购买链接: https://item.taobao.com/item.htm?id=609079385265
git clone https://github.com/u-boot/u-boot -b v2021.07补丁包下载: smallwitpi_lite_v3x_uboot_patch_for_202107.diff
进入u-boot目录打上补丁:
patch -p1 < smallwitpi_lite_v3x_uboot_patch_for_202107.diff现在的目录结构:
u-boot$ git status .
Not currently on any branch.
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git checkout -- <file>..." to discard changes in working directory)
        modified:   arch/arm/dts/Makefile
        modified:   arch/arm/dts/sun8i-v3s.dtsi
        modified:   arch/arm/include/asm/arch-sunxi/gpio.h
        modified:   arch/arm/mach-sunxi/Kconfig
        modified:   arch/arm/mach-sunxi/board.c
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        arch/arm/dts/sun8i-v3x-smallwitpi-lite-debug-uart0.dts
        arch/arm/dts/sun8i-v3x-smallwitpi-lite-debug-uart1.dts
        arch/arm/dts/sun8i-v3x-smallwitpi-lite-debug-uart2.dts
        configs/smallwitpi_lite_v3s_ddr2_debug_uart0_pb8_pb9_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart0_pf2_pf4_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart1_pe21_pe22_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart1_pg6_pg7_defconfig
        configs/smallwitpi_lite_v3s_ddr2_debug_uart2_pb0_pb1_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart0_pb8_pb9_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart0_pf2_pf4_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart1_pe21_pe22_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart1_pg6_pg7_defconfig
        configs/smallwitpi_lite_v3x_ddr3_debug_uart2_pb0_pb1_defconfig
no changes added to commit (use "git add" and/or "git commit -a")
u-boot$V3s u-boot 配置(五组串口随意选择):
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart0_pb8_pb9_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart0_pf2_pf4_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart1_pe21_pe22_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart1_pg6_pg7_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3s_ddr2_debug_uart2_pb0_pb1_defconfig  V3x u-boot 配置(五组串口随意选择):
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart0_pb8_pb9_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart0_pf2_pf4_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart1_pe21_pe22_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart1_pg6_pg7_defconfig
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make smallwitpi_lite_v3x_ddr3_debug_uart2_pb0_pb1_defconfig  如果还需要其他 u-boot 配置执行:
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make menuconfig 编译:
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make请注意!!!如果使用pf2/pf4作为串口输出,那么不支持tf卡启动!!!
V3s手册V1.0: Allwinner_V3s_Datasheet_V1.0.pdf
V3LP手册V1.0: V3LP_Datasheet_V1.0.pdf
