[    0.248887] map mainkey [leds_para] to pinctrl, map number [4]
[    0.248900] mainkey name : gpio_para, pin count : 5
[    0.248910] axp pinctrl driver probe ok
[    0.250608] [sunxi-module]: [sunxi-module.0] probe success
[    0.250660] script config pll3 to 297 Mhz
[    0.250678] script config pll4 to 300 Mhz
[    0.250716] script config pll6 to 600 Mhz
[    0.250730] script config pll8 to 408 Mhz
[    0.250752] script config pll9 to 480 Mhz
[    0.250766] script config pll10 to 297 Mhz
<4>[    0.250775] sunxi_default_clk_init
[    0.250783] try to set pll6ahb1 to 200000000
[    0.250836] try to set ahb clk source to pll6ahb1
[    0.250846] set ahb clk source to pll6ahb1
[    0.250857] try to set ahb1 to 200000000
[    0.250869] try to set apb1 to 100000000
[    0.260302] bio: create slab <bio-0> at 0
[    0.260499] [ARISC] :sunxi-arisc driver v1.60
[    0.296211] [ARISC] :arisc version: [v0.0.76]
[    0.296224] [sunxi-module]: arisc register success
[    0.515785] [ARISC] :sunxi-arisc driver v1.60 startup succeeded
[    0.520575] SCSI subsystem initialized
[    0.520817] usbcore: registered new interface driver usbfs
[    0.520906] usbcore: registered new interface driver hub
[    0.520956] usbcore: registered new device driver usb
[    0.520956] twi_chan_cfg()350 - [twi0] has no twi_regulator.
[    0.520956] twi_chan_cfg()350 - [twi1] has no twi_regulator.
[    0.520956] twi_chan_cfg()350 - [twi2] has no twi_regulator.
[    0.521240] Linux video capture interface: v2.00
[    0.520044] axp22_board axp22_board: AXP (CHIP ID: 0x06) detected
[    0.522119] axp22_dcdc1: 1600 <--> 3400 mV at 3000 mV
[    0.522119] axp22_dcdc2: 600 <--> 1540 mV at 1100 mV
[    0.522119] axp22_dcdc3: 600 <--> 1860 mV at 1200 mV
[    0.522119] axp22_dcdc4: 600 <--> 1540 mV at 1100 mV
[    0.522119] axp22_dcdc5: 1000 <--> 2550 mV at 1500 mV
[    0.522119] axp22_rtc: 3000 mV
[    0.522119] axp22_aldo1: 700 <--> 3300 mV at 3000 mV
[    0.522119] axp22_aldo2: 700 <--> 3300 mV at 2500 mV
[    0.522119] axp22_aldo3: 700 <--> 3300 mV at 3000 mV
[    0.522119] axp22_dldo1: 700 <--> 3300 mV at 700 mV
[    0.522119] axp22_dldo2: 700 <--> 3300 mV at 700 mV
[    0.522119] axp22_dldo3: 700 <--> 3300 mV at 700 mV
[    0.530036] axp22_dldo4: 700 <--> 3300 mV at 700 mV
[    0.530233] axp22_eldo1: 700 <--> 3300 mV at 3300 mV
[    0.530233] axp22_eldo1: supplied by axp22_dcdc1
[    0.530308] axp22_eldo2: 700 <--> 3300 mV at 700 mV
[    0.530308] axp22_eldo2: supplied by axp22_dcdc1
[    0.530308] axp22_eldo3: 700 <--> 3300 mV at 700 mV
[    0.530308] axp22_eldo3: supplied by axp22_dcdc1
[    0.530308] axp22_dc5ldo: 700 <--> 1400 mV at 1100 mV
[    0.530308] axp22_ldoio0: 700 <--> 3300 mV at 3800 mV
[    0.530308] axp22_ldoio1: 700 <--> 3300 mV at 3800 mV
[    0.530308] axp22_dc1sw: at 700 mV
[    0.530308] axp22_dc1sw: supplied by axp22_dcdc1
[    0.530429] input: axp22-supplyer as /devices/platform/axp22_board/axp22-supplyer.20/input/input0
[    0.530676] now_rest_vol = 100
[    0.530676] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.530915] Bluetooth: Core ver 2.16
[    0.530993] NET: Registered protocol family 31
[    0.531006] Bluetooth: HCI device and connection manager initialized
[    0.531023] Bluetooth: HCI socket layer initialized
