楼主 # 2022-02-12 13:33:22
dianjixz
D1 PD1&PD2引脚复用出现错误
最近使用 D1 时,想要使用 PD1&PD2 的串口复用功能.结果这个两个引脚一直在输出一个脉冲信号.改变了引脚复用关系寄存器后信号还在.
不知道是不是芯片自身的硬件引脚 bug.求大佬解答!
设备树引脚配置
两个引脚输出的情况!
在全志论坛的提问帖子!
https://bbs.aw-ol.com/topic/1025/d1-uart2-pd1-pd2%E5%BC%95%E8%84%9A%E7%94%B5%E5%B9%B3%E6%9C%89%E8%84%89%E5%86%B2-%E6%B1%82%E8%A7%A3
求有关大佬考证解答!
最近编辑记录 dianjixz (2022-02-12 13:36:50)
#1 2022-02-12 13:45:28
已发帖子: 3,391
Re: D1 PD1&PD2引脚复用出现错误
请发一下完整的 board.dts
楼主 #2 2022-02-12 14:12:35
dianjixz
卸掉 fb 模块后,引脚电平正常了.看样子是芯片的 disp 模块会强制在该引脚上输出一个信号.复用寄存器都屏蔽不掉这个信号.
比较坑的是,就算屏蔽了 fb 模块的设备树节点, D1 芯片的 disp 模块还是在工作,还是会输出一个信号.
简单的说就是 gpio 复用寄存器无法切断 disp 模块输出的信号.这是一大坑呀!
楼主 #3 2022-02-12 14:47:02
dianjixz
情况并没有改善,开启 uart2 后,信号又出现了!
下面是设备树配置
 * Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
 * fpga support.
/dts-v1/;
#include "sun20iw1p1.dtsi"
	compatible = "allwinner,d1", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
	aliases {
		dsp0 = &dsp0;
		dsp0_gpio_int= &dsp0_gpio_int;
	mcp2515_clock: mcp2515_clock {
		compatible = "fixed-clock";
		#clock-cells = <0>;
		clock-frequency  = <8000000>;
	reg_can_3v3: regulator@0 {
		reg = <0>;
		regulator-name = "can-3v3";
	dsp0: dsp0 {
		compatible = "allwinner,sun20iw1-dsp";
	dsp0_gpio_int: dsp0_gpio_int {
		compatible = "allwinner,sun20iw1-dsp-gpio-int";
		pin-group = "PB", "PC", "PD", "PE";
		status = "disabled";
	reg_vdd_cpu: vdd-cpu {
		compatible = "sunxi-pwm-regulator";
		pwms = <&pwm 0 5000 0>;
		regulator-name = "vdd_cpu";
		regulator-min-microvolt = <810000>;
		regulator-max-microvolt = <1160000>;
		regulator-ramp-delay = <25>;
		regulator-always-on;
		regulator-boot-on;
	reg_usb1_vbus: usb1-vbus {
		regulator-name = "usb1-vbus";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-enable-ramp-delay = <1000>;
		gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
		enable-active-high;
&CPU0 {
	cpu-supply = <&reg_vdd_cpu>;
&pio {
	sdc0_pins_a: sdc0@0 {
		allwinner,pins = "PF0", "PF1", "PF2",
				 "PF3", "PF4", "PF5";
		allwinner,function = "sdc0";
		allwinner,muxsel = <2>;
		allwinner,drive = <3>;
		allwinner,pull = <1>;
		function = "sdc0";
		drive-strength = <30>;
		bias-pull-up;
		power-source = <3300>;
	sdc0_pins_b: sdc0@1 {
		function = "sdc0";
		bias-pull-up;
		power-source = <1800>;
	sdc0_pins_c: sdc0@2 {
		function = "gpio_in";
	/* TODO: add jtag pin */
	sdc0_pins_d: sdc0@3 {
		pins = "PF2", "PF4";
		function = "uart0";
		drive-strength = <10>;
		bias-pull-up;
	sdc0_pins_e: sdc0@4 {
		pins = "PF0", "PF1", "PF3",
			"PF5";
		function = "jtag";
		bias-pull-up;
	sdc1_pins_a: sdc1@0 {
		pins = "PG0", "PG1", "PG2",
		       "PG3", "PG4", "PG5";
		function = "sdc1";
		bias-pull-up;
	sdc1_pins_b: sdc1@1 {
	sdc2_pins_a: sdc2@0 {
		allwinner,pins = "PC2", "PC3", "PC4",
				 "PC5", "PC6", "PC7";
		allwinner,function = "sdc2";
		allwinner,muxsel = <3>;
		function = "sdc2";
		bias-pull-up;
	sdc2_pins_b: sdc2@1 {
	wlan_pins_a:wlan@0 {
		pins = "PG11";
		function = "clk_fanout1";
	uart0_pins_a: uart0_pins@0 {  /* For nezha board */
		pins = "PB8", "PB9";
		function = "uart0";
		bias-pull-up;
	uart0_pins_b: uart0_pins@1 {  /* For nezha board */
	uart1_pins_a: uart1_pins@0 {  /* For EVB1 board */
		pins = "PG6", "PG7", "PG8", "PG9";
		function = "uart1";
		bias-pull-up;
	uart1_pins_b: uart1_pins {  /* For EVB1 board */
	uart2_pins_a: uart2_pins@0 {  /* For EVB1 board */
		pins = "PD1", "PD2";
		function = "uart2";
		// muxsel = <5>;
		// muxsel = <1>;
		bias-pull-up;
	uart2_pins_b: uart2_pins@1 {  /* For EVB1 board */
	// uart2_pins_c: uart2_pins {  /* For EVB1 board */
	// 	pins = "PC1";
	// 	function = "gpio_in";
	uart3_pins_a: uart3_pins@0 {  /* For EVB1 board */
		pins = "PC6", "PC7";
		// pins = "PD10", "PD11";
		function = "uart3";
		muxsel = <4>;
		// muxsel = <5>;
		bias-pull-up;
	uart4_pins_a: uart4_pins@0 {  /* For EVB1 board */
		pins = "PB2", "PB3";
		function = "uart4";
		muxsel = <7>;
		// muxsel = <5>;
		bias-pull-up;
	twi0_pins_a: twi0@0 {
		pins = "PB10", "PB11";	/*sck sda*/
		function = "twi0";
	twi0_pins_b: twi0@1 {