用户手册:Allwinner_V3s_User_Manual_V1_0.pdf
原理图:ORCAD_V3S_CDR_STD_V1_0_20150526.zip
克隆:
git clone https://github.com/buildroot/buildroot -b 2020.02.4
patch 下载: br2_v3_uart0_pf2_pf4.tgz
使用方法,直接解压到buildroot根目录:
tar xvf br2_v3_uart0_pf2_pf4.tgz
编译指令:
make br2_v3_uart0_pf2_pf4_defconfig
flash固件下载: firmware-smallwitpi-lite-v1-spinor-20211017173200.7z (用于V3s,串口UART0 PF2/PF4)
最近编辑记录 小智跑腿 (2021-10-17 17:33:52)
patch 下载: br2_v3_uart0_pb8_pb9-spinor-tfcard-20211017201000.tgz
编译指令: make br2_v3_uart0_pb8_pb9_defconfig
tf卡固件下载: firmware-smallwitpi-lite-v1-sdcard-uart0-pb8-pb9-tfcard-20211017201400.7z (用于V3s,串口UART0 PB8/9)
spi nor 固件: firmware-smallwitpi-lite-v1-spinor-uart0-pb8-pb9-spinor-20211024174500.7z (用于V3s,串口UART0 PB8/9,16M spinor)
小智V3x开发板16M SPI NOR /TFCARD 固件,分辨率480x272:
 firmware-smallwitpi-lite-v1-spinor-uart0-pb8-pb9-480x272-开机显示一朵荷花.7z
小智V3x开发板TFCard 固件,分辨率480x272:
 firmware-smallwitpi-lite-v1-sdcard-uart0-pb8-pb9-480x272-开机显示一朵荷花.7z
克隆:
buildroot patch: br2_v3_uart0_pb8_pb9-spinor-tfcard-20211026132800.tgz
解压:
tar xvf br2_v3_uart0_pb8_pb9-spinor-tfcard-20211026132800.tgz
生成 V3s / S3L 固件:
make br2_smallwitpi_lite_v3_ddr2_uart0_pb8_pb9_tfcard_spinor_defconfig
生成 V3x / S3 固件:
make br2_smallwitpi_lite_v3_ddr3_uart0_pb8_pb9_tfcard_spinor_defconfig
电阻触摸屏触摸校正与测试(NS2009 I2C PB8/9, 中断: PB0 ):
TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
TSLIB_TSDEVICE=/dev/input/event0 ts_test
占位
占位
buildroot 源码补丁: smallwitpi_lite_patch_5inch_800x480_ns2009_rtp_20220222_src.tgz
5寸 800x480 电阻触摸屏固件: smallwitpi_lite_patch_5inch_800x480_ns2009_rtp_20220222_firmware.7z
源码使用方法:
①克隆:
② 解压源码补丁: tar xvf smallwitpi_lite_patch_5inch_800x480_ns2009_rtp_20220222_src.tgz
③编译:
make
④固件位置:
TF卡固件:          output/images/firmware-smallwitpi-lite-v1-sdcard.img
SPI FLASH固件: output/images/firmware-smallwitpi-lite-v1-spinor.img
占位
占位
picogl / tinygl软件渲染,段错误死机了,只能看到一帧。
请问如果配置RGB的cd屏幕
v3s刚入门的收藏了。
用lichee zero接5寸屏,没有显示。有没有小智板的电路图的,是不是硬件哪里不一样
zjf0519 说:用lichee zero接5寸屏,没有显示。有没有小智板的电路图的,是不是硬件哪里不一样
示波器看下 HSYNC VSUNC DE RGB 那些信号是不是都正常?
烧了官方配置编译的镜像是可以显示的,
启动日志如下:
U-Boot SPL 2021.07 (Feb 14 2022 - 22:35:08 +0800)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2021.07 (Feb 14 2022 - 22:35:08 +0800) Allwinner Technology
Model: Smallwit Pi Lite
DRAM:  64 MiB
MMC:   mmc@1c0f000: 0
Loading Environment from nowhere... OK
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   No ethernet found.
switch to partitions #0, OK
mmc0 is current device
MMC Device 1 not found
no mmc device at slot 1
jedec_spi_nor spi_flash@0:0: unrecognized JEDEC id bytes: 0b, 40, 18
Unknown command 'mtd' - try 'help'
Boot Device: mmc0
Boot Slot 0: mmc0
Boot Slot 1: empty
DFU waiting on MMC0...
Unknown command 'dfu' - try 'help'
Booting from MMC0...
