开机日志如下,期间一直在使用触摸屏
[37]HELLO! BOOT0 is starting!
[40]BOOT0 commit : dc54be6
[43]set pll start
[45]periph0 has been enabled
[48]set pll end
[50][pmu]: bus read error
[52][pmu]: bus read error
[60]vaild para:1 select dram para0
[63]board init ok
[65]DRAM BOOT DRIVE INFO: V0.19
[68]the chip id is 0x2400
[71]the chip id is 0x2400
[73]the chip id is 0x2400
[76]the chip id is 0x2400
[79]the chip id is 0x2400
[81]chip id check OK
[83]DRAM_VCC set to 1100 mv
[86]DRAM CLK =792 MHZ
[88]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[96]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6063
[109]DRAM simple test OK.
[111]dram size =1024
[113]chipid = 53002400
[115]nsi init ok 2020-4-7
[119]card no is 2
[120]sdcard 2 line count 8
[123][mmc]: mmc driver ver 2020-05-25 09:40
[133][mmc]: Wrong media type 0x0
[136][mmc]: ***Try SD card 2***
[140][mmc]: mmc 2 cmd 8 timeout, err 100
[144][mmc]: mmc 2 cmd 8 err 100
[147][mmc]: mmc 2 send if cond failed
[152][mmc]: mmc 2 cmd 55 timeout, err 100
[156][mmc]: mmc 2 cmd 55 err 100
[159][mmc]: mmc 2 send app cmd failed
[163][mmc]: ***Try MMC card 2***
[187][mmc]: RMCA OK!
[189][mmc]: mmc 2 bias 4
[192][mmc]: MMC 5.1
[194][mmc]: HSSDR52/SDR25 8 bit
[198][mmc]: 50000000 Hz
[200][mmc]: 14910 MB
[202][mmc]: ***SD/MMC 2 init OK!!!***
[258]Loading boot-pkg Succeed(index=0).
[262]Entry_name = u-boot
[269]Entry_name = monitor
[272]Entry_name = scp
[280]set arisc reset to de-assert state
[284]Entry_name = dtb
[288]tunning data addr:0x4a0003e8
[291]Jump to second Boot.
NOTICE: BL3-1: v1.0(debug):cc1f5d7
NOTICE: BL3-1: Built : 10:23:25, 2020-04-08
NOTICE: BL3-1 commit: 8
ERROR: Error initializing runtime service tspd_fast
NOTICE: BL3-1: Preparing for EL3 exit to normal world
NOTICE: BL3-1: Next image address = 0x4a000000
NOTICE: BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05 (Mar 03 2022 - 14:40:16 +0000) Allwinner Technology
[00.369]CPU: Allwinner Family
[00.372]Model: sun50iw10
I2C: ready
[00.493]DRAM: 1 GiB
[00.496]Relocation Offset is: 35f12000
[00.525]secure enable bit: 0
[00.528]pmu_axp806_probe pmic_bus_read fail
[00.532]pmu_axp81X_probe pmic_bus_read fail
[00.536]pmu_axp858_probe pmic_bus_read fail
[00.540]PMU: no found
[00.542]bmu_axp81X_probe pmic_bus_read fail
[00.546]BMU: no found
[00.548]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[00.557]gic: sec monitor mode
[00.559]sunxi flash type@2 not support fast burn key
[00.564]flash init start
[00.566]workmode = 0,storage type = 2
[00.569][mmc]: mmc driver ver uboot2018:2021-01-14 19:04:00
[00.582][mmc]: SUNXI SDMMC Controller Version:0x50300
[00.607][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
[00.614]sunxi flash init ok
[00.616]non secure, do not need update backup boot0 to toc0
[00.622]init_clocks:finish
[00.624]drv_disp_init
partno erro : can't find partition bootloader
16 bytes read in 1 ms (15.6 KiB/s)
[00.665]get flash lcd idx 0
request pwm success, pwm8:pwm8:0x300a000.
[00.684]drv_disp_init finish
[00.735]boot_gui_init:start
[00.738]set disp.dev2_output_type fail. using defval=0
[00.743]=====================LCD_open_flow
[00.746]disp 1, clk: pll(176000000),clk(176000000),dclk(11000000) dsi_rate(176000000)
clk real:pll(288000000),clk(288000000),dclk(18000000) dsi_rate(0)
[00.760]=====================LCD_open_flow
[00.764]=====================LCD_power_on
[01.071]switch device: sel=1, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
[01.079]boot_gui_init:finish
partno erro : can't find partition bootloa[01.091]=====================LCD_open_flow
[01.095]=====================LCD_panel_init
der
337656 bytes read in 4 ms (80.5 MiB/s)
[01.317]Loading Environment f[01.320]=====================LCD_open_flow
[01.323]soc ic_ver:0x0, qa_val:0x0, markid:0x2400 dclk[0-9999] display_cfg_flag:0
rom SUNXI_FLASH... OK
[01.338]no secure os for keybox operation
[01.342]try to burn key
[01.345]out of usb burn from boot: not need burn key
[01.350][ARISC] :arisc initialize
[01.355][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [7ffa4ae8, 7ffa4e00]
[01.366][ARISC] :arisc para ok
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [e9882a9f84dd729c700fbb8a0a7d7fdf7eca7135]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[01.397][ARISC] :sunxi-arisc driver startup succeeded
[01.402]read item0 copy0
[01.404]Item0 (Map) magic is bad
[01.407]the secure storage item0 copy0 magic is bad
[01.412]Item0 (Map) magic is bad
[01.414]the secure storage item0 copy1 magic is bad
[01.419]Item0 (Map) magic is bad
[01.422]the secure storage map is empty
List file under ULI/factory
** Unrecognized filesystem ty[01.431]=====================LCD_open_flow
[01.434]=====================LCD_bl_open
[01.438]pwm device hdl is NULL
[01.441]=====================LCD_open_flow
[01.445]=====================LCD_open_flow
[01.448]LCD open finish
pe **
[01.451]no item name panic in the map
[01.455]no item name rootwait init in the map
[01.459]no item name rdinit in the map
[01.462]no item name rotpk_status in the map
root_partition is rootfs
set root to /dev/mmcblk0p5
[01.471]update part info
[01.475]key 0
[01.477]no misc partition is found
[01.480]update bootcmd
[01.482]serial num is: 0c001415a0c08851e4d
[01.487][mmc]: delete mmc-hs400-1_8v from dtb
[01.491][mmc]: delete mmc-hs200-1_8v from dtb
[01.497](weak)update dtb dram start
[01.501]update dtb dram end
[01.509]update dts
[01.519]partinfo: name boot, start 0xb000, size 0x7800
[01.646]in boot normal mode,pass normal para to cmdline
[01.652]android.hardware = sun50iw10p1
Android's image name: mr813-a3
[01.720]Starting kernel ...
