我下载最新的2022版的buildroot去构建根文件系统,配置按照wiki的方法,结果kernel painc,不知道什么原因,求大佬赐教
[ 0.000000] Linux version 5.2.0-licheepi-nano+ (lorenzo@ubuntu) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #1 Fri Mar 25 10:31:43 CST 2022
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw
[ 0.000000] Memory: 55196K/65536K available (6144K kernel code, 235K rwdata, 1472K rodata, 1024K init, 228K bss, 10340K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] random: get_random_bytes called from start_kernel+0x254/0x42c with crng_init=0
[ 0.000047] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000123] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000635] Console: colour dummy device 80x30
[ 0.001241] printk: console [tty0] enabled
[ 0.001337] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070268] pid_max: default: 32768 minimum: 301
[ 0.070712] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070782] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072418] CPU: Testing write buffer coherency: ok
[ 0.074359] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076640] devtmpfs: initialized
[ 0.082315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082473] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.082818] pinctrl core: initialized pinctrl subsystem
[ 0.084815] NET: Registered protocol family 16
[ 0.086271] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.088342] cpuidle: using governor menu
[ 0.135283] SCSI subsystem initialized
[ 0.135751] usbcore: registered new interface driver usbfs
[ 0.135979] usbcore: registered new interface driver hub
[ 0.136210] usbcore: registered new device driver usb
[ 0.136686] pps_core: LinuxPPS API ver. 1 registered
[ 0.136764] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.137366] Advanced Linux Sound Architecture Driver Initialized.
[ 0.139060] clocksource: Switched to clocksource timer
[ 0.167444] NET: Registered protocol family 2
[ 0.169170] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[ 0.169359] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.169470] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.169554] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.169877] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.169993] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.170541] NET: Registered protocol family 1
[ 0.173095] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.175191] Initialise system trusted keyrings
[ 0.175789] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.202460] Key type asymmetric registered
[ 0.202569] Asymmetric key parser 'x509' registered
[ 0.202783] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.202874] io scheduler mq-deadline registered
[ 0.202922] io scheduler kyber registered
[ 0.214623] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.391836] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.397324] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.399268] printk: console [ttyS0] disabled
[ 0.419575] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[ 0.798229] printk: console [ttyS0] enabled
[ 0.806206] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.824061] SCSI Media Changer driver v0.25
[ 0.829782] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.836381] ehci-platform: EHCI generic platform driver
[ 0.842008] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.848296] ohci-platform: OHCI generic platform driver
[ 0.854049] usbcore: registered new interface driver usb-storage
[ 0.860864] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.870019] i2c /dev entries driver
[ 0.875266] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 0.913313] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 0.922673] usbcore: registered new interface driver usbhid
[ 0.928319] usbhid: USB HID core driver
[ 0.948151] NET: Registered protocol family 17
[ 0.952926] Key type dns_resolver registered
[ 0.959773] Loading compiled-in X.509 certificates
[ 0.974129] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.985620] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[ 0.996605] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0737c74)
[ 1.005757] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc07368cc)
[ 1.013638] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.020356] [drm] No driver support for vblank timestamp query.
[ 1.027642] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.249839] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.250303] mmc0: new SDHC card at address 0001
[ 1.254748] mmcblk0: mmc0:0001 USD00 14.7 GiB
[ 1.257968] mmcblk0: p1 p2
[ 1.281073] Console: switching to colour frame buffer device 100x30
[ 1.410424] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[ 1.432564] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.465459] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.486645] ALSA device list:
[ 1.503828] #0: Loopback 1
[ 1.521482] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.544398] cfg80211: failed to load regulatory.db
[ 1.580598] EXT4-fs (mmcblk0p2): recovery complete
[ 1.599558] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.622046] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.645211] devtmpfs: mounted
[ 1.669968] Freeing unused kernel memory: 1024K
[ 1.689108] Run /sbin/init as init process
[ 1.717051] random: fast init done
[ 1.756723] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.778437] CPU: 0 PID: 1 Comm: init Not tainted 5.2.0-licheepi-nano+ #1
[ 1.798877] Hardware name: Allwinner suniv Family
[ 1.817136] [<c010e42c>] (unwind_backtrace) from [<c010ba04>] (show_stack+0x10/0x14)
[ 1.838730] [<c010ba04>] (show_stack) from [<c0116dc0>] (panic+0xe8/0x2e4)
[ 1.859301] [<c0116dc0>] (panic) from [<c01185f4>] (do_exit+0x9dc/0xa18)
[ 1.879499] [<c01185f4>] (do_exit) from [<c0119190>] (do_group_exit+0x3c/0xb4)
[ 1.900223] [<c0119190>] (do_group_exit) from [<c0122d6c>] (get_signal+0x10c/0x7bc)
[ 1.921489] [<c0122d6c>] (get_signal) from [<c010af70>] (do_work_pending+0x1a8/0x558)
[ 1.943001] [<c010af70>] (do_work_pending) from [<c0101068>] (slow_work_pending+0xc/0x20)
[ 1.964771] Exception stack(0xc3835fb0 to 0xc3835ff8)
[ 1.983153] 5fa0: befa8f10 00000000 00000000 00000000
[ 2.004961] 5fc0: 00000940 00000000 00000000 00000000 00000000 00000000 000275e4 00000000
[ 2.026820] 5fe0: 00000000 befa8f10 b6ef3b53 b6ef4000 00000030 ffffffff
[ 2.047214] Rebooting in 5 seconds..
[ 8.040014] Reboot failed -- System halted离线
Target options --->
Target Architecture Variant (arm926t) ---> // arm926ejs架构
[ ] Enable VFP extension support // Nano 没有 VFP单元,勾选会导致某些应用无法运行
Target ABI (EABI) --->
Floating point strategy (Soft float) ---> // 软浮点
System configuration --->
(Lichee Pi) System hostname // hostname
(licheepi) Root password // 默认账户为root 密码为licheepi
[*] remount root filesystem read-write during boot // 启动时重新挂在文件系统使其可读写按照这个配置的
很可能gcc有问题,参考这个
buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 已支持DVP摄像头
https://whycan.com/t_5221.html
cube wrote:
很可能gcc有问题,参考这个
gcc版本问题吗? 好的谢谢
