驱动50Pin rgb接口LCD屏幕
有个奇怪问题
Number of controls: 13
ctl type num name value
0 INT 1 DAC Playback Volume 63 (range 0->63)
1 INT 1 Headphone Playback Volume 0 (range 0->63)
2 BOOL 2 Headphone Playback Switch Off, Off
3 INT 1 Mic1 Playback Volume 3 (range 0->7)
4 INT 1 Mic1 Boost Volume 4 (range 0->7)
5 INT 1 ADC Gain Capture Volume 3 (range 0->7)
6 BOOL 2 DAC Playback Switch Off, Off
7 BOOL 2 DAC Reversed Playback Switch Off, Off
8 BOOL 2 Mic1 Playback Switch Off, Off
9 BOOL 2 Mixer Capture Switch Off, Off
10 BOOL 2 Mixer Reversed Capture Switch Off, Off
11 BOOL 2 Mic1 Capture Switch Off, Off
12 ENUM 2 Headphone Source Playback Route , DACMixer, , DACMixer
tinymix set 2 1设置了,还是off
同一张就卡插到zero开发板,播放音乐正常,而做的板子只有滋滋的声音
重新焊接后正常