[01.723][mmc]: mmc exit start
[01.742][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 4.9.170 (yuzuki@YuzukiOMEN) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #85 SMP PREEMPT Fri Mar 4 16:13:08 UTC 2022
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] disp reserve base 0x7bf4d040 ,size 0xe1000
[ 0.000000] cma: Reserved 8 MiB at 0x000000007f800000
[ 0.000000] On node 0 totalpages: 262144
[ 0.000000] DMA zone: 4096 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 262144 pages, LIFO batch:31
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc03f70b000 s45336 r8192 d32488 u86016
[ 0.000000] pcpu-alloc: s45336 r8192 d32488 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
[ 0.000000] Kernel command line: panic=10 console=ttyS0,115200 root=/dev/mmcblk0p5 rootwait init=/sbin/init rdinit=/rdinit loglevel=8 earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 loglevel=8 partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:rootfs_data@mmcblk0p6:private@mmcblk0p7:recovery@mmcblk0p8:UDISK@mmcblk0p9 cma=8M gpt=1 rotpk_status=0 androidboot.mode=normal androidboot.serialno=0c001415a0c08851e4d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 gpt=1 uboot_message=2018.05(03/03/2022-14:40:16) disp_reserve=921600,0x7bf4d040 bootreason=button
[ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
[ 0.000000] log_buf_len min size: 16384 bytes
[ 0.000000] log_buf_len: 32768 bytes
[ 0.000000] early log buf free: 14176(86%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 993460K/1048576K available (6462K kernel code, 1278K rwdata, 1992K rodata, 384K init, 342K bss, 46924K reserved, 8192K cma-reserved)
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff80086d0000 ( 6464 KB)
[ 0.000000] .rodata : 0xffffff80086d0000 - 0xffffff80088d0000 ( 2048 KB)
[ 0.000000] .init : 0xffffff80088d0000 - 0xffffff8008930000 ( 384 KB)
[ 0.000000] .data : 0xffffff8008930000 - 0xffffff8008a6f808 ( 1279 KB)
[ 0.000000] .bss : 0xffffff8008a6f808 - 0xffffff8008ac5044 ( 343 KB)
[ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008222] Console: colour dummy device 80x25
[ 0.012413] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.022619] pid_max: default: 32768 minimum: 301
[ 0.027677] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.033898] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.044131] sched-energy: CPU device node has no sched-energy-costs
[ 0.047283] Invalid sched_group_energy for CPU0
[ 0.051749] CPU0: update cpu_capacity 1024
[ 0.067890] ASID allocator initialised with 32768 entries
[ 0.124104] Detected VIPT I-cache on CPU1
[ 0.124155] Invalid sched_group_energy for CPU1
[ 0.124159] CPU1: update cpu_capacity 1024
[ 0.124162] CPU1: Booted secondary processor [410fd034]
[ 0.152148] Detected VIPT I-cache on CPU2
[ 0.152179] Invalid sched_group_energy for CPU2
[ 0.152183] CPU2: update cpu_capacity 1024
[ 0.152185] CPU2: Booted secondary processor [410fd034]
[ 0.180214] Detected VIPT I-cache on CPU3
[ 0.180242] Invalid sched_group_energy for CPU3
[ 0.180245] CPU3: update cpu_capacity 1024
[ 0.180247] CPU3: Booted secondary processor [410fd034]
[ 0.180321] Brought up 4 CPUs
[ 0.230958] SMP: Total of 4 processors activated.
[ 0.235647] CPU features: detected feature: 32-bit EL0 Support
[ 0.241453] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.251471] CPU: All CPU(s) started at EL1
[ 0.252732] alternatives: patching kernel code
[ 0.257638] Invalid sched_group_energy for CPU3
[ 0.261650] Invalid sched_group_energy for Cluster3
[ 0.266499] Invalid sched_group_energy for CPU2
[ 0.271006] Invalid sched_group_energy for Cluster2
[ 0.275858] Invalid sched_group_energy for CPU1
[ 0.280365] Invalid sched_group_energy for Cluster1
[ 0.285218] Invalid sched_group_energy for CPU0
[ 0.289725] Invalid sched_group_energy for Cluster0
[ 0.295736] devtmpfs: initialized
[ 0.551556] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.555678] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.562542] atomic64_test: passed
[ 0.565187] pinctrl core: initialized pinctrl subsystem
[ 0.575413] NET: Registered protocol family 16
[ 0.579445] dump_class_init,861, success
[ 0.582820] sunxi iommu: irq = 8
[ 0.583603] vdso: 2 pages (1 code @ ffffff80086d6000, 1 data @ ffffff8008934000)
[ 0.590542] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.607241] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
[ 0.685926] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
[ 0.699438] iommu: Adding device 1c0e000.ve to group 0
[ 0.718800] iommu: Adding device 6000000.disp to group 0
[ 0.721434] iommu: Adding device 6480000.g2d to group 0
[ 0.738360] iommu: Adding device csi0 to group 0
[ 0.739634] iommu: Adding device csi1 to group 0
[ 0.744971] iommu: Adding device 2108000.tdm to group 0
[ 0.748385] iommu: Adding device 2100000.isp to group 0
[ 0.753619] iommu: Adding device 2102000.isp to group 0
[ 0.758418] iommu: Adding device 2110000.scaler to group 0
[ 0.763886] iommu: Adding device 2110400.scaler to group 0
[ 0.769335] iommu: Adding device 2110800.scaler to group 0
[ 0.774774] iommu: Adding device 2110c00.scaler to group 0
[ 0.858662] pwm module init!
[ 0.869293] sunxi-pm debug v3.10
[ 0.875938] SCSI subsystem initialized
[ 0.877957] usbcore: registered new interface driver usbfs
[ 0.879883] usbcore: registered new interface driver hub
[ 0.885069] usbcore: registered new device driver usb
[ 0.890459] sunxi_i2c_adap_init()2541 - init
[ 0.895264] sunxi_i2c_probe()2289 - [i2c0] twi_drv_used = 0
[ 0.899644] sunxi_i2c_probe()2293 - [i2c0] twi_pkt_interval = 0
[ 0.905542] twi0 supply twi not found, using dummy regulator
[ 0.911432] twi_request_gpio()453 - [i2c0] init name: twi0
[ 0.918579] sunxi_i2c_probe()2289 - [i2c2] twi_drv_used = 0
[ 0.922179] sunxi_i2c_probe()2293 - [i2c2] twi_pkt_interval = 0
[ 0.928072] twi2 supply twi not found, using dummy regulator
[ 0.933913] twi_request_gpio()453 - [i2c2] init name: twi2
[ 0.940874] sunxi_i2c_probe()2289 - [i2c3] twi_drv_used = 0
[ 0.944711] sunxi_i2c_probe()2293 - [i2c3] twi_pkt_interval = 0
[ 0.950610] twi3 supply twi not found, using dummy regulator
[ 0.956485] twi_request_gpio()453 - [i2c3] init name: twi3
[ 0.963450] sunxi_i2c_probe()2289 - [i2c5] twi_drv_used = 0
[ 0.967243] sunxi_i2c_probe()2293 - [i2c5] twi_pkt_interval = 0
[ 0.973137] twi5 supply twi not found, using dummy regulator
[ 0.978973] twi_request_gpio()453 - [i2c5] init name: twi5
[ 0.986160] media: Linux media interface: v0.10
[ 0.988998] Linux video capture interface: v2.00
[ 0.995721] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[ 1.000832] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[ 1.007208] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
[ 1.014188] ion_heap_create: Invalid heap type 6
[ 1.018386] Advanced Linux Sound Architecture Driver Initialized.
[ 1.026995] Bluetooth: Core ver 2.22
[ 1.027585] NET: Registered protocol family 31
[ 1.031901] Bluetooth: HCI device and connection manager initialized
[ 1.038249] Bluetooth: HCI socket layer initialized
[ 1.043099] Bluetooth: L2CAP socket layer initialized
[ 1.048210] Bluetooth: SCO socket layer initialized
[ 1.055725] clocksource: Switched to clocksource arch_sys_counter
[ 1.114296] udc_init,0
[ 1.114693] NET: Registered protocol family 2
[ 1.144205] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.145704] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 1.152305] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.158594] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.164378] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.171473] NET: Registered protocol family 1
[ 1.175833] Unpacking initramfs...