4214168 bytes read in 235 ms (17.1 MiB/s)
13415 bytes read in 2 ms (6.4 MiB/s)
Kernel image @ 0x40000000 [ 0x000000 - 0x404d98 ]
## Flattened Device Tree blob at 40700000
   Booting using the fdt blob at 0x40700000
   Loading Device Tree to 416f9000, end 416ff466 ... OK
[    0.000000] Linux version 5.4.70-smallwitpi (ddd@ddd-virtual-machine) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05)) #1 SMP Mon Feb 14 22:36:17 CST 2022
[    0.000000] OF: fdt: Machine model: YKHMI
[    0.000000] cma: Reserved 16 MiB at 0x42c00000
[    0.000000] percpu: Embedded 15 pages/cpu s30668 r8192 d22580 u61440
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk rootwait consoleblank=0 net.ifnames=0 biosdevname=0 root=/dev/mmcblk0p3
[    0.000000] Memory: 38512K/65536K available (6144K kernel code, 409K rwdata, 1756K rodata, 1024K init, 251K bss, 10640K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000000] random: get_random_bytes called from start_kernel+0x2b4/0x44c with crng_init=0
[    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000030] Switching to timer-based delay loop, resolution 41ns
[    0.000424] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000867] Console: colour dummy device 80x30
[    0.000967] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000989] pid_max: default: 32768 minimum: 301
[    0.001267] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001291] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001458] *** VALIDATE tmpfs ***
[    0.002483] *** VALIDATE proc ***
[    0.002780] *** VALIDATE cgroup1 ***
[    0.002804] *** VALIDATE cgroup2 ***
[    0.002831] CPU: Testing write buffer coherency: ok
[    0.003739] /cpus/cpu@0 missing clock-frequency property
[    0.003784] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005086] Setting up static identity map for 0x40100000 - 0x40100060
[    0.005463] rcu: Hierarchical SRCU implementation.
[    0.006394] smp: Bringing up secondary CPUs ...
[    0.006432] smp: Brought up 1 node, 1 CPU
[    0.006444] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.006454] CPU: All CPU(s) started in HYP mode.
[    0.006461] CPU: Virtualization extensions available.
[    0.007561] devtmpfs: initialized
[    0.013520] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.014066] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.014111] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.015355] pinctrl core: initialized pinctrl subsystem
[    0.017418] NET: Registered protocol family 16
[    0.019255] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.021550] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.021583] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.048165] SCSI subsystem initialized
[    0.048648] usbcore: registered new interface driver usbfs
[    0.048741] usbcore: registered new interface driver hub
[    0.048914] usbcore: registered new device driver usb
[    0.049275] mc: Linux media interface: v0.10
[    0.049336] videodev: Linux video capture interface: v2.00
[    0.049392] pps_core: LinuxPPS API ver. 1 registered
[    0.049401] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.049432] PTP clock support registered
[    0.052408] clocksource: Switched to clocksource arch_sys_counter
[    0.052923] *** VALIDATE ramfs ***
[    0.071671] thermal_sys: Registered thermal governor 'step_wise'
[    0.072636] NET: Registered protocol family 2
[    0.073877] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.073937] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.073977] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.074009] TCP: Hash tables configured (established 1024 bind 1024)
[    0.074293] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.074378] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.074804] NET: Registered protocol family 1
[    0.077765] Initialise system trusted keyrings
[    0.078394] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.088932] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.089525] utf8_selftest: All 154 tests passed
[    0.089543] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.090429] *** VALIDATE jffs2 ***
[    0.138843] Key type asymmetric registered
[    0.138874] Asymmetric key parser 'x509' registered
[    0.139027] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.139047] io scheduler mq-deadline registered
[    0.139055] io scheduler kyber registered
[    0.139063] test_strscpy: loaded.
