楼主 # 2022-04-01 09:11:21
Cadence
已发帖子: 71
怎么使用BBCode?
HELLO! BOOT0 is starting!
BOOT0 commit : 023b78d-dirty
set pll start
periph0 has been enabled
set pll end
[pmu]: bus read error
board init ok
ZQ value = 0x2f***********
get_pmu_exist() = -1
ddr_efuse_type: 0xa
[AUTO DEBUG] single rank and full DQ!
ddr_efuse_type: 0xa
[AUTO DEBUG] rank 0 row = 13
[AUTO DEBUG] rank 0 bank = 4
[AUTO DEBUG] rank 0 page size = 2 KB
DRAM BOOT DRIVE INFO: V0.24
DRAM CLK = 528 MHz
DRAM Type = 2 (2:DDR2,3:DDR3)
DRAMC read ODT  off.
DRAM ODT off.
ddr_efuse_type: 0xa
DRAM SIZE =64 M
DRAM simple test OK.
dram size =64
spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 16
Jump to second Boot.
U-Boot 2022.01-rc3-00096-gc0ffc12a70-dirty (Apr 01 2022 - 07:21:09 +0800)
DRAM:  64 MiB
drivers/spi/spi-uclass.c 527 0
[00.244]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0
GNU ld (GNU Binutils) 2.32