[ 1.178432] Initramfs unpacking failed: junk in compressed archive
[ 1.192226] workingset: timestamp_bits=61 max_order=18 bucket_order=0
[ 1.289806] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.291958] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.304051] io scheduler noop registered
[ 1.304096] io scheduler deadline registered
[ 1.308935] io scheduler cfq registered (default)
[ 1.317816] [DISP]disp_module_init
[ 1.320123] [DISP] disp_init,line:2260:
[ 1.320161] smooth display screen:1 type:1 mode:4
[ 1.394771] [DISP] lcd_clk_config,line:662:
[ 1.394816] disp 1, clk: pll(66000000),clk(66000000),dclk(11000000) dsi_rate(66000000)
[ 1.394816] clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
[ 1.396842] [DISP]disp_module_init finish
[ 1.421844] uart uart0: get regulator failed
[ 1.421905] uart0 supply uart not found, using dummy regulator
[ 1.426930] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
[ 1.434212] sw_console_s[ 1.442252] console [ttyS0] enabled
[ 1.446260] bootconsole [earlycon0] disabled
[ 1.456847] uart uart1: get regulator failed
[ 1.463522] uart1 supply uart not found, using dummy regulator
[ 1.470683] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
[ 1.482345] misc dump reg init
[ 1.489747] [drm] Initialized
[ 1.493933] Unable to detect cache hierarchy for CPU 0
[ 1.499900] [NAND][NE] Not found valid nand node on dts
[ 1.507631] [ADDR_MGT] addr_mgt_probe: success.
[ 1.518381] libphy: Fixed MDIO Bus: probed
[ 1.523009] tun: Universal TUN/TAP device driver, 1.6
[ 1.528709] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.536481] PPP generic driver version 2.4.2
[ 1.542185] PPP BSD Compression module registered
[ 1.547498] PPP Deflate Compression module registered
[ 1.553217] PPP MPPE Compression module registered
[ 1.558620] NET: Registered protocol family 24
[ 1.563690] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.571542] get ehci0-controller, regulator_io is no nocare
[ 1.577823] get ehci0-controller wakeup-source is fail.
[ 1.584081] sunxi ehci0-controller don't init wakeup source
[ 1.590366] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff8008aa3e80, 0x:ffffff8008bbd000, irq_no:164
[ 1.604076] [sunxi-ehci0]: Not init ehci0
[ 1.608838] get ehci1-controller, regulator_io is no nocare
[ 1.615572] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff8008aa4590, 0x:ffffff8008bc7000, irq_no:166
[ 1.629320] 5200000.ehci1-controller supply drvvbus not found, using dummy regulator
[ 1.638357] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.648624] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 1.658956] sunxi-ehci 5200000.ehci1-controller: irq 358, io mem 0xffffff8008bc7000
[ 1.679748] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
[ 1.691442] hub 1-0:1.0: USB hub found
[ 1.695781] hub 1-0:1.0: 1 port detected
[ 1.702740] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.710210] get ohci0-controller, regulator_io is no nocare
[ 1.716490] get ohci0-controller wakeup-source is fail.
[ 1.722711] sunxi ohci0-controller don't init wakeup source
[ 1.729131] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff8008aa4208
[ 1.739614] [sunxi-ohci0]: Not init ohci0
[ 1.744348] get ohci1-controller, regulator_io is no nocare
[ 1.751253] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff8008aa4918
[ 1.761781] 5200000.ohci1-controller supply drvvbus not found, using dummy regulator
[ 1.770767] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 1.780631] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
[ 1.790609] sunxi-ohci 5200000.ohci1-controller: irq 359, io mem 0x00000040
[ 1.863334] hub 2-0:1.0: USB hub found
[ 1.867678] hub 2-0:1.0: 1 port detected
[ 1.874994] usbcore: registered new interface driver uas
[ 1.881389] usbcore: registered new interface driver usb-storage
[ 1.888338] usbcore: registered new interface driver ums-alauda
[ 1.895193] usbcore: registered new interface driver ums-cypress
[ 1.902154] usbcore: registered new interface driver ums-datafab
[ 1.909098] usbcore: registered new interface driver ums_eneub6250
[ 1.916246] usbcore: registered new interface driver ums-freecom
[ 1.923187] usbcore: registered new interface driver ums-isd200
[ 1.930053] usbcore: registered new interface driver ums-jumpshot
[ 1.937102] usbcore: registered new interface driver ums-karma
[ 1.943866] usbcore: registered new interface driver ums-onetouch
[ 1.951039] usbcore: registered new interface driver ums-realtek
[ 1.957985] usbcore: registered new interface driver ums-sddr09
[ 1.964834] usbcore: registered new interface driver ums-sddr55
[ 1.971684] usbcore: registered new interface driver ums-usbat
[ 1.978565] usb_serial_number:20080411
[ 1.984149] sunxikbd_key_init: key0 vol= 210 code= 115
[ 1.989958] sunxikbd_key_init: key1 vol= 410 code= 114
[ 1.995752] sunxikbd_key_init: key2 vol= 590 code= 139
[ 2.001543] sunxikbd_key_init: key3 vol= 750 code= 28
[ 2.007240] sunxikbd_key_init: key4 vol= 880 code= 102
[ 2.014435] input: sunxi-keyboard as /devices/virtual/input/input0
[ 2.022405] evbug: Connected device: input0 (sunxi-keyboard at sunxikbd/input0)
[ 2.033235] [FTS]fts_ts_init: Enter
[ 2.037410] [FTS][Info]Init FTS
[ 2.040975] [FTS]fts_ts_probe: Enter
[ 2.045012] [FTS]fts_parse_dt: Enter
[ 2.049075] [FTS]max_touch_number=2
[ 2.053009] [FTS]fts_parse_dt: Exit(933)
[ 2.057470] [FTS]fts_input_dev_init: Enter
[ 2.063253] input: fts_ts as /devices/platform/soc/twi5/i2c-5/5-0048/input/input1
[ 2.072485] evbug: Connected device: input1 (fts_ts at unknown)
[ 2.079167] [FTS]fts_input_dev_init: Exit(246)
[ 2.084173] [FTS]fts_ctpm_get_upgrade_array: Enter
[ 2.089573] [FTS][Info]CHIP TYPE ID = 0x5422
[ 2.111975] [FTS][Error]hidi2c change to stdi2c error!!
[ 2.117868] [FTS]fts_ctpm_get_upgrade_array: Exit(167)
[ 2.123657] [FTS]fts_power_source_init: Enter
[ 2.128586] 5-0048 supply not found, using dummy regulator
[ 2.135092] 5-0048 supply not found, using dummy regulator
[ 2.141443] [FTS]fts_power_source_init: Exit(301)
[ 2.146749] [FTS]fts_power_source_ctrl: Enter
[ 2.151657] [FTS]fts_power_source_ctrl: Exit(341)
[ 2.156954] [FTS]fts_gpio_configure: Enter
[ 2.161656] [FTS]fts_gpio_configure: Exit(787)
[ 2.399983] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.431980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.463979] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.495980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.527980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.559979] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.591980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.623980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.655980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.687980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.719980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.751980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.783979] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.815980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.847980] [FTS][Info]TP Not Ready, ReadData = 0x64
[ 2.880139] [FTS][Mode]create sysfs succeeded
[ 2.885053] [FTS]fts_ts_probe: Exit(1158)
[ 2.889774] [FTS]fts_ts_init: Exit(1403)
[ 2.895132] sunxi_gpadc_init,1536, success
[ 2.900544] [FTS]point number: 1, touch point: 1
[ 2.902409] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[ 2.902679] sunxi-rtc rtc: RTC enabled
[ 2.903125] i2c /dev entries driver
[ 2.903805] random: fast init done
[ 2.906702] IR NEC protocol handler initialized
[ 2.906707] IR RC5(x/sz) protocol handler initialized
[ 2.906711] IR RC6 protocol handler initialized
[ 2.906714] IR JVC protocol handler initialized
[ 2.906718] IR Sony protocol handler initialized
[ 2.906721] IR SANYO protocol handler initialized
[ 2.906725] IR Sharp protocol handler initialized
[ 2.906729] IR MCE Keyboard/mouse protocol handler initialized
[ 2.906732] IR XMP protocol handler initialized
[ 2.906735] sunxi cedar version 0.1
[ 2.907045] VE: install start!!!
[ 2.907045]
[ 2.907265] cedar_ve: cedar-ve the get irq is 347
[ 2.908523] VE: get debugfs_mpp_root is NULL, please check mpp
[ 2.908523]
[ 2.908526] VE: sunxi ve debug register driver failed!