[    0.531035] Bluetooth: L2CAP socket layer initialized
[    0.531069] Bluetooth: SCO socket layer initialized
<6>[    0.531362] cfg80211: Calling CRDA to update world regulatory domain
[    0.531402] Switching to clocksource arch_sys_counter
[    0.553724] ro.twd get target ddrx2 fail
[    0.554040] FS-Cache: Loaded
[    0.554409] CacheFiles: Loaded
[    0.565887] [sunxi_hci_sunxi]: sunxi-ehci1(restrict_gpio) is invalid
[    0.565904] [sunxi_hci_sunxi]: sunxi-ehci1(drv vbus) is invalid
[    0.565920] [sunxi_hci_sunxi]: get usb_regulator is nocare
[    0.565953] [sunxi_hci_sunxi]: sunxi-ohci1(restrict_gpio) is invalid
[    0.565966] [sunxi_hci_sunxi]: sunxi-ohci1(drv vbus) is invalid
[    0.565979] [sunxi_hci_sunxi]: get usb_regulator is nocare
[    0.566217] [usb_manager]: CONFIG_USB_SUNXI_USB0_OTG
[    0.566245] no usbc(0) det_vbus gpio and try to axp det_pin
[    0.566258] get usbc0(usb_restrict pin) failed
[    0.566681] [sw_udc]: udc_init: version 20080411
[    0.567205] [ddrfreq] dram_clk value is 456
[    0.567216] [ddrfreq] sunxi_ddrfreq_max=456000
[    0.567226] [ddrfreq] dram_type value is 3
[    0.567237] [ddrfreq] dram_zq value is 0x3bbb
[    0.567247] [ddrfreq] dram_odt_en value is 1
[    0.567258] [ddrfreq] dram_para1 value is 0x10f20400
[    0.567269] [ddrfreq] dram_para2 value is 0x1000
[    0.567279] [ddrfreq] dram_mr0 value is 0x1c70
[    0.567289] [ddrfreq] dram_mr1 value is 0x40
[    0.567299] [ddrfreq] dram_mr2 value is 0x18
[    0.567309] [ddrfreq] dram_mr3 value is 0x0
[    0.567320] [ddrfreq] dram_tpr0 value is 0x46210d
[    0.567330] [ddrfreq] dram_tpr1 value is 0x1c22109
[    0.567341] [ddrfreq] dram_tpr2 value is 0x50037
[    0.567351] [ddrfreq] dram_tpr3 value is 0x0
[    0.567361] [ddrfreq] dram_tpr4 value is 0x0
[    0.567371] [ddrfreq] dram_tpr5 value is 0x0
[    0.567381] [ddrfreq] dram_tpr6 value is 0x0
[    0.567391] [ddrfreq] dram_tpr7 value is 0x0
[    0.567401] [ddrfreq] dram_tpr8 value is 0x0
[    0.567411] [ddrfreq] dram_tpr9 value is 0x0
[    0.567421] [ddrfreq] dram_tpr10 value is 0x0
[    0.567431] [ddrfreq] dram_tpr11 value is 0x0
[    0.567441] [ddrfreq] dram_tpr12 value is 168
[    0.567451] [ddrfreq] sunxi_ddrfreq_min=168000
[    0.567461] [ddrfreq] dram_tpr13 value is 0x10901
[    0.567627] [dsm] use sysconfig
[    0.567636] [dsm] -----------Dram scene-freq Table------------
[    0.567647] [dsm] scene =    0 	frequency = 456000KHz
[    0.567657] [dsm] scene =    1 	frequency = 360000KHz
[    0.567666] [dsm] scene =    2 	frequency = 240000KHz
[    0.567676] [dsm] scene =    3 	frequency = 168000KHz
[    0.567685] [dsm] --------------------------------------------
[    0.567831] [ddrfreq] LV_count value is 3
[    0.567855] [ddrfreq] ---------------Dram V-F Table---------------
[    0.567867] [ddrfreq] voltage = 1100mv 	frequency = 552000KHz
[    0.567878] [ddrfreq] voltage = 1100mv 	frequency = 360000KHz
[    0.567888] [ddrfreq] voltage = 1100mv 	frequency =    0KHz
[    0.567898] [ddrfreq] --------------------------------------------
[    0.568092] [ddrfreq] last_vdd=1100
[    0.568180] [ddrfreq] __sram_start: 0xc09b9000, __sram_end: 0xc09ba074, __sram_text_start: 0xf0000000, __sram_data_end: 0xf0001074
[    0.568195] [ddrfreq] sunxi dramfreq probe ok!
