楼主 # 2022-02-02 21:29:46
lengyuefneg
已发帖子: 29
全志V3S debian系统 内存不足
今天试了一下debian系统,用的是debian9.9,然后配置好了以太网,正准备下载工具的时候,出现了问题。
在执行
apt-get install vim时,出现
[ 2690.831927] Tasks state (memory values in pages):
[ 2690.836623] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
[ 2690.845247] [    105]     0   105     3703      231    14336        0             0 systemd-journal
[ 2690.854296] [    107]     0   107     2991       85    12288        0         -1000 systemd-udevd
[ 2690.863173] [    145]   100   145     3967      103    16384        0             0 systemd-timesyn
[ 2690.872219] [    171]     0   171      744       49    10240        0             0 cron
[ 2690.880314] [    173]     0   173     5637      175    16384        0             0 rsyslogd
[ 2690.888743] [    192]     0   192      512       26     8192        0             0 agetty
[ 2690.897010] [    196]     0   196      512       26    10240        0             0 agetty
[ 2690.905278] [    197]     0   197      512       26     8192        0             0 agetty
[ 2690.913545] [    202]     0   202      512       26     8192        0             0 agetty
[ 2690.921811] [    203]     0   203      512       26     6144        0             0 agetty
[ 2690.930080] [    204]     0   204      512       26    10240        0             0 agetty
[ 2690.938334] [    205]     0   205     1144      101    10240        0             0 login
[ 2690.946515] [    227]     0   227      713       92    10240        0             0 bash
[ 2690.954610] [    540]     0   540     8428     7038    43008        0             0 apt-get
[ 2690.962964] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),task=apt-get,pid=540,uid=0
[ 2690.971252] Out of memory: Killed process 540 (apt-get) total-vm:33712kB, anon-rss:28152kB, file-rss:0kB, shmem-rss:0kB
[ 2691.003279] oom_reaper: reaped process 540 (apt-get), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Killed
应该是内存不足,有知道怎么去解决的吗?
#1 2022-02-07 09:27:43
mysteryli
已发帖子: 507
Re: 全志V3S debian系统 内存不足
可以开一下交换内存试试
#2 2022-02-07 09:37:07
shaoxi2010
已发帖子: 398
打开swap就行了,缺点就是慢,这么小的内存不适合debian
#3 2022-02-07 17:36:28
Fomalhaut
已发帖子: 38
V3s不是有512M内存吗?这也会不够,到底运行了多少程序?
楼主 #4 2022-02-08 22:20:43
lengyuefneg
已发帖子: 29
shaoxi2010 说:
好的,多谢。
#5 2022-02-08 22:24:59
shaoxi2010
已发帖子: 398
v3s有512M?不是64M么
#6 2022-02-09 11:02:59
romanljw
各位大佬,请问下应该如何打开swap,小白一个见笑了