[ 2.908526]
[ 2.910088] Bluetooth: HCI UART driver ver 2.3
[ 2.910094] Bluetooth: HCI UART protocol H4 registered
[ 2.910099] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.06
[ 2.912877] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[ 2.913150] sunxi-mmc sdc2: No vmmc regulator found
[ 2.913155] sunxi-mmc sdc2: No vqmmc regulator found
[ 2.913159] sunxi-mmc sdc2: No vdmmc regulator found
[ 2.913164] sunxi-mmc sdc2: No vd33sw regulator found
[ 2.913168] sunxi-mmc sdc2: No vd18sw regulator found
[ 2.913173] sunxi-mmc sdc2: No vq33sw regulator found
[ 2.913177] sunxi-mmc sdc2: No vq18sw regulator found
[ 2.914049] sunxi-mmc sdc2: set host busy
[ 2.914139] mmc:failed to get gpios
[ 2.914927] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.931746] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.951756] sunxi-mmc sdc2: detmode:alway in(non removable)
[ 2.951779] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.954261] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.955352] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.955767] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.955854] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.958316] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.959550] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[ 2.959703] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
[ 2.959788] sunxi-mmc sdc1: No vmmc regulator found
[ 2.959792] sunxi-mmc sdc1: No vqmmc regulator found
[ 2.959797] sunxi-mmc sdc1: No vdmmc regulator found
[ 2.959801] sunxi-mmc sdc1: No vd33sw regulator found
[ 2.959806] sunxi-mmc sdc1: No vd18sw regulator found
[ 2.959810] sunxi-mmc sdc1: No vq33sw regulator found
[ 2.959815] sunxi-mmc sdc1: No vq18sw regulator found
[ 2.960666] sunxi-mmc sdc1: set host busy
[ 2.960773] mmc:failed to get gpios
[ 2.960800] sunxi-mmc sdc1: min-frequency:400000
[ 2.961542] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.961567] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 2.979754] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.980976] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.993652] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[ 2.994074] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[ 2.994403] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
[ 2.994722] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
[ 2.994998] mmc0: new DDR MMC card at address 0001
[ 2.997332] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.998036] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 3.002694] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 3.003785] sunxi-mmc sdc1: detmode:manually by software
[ 3.006199] usbcore: registered new interface driver usbhid
[ 3.006202] usbhid: USB HID core driver
[ 3.006821] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 3.009849] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.010312] u32 classifier
[ 3.010314] Actions configured
[ 3.010509] Initializing XFRM netlink socket
[ 3.010741] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 3.013991] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.017079] sunxi-mmc sdc1: card claims to support voltages below defined range
[ 3.018838] NET: Registered protocol family 10
[ 3.032454] NET: Registered protocol family 17
[ 3.033136] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 3.033284] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 3.033502] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 3.034063] 8021q: 802.1Q VLAN Support v1.8
[ 3.034819] mmc1: new high speed SDIO card at address 0001
[ 3.077221] get usb_detect_mode is fail, 22
[ 3.078922] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:04 UTC (4)
[ 3.079804] usb1-vbus: disabling
[ 3.079810] vdd_3v3: disabling
[ 3.079814] ALSA device list:
[ 3.079817] No soundcards found.
[ 3.494754] [FTS][B]P0(157, 221)[p:63,tm:9] DOWN!
[ 3.500058] evbug: Event. Dev: input1, Type: 3, Code: 57, Value: 0
[ 3.507005] evbug: Event. Dev: input1, Type: 3, Code: 58, Value: 63
[ 3.514050] evbug: Event. Dev: input1, Type: 3, Code: 48, Value: 9
[ 3.520996] evbug: Event. Dev: input1, Type: 3, Code: 53, Value: 157
[ 3.526991] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
[ 3.529265] devtmpfs: mounted
[ 3.529596] Freeing unused kernel memory: 384K
[ 3.544468] evbug: Event. Dev: input1, Type: 3, Code: 54, Value: 221
[ 3.551611] evbug: Event. Dev: input1, Type: 1, Code: 330, Value: 1
[ 3.558653] evbug: Event. Dev: input1, Type: 0, Code: 0, Value: 0
[ 3.567467] [FTS]point number: 1, touch point: 1
[ 3.572707] [FTS][B]P0(144, 236)[p:63,tm:9] DOWN!
[ 3.578013] evbug: Event. Dev: input1, Type: 3, Code: 57, Value: 0
[ 3.584960] evbug: Event. Dev: input1, Type: 3, Code: 58, Value: 63
[ 3.592006] evbug: Event. Dev: input1, Type: 3, Code: 48, Value: 9
[ 3.598962] evbug: Event. Dev: input1, Type: 3, Code: 53, Value: 144
[ 3.606114] evbug: Event. Dev: input1, Type: 3, Code: 54, Value: 236
[ 3.613259] evbug: Event. Dev: input1, Type: 0, Code: 0, Value: 0
[ 4.025494] init: Console is alive
[ 4.029729] init: - preinit -
[ 4.440829] random: procd: uninitialized urandom read (4 bytes read)
/dev/by-name/UDISK already format by ext4
/dev/by-name/rootfs_data already format by ext4
[ 4.785882] mount_root: mounting /dev/root
[ 4.791756] mount_root: loading kmods from internal overlay
[ 4.812361] mount_root: failed to launch kmodloader from internal overlay
[ 4.883024] block: attempting to load /etc/config/fstab
e2fsck 1.42.12 (29-Aug-2014)
/dev/by-name/rootfs_data: recovering journal
/dev/by-name/rootfs_data: clean, 30/1024 files, 1201/4096 blocks
[ 5.068130] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts:
[ 5.079270] block: extroot: UUID match (root: aba41689-54c78582-c1d87957-714df56e, overlay: aba41689-54c78582-c1d87957-714df56e)
[ 5.109740] mount_root: switched to extroot
[ 5.126381] procd: - early -
[ 5.219020] random: procd: uninitialized urandom read (4 bytes read)
[ 5.352797] procd: - ubus -
[ 5.357745] procd (1): /proc/1029/oom_adj is deprecated, please use /proc/1029/oom_score_adj instead.
[ 5.432143] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.460992] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.512380] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.563444] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.617805] procd: - init -
Please press Enter to activate this console.
[ 5.789496] udevd[1074]: starting version 3.2.9
[ 5.821353] udevd[1074]: specified group 'tty' unknown
[ 5.832122] udevd[1074]: specified group 'dialout' unknown
[ 5.842167] udevd[1074]: specified group 'kmem' unknown
[ 5.848333] udevd[1074]: specified group 'input' unknown
[ 5.854671] udevd[1074]: specified group 'video' unknown
[ 5.861227] udevd[1074]: specified group 'lp' unknown
[ 5.896110] udevd[1074]: specified group 'disk' unknown
[ 5.902616] udevd[1074]: specified group 'cdrom' unknown
[ 5.914166] udevd[1074]: specified group 'tape' unknown
[ 5.974373] udevd[1137]: starting eudev-3.2.9
[ 6.219325] file system registered
[ 6.283521] configfs-gadget 5100000.udc-controller: failed to start g1: -19
[ 6.385771] read descriptors
[ 6.389533] read strings
[ 6.640985] e2fsck 1.42.12 (29-Aug-2014)
[ 6.693111] /dev/by-name/UDISK: recovering journal
[ 6.788304] /dev/by-name/UDISK: clean, 11/946560 files, 101426/3785851 blocks
[ 6.829227] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts:
Trying to connect to SWUpdate...
[ 9.567762]
[ 9.567762] insmod_device_driver
[ 9.567762]
[ 9.730471] sunxi_set_cur_vol_work()402 WARN: get power supply failed
[ 9.811871] android_work: sent uevent USB_STATE=CONNECTED
[ 9.836177] configfs-gadget gadget: high-speed config #1: c
[ 9.843215] android_work: sent uevent USB_STATE=CONFIGURED只要到
init: Console is alive 在按下触摸屏就没有event相应了
最近编辑记录 YuzukiTsuru (2022-03-05 00:20:18)
编译成模组后insmod完全无反应
另外一块屏幕开机也是一样的情况(我改了一下#define FTS_CHIP_TYPE _FT6336U,就不会出现TP Not Ready了)
..............................[37]HELLO! BOOT0 is starting!