	twi1_pins_a: twi1@0 {
		pins = "PB4", "PB5";
		function = "twi1";
	twi1_pins_b: twi1@1 {
	twi2_pins_a: twi2@0 {
		pins = "PB0", "PB1";
		function = "twi2";
	twi2_pins_b: twi2@1 {
	twi3_pins_a: twi3@0 {
		pins = "PB6", "PB7";
		function = "twi3";
	twi3_pins_b: twi3@1 {
	gmac_pins_a: gmac@0 {
		// pins = "PE0", "PE1", "PE2", "PE3",
		//        "PE4", "PE5", "PE6", "PE7",
		//        "PE8", "PE9", "PE10", "PE11",
		//        "PE12", "PE13", "PE14", "PE15";
		       "PE8", "PE9";
		function = "gmac0";
	gmac_pins_b: gmac@1 {
		       "PE8", "PE9";
	// dmic_pins_a: dmic@0 {
	// 	/* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
	// 	pins = "PE17", "PB11", "PB10", "PD17";
	// 	function = "dmic";
	// 	drive-strength = <20>;
	// 	bias-disable;
	// dmic_pins_b: dmic@1 {
	// 	function = "io_disabled";
	// 	bias-disable;
	// daudio0_pins_a: daudio0@0 {
	// 	pins = "PE17", "PE16", "PE15", "PE14", "PE13";
	// 	function = "i2s0";
	// 	bias-disable;
	// daudio0_pins_b: daudio0_sleep@0 {
	// 	bias-disable;
	// daudio1_pins_a: daudio1@0 {
	// 	pins = "PG11", "PG12", "PG13", "PG14", "PG15";
	// 	function = "i2s1";
	// 	bias-disable;
	// daudio1_pins_b: daudio1_sleep@0 {
	// 	bias-disable;
	// daudio2_pins_a: daudio2@0 {
	// 	/* I2S_PIN: MCLK, BCLK, LRCK */
	// 	pins = "PB7", "PB5", "PB6";
	// 	function = "i2s2";
	// 	bias-disable;
	// daudio2_pins_b: daudio2@1 {
	// 	/* I2S_PIN: DOUT0 */
	// 	pins = "PB4";
	// 	function = "i2s2_dout";
	// 	bias-disable;
	// daudio2_pins_c: daudio2@2 {
	// 	/* I2S_PIN: DIN0 */
	// 	pins = "PB3";
	// 	function = "i2s2_din";
	// 	bias-disable;
	// daudio2_pins_d: daudio2_sleep@0 {
	// 	pins = "PB7", "PB5", "PB6", "PB4", "PB3";
	// 	bias-disable;
	spdif_pins_a: spdif@0 {
		/* SPDIF_PIN: SPDIF_OUT */
		pins = "PB0";
		function = "spdif";
		bias-disable;
	spdif_pins_b: spdif_sleep@0 {
		pins = "PB0";
		bias-disable;
	spi0_pins_a: spi0@0 {
		// pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
		pins = "PC2", "PC4", "PC5"; /*clk mosi miso hold wp*/
		function = "spi0";
		muxsel = <2>;
	spi0_pins_b: spi0@1 {
		// pins = "PC3", "PC7", "PC6";
		pins = "PC3";
		function = "spi0";
		muxsel = <2>;
		bias-pull-up;   /* only CS should be pulled up */
	spi0_pins_c: spi0@2 {
		// pins = "PC2", "PC3", "PC4", "PC5","PC6", "PC7";
		pins = "PC2", "PC3", "PC4", "PC5";
		muxsel = <0>;
	can0_pins_a: can0@0 {
		pins = "PD16";
		muxsel = <0>;
		bias-pull-up;
	spi1_pins_a: spi1@0 {
		pins = "PD11", "PD12", "PD13","PD14", "PD15"; /*clk mosi miso hold wp*/
		function = "spi1";
	spi1_pins_b: spi1@1 {
		pins = "PD10";
		function = "spi1";
		bias-pull-up;   // only CS should be pulled up
	spi1_pins_c: spi1@2 {
		pins = "PD10", "PD11", "PD12", "PD13","PD14", "PD15";
	ledc_pins_a: ledc@0 {
		pins = "PC0";
		function = "ledc";
	ledc_pins_b: ledc@1 {
		pins = "PC0";
	pwm0_pin_a: pwm0@0 {
		pins = "PD16";
		function = "pwm0";
		bias-pull-up;
	pwm0_pin_b: pwm0@1 {
		pins = "PD16";
		bias-disable;
	pwm2_pin_a: pwm2@0 {
		pins = "PD18";
		function = "pwm2";
		bias-pull-up;
	pwm2_pin_b: pwm2@1 {
		pins = "PD18";
	pwm7_pin_a: pwm7@0 {
		pins = "PD22";
		function = "pwm7";
		bias-pull-up;
	pwm7_pin_b: pwm7@1 {
		pins = "PD22";
	s_cir0_pins_a: s_cir@0 {
		pins = "PB12";
		function = "ir";
		bias-pull-up;
	s_cir0_pins_b: s_cir@1 {
		pins = "PB12";
	ir1_pins_a: ir1@0 {
		pins = "PB0";
		function = "ir";
		bias-pull-up;
	ir1_pins_b: ir1@1 {
		pins = "PB0";
&uart0 {
	pinctrl-0 = <&uart0_pins_a>;
	pinctrl-1 = <&uart0_pins_b>;
&uart1 {
	pinctrl-0 = <&uart1_pins_a>;
	pinctrl-1 = <&uart1_pins_b>;
echo 98 > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio98/direction
echo 1 > /sys/class/gpio/gpio98/value
&uart2 {
	pinctrl-0 = <&uart2_pins_a>;
	pinctrl-1 = <&uart2_pins_b>;
	uart3_type = <2>;
&uart3 {
	/*compatible = "allwinner,sun20iw1-dsp-uart";*/
	pinctrl-0 = <&uart3_pins_a>;
	pinctrl-1 = <&uart3_pins_a>;
	uart3_type = <2>;
&uart4 {
	pinctrl-0 = <&uart4_pins_a>;
	pinctrl-1 = <&uart4_pins_a>;
	uart4_type = <2>;
&soc {
	card0_boot_para@2 {
		 * Avoid dtc compiling warnings.