[    0.139094] test_strscpy: all 32 tests passed
[    0.140774] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.147409] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.148360] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.149695] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.331114] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.338438] printk: console [ttyS0] disabled
[    0.358915] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 31, base_baud = 1500000) is a U6_16550A
[    0.969421] printk: console [ttyS0] enabled
[    0.974942] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    1.007143] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 32, base_baud = 1500000) is a U6_16550A
[    1.039427] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 33, base_baud = 1500000) is a U6_16550A
[    1.084344] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    1.096885] spi-nor spi0.0: unrecognized JEDEC id bytes: 0b 40 18 0b 40 18
[    1.105183] libphy: Fixed MDIO Bus: probed
[    1.109890] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
[    1.116411] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
[    1.122667] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    1.128501] dwmac-sun8i 1c30000.ethernet: No regulator found
[    1.135345] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    1.142717] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    1.149938] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    1.154935] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    1.161721] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    1.167396] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    1.173096] dwmac-sun8i 1c30000.ethernet: device MAC address 0a:aa:34:e5:f5:f1
[    1.180756] libphy: stmmac: probed
[    1.185414] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    1.191826] libphy: mdio_mux: probed
[    1.195604] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    1.201970] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    1.210545] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.217301] ehci-platform: EHCI generic platform driver
[    1.223062] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.228711] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.237254] ehci-platform 1c1a000.usb: irq 23, io mem 0x01c1a000
[    1.272370] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.280252] hub 1-0:1.0: USB hub found
[    1.284368] hub 1-0:1.0: 1 port detected
[    1.289344] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.295776] ohci-platform: OHCI generic platform driver
[    1.301553] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.308395] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.316755] ohci-platform 1c1a400.usb: irq 24, io mem 0x01c1a400
[    1.400879] hub 2-0:1.0: USB hub found
[    1.404978] hub 2-0:1.0: 1 port detected
[    1.410173] usbcore: registered new interface driver usb-storage
[    1.417707] mousedev: PS/2 mouse device common for all mice
[    1.424317] i2c /dev entries driver
[    1.431491] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.440841] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.478953] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.487688] usbcore: registered new interface driver usbhid
[    1.493421] usbhid: USB HID core driver
[    1.498633] IPv4 over IPsec tunneling driver
[    1.504208] NET: Registered protocol family 17
[    1.508790] Key type dns_resolver registered
[    1.513402] Registering SWP/SWPB emulation handler
[    1.519859] Loading compiled-in X.509 certificates
[    1.535995] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    1.548703] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.560934] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.566910] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.577476] hub 3-0:1.0: USB hub found
[    1.581460] hub 3-0:1.0: 1 port detected
[    1.587948] hctosys: unable to open rtc device (rtc0)
[    1.595412] Waiting for root device /dev/mmcblk0p3...
[    1.626213] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.636373] mmc0: new high speed SDHC card at address b368
[    1.643991] mmcblk0: mmc0:b368 LEXAR 7.46 GiB
[    1.653354]  mmcblk0: p1 p2 p3
[    1.691226] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[    1.698796] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[    1.723550] random: fast init done
[    1.809748] EXT4-fs (mmcblk0p3): recovery complete
[    1.819596] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    1.828022] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[    1.836348] devtmpfs: mounted
[    1.841715] Freeing unused kernel memory: 1024K
[    1.846604] Run /sbin/init as init process
[    2.080891] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
Mounting OverlayFS: Skip
Populating /dev using udev: [    2.415235] udevd[80]: starting version 3.2.9
[    2.449150] random: udevd: uninitialized urandom read (16 bytes read)
[    2.466479] random: udevd: uninitialized urandom read (16 bytes read)
[    2.482295] random: udevd: uninitialized urandom read (16 bytes read)
[    2.607387] udevd[81]: starting eudev-3.2.9
open /dev/fb0: No such file or directory
[    3.686394] rtc-hym8563 0-0051: could not init device, -6
[    3.699266] input: TSC2007 Touchscreen as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
done
Saving random seed: [    5.836686] random: dd: uninitialized urandom read (512 bytes read)
OK
Starting network: OK
[    8.962454] random: crng init done
ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Starting sshd: Privilege separation user sshd does not exist
OK
Starting DHCP server: FAIL
# [   31.842391] vcc3v0: disabling
[   31.845409] vcc5v0: disabling离线
解决了,应该是编译残留的文件问题。把output目录全删掉后再重新编译就可以了。但有个问题,就是我用的800*480的屏。但这个固件里面是480*272的驱动。不知道哪里能够改。
请问开发板哪里有出售?
请问开发板哪里有出售?
5寸GT911电容屏是咋样修改?
请问开发板哪里有出售?
楼主请问可以帮忙有偿编译内核吗?我需要串口波特率到921600?
开发板的外设有点少,价格有点小.
明明已经编译出了u-boot,为什么buildroot里make的时候还是要从ftp://ftp.denx.de/pub/u-boot/u-boot-2020.01.tar.bz2去下载u-boot呢?
这个buildroot是不是又缺陷?