[43]set pll start
[48]set pll end
[63]board init ok
[119]card no is 2
[192][mmc]: MMC 5.1
[00.368]CPU: Allwinner Family
[00.371]Model: sun50iw10
I2C: ready
[00.488]DRAM: 1 GiB
[00.492]Relocation Offset is: 35f12000
[00.521]secure enable bit: 0
[00.524]pmu_axp806_probe pmic_bus_read fail
[00.528]pmu_axp81X_probe pmic_bus_read fail
[00.532]pmu_axp858_probe pmic_bus_read fail
[00.535]PMU: no found
[00.538]bmu_axp81X_probe pmic_bus_read fail
[00.541]BMU: no found
[00.543]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[00.552]gic: sec monitor mode
[00.555]sunxi flash type@2 not support fast burn key
[00.560]flash init start
[00.562]workmode = 0,storage type = 2
[00.565][mmc]: mmc driver ver uboot2018:2021-01-14 19:04:00
[00.578][mmc]: SUNXI SDMMC Controller Version:0x50300
[00.603][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
[00.610]sunxi flash init ok
[00.612]non secure, do not need update backup boot0 to toc0
[00.618]init_clocks:finish
[00.620]drv_disp_init
[00.660]get flash lcd idx 0
[00.679]drv_disp_init finish
[00.730]boot_gui_init:start
[00.733]set disp.dev2_output_type fail. using defval=0
[00.738]=====================LCD_open_flow
[00.741]disp 1, clk: pll(176000000),clk(176000000),dclk(11000000) dsi_rate(176000000)
[00.755]=====================LCD_open_flow
[00.759]=====================LCD_power_on
[01.066]switch device: sel=1, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
[01.074]boot_gui_init:finish
[01.086]=====================LCD_open_flow
[01.090]=====================LCD_panel_init
[01.310]Loading Environment from SUNXI_FLASH... [01.315]=====================LCD_open_flow
[01.318]soc ic_ver:0x0, qa_val:0x0, markid:0x2400 dclk[0-9999] display_cfg_flag:0
OK
[01.330]no secure os for keybox operation
[01.333]try to burn key
[01.337]out of usb burn from boot: not need burn key
[01.341][ARISC] :arisc initialize
[01.346][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
[01.358][ARISC] :arisc para ok
[SCP] :0x1
[01.388][ARISC] :sunxi-arisc driver startup succeeded
[01.393]read item0 copy0
[01.395]Item0 (Map) magic is bad
[01.398]the secure storage item0 copy0 magic is bad
[01.403]Item0 (Map) magic is bad
[01.406]the secure storage item0 copy1 magic is bad
[01.410]Item0 (Map) magic is bad
[01.413]the secure storage map is empty
** Unrecognized filesystem type **
[01.423]no item name panic in the[01.425]=====================LCD_open_flow
[01.429]=====================LCD_bl_open
[01.433]pwm device hdl is NULL
[01.436]=====================LCD_open_flow
[01.439]=====================LCD_open_flow
[01.443]LCD open finish
map
[01.446]no item name rootwait init in the map
[01.450]no item name rdinit in the map
[01.454]no item name rotpk_status in the map
[01.462]update part info
[01.467]key 0
[01.468]no misc partition is found
[01.471]update bootcmd
[01.473]serial num is: 0c001415a0c08851e4d
[01.479][mmc]: delete mmc-hs400-1_8v from dtb
[01.483][mmc]: delete mmc-hs200-1_8v from dtb
[01.488](weak)update dtb dram start
[01.493]update dtb dram end
[01.501]update dts
[01.511]partinfo: name boot, start 0xb000, size 0x7800
[01.637]in boot normal mode,pass normal para to cmdline
[01.643]android.hardware = sun50iw10p1
[01.712]Starting kernel ...
[01.714][mmc]: mmc exit start
[01.733][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 4.9.170 (yuzuki@YuzukiOMEN) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #87 SMP PREEMPT Fri Mar 4 16:31:21 UTC 2022
[ 0.000000] Memory: 993524K/1048576K available (6462K kernel code, 1278K rwdata, 1988K rodata, 384K init, 281K bss, 46860K reserved, 8192K cma-reserved)
[ 0.000000] .bss : 0xffffff8008a6f808 - 0xffffff8008ab5fc4 ( 282 KB)
[ 0.008219] Console: colour dummy device 80x25
[ 0.012412] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.022618] pid_max: default: 32768 minimum: 301
[ 0.027676] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.033897] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.044135] sched-energy: CPU device node has no sched-energy-costs
[ 0.047282] Invalid sched_group_energy for CPU0
[ 0.051748] CPU0: update cpu_capacity 1024
[ 0.124152] Invalid sched_group_energy for CPU1
[ 0.124156] CPU1: update cpu_capacity 1024
[ 0.124159] CPU1: Booted secondary processor [410fd034]
[ 0.152146] Detected VIPT I-cache on CPU2
[ 0.152177] Invalid sched_group_energy for CPU2
[ 0.152180] CPU2: update cpu_capacity 1024
[ 0.152183] CPU2: Booted secondary processor [410fd034]
[ 0.180210] Detected VIPT I-cache on CPU3
[ 0.180238] Invalid sched_group_energy for CPU3
[ 0.180241] CPU3: update cpu_capacity 1024
[ 0.180244] CPU3: Booted secondary processor [410fd034]
[ 0.180318] Brought up 4 CPUs
[ 0.230954] SMP: Total of 4 processors activated.
[ 0.235643] CPU features: detected feature: 32-bit EL0 Support
[ 0.241448] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.251461] CPU: All CPU(s) started at EL1
[ 0.252729] alternatives: patching kernel code
[ 0.257633] Invalid sched_group_energy for CPU3
[ 0.261646] Invalid sched_group_energy for Cluster3
[ 0.266495] Invalid sched_group_energy for CPU2
[ 0.271002] Invalid sched_group_energy for Cluster2
[ 0.275854] Invalid sched_group_energy for CPU1
[ 0.280361] Invalid sched_group_energy for Cluster1
[ 0.285214] Invalid sched_group_energy for CPU0
[ 0.289721] Invalid sched_group_energy for Cluster0
[ 0.295737] devtmpfs: initialized
[ 0.553347] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.557475] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.564322] atomic64_test: passed
[ 0.566978] pinctrl core: initialized pinctrl subsystem
[ 0.577230] NET: Registered protocol family 16
[ 0.581229] dump_class_init,861, success
[ 0.584593] sunxi iommu: irq = 8
[ 0.585392] vdso: 2 pages (1 code @ ffffff80086d6000, 1 data @ ffffff8008934000)
[ 0.592352] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.609108] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
[ 0.688062] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
[ 0.701642] iommu: Adding device 1c0e000.ve to group 0
[ 0.721130] iommu: Adding device 6000000.disp to group 0
[ 0.723791] iommu: Adding device 6480000.g2d to group 0
[ 0.740769] iommu: Adding device csi0 to group 0
[ 0.742053] iommu: Adding device csi1 to group 0
[ 0.747382] iommu: Adding device 2108000.tdm to group 0
[ 0.750849] iommu: Adding device 2100000.isp to group 0
[ 0.756003] iommu: Adding device 2102000.isp to group 0
[ 0.760817] iommu: Adding device 2110000.scaler to group 0
[ 0.766314] iommu: Adding device 2110400.scaler to group 0
[ 0.771757] iommu: Adding device 2110800.scaler to group 0
[ 0.777187] iommu: Adding device 2110c00.scaler to group 0
[ 0.856828] pwm module init!