		 * @TODO: Developer should modify this to the actual value
		reg = <0x0 0x2 0x0 0x0>;
		device_type = "card0_boot_para";
		card_ctrl = <0x0>;
		card_high_speed = <0x1>;
		card_line = <0x4>;
		pinctrl-0 = <&sdc0_pins_a>;
	card2_boot_para@3 {
		reg = <0x0 0x3 0x0 0x0>;
		device_type = "card2_boot_para";
		card_ctrl = <0x2>;
		card_line = <0x4>;
		pinctrl-0 = <&sdc2_pins_a>;
		/*pinctrl-0 = <&sdc0_pins_a>;*/
		/*sdc_ex_dly_used = <0x2>;*/
		sdc_io_1v8 = <0x1>;
		/*sdc_type = "tm4";*/
		sdc_tm4_hs200_max_freq = <150>;
		sdc_tm4_hs400_max_freq = <100>;
		sdc_ex_dly_used = <2>;
		/*sdc_tm4_win_th = <8>;*/
		/*sdc_dis_host_caps = <0x180>;*/
	rfkill: rfkill@0 {
		compatible    = "allwinner,sunxi-rfkill";
		chip_en;
		power_en;
		status        = "okay";
		wlan: wlan@0 {
			compatible    = "allwinner,sunxi-wlan";
			pinctrl-0 = <&wlan_pins_a>;
			pinctrl-names = "default";
			clock-names = "32k-fanout1";
			clocks = <&ccu CLK_FANOUT1_OUT>;
			wlan_busnum    = <0x1>;
			wlan_regon    = <&pio PG 12 GPIO_ACTIVE_HIGH>;
			wlan_hostwake  = <&pio PG 10 GPIO_ACTIVE_HIGH>;
			/*wlan_power    = "VCC-3V3";*/
			/*wlan_power_vol = <3300000>;*/
			/*interrupt-parent = <&pio>;
			interrupts = < PG 10 IRQ_TYPE_LEVEL_HIGH>;*/
			wakeup-source;
		bt: bt@0 {
			compatible    = "allwinner,sunxi-bt";
			/*bt_power_num = <0x01>;*/
			/*bt_power      = "axp803-dldo1";*/
			/*bt_io_regulator = "axp803-dldo1";*/
			/*bt_io_vol = <3300000>;*/
			/*bt_power_vol = <330000>;*/
			bt_rst_n      = <&pio PG 18 GPIO_ACTIVE_LOW>;
			status        = "okay";
	btlpm: btlpm@0 {
		compatible  = "allwinner,sunxi-btlpm";
		uart_index  = <0x1>;
		bt_wake     = <&pio PG 16 GPIO_ACTIVE_HIGH>;
		bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
		status      = "okay";
	addr_mgt: addr_mgt@0 {
		compatible     = "allwinner,sunxi-addr_mgt";
		type_addr_wifi = <0x0>;
		type_addr_bt   = <0x0>;
		type_addr_eth  = <0x0>;
		status         = "okay";
&sdc2 {
	non-removable;
	bus-width = <4>;
	mmc-ddr-1_8v;
	mmc-hs200-1_8v;
	no-sdio;
	no-sd;
	ctl-spec-caps = <0x308>;
	cap-mmc-highspeed;
	sunxi-power-save-mode;
	sunxi-dis-signal-vol-sw;
	mmc-bootpart-noacc;
	max-frequency = <150000000>;
	/*vmmc-supply = <&reg_dcdc1>;*/
	/*emmc io vol 3.3v*/
	/*vqmmc-supply = <&reg_aldo1>;*/
	/*emmc io vol 1.8v*/
	/*vqmmc-supply = <&reg_eldo1>;*/
&sdc0 {
	bus-width = <4>;
	cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
	/*non-removable;*/
	/*broken-cd;*/
	cd-inverted;
	/*data3-detect;*/
	/*card-pwr-gpios = <&pio PH 14 1 1 2 0xffffffff>;*/
	cd-used-24M;
	cap-sd-highspeed;
	/*sd-uhs-sdr50;*/
	/*sd-uhs-ddr50;*/
	/*sd-uhs-sdr104;*/
	no-sdio;
	no-mmc;
	/*sunxi-dis-signal-vol-sw;*/
	ctl-spec-caps = <0x8>;
	/*vqmmc33sw-supply = <&reg_dcdc1>;*/
	/*vdmmc33sw-supply = <&reg_dcdc1>;*/
	/*vqmmc18sw-supply = <&reg_eldo1>;*/
	/*vdmmc18sw-supply = <&reg_eldo1>;*/
&sdc1 {
	bus-width = <4>;
	no-mmc;
	no-sd;
	cap-sd-highspeed;
	/*sd-uhs-sdr12*/
	/*sd-uhs-sdr25;*/
	/*sd-uhs-sdr50;*/
	/*sd-uhs-ddr50;*/
	/*sd-uhs-sdr104;*/
	/*sunxi-power-save-mode;*/
	cap-sdio-irq;
	keep-power-in-suspend;
	ignore-pm-notify;
tvd configuration
used                   (create device, 0: do not create device, 1: create device)
agc_auto_enable        (0: agc manual mode,agc_manual_value is valid; 1: agc auto mode)
agc_manual_value       (agc manual value, default value is 64)
cagc_enable            (cagc        0: disable, 1: enable)
fliter_used            (3d fliter   0: disable, 1: enable)
support two PMU power  (tvd_power0, tvd_power1)
support two GPIO power (tvd_gpio0, tvd_gpio1)
NOTICE: If tvd need pmu power or gpio power,params need be configured under [tvd]
tvd_sw                 (the switch of all tvd driver.)
