楼主 # 2021-09-10 20:59:51
hoel
已发帖子: 96
F1C00S MELIS MDK 运行时错误 0x6972 addr error
我用MDK编译MELIS,编译没有错误,生成新镜像并烧录,但是我在循环中出现这个错误,有人知道这个问题吗?
BOOT0 is starting
DBG: init jtag OK
init dram , base        is 0x80000000
init dram , clk         is 120
init dram , access_mode is 1
init dram , cs_num      is 1
init dram , ddr8_remap  is 0
init dram , sdr_ddr     is 1
init dram , bwidth      is 16
init dram , col_width   is 10
init dram , row_width   is 13
init dram , bank_size   is 4
init dram , cas         is 3
init dram , size        is 0
dram init successed,size is 32
DBG: init heap OK, base address is 0x80000000, size is 0x00100000
DBG: load boot1 from spinor
DBG: init spinor OK
DBG: the size of BOOT1 is 71168
DBG: src_sum = 0x0x19c0ac68
DBG: sum = 0x0x19c0ac68
succeed in loading BOOT1
jump to BOOT1
DBG: boot1 starting!
DBG: init heap OK, base address is 0x80800000, size is 0x00100000
begin to init file system
DBG: init block device OK
DBG: init mini file system OK
DBG: mount c partition OK
0
jump to kernal
port=4,port_num=1,mul_sel=6 eint_num=1 trigger=2
hread running.....
partition [D] plug in..
Parts Thread work now.....
.Start Shell from partion 'c'..................................................................................
Mount Parts Thread work end....
x6969637765....
765 data fail....
&&&&&&&&&&&&0x6972 addr error&&&&&&&&&&
rror&&&&&&&&&&
37765....
ta fail....
0x6969637765....
7765 data fail....
&&addr=0x6969637765....
x6969637765 data fail....
5....
ail....
r error&&&&&&&&&&
69637765....
 data fail....
dr=0x6969637765....
**0x6969637765 data fail....
set iic clock fail
969637765....
5 data fail....
***0x6969637765 data fail....
rror&&&&&&&&&&
37765....
ta fail....
0x6969637765....
7765 data fail....
5....
ail....
r error&&&&&&&&&&
69637765....
 data fail....
dr=0x6969637765....
set iic clock fail
969637765....
5 data fail....
rror&&&&&&&&&&
37765....
ta fail....
0x6969637765....
7765 data fail....
5....
ail....
r error&&&&&&&&&&
69637765....
 data fail....
dr=0x6969637765....
partition [E] plug in..
WRN:L27(osal_cache.c):he: Parameter of Length cannot be 0!
pend event sem overtime!
der=9
r_used=1 ret=0
press enter key(keypad or irkey) to continue!
egin..............
.bin failed.
 fail
rror&&&&&&&&&&
37765....
ta fail....
0x6969637765....
7765 data fail....
rror&&&&&&&&&&
37765....
ta fail....
0x6969637765....
7765 data fail....
rror&&&&&&&&&&
37765....
ta fail....
2
enned!........................................................................................
6969637765....
65 data fail....
****0x6969637765 data fail....
l....
rror&&&&&&&&&&
37765....
ta fail....
0x6969637765....
7765 data fail....
5....
ail....
r error&&&&&&&&&&
69637765....
 data fail....
4
set iic clock fail
969637765....
5 data fail....
&&&&&& fail &&&&&&
969637765....
5 data fail....
&&&&&& fail &&&&&&
969637765....
5 data fail....
&&&&&& fail &&&&&&
969637765....
5 data fail....
&&&&&& fail &&&&&&
969637765....
5 data fail....
&&&&&& fail &&&&&&
969637765....
5 data fail....
过了一会儿我发现了问题,2个文件路径错误,被默默忽略了。这导致了错误,在制作IMG之后和刻录之前确保检查UPDATE.TXT并确保这里没有文件复制错误,如果没有复制一个文件,请在update.bat中找到哪个文件并修复问题然后重新制作IMG和闪光
BOOT0 is starting
DBG: init jtag OK
DBG: init spinor OK
DBG: src_sum = 0x0x19c0acb7
DBG: sum = 0x0x19c0acb7
jump to BOOT1
0
jump to kernal
hread running.....
BOOT0 is starting
DBG: init jtag OK
DBG: init spinor OK
jump to BOOT1
0
jump to kernal
hread running.....
最近编辑记录 hoel (2021-09-10 21:33:35)
#1 2022-02-20 17:50:04
cctv74
Re: F1C00S MELIS MDK 运行时错误 0x6972 addr error
是如何修复的,我也遇到同样的问题,我用的是群里下载的那个SDK MELIS100A, 谢谢。
最近编辑记录 cctv74 (2022-02-20 18:04:31)
楼主 #2 2022-02-23 06:28:54
hoel
已发帖子: 96
好吧,解决方案已经写好了,你可以阅读它