[ 0.867495] sunxi-pm debug v3.10
[ 0.874004] SCSI subsystem initialized
[ 0.876155] usbcore: registered new interface driver usbfs
[ 0.877918] usbcore: registered new interface driver hub
[ 0.883145] usbcore: registered new device driver usb
[ 0.888518] sunxi_i2c_adap_init()2541 - init
[ 0.893324] sunxi_i2c_probe()2289 - [i2c0] twi_drv_used = 0
[ 0.897706] sunxi_i2c_probe()2293 - [i2c0] twi_pkt_interval = 0
[ 0.903610] twi0 supply twi not found, using dummy regulator
[ 0.909497] twi_request_gpio()453 - [i2c0] init name: twi0
[ 0.916668] sunxi_i2c_probe()2289 - [i2c2] twi_drv_used = 0
[ 0.920238] sunxi_i2c_probe()2293 - [i2c2] twi_pkt_interval = 0
[ 0.926149] twi2 supply twi not found, using dummy regulator
[ 0.931976] twi_request_gpio()453 - [i2c2] init name: twi2
[ 0.938939] sunxi_i2c_probe()2289 - [i2c3] twi_drv_used = 0
[ 0.942769] sunxi_i2c_probe()2293 - [i2c3] twi_pkt_interval = 0
[ 0.948672] twi3 supply twi not found, using dummy regulator
[ 0.954549] twi_request_gpio()453 - [i2c3] init name: twi3
[ 0.961529] sunxi_i2c_probe()2289 - [i2c5] twi_drv_used = 0
[ 0.965304] sunxi_i2c_probe()2293 - [i2c5] twi_pkt_interval = 0
[ 0.971205] twi5 supply twi not found, using dummy regulator
[ 0.977034] twi_request_gpio()453 - [i2c5] init name: twi5
[ 0.984228] media: Linux media interface: v0.10
[ 0.987058] Linux video capture interface: v2.00
[ 0.993790] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[ 0.998893] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[ 1.005272] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
[ 1.012246] ion_heap_create: Invalid heap type 6
[ 1.016456] Advanced Linux Sound Architecture Driver Initialized.
[ 1.025074] Bluetooth: Core ver 2.22
[ 1.025649] NET: Registered protocol family 31
[ 1.029961] Bluetooth: HCI device and connection manager initialized
[ 1.036311] Bluetooth: HCI socket layer initialized
[ 1.041166] Bluetooth: L2CAP socket layer initialized
[ 1.046274] Bluetooth: SCO socket layer initialized
[ 1.053773] clocksource: Switched to clocksource arch_sys_counter
[ 1.112491] udc_init,0
[ 1.112887] NET: Registered protocol family 2
[ 1.130278] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.131774] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 1.138379] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.144667] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.150449] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.157541] NET: Registered protocol family 1
[ 1.161900] Unpacking initramfs...
[ 1.164504] Initramfs unpacking failed: junk in compressed archive
[ 1.178311] workingset: timestamp_bits=61 max_order=18 bucket_order=0
[ 1.276270] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.278434] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.290386] io scheduler noop registered
[ 1.290430] io scheduler deadline registered
[ 1.294976] io scheduler cfq registered (default)
[ 1.304224] [DISP]disp_module_init
[ 1.306541] [DISP] disp_init,line:2260:
[ 1.306579] smooth display screen:1 type:1 mode:4
[ 1.381725] [DISP] lcd_clk_config,line:662:
[ 1.381799] disp 1, clk: pll(66000000),clk(66000000),dclk(11000000) dsi_rate(66000000)
[ 1.381799] clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
[ 1.386875] [DISP]disp_module_init finish
[ 1.411779] uart uart0: get regulator failed
[ 1.411840] uart0 supply uart not found, using dummy regulator
[ 1.416866] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
[ 1.424162] sw_console_.[ 1.432146] console [ttyS0] enabled
[ 1.436153] bootconsole [earlycon0] disabled
[ 1.446732] uart uart1: get regulator failed
[ 1.453407] uart1 supply uart not found, using dummy regulator
[ 1.460579] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
[ 1.472242] misc dump reg init
[ 1.479679] [drm] Initialized
[ 1.483870] Unable to detect cache hierarchy for CPU 0
[ 1.489851] [NAND][NE] Not found valid nand node on dts
[ 1.497613] [ADDR_MGT] addr_mgt_probe: success.
[ 1.508342] libphy: Fixed MDIO Bus: probed
[ 1.512989] tun: Universal TUN/TAP device driver, 1.6
[ 1.518684] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.526464] PPP generic driver version 2.4.2
[ 1.532188] PPP BSD Compression module registered
[ 1.537502] PPP Deflate Compression module registered
[ 1.543224] PPP MPPE Compression module registered
[ 1.548635] NET: Registered protocol family 24
[ 1.553701] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.561546] get ehci0-controller, regulator_io is no nocare
[ 1.567834] get ehci0-controller wakeup-source is fail.
[ 1.574077] sunxi ehci0-controller don't init wakeup source
[ 1.580362] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff8008aa3e80, 0x:ffffff8008bad000, irq_no:164
[ 1.594072] [sunxi-ehci0]: Not init ehci0
[ 1.598855] get ehci1-controller, regulator_io is no nocare
[ 1.605593] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff8008aa4590, 0x:ffffff8008bb7000, irq_no:166
[ 1.619348] 5200000.ehci1-controller supply drvvbus not found, using dummy regulator
[ 1.628388] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.638664] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 1.649001] sunxi-ehci 5200000.ehci1-controller: irq 358, io mem 0xffffff8008bb7000
[ 1.669793] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
[ 1.681501] hub 1-0:1.0: USB hub found
[ 1.685839] hub 1-0:1.0: 1 port detected
[ 1.692817] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.700294] get ohci0-controller, regulator_io is no nocare
[ 1.706587] get ohci0-controller wakeup-source is fail.
[ 1.712813] sunxi ohci0-controller don't init wakeup source
[ 1.719232] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff8008aa4208
[ 1.729722] [sunxi-ohci0]: Not init ohci0
[ 1.734457] get ohci1-controller, regulator_io is no nocare
[ 1.741392] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff8008aa4918
[ 1.751920] 5200000.ohci1-controller supply drvvbus not found, using dummy regulator
[ 1.760913] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 1.770776] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
[ 1.780760] sunxi-ohci 5200000.ohci1-controller: irq 359, io mem 0x00000040
[ 1.853377] hub 2-0:1.0: USB hub found
[ 1.857718] hub 2-0:1.0: 1 port detected
[ 1.865067] usbcore: registered new interface driver uas
[ 1.871445] usbcore: registered new interface driver usb-storage
[ 1.878397] usbcore: registered new interface driver ums-alauda
[ 1.885266] usbcore: registered new interface driver ums-cypress
[ 1.892220] usbcore: registered new interface driver ums-datafab
[ 1.899164] usbcore: registered new interface driver ums_eneub6250
[ 1.906313] usbcore: registered new interface driver ums-freecom
[ 1.913252] usbcore: registered new interface driver ums-isd200
[ 1.920123] usbcore: registered new interface driver ums-jumpshot
[ 1.927166] usbcore: registered new interface driver ums-karma
[ 1.933926] usbcore: registered new interface driver ums-onetouch
[ 1.941099] usbcore: registered new interface driver ums-realtek
[ 1.948046] usbcore: registered new interface driver ums-sddr09
[ 1.954902] usbcore: registered new interface driver ums-sddr55
[ 1.961743] usbcore: registered new interface driver ums-usbat
[ 1.968618] usb_serial_number:20080411
[ 1.974197] sunxikbd_key_init: key0 vol= 210 code= 115
[ 1.979992] sunxikbd_key_init: key1 vol= 410 code= 114
[ 1.985786] sunxikbd_key_init: key2 vol= 590 code= 139
[ 1.991585] sunxikbd_key_init: key3 vol= 750 code= 28
[ 1.997280] sunxikbd_key_init: key4 vol= 880 code= 102
[ 2.004472] input: sunxi-keyboard as /devices/virtual/input/input0
[ 2.012428] evbug: Connected device: input0 (sunxi-keyboard at sunxikbd/input0)
[ 2.023304] [FTS]fts_ts_init: Enter
[ 2.027493] [FTS]fts_ts_probe: Enter
[ 2.031538] [FTS]fts_parse_dt: Enter
[ 2.035597] [FTS]max_touch_number=2
[ 2.039536] [FTS]fts_parse_dt: Exit(1015)
[ 2.044099] [FTS]fts_input_dev_init: Enter
[ 2.049906] input: fts_ts as /devices/platform/soc/twi5/i2c-5/5-0048/input/input1
[ 2.059150] evbug: Connected device: input1 (fts_ts at unknown)
[ 2.065822] [FTS]fts_input_dev_init: Exit(255)
[ 2.070834] [FTS]fts_ctpm_get_upgrade_array: Enter
[ 2.076246] [FTS][Info]CHIP TYPE ID = 0x6426
[ 2.098023] [FTS][Error]hidi2c change to stdi2c error!!