tvd_interface          (0: cvbs, 1: ypbpr,)
tvd_format             (0:TVD_PL_YUV420 , 1: MB_YUV420, 2: TVD_PL_YUV422)
tvd_system             (0:ntsc, 1:pal)
tvd_row                (total row number in multi channel mode 1-2)
tvd_column             (total column number in multi channel mode 1-2)
tvd_channelx_en        (0:disable, 1~4:position in multi channel mode,In single channel
                       mode,mean enable)
tvd_row*tvd_column is the total tvd channel number to be used in multichannel mode
|         1          |         2          |
|         3          |         4          |
// &tvd {
// 	tvd_sw          = <1>;
// 	tvd_interface   = <0>;
// 	tvd_format      = <0>;
// 	tvd_system      = <1>;
// 	tvd_row         = <1>;
// 	tvd_column      = <1>;
// 	tvd_channel0_en = <1>;
// 	tvd_channel1_en = <0>;
// 	tvd_channel2_en = <0>;
// 	tvd_channel3_en = <0>;
// 	/*tvd_gpio0 = <&pio PD 22 GPIO_ACTIVE_HIGH>;*/
// 	/*tvd_gpio1 = <&pio PD 23 GPIO_ACTIVE_HIGH>;*/
// 	/*tvd_gpio2 = <&pio PD 24 GPIO_ACTIVE_HIGH>;*/
// 	/*	dc1sw-supply = <&reg_dc1sw>;*/
// 	/*	eldo3-supply = <&reg_eldo3>;*/
// 	/*tvd_power0      = "dc1sw"*/
// 	/*tvd_power1      = "eldo3"*/
// &tvd0 {
// 	used                    = <1>;
// 	agc_auto_enable         = <1>;
// 	agc_manual_value        = <64>;
// 	cagc_enable             = <1>;
// 	fliter_used             = <1>;
/* Audio Driver modules */
&sunxi_rpaf_dsp0 {
/* if audiocodec is used, sdc0 and uart0 should be closed to enable PA. */
&codec {
	/* MIC and headphone gain setting */
	mic1gain 	= <0x13>;
	mic2gain 	= <0x13>;
	mic3gain 	= <0x13>;
	/* ADC/DAC DRC/HPF func enabled */
        /* 0x1:DAP_HP_EN; 0x2:DAP_SPK_EN; 0x3:DAP_HPSPK_EN */
	adcdrc_cfg 	= <0x0>;
	adchpf_cfg 	= <0x1>;
	dacdrc_cfg 	= <0x0>;
	dachpf_cfg 	= <0x0>;
	/* Volume about */
	digital_vol 	= <0x00>;
	lineout_vol 	= <0x1a>;
	headphonegain	= <0x03>;
	/* Pa enabled about */
	pa_level 	= <0x01>;
	pa_pwr_level 	= <0x01>;
	pa_msleep_time 	= <0x78>;
	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>; */
	/* gpio-spk-pwr	= <&pio PF 4 GPIO_ACTIVE_HIGH>; */
	/* regulator about */
	/* avcc-supply	= <&reg_aldo1>; */
	/* hpvcc-supply	= <&reg_eldo1>; */
// &sndcodec {
// 	hp_detect_case	= <0x01>;
// 	jack_enable	= <0x01>;
// 	status = "okay";
&dummy_cpudai {
	/* CMA config about */
	playback_cma	= <128>;
	capture_cma	= <256>;
// &dmic {
// 	pinctrl-names   = "default","sleep";
// 	pinctrl-0       = <&dmic_pins_a>;
// 	pinctrl-1       = <&dmic_pins_b>;
// 	status = "okay";
// &sounddmic {
// 	status = "okay";
// &dmic_codec {
// 	status = "okay";
 * pcm_lrck_period	16/32/64/128/256
 *			(set 0x20 for HDMI audio out)
 * slot_width_select	16bits/20bits/24bits/32bits
 * frametype		0 --> short frame = 1 clock width;
 *			1 --> long frame = 2 clock width;
 * tdm_config		0 --> pcm
 *			1 --> i2s
 *			(set 0x01 for HDMI audio out)
 * mclk_div		0 --> not output
 *			1/2/4/6/8/12/16/24/32/48/64/96/128/176/192
 *			(set mclk as external codec clk source, freq is pll_audio/mclk_div)
 * pinctrl_used		0 --> I2S/PCM use for internal (e.g. HDMI)
 *			1 --> I2S/PCM use for external audio
 * daudio_type:		0 --> external audio type
 *			1 --> HDMI audio type
// &daudio0 {
// 	mclk_div 	= <0x01>;
// 	frametype 	= <0x00>;
// 	tdm_config 	= <0x01>;
// 	sign_extend 	= <0x00>;
// 	msb_lsb_first 	= <0x00>;
// 	pcm_lrck_period = <0x80>;
// 	slot_width_select = <0x20>;
// 	pinctrl-names   = "default", "sleep";
// 	pinctrl-0       = <&daudio0_pins_a>;
// 	pinctrl-1       = <&daudio0_pins_b>;
// 	pinctrl_used	= <0x0>;
// 	status = "disabled";
 * simple-audio-card,name	name of sound card, e.g.