[    0.568548] NET: Registered protocol family 2
[    0.568864] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.569461] ro.twd get target ddrx2 fail
[    0.569642] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.571615] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.572542] TCP: Hash tables configured (established 131072 bind 65536)
[    0.572555] TCP: reno registered
[    0.572570] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.572610] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.572980] NET: Registered protocol family 1
[    0.573429] RPC: Registered named UNIX socket transport module.
[    0.573442] RPC: Registered udp transport module.
[    0.573452] RPC: Registered tcp transport module.
[    0.573461] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.573730] Unpacking initramfs...
[    0.704177] Freeing initrd memory: 1828K
[    0.704662] [pm]aw_pm_init!
[    0.704675] standby_mode = 1.
[    0.704684] wakeup src cnt is : 2.
[    0.704696] [exstandby]leave extended_standby_enable_wakeup_src : event 0x2000
[    0.704708] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x80
[    0.704720] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x0
[    0.704732] [exstandby]leave extended_standby_enable_wakeup_src : event 0x2000
[    0.704744] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x280
[    0.704756] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x0
[    0.704777] [wifi_pm]: no wifi used in configuration
[    0.704787] sunxi_reg_init enter
[    0.705900] audit: initializing netlink socket (disabled)
[    0.705971] type=2000 audit(0.700:1): initialized
[    0.706810] highmem bounce pool size: 64 pages
[    0.708963] NTFS driver 2.1.30 [Flags: R/W].
[    0.709175] fuse init (API version 7.18)
[    0.709681] ro.twd get target ddrx2 fail
[    0.709695] msgmni has been set to 1477
[    0.709749] SELinux:  Registering netfilter hooks
[    0.712127] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.712148] io scheduler noop registered
[    0.712159] io scheduler deadline registered
[    0.712260] io scheduler cfq registered (default)
[    0.712727] pwm module init!
[    0.713327] sw_uart_get_devinfo()1416 - uart0 has no uart_regulator.
[    0.713346] sw_uart_get_devinfo()1416 - uart1 has no uart_regulator.
[    0.713683] sw_uart_request_gpio()776 - UART0 devm_pinctrl_get() failed! return -22
[    0.713709] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.713731] sw_console_setup()1176 - console setup baud 115200 parity n bits 8, flow n
[    0.906177] console [ttyS0] enabled
[    1.002252] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    1.198507] loop: module loaded
[    1.294072] sunxi_spi_chan_cfg()1368 - [spi-0] has no spi_regulator.
[    1.580385] sunxi_spi_chan_cfg()1368 - [spi-1] has no spi_regulator.