[ 2.103914] [FTS]fts_ctpm_get_upgrade_array: Exit(175)
[ 2.109703] [FTS]fts_power_source_init: Enter
[ 2.114633] 5-0048 supply not found, using dummy regulator
[ 2.121141] 5-0048 supply not found, using dummy regulator
[ 2.127492] [FTS]fts_power_source_init: Exit(316)
[ 2.132798] [FTS]fts_power_source_ctrl: Enter
[ 2.137706] [FTS]fts_power_source_ctrl: Exit(362)
[ 2.143003] [FTS]fts_gpio_configure: Enter
[ 2.147702] [FTS][Info]DONW......................
[ 2.153001] [FTS]fts_gpio_configure: Exit(859)
[ 2.157997] [FTS][Info]fts_reset_proc................
[ 2.397783] [FTS][Info].................fts_reset_proc................
[ 2.405383] [FTS][Info]TP Ready, Device ID = 0x64
[ 2.411085] [FTS][Mode]create sysfs succeeded
[ 2.416008] [FTS]fts_ts_probe: Exit(1248)
[ 2.420705] [FTS]fts_ts_init: Exit(1493)
[ 2.425869] sunxi_gpadc_init,1536, success
[ 2.432676] [FTS]point number: 1, touch point: 1
[ 2.433427] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[ 2.433697] sunxi-rtc rtc: RTC enabled
[ 2.434176] i2c /dev entries driver
[ 2.437682] IR NEC protocol handler initialized
[ 2.437686] IR RC5(x/sz) protocol handler initialized
[ 2.437690] IR RC6 protocol handler initialized
[ 2.437694] IR JVC protocol handler initialized
[ 2.437697] IR Sony protocol handler initialized
[ 2.437701] IR SANYO protocol handler initialized
[ 2.437705] IR Sharp protocol handler initialized
[ 2.437708] IR MCE Keyboard/mouse protocol handler initialized
[ 2.437712] IR XMP protocol handler initialized
[ 2.437714] sunxi cedar version 0.1
[ 2.438031] VE: install start!!!
[ 2.438031]
[ 2.438249] cedar_ve: cedar-ve the get irq is 347
[ 2.439464] VE: get debugfs_mpp_root is NULL, please check mpp
[ 2.439464]
[ 2.439467] VE: sunxi ve debug register driver failed!
[ 2.439467]
[ 2.441011] Bluetooth: HCI UART driver ver 2.3
[ 2.441017] Bluetooth: HCI UART protocol H4 registered
[ 2.441022] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.06
[ 2.443809] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[ 2.444081] sunxi-mmc sdc2: No vmmc regulator found
[ 2.444086] sunxi-mmc sdc2: No vqmmc regulator found
[ 2.444090] sunxi-mmc sdc2: No vdmmc regulator found
[ 2.444095] sunxi-mmc sdc2: No vd33sw regulator found
[ 2.444099] sunxi-mmc sdc2: No vd18sw regulator found
[ 2.444104] sunxi-mmc sdc2: No vq33sw regulator found
[ 2.444108] sunxi-mmc sdc2: No vq18sw regulator found
[ 2.445001] sunxi-mmc sdc2: set host busy
[ 2.445091] mmc:failed to get gpios
[ 2.445912] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.465798] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.485800] sunxi-mmc sdc2: detmode:alway in(non removable)
[ 2.485823] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.488305] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.489397] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.489808] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.489895] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.492358] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.493625] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[ 2.493809] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
[ 2.493868] sunxi-mmc sdc1: No vmmc regulator found
[ 2.493873] sunxi-mmc sdc1: No vqmmc regulator found
[ 2.493877] sunxi-mmc sdc1: No vdmmc regulator found
[ 2.493882] sunxi-mmc sdc1: No vd33sw regulator found
[ 2.493887] sunxi-mmc sdc1: No vd18sw regulator found
[ 2.493891] sunxi-mmc sdc1: No vq33sw regulator found
[ 2.493895] sunxi-mmc sdc1: No vq18sw regulator found
[ 2.494758] sunxi-mmc sdc1: set host busy
[ 2.494867] mmc:failed to get gpios
[ 2.494893] sunxi-mmc sdc1: min-frequency:400000
[ 2.495638] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.495663] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 2.513792] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.515018] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.527687] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[ 2.528112] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[ 2.528441] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
[ 2.528746] sunxi-mmc sdc2: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
[ 2.529022] mmc0: new DDR MMC card at address 0001
[ 2.531376] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.532091] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 2.536753] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 2.537808] sunxi-mmc sdc1: detmode:manually by software
[ 2.540286] usbcore: registered new interface driver usbhid
[ 2.540289] usbhid: USB HID core driver
[ 2.544023] u32 classifier
[ 2.544026] Actions configured
[ 2.544205] Initializing XFRM netlink socket
[ 2.549879] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 2.550164] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.552047] NET: Registered protocol family 10
[ 2.552693] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.553968] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 2.554171] sunxi-mmc sdc1: card claims to support voltages below defined range
[ 2.564165] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.564325] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.564576] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 2.565723] random: fast init done
[ 2.566016] mmc1: new high speed SDIO card at address 0001
[ 2.568031] NET: Registered protocol family 17
[ 2.569176] 8021q: 802.1Q VLAN Support v1.8
[ 2.611791] get usb_detect_mode is fail, 22
[ 2.617575] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:03 UTC (3)
[ 2.618416] usb1-vbus: disabling
[ 2.618421] vdd_3v3: disabling
[ 2.618425] ALSA device list:
[ 2.618428] No soundcards found.
[ 3.026963] [FTS][B]P0(502, 346)[p:63,tm:9] DOWN!
[ 3.032264] evbug: Event. Dev: input1, Type: 3, Code: 57, Value: 0
[ 3.039210] evbug: Event. Dev: input1, Type: 3, Code: 58, Value: 63
[ 3.046254] evbug: Event. Dev: input1, Type: 3, Code: 48, Value: 9
[ 3.053200] evbug: Event. Dev: input1, Type: 3, Code: 53, Value: 502
[ 3.059242] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
[ 3.061454] devtmpfs: mounted
[ 3.061804] Freeing unused kernel memory: 384K
[ 3.076675] evbug: Event. Dev: input1, Type: 3, Code: 54, Value: 346
[ 3.083819] evbug: Event. Dev: input1, Type: 1, Code: 330, Value: 1
[ 3.090862] evbug: Event. Dev: input1, Type: 0, Code: 0, Value: 0
[ 3.558494] init: Console is alive
[ 3.562724] init: - preinit -
[ 4.331868] mount_root: mounting /dev/root
[ 4.337708] mount_root: loading kmods from internal overlay
[ 4.358191] mount_root: failed to launch kmodloader from internal overlay
[ 4.393574] random: procd: uninitialized urandom read (4 bytes read)
[ 4.446293] block: attempting to load /etc/config/fstab
[ 4.615728] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts:
[ 4.626941] block: extroot: UUID match (root: aba41689-54c78582-c1d87957-714df56e, overlay: aba41689-54c78582-c1d87957-714df56e)
[ 4.659133] mount_root: switched to extroot
[ 4.675816] procd: - early -
[ 4.765318] random: procd: uninitialized urandom read (4 bytes read)
[ 4.902304] procd: - ubus -
[ 4.907147] procd (1): /proc/1029/oom_adj is deprecated, please use /proc/1029/oom_score_adj instead.
