楼主 # 2022-04-01 01:00:00
鱼尾
所在地: 杭州
已发帖子: 47
F1C100S 根文件系统无法启动 u-boot 系统内核正常不知道为什么
[    0.975913] ohci-platform: OHCI generic platform driver
[    0.981615] usbcore: registered new interface driver usb-storage
[    0.988708] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    0.997640] i2c /dev entries driver
[    1.058021] sunxi-mmc 1c0f000.mmc: base:0x31b7144d irq:19
[    1.066860] usbcore: registered new interface driver usbhid
[    1.072559] usbhid: USB HID core driver
[    1.094195] NET: Registered protocol family 17
[    1.099012] Key type dns_resolver registered
[    1.105532] Loading compiled-in X.509 certificates
[    1.120773] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0739c38)
[    1.129712] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0738f1c)
[    1.137377] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.144092] [drm] No driver support for vblank timestamp query.
[    1.282441] Console: switching to colour frame buffer device 100x30
[    1.322187] sun4i-drm display-engine: fb0:  frame buffer device
[    1.329288] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.338569] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.350637] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.356440] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.366825] hub 1-0:1.0: USB hub found
[    1.370904] hub 1-0:1.0: 1 port detected
[    1.376466] using random self ethernet address
[    1.381110] using random host ethernet address
[    1.387426] usb0: HOST MAC 66:5e:3a:64:f7:01
[    1.391968] usb0: MAC 92:4c:1c:0c:df:9d
[    1.395961] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.403520] g_cdc gadget: g_cdc ready
[    1.410521] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.428583] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.435347] vcc3v3: disabling
[    1.438438] ALSA device list:
[    1.441415]   #0: Loopback 1
[    1.445238] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.453955] cfg80211: failed to load regulatory.db
[    1.459705] List of all partitions:
[    1.463297] No filesystem could mount root, tried:
[    1.463310]  jffs2
[    1.468303]
[    1.471827] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    1.480078] CPU: 0 PID: 1 Comm: swapper Not tainted 4.15.0-rc8-licheepi-nano+ #2
[    1.487449] Hardware name: Allwinner suniv Family
[    1.492231] [<c010e550>] (unwind_backtrace) from [<c010b6a8>] (show_stack+0x10/0x14)
[    1.499987] [<c010b6a8>] (show_stack) from [<c0116878>] (panic+0xb8/0x230)
[    1.506886] [<c0116878>] (panic) from [<c0901204>] (mount_block_root+0x1e4/0x250)
[    1.514375] [<c0901204>] (mount_block_root) from [<c0901364>] (mount_root+0xf4/0x120)
[    1.522203] [<c0901364>] (mount_root) from [<c09014b8>] (prepare_namespace+0x128/0x188)
[    1.530205] [<c09014b8>] (prepare_namespace) from [<c0900dc0>] (kernel_init_freeable+0x174/0x1b8)
[    1.539067] [<c0900dc0>] (kernel_init_freeable) from [<c0667210>] (kernel_init+0x8/0x10c)
[    1.547241] [<c0667210>] (kernel_init) from [<c0107dc0>] (ret_from_fork+0x14/0x34)
[    1.554801] Rebooting in 5 seconds..
[    7.534035] Reboot failed -- System halted