[    2.662615] spi spi0: master is unqueued, this is deprecated
[    2.669033] tun: Universal TUN/TAP device driver, 1.6
[    2.674671] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.681790] PPP generic driver version 2.4.2
[    2.686715] PPP BSD Compression module registered
[    2.691954] PPP Deflate Compression module registered
[    2.698497] PPP MPPE Compression module registered
[    2.703845] NET: Registered protocol family 24
[    2.708817] PPTP driver version 0.8.5
[    2.713234] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.720609] [sunxi_hci_sunxi]: [sunxi-ehci1]: probe, pdev->name: sunxi-ehci, pdev->id: 1, sunxi_ehci: 0xc0a13e2c
[    2.731929] [sunxi_hci_sunxi]: [sunxi-ehci1]: open clock, is_open: 0
[    2.759009] [sunxi_hci_sunxi]: [sunxi-ehci1]: Set USB Power ON
[    2.765500] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.774421] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    2.784650] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    2.810049] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    2.816628] ehci_irq: highspeed device connect
[    2.821715] hub 1-0:1.0: USB hub found
[    2.825893] hub 1-0:1.0: 1 port detected
[    2.830719] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.837649] [sunxi_hci_sunxi]: [sunxi-ohci1]: probe, pdev->name: sunxi-ohci, pdev->id: 1, sunxi_ohci: 0xc0a13f30
[    2.848979] [sunxi_hci_sunxi]: [sunxi-ohci1]: open clock, is_open: 0
[    2.876062] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.884588] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[    2.893035] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    2.954668] hub 2-0:1.0: USB hub found
[    2.958847] hub 2-0:1.0: 1 port detected
[    2.963799] usbcore: registered new interface driver cdc_acm
[    2.970107] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.978990] Initializing USB Mass Storage driver...
[    2.984522] usbcore: registered new interface driver usb-storage
[    2.991203] USB Mass Storage support registered.
[    2.996371] usbcore: registered new interface driver ums-alauda
[    3.002998] usbcore: registered new interface driver ums-cypress
[    3.009705] usbcore: registered new interface driver ums-datafab
[    3.016570] usbcore: registered new interface driver ums_eneub6250
[    3.023503] usbcore: registered new interface driver ums-freecom
[    3.030271] usbcore: registered new interface driver ums-isd200
[    3.036889] usbcore: registered new interface driver ums-jumpshot
[    3.043715] usbcore: registered new interface driver ums-karma
[    3.050254] usbcore: registered new interface driver ums-onetouch
[    3.057073] usbcore: registered new interface driver ums-realtek
[    3.063835] usbcore: registered new interface driver ums-sddr09
[    3.070465] usbcore: registered new interface driver ums-sddr55
[    3.077072] usbcore: registered new interface driver ums-usbat
[    3.083696] usbcore: registered new interface driver usbserial
[    3.090187] usbserial: USB Serial Driver core
[    3.095069] usbcore: registered new interface driver option
[    3.101305] USB Serial support registered for GSM modem (1-port)
[    3.150061] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[    3.303408] [sw_udc]: [sunxi_usb_udc]: binding gadget driver 'android_usb'
[    3.311088] [sw_udc]: alloc request: ep(0xc0986ed0, ep0, 64), req(0xee9875c0)
[    3.319021] sunxi_udc_set_selfpowered_2300: usb device is not active
[    3.326078] [sw_udc]: sunxi_udc_pullup, is_on = 0
[    3.331320] sunxi_udc_set_pullup_2317: usb device is not active
[    3.337991] file system registered
[    3.343776] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    3.351435] android_usb gadget: Number of LUNs=3
[    3.356559]  lun0: LUN: removable file: (no medium)
[    3.361986]  lun1: LUN: removable file: (no medium)
[    3.367399]  lun2: LUN: removable file: (no medium)
[    3.373208] android_bind, serial_unique = 1
[    3.377860] sunxi_udc_set_selfpowered_2300: usb device is not active
[    3.384943] android_usb gadget: android_usb ready
[    3.390196] [sw_hcd0]: usb host driver initialize........
