楼主 # 2022-03-22 07:13:21
memory
已发帖子: 722
D1哪吒开发板使用 RTL8723DS 作为WIFI中继 (转)
https://bbs.aw-ol.com/topic/1194
试一试把 V3s 当做 无线 wifi 热点
https://whycan.com/t_2869.html#p23455
楼主 #1 2022-03-22 07:13:34
memory
已发帖子: 722
Re: D1哪吒开发板使用 RTL8723DS 作为WIFI中继 (转)
1。驱动RTL8723DS之后, ifconfig -a 命令出现两个设备:
root@TinaLinux:/# ifconfig -a
wlan0     Link encap:Ethernet  HWaddr 00:E0:4C:A7:D1:3A
          inet addr:192.168.3.119  Bcast:192.168.3.255  Mask:255.255.255.0
          RX packets:179282 errors:0 dropped:206 overruns:0 frame:0
          TX packets:87704 errors:0 dropped:1 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:195274967 (186.2 MiB)  TX bytes:15296595 (14.5 MiB)
wlan1     Link encap:Ethernet  HWaddr 02:E0:4C:A7:D1:3A
          inet addr:192.168.10.1  Bcast:192.168.10.255  Mask:255.255.255.0
          inet6 addr: fe80::e0:4cff:fea7:d13a/64 Scope:Link
          RX packets:93844 errors:0 dropped:0 overruns:0 frame:0
          TX packets:157945 errors:0 dropped:1551 overruns:0 carrier:0
          RX bytes:15869708 (15.1 MiB)  TX bytes:189752370 (180.9 MiB)
我们现在用 wlan0 作为sta,用wlan1作为soft ap,两个组合起来,作为家里wifi路由器的中继。
2。wlan0 连接路由器:
wifi_connect_ap_test memory 13800138000
3。设置wlan1 地址:
ifconfig wlan1 192.168.10.1 netmask 255.255.255.0 up
4。给wlan1开启dhcp服务器:
mkdir /var/lib/misc/ -p
touch /var/lib/misc/dnsmasq.leases
dnsmasq -i wlan1 --dhcp-range=192.168.10.100,192.168.10.109,2h
5。设置转发:
iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE
6。设置/etc/hostapd.conf:
interface=wlan1
driver=nl80211
#driver=madwifi
ssid=memory
channel=9
hw_mode=g
macaddr_acl=0
ignore_broadcast_ssid=0
auth_algs=1
wpa=3
wpa_passphrase=123456
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
7。用 hostapd 开启热点:
hostapd /etc/hostapd.conf  &
最近编辑记录 memory (2022-03-22 07:14:44)