 *				"snddaudio0" --> use for external audio
 *				"sndhdmi" --> use for HDMI audio
 * sound-dai			"snd-soc-dummy" --> use for I2S
 *				"hdmiaudio" --> use for HDMI audio
 *				"ac108" --> use for external audio of ac108
// &sounddaudio0 {
// 	/* simple-audio-card,format = "i2s"; */
// 	/* simple-audio-card,frame-master = <&daudio0_master>; */
// 	/* simple-audio-card,bitclock-master = <&daudio0_master>; */
// 	/* simple-audio-card,bitclock-inversion; */
// 	/* simple-audio-card,frame-inversion; */
// 	daudio0_master: simple-audio-card,codec {
// 		/* sound-dai = <&ac108>; */
// &daudio1 {
// 	pinctrl-0       = <&daudio1_pins_a>;
// 	pinctrl-1       = <&daudio1_pins_b>;
// &sounddaudio1 {
// 	daudio1_master: simple-audio-card,codec {
// &daudio2 {
// 	mclk_div 	= <0x00>;
// 	tx_data_mode 	= <0x00>;
// 	rx_data_mode 	= <0x00>;
// 	pcm_lrck_period = <0x20>;
// 	asrc_function_en  = <0x00>;
// 	/*pinctrl-0       = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>;*/
// 	/*pinctrl-1       = <&daudio2_pins_d>;*/
// 	/* HDMI audio, no need pin */
// 	pinctrl-0;
// 	pinctrl-1;
// 	daudio_type	= <0x1>;
// 	status = "okay";
/* if HDMI audio is used, daudio2 should be enable. */
// &hdmiaudio {
// 	status = "okay";
// &sounddaudio2 {
// 	status = "okay";
// 	simple-audio-card,name = "sndhdmi";
// 	daudio2_master: simple-audio-card,codec {
// 		sound-dai = <&hdmiaudio>;
&spdif {
	pinctrl-0       = <&spdif_pins_a>;
	pinctrl-1       = <&spdif_pins_b>;
// &soundspdif {
 *usb_port_type: usb mode. 0-device, 1-host, 2-otg.
 *usb_detect_type: usb hotplug detect mode. 0-none, 1-vbus/id detect, 2-id/dpdm detect.
 *usb_detect_mode: 0-thread scan, 1-id gpio interrupt.
 *usb_id_gpio: gpio for id detect.
 *usb_det_vbus_gpio: gpio for id detect. gpio or "axp_ctrl";
 *usb_wakeup_suspend:0-SUPER_STANDBY, 1-USB_STANDBY.
&usbc0 {
	device_type = "usbc0";
	usb_port_type = <0x2>;
	usb_detect_type = <0x1>;
	usb_detect_mode = <0>;
	usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
	enable-active-high;
	usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
	usb_wakeup_suspend = <0>;
	usb_serial_unique = <0>;
	usb_serial_number = "20080411";
	rndis_wceis = <1>;
&ehci0 {
	drvvbus-supply = <&reg_usb1_vbus>;
&ohci0 {
&usbc1 {
	device_type = "usbc1";
	usb_regulator_io = "nocare";
&ehci1 {
&ohci1 {
&twi0 {
	clock-frequency = <400000>;
	pinctrl-0 = <&twi0_pins_a>;
	pinctrl-1 = <&twi0_pins_b>;
	eeprom@50 {
		compatible = "atmel,24c16";
		reg = <0x50>;
&twi1 {
	pinctrl-0 = <&twi1_pins_a>;
	pinctrl-1 = <&twi1_pins_b>;
&twi2 {
	pinctrl-0 = <&twi2_pins_a>;
	pinctrl-1 = <&twi2_pins_b>;
	dmas = <&dma 45>, <&dma 45>;
	dma-names = "tx", "rx";
	/* pcf8574-usage:
	 * only use gpio0~7, 0 means PP0.