[    3.396281] [sw_hcd0]: open_usb_clock
[    3.400681] [sunxi_hcd0]: host_init_state = 0
[    3.405713] [sw_hcd0]: platform is usb host
[    3.410448] [sw_hcd0]: sunxi_hcd_init_controller: sunxi_hcd_host0: USB Host mode controller at f1c19000 using PIO, IRQ 103
[    3.422737] sunxi_hcd_host0 sunxi_hcd_host0: sunxi_hcd host driver
[    3.429597] sunxi_hcd_host0 sunxi_hcd_host0: new USB bus registered, assigned bus number 3
[    3.439443] hub 3-0:1.0: USB hub found
[    3.443642] hub 3-0:1.0: 1 port detected
[    3.448381] [sw_hcd0]: sunxi_usb_host0_disable start
[    3.453913] [sw_hcd0]: sunxi_hcd_wait_for_disconnect cnt=0
[    3.460019] [sunxi_hcd_host0]: Set USB Power OFF
[    3.465250] -------sunxi_hcd0_soft_disconnect---------
[    3.470956] wrn: hcd is not enable, need not stop hcd
[    3.476573] [sunxi_hcd_host0]: Set USB Power OFF
[    3.481833] [sw_hcd0]: close_usb_clock
[    3.486013] [sw_hcd0]: sunxi_usb_host0_disable end
[    3.491729] mousedev: PS/2 mouse device common for all mice
[    3.498508] hn sunxi_rtc_probe enter
[    3.502632] hn rtc_device_register enter
[    3.507097] hn rtc-sunxi.c sunxi_rtc_gettime enter
[    3.512526] hn rtc-sunxi.c sunxi_rtc_settime enter
[    3.517936] hn rtc-sunxi.c sunxi_rtc_gettime enter
[    3.523365] hn rtc-sunxi.c sunxi_rtc_gettime enter
[    3.528778] hn rtc_device_register rtc->name= sunxi-rtc
[    3.534685] hn rtc_dev_prepare enter
[    3.538891] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    3.546461] sunxi cedar version 0.1
[    3.550500] [cedar]: install start!!!
[    3.554799] [cedar]: install end!!!
[    3.561821] axp22_dcdc1: Failed to create debugfs directory
[    3.569776] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    3.579233] Bluetooth: HCI UART driver ver 2.2
[    3.584183] Bluetooth: HCI H4 protocol initialized
[    3.589497] Bluetooth: HCI BCSP protocol initialized
[    3.595120] usbcore: registered new interface driver btusb
[    3.601225] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.607540] Bluetooth: BlueSleep Mode Driver Ver 1.1
[    3.613796] autohotplug_init init ok
[    3.617797] sunxi_cpufreq_initcall: clocks pll=1008000000,cpu=1008000000,axi=336000000
[    3.626621] cur: pll=1008000000, cpudiv=1, axidiv=3
[    3.632067] axp22_dcdc3: Failed to create debugfs directory
[    3.638265] sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 1200MHz, min freq: 120MHz
[    3.648994] -------------------CPU V-F Table--------------------
[    3.655680] 	frequency = 1536000KHz 	voltage = 1500mv
[    3.661307] 	frequency = 1344000KHz 	voltage = 1460mv
[    3.666910] 	frequency = 1200000KHz 	voltage = 1320mv
[    3.672528] 	frequency = 1008000KHz 	voltage = 1200mv
[    3.678132] 	frequency = 816000KHz 	voltage = 1100mv
[    3.683662] 	frequency = 648000KHz 	voltage = 1040mv
[    3.689168] 	frequency =    0KHz 	voltage = 1040mv
[    3.694498] 	frequency =    0KHz 	voltage = 1040mv
[    3.699813] -----------------------------------------------------
[    3.708980] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.85 2014-08-01 15:11) Compiled in Jan 24 2022 at 10:27:58
[    3.720387] [mmc]: sunxi_mci_init
[    3.724077] [mmc]: get mmc0's power supply 'axp22_dcdc1' ok
[    3.730268] [mmc]: get mmc0's 2xmode fail
[    3.734710] [mmc]: get mmc0's ddrmode fail
[    3.739249] [mmc]: get mmc0's sdc_ex_dly_used failed, use default dly
[    3.746413] [mmc]: get mmc1's sdc_power failed
[    3.751350] [mmc]: get mmc1's 2xmode fail
[    3.755792] [mmc]: get mmc1's ddrmode fail
[    3.760343] [mmc]: get mmc1's sdc_ex_dly_used failed, use default dly
[    3.767488] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
楼主 #2 2022-01-26 16:23:23
996054544
刚学习,也不是很会看日志,感觉重点就是,但不知道怎么解决,求大佬看看