[ 4.984219] random: ubusd: uninitialized urandom read (4 bytes read)
[ 5.013601] procd: - init -
[ 5.290154] udevd[1063]: starting version 3.2.9
[ 5.334191] udevd[1063]: specified group 'tty' unknown
[ 5.340453] udevd[1063]: specified group 'dialout' unknown
[ 5.347446] udevd[1063]: specified group 'kmem' unknown
[ 5.353551] udevd[1063]: specified group 'input' unknown
[ 5.359824] udevd[1063]: specified group 'video' unknown
[ 5.366288] udevd[1063]: specified group 'lp' unknown
[ 5.372321] udevd[1063]: specified group 'disk' unknown
[ 5.378410] udevd[1063]: specified group 'cdrom' unknown
[ 5.385220] udevd[1063]: specified group 'tape' unknown
[ 5.471698] udevd[1148]: starting eudev-3.2.9
[ 5.662314] file system registered
[ 5.712719] configfs-gadget 5100000.udc-controller: failed to start g1: -19
[ 5.815986] read descriptors
[ 5.819332] read strings
[ 5.995878] e2fsck 1.42.12 (29-Aug-2014)
[ 6.065646] /dev/by-name/UDISK: recovering journal
[ 6.132646] /dev/by-name/UDISK: clean, 11/946560 files, 101426/3785851 blocks
[ 6.208023] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts:
[ 9.009831]
[ 9.009831] insmod_device_driver
[ 9.009831]
[ 9.171782] sunxi_set_cur_vol_work()402 WARN: get power supply failed
[ 9.253971] android_work: sent uevent USB_STATE=CONNECTED
[ 9.280621] configfs-gadget gadget: high-speed config #1: c
[ 9.287145] android_work: sent uevent USB_STATE=CONFIGURED最近编辑记录 YuzukiTsuru (2022-03-05 00:36:02)
解决了,配置dts问题
Device Drivers --->
Input device support --->
[*] Touchscreens --->
<*> FT6236 I2C touchscreen twi5_pins_a: twi5@0 {
allwinner,pins = "PI8", "PI9";
allwinner,pname = "twi5_scl", "twi5_sda";
allwinner,function = "twi5";
allwinner,drive = <1>;
allwinner,pull = <0>;
twi5_pins_b: twi5@1 {
allwinner,function = "io_disabled";
twi5: twi@0x05003400{
clock-frequency = <400000>;
pinctrl-0 = <&twi5_pins_a>;
pinctrl-1 = <&twi5_pins_b>;
ft6x06@48 {
compatible = "focaltech,ft6236";
reg = <0x48>;
interrupt-parent = <&pio>;
interrupts = <PJ 8 IRQ_TYPE_LEVEL_LOW>;
reset-gpios = <&pio PJ 9 1 0xffffffff 0xffffffff 1>;
touchscreen-size-x = <480>;
touchscreen-size-y = <480>;
touchscreen-inverted-x;
touchscreen-swapped-x-y;
};离线
楼主你好,你用的是什么芯片阿,这个ft6336的驱动是那里获取的,内核好像没有。我找了个驱动Focaltech_Touch_FT5436_Driver_for_Qualcomm_V2.2_20180321,将文件夹整个复制进内核编译后打开报错,日志如下:
[ 1.028443] [FTS]fts_ts_init: Enter
[ 1.032049] [FTS]fts_ts_init: Exit(1679)
[ 1.035968] i2c /dev entries driver
[ 1.040274] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.053051] [FTS]fts_ts_probe: Enter
[ 1.056651] [FTS]fts_parse_dt: Enter
[ 1.060371] [FTS][Info]display x(0 480) y(0 480)
[ 1.065093] [FTS][Info]max touch number:5, irq gpio:128, reset gpio:0
[ 1.071587] [FTS]fts_parse_dt: Exit(1194)
[ 1.076026] [FTS]fts_input_init: Enter
[ 1.080544] input: fts_ts as /devices/platform/soc/1c27000.i2c/i2c-0/0-0038/input/input0
[ 1.089444] [FTS]fts_input_init: Exit(997)
[ 1.093549] [FTS]fts_gpio_configure: Enter
[ 1.097857] [FTS]fts_gpio_configure: Exit(1058)
[ 1.102385] [FTS]fts_reset_proc: Enter
[ 1.357761] [FTS]fts_reset_proc: Exit(254)
[ 1.362810] [FTS]verify id:0x6426
[ 1.366132] [FTS]TP not ready, read:0x6426
[ 1.488676] [FTS]verify id:0x6426
[ 1.492000] [FTS]TP not ready, read:0x6426
[ 1.608670] [FTS]verify id:0x6426
[ 1.611986] [FTS]TP not ready, read:0x6426
[ 1.728663] [FTS]verify id:0x6426
[ 1.731982] [FTS]TP not ready, read:0x6426
[ 1.848644] [FTS]verify id:0x6426
[ 1.851964] [FTS]TP not ready, read:0x6426
[ 1.968657] [FTS]verify id:0x6426
[ 1.971976] [FTS]TP not ready, read:0x6426
[ 2.088656] [FTS]verify id:0x6426
[ 2.091978] [FTS]TP not ready, read:0x6426
[ 2.208663] [FTS]verify id:0x6426
[ 2.211980] [FTS]TP not ready, read:0x6426
[ 2.328658] [FTS]verify id:0x6426
[ 2.331978] [FTS]TP not ready, read:0x6426
[ 2.448227] random: fast init done
[ 2.451990] [FTS]verify id:0x6426
[ 2.455304] [FTS]TP not ready, read:0x6426
[ 2.577746] [FTS][Info]fw is invalid, need read boot id
[ 2.608580] [FTS][Error]read boot id fail
[ 2.612593] [FTS][Error]not focal IC, unregister driver
[ 2.619293] [FTS]fts_ts_probe: Exit(1452)
[ 2.623385] fts_ts: probe of 0-0038 failed with error -5
[ 2.630924] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
设备数是这样的:
focaltech@38{
compatible = "focaltech,fts";
reg = <0x38>;
// interrupt-parent = <&msm_gpio>;
// interrupts = <13 0x02>;
// focaltech,reset-gpio = <&msm_gpio 12 0x01>;
// focaltech,irq-gpio = <&msm_gpio 13 0x02>;
// interrupts = <4 0 IRQ_TYPE_EDGE_FALLING>; // PA1
focaltech,irq-gpio = <&pio 4 0 GPIO_ACTIVE_HIGH>; // PA1
focaltech,reset-gpio = <&pio 0 0 GPIO_ACTIVE_HIGH>; // PA0
focaltech,max-touch-number = <5>;
focaltech,display-coords = <0 0 480 480>;
// pinctrl-names = "pmx_ts_active","pmx_ts_suspend","pmx_ts_release";
// pinctrl-0 = <&ts_int_active &ts_reset_active>;
// pinctrl-1 = <&ts_int_suspend &ts_reset_suspend>;
// pinctrl-2 = <&ts_release>;
// focaltech,have-key;
// focaltech,key-number = <3>;
// focaltech,keys = <139 102 158>;
// focaltech,key-y-coord = <2000>;
// focaltech,key-x-coords = <200 600 800>;
可以借用一下你的驱动吗
对我来说,它被识别了,但什么也没做,是司机还是司机