	 * pin set:
	 * gpios = <&pcf8574 0 GPIO_ACTIVE_LOW>;
	 * interrupt set:
	 * interrupt-parent = <&pcf8574>;
	 * interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
	pcf8574: gpio@38 {
		compatible = "nxp,pcf8574";
		reg = <0x38>;
		gpio_base = <2020>;
		gpio-controller;
		#gpio-cells = <2>;
		interrupt-controller;
		#interrupt-cells = <2>;
		interrupts = <PB 2 IRQ_TYPE_EDGE_FALLING>;
	ctp@14 {
		compatible = "allwinner,goodix";
		device_type = "ctp";
		reg = <0x14>;
		ctp_name = "gt9xxnew_ts";
		ctp_twi_id = <0x2>;
		ctp_twi_addr = <0x14>;
		ctp_screen_max_x = <0x320>;
		ctp_screen_max_y = <0x500>;
		ctp_revert_x_flag = <0x0>;
		ctp_revert_y_flag = <0x0>;
		ctp_exchange_x_y_flag = <0x0>;
		ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
		ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
&twi3 {
	pinctrl-0 = <&twi3_pins_a>;
	pinctrl-1 = <&twi3_pins_b>;
&gmac0 {
	phy-mode = "rmii";
	use_ephy25m = <1>;
	pinctrl-0 = <&gmac_pins_a>;
	pinctrl-1 = <&gmac_pins_b>;
	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
	tx-delay = <7>; /*2~4*/
	rx-delay = <31>;
&spi0 {
	clock-frequency = <100000000>;
	pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
	pinctrl-1 = <&spi0_pins_c>;
	/*spi-supply = <&reg_dcdc1>;*/
	spi_slave_mode = <0>;
	spi0_cs_number = <1>;
	spi0_cs_bitmap = <1>;
	// spi-nand@0 {
	// 	compatible = "spi-nand";
	// 	spi-max-frequency=<0x5F5E100>;
	// 	reg = <0x0>;
	// 	spi-rx-bus-width=<0x04>;
	// 	spi-tx-bus-width=<0x04>;
	// 	status="disabled";
	can0@0 {
		compatible = "microchip,mcp2515";
		spi-max-frequency=<0x989680>;
		reg = <0>;
		pinctrl-0 = <&can0_pins_a>;
		pinctrl-1 = <&can0_pins_a>;
		clocks = <&mcp2515_clock>;
		interrupts = <PD 16 IRQ_TYPE_EDGE_FALLING>;
		vdd-supply = <&reg_pio3_3>;
		xceiver-supply = <&reg_pio3_3>;
&spi1 {
	pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
	pinctrl-1 = <&spi1_pins_c>;
	// spi_board1@0 {
	// 	device_type = "spi_board1";
	// 	compatible = "rohm,dh2228fv";
	// 	spi-max-frequency = <0x5f5e100>;
	// 	reg = <0x0>;
	// 	spi-rx-bus-width = <0x4>;
	// 	spi-tx-bus-width = <0x4>;
&ledc {
	pinctrl-0 = <&ledc_pins_a>;
	pinctrl-1 = <&ledc_pins_b>;
	led_count = <12>;
	output_mode = "GRB";
	reset_ns = <84>;
	t1h_ns = <800>;
	t1l_ns = <320>;
	t0h_ns = <300>;
	t0l_ns = <800>;
	wait_time0_ns = <84>;
	wait_time1_ns = <84>;
	wait_data_time_ns = <600000>;
	status	= "okay";
&keyboard0 {
	key0 = <210 0x160>;
	wakeup-source;
disp init configuration
disp_mode             (0:screen0<screen0,fb0>)
screenx_output_type   (0:none; 1:lcd; 2:tv; 3:hdmi;5:vdpo)
screenx_output_mode   (used for hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50)
                      (5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60)
screenx_output_format (for hdmi, 0:RGB 1:yuv444 2:yuv422 3:yuv420)
screenx_output_bits   (for hdmi, 0:8bit 1:10bit 2:12bit 2:16bit)
screenx_output_eotf   (for hdmi, 0:reserve 4:SDR 16:HDR10 18:HLG)
screenx_output_cs     (for hdmi, 0:undefined  257:BT709 260:BT601  263:BT2020)
screenx_output_dvi_hdmi (for hdmi, 0:undefined 1:dvi mode 2:hdmi mode)
screen0_output_range   (for hdmi, 0:default 1:full 2:limited)
screen0_output_scan    (for hdmi, 0:no data 1:overscan 2:underscan)
screen0_output_aspect_ratio  (for hdmi, 8-same as original picture 9-4:3 10-16:9 11-14:9)
fbx format            (4:RGB655 5:RGB565 6:RGB556 7:ARGB1555 8:RGBA5551 9:RGB888 10:ARGB8888 12:ARGB4444)
fbx pixel sequence    (0:ARGB 1:BGRA 2:ABGR 3:RGBA)
fb0_scaler_mode_enable(scaler mode enable, used FE)
fbx_width,fbx_height  (framebuffer horizontal/vertical pixels, fix to output resolution while equal 0)
lcdx_backlight        (lcd init backlight,the range:[0,256],default:197
lcdx_yy               (lcd init screen bright/contrast/saturation/hue, value:0~100, default:50/50/57/50)
lcd0_contrast         (LCD contrast, 0~100)
lcd0_saturation       (LCD saturation, 0~100)
lcd0_hue              (LCD hue, 0~100)
framebuffer software rotation setting:
disp_rotation_used:   (0:disable; 1:enable,you must set fbX_width to lcd_y,
set fbX_height to lcd_x)
degreeX:              (X:screen index; 0:0 degree; 1:90 degree; 3:270 degree)
degreeX_Y:            (X:screen index; Y:layer index 0~15; 0:0 degree; 1:90 degree; 3:270 degree)
devX_output_type : config output type in bootGUI framework in UBOOT-2018.
				   (0:none; 1:lcd; 2:tv; 4:hdmi;)
devX_output_mode : config output resolution(see include/video/sunxi_display2.h) of bootGUI framework in UBOOT-2018
devX_screen_id   : config display index of bootGUI framework in UBOOT-2018
devX_do_hpd      : whether do hpd detectation or not in UBOOT-2018
chn_cfg_mode     : Hardware DE channel allocation config. 0:single display with 6
				   channel, 1:dual display with 4 channel in main display and 2 channel in second
                   display, 2:dual display with 3 channel in main display and 3 channel in second
                   in display.
