楼主 # 2022-01-26 16:27:10
droptop
已发帖子: 23
No Spidev device
Hi everyone,
I recently just built flashed the r3 with a nand image, using the sources from this repo.
cat /lib/modules/5.4.99/modules.builtin | grep spi
  confirms the presence of the spidev module. However there isn't any
/dev/spi*
file.  Looking at the contents of the file 'board/widora/mangopi/r3/devicetree/linux/devicetree.dts' I only find the device node for the first SPI controller (spi0) with child nodes spi-nor & spi-nand and none for the second SPI controller (spi1 ?). Do I need add another SPI device node to these file?? or is there something I'm missing??
Any help would be much appreciated
#1 2022-01-26 16:33:47
孤星泪
已发帖子: 235
Re: No Spidev device
please check CONFIG_SPI_SPIDEV=y
楼主 #2 2022-01-27 16:00:37
droptop
已发帖子: 23
Thank you @Lone Star Tears, for the quick response and sorry I'm only getting back now.
This is the section where CONFIG_SPI_SPIDEV is already set.
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=y
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
Do I need to set CONFIG_SPI_SLAVE??. And also what make target do I use to avoid recompiling everything.
#3 2022-01-27 16:13:48
shaoxi2010
已发帖子: 397
check the device tree compatible property, try "rohm,dh2228fv"
楼主 #4 2022-01-27 17:56:39
droptop
已发帖子: 23
Hi shaoxi2010,,
Checked board/allwinner/suniv-f1c100s/devicetree/linux/suniv-f1c100s.dtsi and board/widora/mangopi/r3/devicetree/linux/devicetree.dts. Got nothing
#5 2022-01-27 18:31:21
shaoxi2010
已发帖子: 397
the spidev need a device tree node, such as this.
&spi0 {
    spidev@0 {
        compatible = "rohm,dh2228fv";
        reg = <0>;
        spi-max-frequency = <24000000>;
楼主 #6 2022-01-27 19:06:03
droptop
已发帖子: 23
Yup I added it. Looking at the source (board/widora/mangopi/r3/devicetree/linux/devicetree.dts) there is no configuration for the second SPI controller (spi1), so I added one. Also the compatible string I use is 'linux,spidev'. I now get the device in /dev but it seems the a test program shows the SPI port isn't working. I'll keep trying..
最近编辑记录 droptop (2022-01-27 19:17:30)