// &disp {
// 	disp_init_enable         = <1>;
// 	disp_mode                = <0>;
// 	screen0_output_type      = <1>;
// 	screen0_output_mode      = <4>;
// 	screen1_output_type      = <3>;
// 	screen1_output_mode      = <10>;
// 	screen1_output_format    = <0>;
// 	screen1_output_bits      = <0>;
// 	screen1_output_eotf      = <4>;
// 	screen1_output_cs        = <257>;
// 	screen1_output_dvi_hdmi  = <2>;
// 	screen1_output_range     = <2>;
// 	screen1_output_scan      = <0>;
// 	screen1_output_aspect_ratio = <8>;
// 	dev0_output_type         = <1>;
// 	dev0_output_mode         = <4>;
// 	dev0_screen_id           = <0>;
// 	dev0_do_hpd              = <0>;
// 	dev1_output_type         = <4>;
// 	dev1_output_mode         = <10>;
// 	dev1_screen_id           = <1>;
// 	dev1_do_hpd              = <1>;
// 	def_output_dev           = <0>;
// 	hdmi_mode_check          = <1>;
// 	fb0_format               = <0>;
// 	fb0_width                = <0>;
// 	fb0_height               = <0>;
// 	fb1_format               = <0>;
// 	fb1_width                = <0>;
// 	fb1_height               = <0>;
// 	chn_cfg_mode             = <1>;
// 	disp_para_zone           = <1>;
// 	/*VCC-LCD*/
// 	/*VCC-DSI*/
// 	/*VCC-PD*/
// /*	dcdc1-supply = <&reg_dcdc1>;*/
;lcd0 configuration
;lcd_if:               0:hv(sync+de); 1:8080; 2:ttl; 3:lvds; 4:dsi; 5:edp; 6:extend dsi
;lcd_hv_if             0:Parallel RGB; 8:Serial RGB; 10:Dummy RGB; 11: RGB Dummy;12:CCIR656
;lcd_hv_clk_phase      0:0 degree;1:90 degree;2:180 degree;3:270 degree
;lcd_hv_sync_polarity  0:vs low,hs low; 1:vs high,hslow; 2:vs low,hs high; 3:vs high,hs high
;lcd_hv_syuv_seq       0:YUYV; 1:YVYU; 2:UYVY; 3:VYUY
;lcd_cpu_if            0:18bit/1 cycle parallel(RGB666); 4:16bit/1cycle parallel (RGB565)
;                      6:18bit/3 cycle parallel(RGB666); 7:16bit/2cycle parallel (RGB565)
;lcd_cpu_te            0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge;
;lcd_dsi_if            0:video mode; 1: Command mode; 2:video burst mode
;lcd_dsi_te            0:frame auto trigger; 1:frame triggered by te rising edge; 2:frame triggered by te falling edge;
;lcd_x:                lcd horizontal resolution
;lcd_y:                lcd vertical resolution
;lcd_width:            width of lcd in mm
;lcd_height:           height of lcd in mm
;lcd_dclk_freq:        in MHZ unit
;lcd_pwm_freq:         in HZ unit
;lcd_pwm_pol:          lcd backlight PWM polarity
;lcd_pwm_max_limit     lcd backlight PWM max limit(<=255)
;lcd_hbp:              hsync back porch(pixel) + hsync plus width(pixel);
;lcd_ht:               hsync total cycle(pixel)
;lcd_vbp:              vsync back porch(line) + vysnc plus width(line)
;lcd_vt:               vysnc total cycle(line)
;lcd_hspw:             hsync plus width(pixel)
;lcd_vspw:             vysnc plus width(pixel)
;lcd_lvds_if:          0:single link;  1:dual link
;lcd_lvds_colordepth:  0:8bit; 1:6bit
;lcd_lvds_mode:        0:NS mode; 1:JEIDA mode
;lcd_frm:              0:disable; 1:enable rgb666 dither; 2:enable rgb656 dither
;lcd_io_phase:         0:noraml; 1:intert phase(0~3bit: vsync phase; 4~7bit:hsync phase;
;                      8~11bit:dclk phase; 12~15bit:de phase)
;lcd_gamma_en          lcd gamma correction enable
;lcd_bright_curve_en   lcd bright curve correction enable
;lcd_cmap_en           lcd color map function enable
;deu_mode              0:smoll lcd screen; 1:large lcd screen(larger than 10inch)
;lcdgamma4iep:         Smart Backlight parameter, lcd gamma vale * 10;
;                      decrease it while lcd is not bright enough; increase while lcd is too bright
;smart_color           90:normal lcd screen 65:retina lcd screen(9.7inch)
;Pin setting for special function ie.LVDS, RGB data or vsync
;   name(donot care) = port:PD12<pin function><pull up or pull down><drive ability><output level>
;Pin setting for gpio:
;   lcd_gpio_X     = port:PD12<pin function><pull up or pull down><drive ability><output level>
;Pin setting for backlight enable pin
;   lcd_bl_en     = port:PD12<pin function><pull up or pull down><drive ability><output level>
;fsync setting, pulse to csi
;lcd_fsync_en          (0:disable fsync,1:enable)
;lcd_fsync_act_time    (active time of fsync, unit:pixel)
;lcd_fsync_dis_time    (disactive time of fsync, unit:pixel)
;lcd_fsync_pol         (0:positive;1:negative)
;gpio config: <&pio for cpu or &r_pio for cpus, port, port num, pio function,
pull up or pull down(default 0), driver level(default 1), data>
;For dual link lvds: use lvds2link_pins_a  and lvds2link_pins_b instead
;For rgb24: use rgb24_pins_a  and rgb24_pins_b instead
;For lvds1: use lvds1_pins_a  and lvds1_pins_b instead
;For lvds0: use lvds0_pins_a  and lvds0_pins_b instead
// &lcd0 {
// 	lcd_used            = <1>;
// 	lcd_driver_name     = "tft08006";
// 	lcd_backlight       = <100>;
// 	lcd_if              = <4>;
// 	lcd_x               = <800>;
// 	lcd_y               = <1280>;
// 	lcd_width           = <52>;
// 	lcd_height          = <52>;
// 	lcd_dclk_freq       = <70>;
// 	lcd_pwm_used        = <1>;
// 	lcd_pwm_ch          = <2>;
// 	lcd_pwm_freq        = <1000>;
// 	lcd_pwm_pol         = <0>;
// 	lcd_pwm_max_limit   = <255>;
// 	lcd_hbp             = <32>;
// 	lcd_ht              = <868>;
// 	lcd_hspw            = <4>;
// 	lcd_vbp             = <12>;
// 	lcd_vt              = <1311>;
// 	lcd_vspw            = <4>;
// 	lcd_dsi_if          = <0>;
// 	lcd_dsi_lane        = <4>;
// 	lcd_lvds_if         = <0>;
// 	lcd_lvds_colordepth = <0>;
// 	lcd_lvds_mode       = <0>;
// 	lcd_frm             = <0>;
// 	lcd_hv_clk_phase    = <0>;
// 	lcd_hv_sync_polarity= <0>;
// 	lcd_io_phase        = <0x0000>;
// 	lcd_gamma_en        = <0>;
// 	lcd_bright_curve_en = <0>;
// 	lcd_cmap_en         = <0>;
// 	lcd_fsync_en        = <0>;
// 	lcd_fsync_act_time  = <1000>;
// 	lcd_fsync_dis_time  = <1000>;
// 	lcd_fsync_pol       = <0>;
// 	deu_mode            = <0>;
// 	lcdgamma4iep        = <22>;
// 	smart_color         = <90>;
// 	lcd_gpio_0 =  <&pio PG 13 GPIO_ACTIVE_HIGH>;
// 	pinctrl-0 = <&dsi4lane_pins_a>;
// 	pinctrl-1 = <&dsi4lane_pins_b>;
// 	status = "disabled";								//-------------------------------------add
// &hdmi {
// 	hdmi_used = <1>;
// 	hdmi_power_cnt = <0>;
// 	hdmi_cts_compatibility = <1>;
// 	hdmi_hdcp_enable = <1>;
// 	hdmi_hdcp22_enable = <0>;
// 	hdmi_cec_support = <1>;
// 	hdmi_cec_super_standby = <0>;
// 	ddc_en_io_ctrl = <0>;
// 	power_io_ctrl = <0>;
&pwm0 {
	pinctrl-names = "active", "sleep";
	pinctrl-0 = <&pwm0_pin_a>;
	pinctrl-1 = <&pwm0_pin_b>;
&pwm2 {
	pinctrl-0 = <&pwm2_pin_a>;
	pinctrl-1 = <&pwm2_pin_b>;
&pwm7 {
	pinctrl-0 = <&pwm7_pin_a>;
	pinctrl-1 = <&pwm7_pin_b>;
&rtp {
	allwinner,tp-sensitive-adjust = <0xf>;
	allwinner,filter-type = <0x1>;
	allwinner,ts-attached;
&gpadc {
	channel_num = <2>;
	channel_select = <3>;
	channel_data_select = <3>;
	channel_compare_select = <3>;
	channel_cld_select = <3>;
	channel_chd_select = <3>;
	channel0_compare_lowdata = <1700000>;
	channel0_compare_higdata = <1200000>;
	channel1_compare_lowdata = <460000>;
	channel1_compare_higdata = <1200000>;
&s_cir0 {
	pinctrl-0 = <&s_cir0_pins_a>;
	pinctrl-1 = <&s_cir0_pins_b>;
&ir1 {
	pinctrl-0 = <&ir1_pins_a>;
	pinctrl-1 = <&ir1_pins_b>;
#4 2022-02-12 15:39:25
已发帖子: 3,391
可以怀疑是除D1外的其他地方有问题吗?
然后用 devmem 把 PD_CFG0 寄存器读出来试一试:
devmem 0x02000090
楼主 #5 2022-02-14 10:28:11
dianjixz
是全志芯片的一个隐藏问题,全志的 tcon 模块上电后会自己运行,然后在 PD 接口上发送信号.同时全志的 GPIO 引脚复用关系寄存器无法切断 tcon 信号的输出.我试过操作 PD_CFG0 寄存器,但是没有用.最后是无意中发现只要在全志的框架下关闭显示功能才能彻底停掉 tcon 信号.这个在使用 PD 组 复用 GPIO 时需要注意的问题.目前不知道全志 D1 裸机情况下会不会出现这个问题.期望开发全志 D1 裸机的大佬验证下这个问题.
#6 2022-02-14 10:33:35
tigger
已发帖子: 172
@dianjixz
这就尴尬了。。。
#7 2022-06-01 14:25:57
yang_AE86
请问楼主,这个问题解决了吗
#8 2022-06-01 14:26:44
yang_AE86
关了内核模块,但是开启串口后,可以正常工作吗?
